747to380to787
Is Anything Wrong With This An-70 Photo?
Mon Dec 24, 2012 5:43 pm
Do you see anything wrong with this PIC?
Photo © Vasiliy Koba
I mean landing gears are retracted and definitely not on display pole. So why both the doors are open?
1) Is it Russian way of getting fresh air? ( I would buy this if we confirm Heater/AC was broken  )
2) Sight seeing flight?
3) Cargo ramp agent was too lazy ?
4) Some kind of test flight?
-- Did not find any thread related to pic.Moderator delete the thread if duplicate.
[Edited 2012-12-24 10:01:04]
MesaFlyGuy
RE: Is Anything Wrong With This An-70 Photo?
Mon Dec 24, 2012 5:47 pm
Seeing as the aircraft is at the Antonov airport, I'd venture to say that it was some kind of test.
The views I express are my own and do not reflect the views and opinions of my company.
aloges
Mon Dec 24, 2012 7:09 pm
It's a test flight for their new contract with Santa Claus. He figured that he needed a backup in case his sleigh got damaged and Antonov provided a suitable cargo aircraft with airdrop capabilities - not a year too soon, either!
longhauler
Mon Dec 24, 2012 7:13 pm
I would imagine they are testing some sort of procedure, as I cant even imagine the hydraulic pressure required to hold the doors open at any flying speed.
I wonder what procedure it would be though, as there must be some mechanism built for this. There also appears to be a step extended in place on both sides, when the door is open.
Spacepope
Mon Dec 24, 2012 7:18 pm
The engine cowlings have been swapped out very recently, those doors can give a pretty good view of them in flight...
Also re the step: are those forward doors useable as jump doors?
747to380to787
Mon Dec 24, 2012 7:38 pm
Quoting mesaflyguy (Reply 1):
The only test I can google for Open-Door flight test is, test performed by NASA for SOFIA
www.nasa.gov/mission_pages/SOFIA/status_update_08_11_10.html
Although I came across many depressurization handling training documents and video.
spacecadet
Tue Dec 25, 2012 12:35 am
Supplemental air brakes?
kanban
Tue Dec 25, 2012 2:21 am
My thought was jump doors especially with the jump platform extended.. but right into the props??/
irshava
Tue Dec 25, 2012 2:39 am
Quoting 747to380to787 (Thread starter):
Ukrainian*
“If you were born without wings, do nothing to prevent them from growing.”
solarflyer22
Tue Dec 25, 2012 2:58 am
It's a military aircraft and is no doubt capable of dropping paratroopers. Usually you'd drop them out the back where its safer but maybe its alternate jump point.
Spacepope
Tue Dec 25, 2012 3:15 am
Quoting solarflyer22 (Reply 9):
The US transports since the C-130 have all used side drop doors, just aft of the wing.
rfields5421
Tue Dec 25, 2012 3:27 am
Quoting kanban (Reply 7):
Looking at photos of the aircraft from head on and on the ground - anyone exiting the door would be well clear of the props or even the immediate prop wash.
The props are about a 2/3 of a prop diameter from the fuselage and they are much higher than the bottom of the door.
TWA772LR
Tue Dec 25, 2012 3:31 am
Quoting rfields5421 (Reply 11):
How about a parachute? Aren't those designed to open as soon as the trooper is out the door?
Eat 'em up Kats!
Acheron
Tue Dec 25, 2012 4:04 am
Quoting Spacepope (Reply 4):
Yes. A la Il-76
The purpose is to shield the troops while they jump. The C-130's have a something similar on the rear side doors.
KC135Hydraulics
Tue Dec 25, 2012 4:07 am
And on the C-17 we have air deflector panels that extend into the airflow just forward of the troop doors for paradrop operations.
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
rfields5421
Tue Dec 25, 2012 5:01 am
Quoting TWA772LR (Reply 12):
See the photo
Though the static line will start to pull the pack releases in just a few feet, the trooper will be well clear of the aircraft before the chute deploys fully.
Q
Tue Dec 25, 2012 5:25 am
It looks like fish's gill some breathe air. LOL! Or emergency air brake. LOL!
Q
DIJKKIJK
Tue Dec 25, 2012 7:54 am
Even 16 years after its first flight, the AN-70 is yet to find a customer.
Why don't they just scrap it or put it in a museum?
Never argue with idiots. They will bring you down to their level, and beat you with experience.
Francoflier
Tue Dec 25, 2012 11:40 am
Quoting DIJKKIJK (Reply 17):
I've always wondered what a joint venture with EADS to bring it to requirements would have given...
It would have been a chaotic collaboration, but I'm guessing the resulting aircraft could have been a very interesting product indeed, and certainly cheaper than the A400.
Wisdