FWAERJ
Is The WN 8-Flight Rule For New Cities Dead?
Mon Dec 17, 2012 6:29 pm
For many years, WN said that they would not start a city unless it could support eight departures a day from day one. This so-called "eight-flight rule" ruled out many airports from being WN candidates.
But that seems to be changing - and fast. At least four full FL station conversions (BKG, DSM, FNT, and ICT) along with several partial station conversions (EYW being one) have five or fewer departures a day. Just three years ago, when WN opened up every new city with seven or eight departures, this would have been unheard of.
Once the WN/FL merger integration is complete, could we see WN opening up more new domestic destinations with five or fewer flights? And has WN almost run out of new cities that they could start with the "eight-flight rule"? (I can think of CVG, FAT, and GSO... and that's about it.)
"Did he really need the triple bypass? Or was it the miles?"
yellowtail
RE: Is The WN 8-Flight Rule For New Cities Dead?
Mon Dec 17, 2012 6:35 pm
Yes, especially on the forthcoming international.....
When in doubt, hold on to your altitude. No-one has ever collided with the sky.
lhcvg
Mon Dec 17, 2012 6:41 pm
For many years WN did a lot of things (flew into secondary airports like PVD vs. BOS, didn't have true hubs, didn't offer connecting service, and the list goes on).
In all seriousness though: yes, that rule is dead. WN is now a major network carrier that simply lacks a regional feeder operations to fill in all the holes that even they can't make a 737 work on. As part of that, as they chase the long tail of demand, there will be fewer markets capable of supporting initial service levels meeting that criteria. That's not to say the rule isn't a good rule of thumb for looking at new stations, but as a hard and fast rule it's time is done.
ouboy79
Mon Dec 17, 2012 6:45 pm
Quoting FWAERJ (Thread starter):
I believe some of the new contracts allow the costs to make sense for some of these smaller cities. We'll see if it lasts. BKG and ICT are subsidized I believe. EYW is one of those unique situations.
The company is evolving and needs to find ways to make these small cities work. However, the company is still going to demand a certain ROI and level of margin on these flights. If they don't meet the margin goal they'll get cut. They also need to have a certain level of high O&D on routes since that makes more money than dealing with connecting pax.
iowaman
Mon Dec 17, 2012 6:48 pm
That was certainly the case for many years, although CRP had been "grandfathered" in and always has and likely will be a small station.
I think down the road it seems logical to add some more destinations and fill in holes. Cities like COS, PIA (Peoria, IL), BTR, LAN (Lansing, MI), and a few others could probably support a token presence (similar to DSM's two daily to MDW). Until WN hits a 15% ROI (Return On Investment) and the merger is largely complete I don't see this as likely.
Quoting yellowtail (Reply 1):
I sure hope CVG gets WN, they are in need of more pax/operations/low fares.
FWAERJ
Mon Dec 17, 2012 6:51 pm
Quoting ouboy79 (Reply 3):
Correct. ICT by the city, and BKG by the local tourism industry.
Quoting LHCVG (Reply 2):
As the company evolves, their rules have to evolve, too. I have a feeling that the famous "eight-flight rule" found in business school textbooks everywhere is in the process of becoming a "three-flight rule" (or even a "two-flight rule" for the upcoming international routes).
[Edited 2012-12-17 10:53:18]
lhcvg
Mon Dec 17, 2012 6:52 pm
ouboy has a good point here, and brings up a good example of a recent exception: DCA-AUS (WN's first original WN DCA service). That flight is likely a cash cow for them even at 1x daily, and may well be a better investment than starting a small "beach market" at 2-3x a day. Obviously post merger they now have FL's ops at DCA, but that's an example of a route that might have been a good starter flight regardless.
SEPilot
I would be suspicious of making any conclusions about WN policy based on the FL acquisition. It may or may not have been a good move; based on their decision to dump the 717's so fast they may be having second thoughts about the whole thing. They had to take FL as they found it; they may or may not keep all of the routes they acquired, but as for making any assumptions about what WN will do in the future based on routes acquired with FL is treading on shaky ground indeed.
AWACSooner
Mon Dec 17, 2012 6:55 pm
You can add DAY and CAK to the list of
FWAERJ
Mon Dec 17, 2012 6:56 pm
Quoting AWACSooner (Reply 8):
You can add DAY
DAY still has FL service and more than eight total WN+FL flights per day.
ouboy79
Mon Dec 17, 2012 7:09 pm
Quoting iowaman (Reply 4):
COS won't shock me if it happens. PIA, BTR, LAN all would. I don't see those happening.
This one seems like a good possibility going forward. I do whonder if DAY would be hurt if it happens though.
Quoting FWAERJ (Reply 5):
I haven't heard of the magic eight flight rule while being with WN, so to me it is meaningless. Focus more on ROI, margin, and O&D. Why do you think short haul routes like IND-MDW are dead?
They'll both be above 8 flights after FL flights are converted. CAK should be a decent sized station when it is all done.
Quoting SEPilot (Reply 7):
I don't think anyone seriously thought the 717s had a chance at WN. It might have been able to work, but the math didn't add up and it was most cost effective to sub lease them off to DL. Are they second guessing? Not at all. Things are just taking time to allow FL to be dismantled and the WN brand to back fill.
Flytravel
Mon Dec 17, 2012 7:15 pm
I'd add MDT. 2 million residents in PA are within 1 hour of MDT, where another major airport isn't closer. WN will have service at 4-5 OH airports but just 2 PA airports, even though PA is larger and greater in population.
MDT-MDW would probably be the network connection, but it is just under 600 miles. It would have been more ideal if that was ~350 miles, but I think WN would be competitive against UA and AA on Harrisburg-Chicago, plus having connections, and it could offer Florida service as well.
[Edited 2012-12-17 11:20:54]
lhcvg
Mon Dec 17, 2012 7:24 pm
Quoting ouboy79 (Reply 10):
Yup that one keeps cropping up from time to time. I'd say one thing in WN's favor is that they have the scale and muscle to break into the market that B6, F9, VX, etc. might not have. If B6 couldn't make the more openly competitive CMH market work, I'd think they or anyone else but WN would have trouble at CVG too. They could have competitive offerings to any/each of BWI, MDW, DEN, or HOU for hub connecting service, let alone other WN cities they might be able to poach from DL specifically (PHX, STL, Florida).
SEPilot
Mon Dec 17, 2012 8:11 pm
That is not what WN was saying at the time.
jetmatt777
Crew
Mon Dec 17, 2012 8:30 pm
Quoting SEPilot (Reply 13):
Talk is cheap. Especially in the airline industry.
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
kcrwflyer
Mon Dec 17, 2012 8:38 pm
I would think.. Of course they cut a handful of cities that could have easily made 3-5 flights work before they decided they could open a station like DSM or PWM with 2 or 3 flights.
I'm sure they believe they can grow every city they keep into at least 6 or 7 flights per day over time, so I'm sure the existence of the rule is in the eye of the beholder.
Quoting jetmatt777 (Reply 14):
As we all know, pre merger promises and discussions manufacture more BS than all the farmland in the Americas. This was no different.
AADC10
Mon Dec 17, 2012 8:49 pm
One of the reasons for the eight flight rule is that with less than 8 flights, the fixed costs on the ground are spread over too few flights and there is not enough work to keep ground staff around full time. However, in stations where FL is already established, WN probably would prefer not to give up on established customers.
Bobloblaw
Mon Dec 17, 2012 8:52 pm
Yes, its dead. Just like WN's rule that they would never serve LGA, DCA or other congested northeastern cities. The only rul that still applies in ORD and DFW.
I would think COS would work. I dont know why there isnt COS-PHX service (Iam not counting F9's less than daily service).
VC10DC10
Mon Dec 17, 2012 9:10 pm
With the DL drawdown at MEM, is it conceivable that once the dust on the FL acquisition settles and WN starts real domestic growth again, would MEM be a possibility?
iowaman
Mon Dec 17, 2012 9:57 pm
Quoting LHCVG (Reply 6):
I think more than anything politics came into play on DCA-AUS. I'm also assuming it was an Air21 slot that gave priority to low-fare entrants that offered to serve previously unserved small and medium markets from DCA.
Quoting VC10DC10 (Reply 18):
MEM will be integrated into the WN network eventually. I see no reason WN couldn't hit the key destinations and stations from MEM such as MDW, HOU, DEN and maybe other stations down the road such as LAS, PHX, BWI, and MCO. It sounds promising WN will be in MEM for the long haul and will be adding new destination(s):
Technically they are already a reality here. They've signed a long term lease here and looking at facilities within the airport," said Memphis-Shelby County Airport Authority President and CEO Larry Cox.
Cox says the carrier plans to convert all of its AirTran operations in nearly two dozen cities, including Memphis, to the Southwest name.
"We don't know the cities they will serve out of Memphis, but they currently serve Atlanta and we expect them to serve a number of other cities," said Cox.
http://www.wmctv.com/story/19837508/...hority-southwest-is-a-reality-here
usflyguy
Mon Dec 17, 2012 10:02 pm
Quoting iowaman (Reply 19):
It was part of the beyond perimeter proceedings earlier this year.
My post is my ideas and my opinions only, I do not represent the ideas or opinions of anyone else or company.
FWAERJ
Mon Dec 17, 2012 10:05 pm
Quoting bobloblaw (Reply 17):
Even then, if gate space opened up at ORD through the proposed west terminal or other means, I could see WN grabbing a few gates and starting a 20-30 flight operation to fight for Chicago's north sider business travelers.
WN serving both MDW and ORD (plus MKE) would be like how they serve these major areas with multiple airports:
-BOS/PVD/MHT
-LGA/EWR/ISP
-BWI/DCA/IAD
-CLE/CAK
-DTW/FNT
-SFO/OAK/SJC
-LAX/SNA/BUR/ONT
lhcvg
Mon Dec 17, 2012 10:07 pm
No doubt politics, but just AUS lobbying for service under:
Quoting usflyguy (Reply 20):
WN really hit a home run there - breaking into DCA in their own right, getting a big route for them given the AUS focus city, and getting a beyond-perimeter exemption at DCA at that.
planespotting
Mon Dec 17, 2012 11:24 pm
Quoting Kcrwflyer (Reply 15):
I know of nothing definitive at the moment, but I would venture a guess that there is more to come with WN at DSM.
Do you like movies about gladiators?
iowaman
Mon Dec 17, 2012 11:47 pm
Interestingly enough, when Southwest first got going in Texas they had relatively small station openings. Maybe this is one thing that is actually heading the direction towards their roots. HRL was started in 1975 at 4 daily, and AMA also opened as a station in 1978 with 5 daily (all to DAL). MSY started in 1979 with just 1x HOU, and ABQ opened with 3 daily flights in 1980. LAX in 1982 opened with 3 daily.
I think the lowering outsourcing costs may have a lot to do with keeping the old FL stations as someone else mentioned.
Quoting planespotting (Reply 23):
I'm guessing one of the following may eventually come to fruitation: DEN, STL, LAS, PHX.
Quoting FWAERJ (Reply 21):
Interesting thoughts. It seems to make sense - although in the short-term I don't think they would have much luck getting gates at ORD.
That makes much more sense, thanks for the correction.
lhcvg
Tue Dec 18, 2012 12:41 am
Quoting iowaman (Reply 24):
That's interesting, because I would have assumed the opposite - that a small/new carrier would want such a rule in order to prevent overextension (focus on strengths until they built up critical mass).
Flytravel
Tue Dec 18, 2012 1:22 am
Another rule was that every city had atleast one short-haul route w/ the exception being IAD. However, now markets along the East including LGA, EWR, PHL, DCA, PBI and on the west SEA have no short-haul.
With the rule changes at WN, I'd think MIA might be reconsidered as now fitting in. Routes: BWI-MIA, ISP-MIA, PVD-MIA. Just like PBI, and maybe unlike PBI, TPA-MIA. TPA is becoming a large station and I think it is far enough from MIA where WN won't think it's too close. Over 200 miles by air. It'd offer many connections as well and compete on O&D from primary airports of the region. PBI-ATL might not convert on WN however where it shrinks, but MIA could be like PBI, ancillary stations to FLL, like IAD/DCA to BWI, but serving a unique role that the big WN airport of the region doesn't serve.
[Edited 2012-12-17 18:02:45]
Cubsrule
Tue Dec 18, 2012 1:50 am
Aren't COS, BTR and LAN too close to DEN, MSY and DTW respectively? There's no point in flying BNA-MDW-COS when I can simply fly BNA-DEN nonstop and drive from there (and yes, I know that that drive can be non-trivial in the winter). PIA - which has a pretty strong local economy and could draw from BMI (another fairly strong local economy), MLI and SPI might be interesting, but it's probably too close to MDW/STL for flights to either place and a pretty long flight to other large WN stations.
   Probably also DAL in 2014. MEM shouldn't have any trouble being an "8 flight" city.
Bobloblaw
Tue Dec 18, 2012 1:56 am
Quoting Cubsrule (Reply 27):
I can see WN serving COS-PHX/LAS/MDW. Using your logic however, why should COS have any HUB air service if driving to DEN and going nonstop is preferable to connecting via DFW or ORD from COS to/from destinations.
Cubsrule
Tue Dec 18, 2012 2:03 am
Quoting bobloblaw (Reply 28):
The legacies don't count on people being willing to drive a couple of hours. WN always has.
737tanker
Tue Dec 18, 2012 3:08 am
A few years ago, after WN had signed a new contact with their ground personnel, I had the COO on my jumpseat. He told me that since the new contract allowed non-WN (ie: contract workers) at new stations WN only needed 4 flights to be profitable. At stations with WN employees they needed 10 flights to be profitable. Having said that IMO after the FL cities are converted the only new WN cities that you will see will be international, not domestic.
airliner371
Tue Dec 18, 2012 3:09 am
Quoting Flytravel (Reply 26):
The big problem with MIA is the fees are outrageous for airlines. Thats why B6 and VX don't serve it though they seem like a good fit. FLL is close enough to count as an alternative.
Take a little time and enjoy The View.
iowaman
Tue Dec 18, 2012 3:50 am
For comparative purposes:
LAN is approximately 1.5 hours from DTW (all of these numbers are traffic dependent), but is a little less than an hour from FNT. It's only a five gate airport so it certainly is small. Only about a quarter of the enplanements as DSM.
BTR is a little less than 1.5 hours from MSY. BTR has less passengers than I thought at about 400,000 enplaned for the year (a little less than half the enplanements of DSM).
COS is about an hour from DEN. COS has slightly less enplanements than DSM.
OMA is about two hours from DSM, and ROC is a little over an hour from BUF.
Good point - the DFW metroplex is a substantial market from MEM.
Quoting airliner371 (Reply 31):
Out of curiousity I wonder how MIA compares with airports like DCA, LGA, SFO, and SEA for fees.
ouboy79
Tue Dec 18, 2012 6:40 am
Quoting Flytravel (Reply 11):
If MDT was really in the cards, it wouldn't have been dropped by FL.
Just like DL said CVG and MEM were safe?
MEM will be a WN city.
IndianicWorld
Tue Dec 18, 2012 7:09 am
At the end of the day, theres only so many cities that can sustain that level of service to start with, so trying to maintain that would only affect the ability to grow.
They have done well to that point following the path they were, but as can be seen now, the move to change the strategy has come about as more of a need to continue to grow and service cities it knows it can do well from, although with a reduced frequency level.
Flytravel
Tue Dec 18, 2012 10:26 am
Quoting ouboy79 (Reply 33):
I didn't suggest "it was in the cards" but answering to the OP's question: "Once the WN/FL merger integration is complete, could we see WN opening up more new domestic destination..."
MDT only had Florida when served by FL, and no proven network history by FL unlike say ROC. However, there are 2 million people that are close to it (within one hour) and closer to it than another major airport with service. Look at MSAs around it.
[Edited 2012-12-18 02:30:27]
Buddys747
Tue Dec 18, 2012 11:48 am
FL didn't drop MDT, WN made the decision. They cited they couldn't make MDT fit there model and the fact that BWI is 1.5 hours away (from the airport) as reasons for leaving.
Quoting Flytravel (Reply 35):
I think that's the key that some are missing out on. We could have kept a small station here I believe with no problems. MDW, MCO, FLL, TPA and BNA. But WN knows a lot from this area will drive to BWI. But most that do are low fare Florida bound passengers. Most business travelers still fly here instead and take a connection. That's where F9 could really step it up here and take advantage of that low fare travelers going to BWI.
Cubsrule
Tue Dec 18, 2012 12:19 pm
Quoting iowaman (Reply 32):
The problem at BTR is the where the airports are located in their respective metro areas. From LSU (south side of Baton Rouge) to MSY (in Kenner), for instance, it's only 72 miles. Most of that is through desolation on Interstate 10, and the drive is doable in an hour. LSU to BTR is probably a 20 minute drive and there's much less service at BTR.
ouboy79
Tue Dec 18, 2012 3:58 pm
Quoting Buddys747 (Reply 36):
That's pretty much what I meant. There really isn't much of a different between FL/WN anymore. I just said FL since it was the one operating.
usflyguy
Tue Dec 18, 2012 4:09 pm
WN run's Boscov's Travel charters from many of the airports in this area to MCO and has done this for quite a while. Having done this, along with the FL financials, I'm sure they have a pretty good idea of if/why it wouldn't work.
http://www.boscovstravel.com/xcursion/TripList.aspx?TripCategoryID=5
FWAERJ
Thu Dec 20, 2012 10:46 pm
Quoting usflyguy (Reply 39):
WN has flown charters from FWA in the past even though they don't serve FWA on a scheduled basis. That said, I do think that WN would work with 3-4 flights per day from FWA (1-2x BWI, 1x DEN, 1x LAS).
Quoting Cubsrule (Reply 37):
Didn't Herb once say that "we're not in the business of flying to small airports - we're in the leakage business"?
ouboy79
Fri Dec 21, 2012 12:32 am
Quoting FWAERJ (Reply 40):
WN does a lot of Honor Flight operations, so you'll see them everywhere.
The O&D numbers are going to have to be there from FWA. So unless those routes can fill up on strong O&D and allow it to hit its 15% ROI goal, it probably won't happen.
Which was accurate when MHT and PVD would launched, today not so much. Why worry about leakage when you just fly to the major city itself?
FWAERJ
Fri Dec 21, 2012 1:47 am
Quoting ouboy79 (Reply 41):
BWI and LAS would have no problem with O&D from FWA. There are many very strong ties between FWA and DC, and also huge demand to LAS. And a lot of traffic to/from both cities (especially LAS) goes to other airports besides FWA, which presents an opportunity for market stimulation.
DEN would probably be a different story - whether it's WN, F9, or even UA, FWA-DEN would rely heavily on connections, much like SBN-DEN does for F9.
I'd say that was accurate as far back as when WN moved most of their Houston ops from IAH to HOU. And that was in the 1970s.
ouboy79
Fri Dec 21, 2012 3:16 am
Quoting FWAERJ (Reply 42):
It'll come down to yield then. WN expects a pretty good premium, so they better be ready to sell out Business Select and a good number of Anytime fares.
FWAERJ
Fri Dec 21, 2012 3:21 am
Quoting ouboy79 (Reply 43):
Almost all the FWA-DC traffic is high-yield business and government travel, so they'll sell out the higher fare buckets on BWI in a jiffy.
LAS would be almost entirely leisure (and mostly "Wanna Get Away") fares, but LAS tends to be low-yield for any carrier.
kcrwflyer
Fri Dec 21, 2012 4:06 am
By FL you mean WN.
I was gonna let that go.
Quoting FWAERJ (Reply 44):
Then you said this. If the FWA-Washington traffic and demand was even 1/4 of what you are marketing it as, somebody would be flying to IAD or DCA. If it really were what you are marketing it to be, you'd have service to both airports.
I don't think they're chasing any extremely low yielding stuff just to make a city viable. Yes, if you make the fares low enough just about anyone could fill a plane to Vegas.
Just talked me out of it.
Just for kicks. When was the last time WN went to an airport to prevent leakage to itself?
ouboy79
Fri Dec 21, 2012 8:11 am
Quoting Kcrwflyer (Reply 45):
By FL you mean WN.
Indeed...which I later clarified if you scroll up.
lhcvg
Fri Dec 21, 2012 11:41 am
Quoting FWAERJ (Reply 44):Almost all the FWA-DC traffic is high-yield business and government travel, so they'll sell out the higher fare buckets on BWI in a jiffy. Then you said this. If the FWA-Washington traffic and demand was even 1/4 of what you are marketing it as, somebody would be flying to IAD or DCA. If it really were what you are marketing it to be, you'd have service to both airports. I don't think they're chasing any extremely low yielding stuff just to make a city viable. Yes, if you make the fares low enough just about anyone could fill a plane to Vegas.
FWIW, here is the FY12 GSA award for FWA-WAS:
FT. WAYNE RONALD REAGAN NATIONAL AIRPORT Delta C 321.00 0.00 0.00 10/01/2011 09/30/2012
FT. WAYNE BALTIMORE/WASHINGTON INT'L AIRPORT Delta C 425.00 0.00 0.00 10/01/2011 09/30/2012
No real surprise to see DL here, but I would bet they probably get a good bit of official government traffic - as crwflyer said if there were really that much demand there, you'd have DCA and/or IAD.
GentFromAlaska
Fri Dec 21, 2012 6:13 pm
WN must use a couple of policies either that or the eight flight per day policy allows some wiggle room for higher volume micro cities/markets.
In the early to mid 90's after my first WN flight I wrote WN asking about potential service to JNU Juneau, Alaska. WN wrote back telling me they do not consider cities unless they can get six flights in per day and JNU could not support six flights a day. The writer who I held the title of market research or planning mentioned she had just taken an Alaska cruise and was quite familiar with Juneau.
It was later discovered WN policy is not only determined by the volume of flyers but by the amount of available gates. JNU had one free gate which would have to be shared by all other carriers. There were not at the time. It was understood in the community AS entered a long term lease on all other gates with or without any intent to use them which was understood as a strategy or tactic to keep other carriers out.
A couple of years later Herb was actually seen in JNU airport which got a few people excited. It was later discovered he was in the area visiting a remote cabin on a vacation.
It would be nice if WN would return to JNU for a look at least seasonally. With all of the avionics and GPS navigation upgrades across the last 15 or so years; the weather argument is dated. I suppose JNU could be a one stop with continued service to ANC in both directions.
Man can be taken from Alaska. Alaska can never be taken from the man.
ouboy79
Fri Dec 21, 2012 6:34 pm
Quoting GentFromAlaska (Reply 48):
My take away from a lot of this is the whole X number of flight rules is from several years ago or longer. The WN business plan is different now and people really need to let go of the idea that so many flights must be required. If WN can make a profit to achieve its 15% ROI goal on investments, it'll consider it more than likely. If the yields aren't there and they can't make it work, it isn't happening.
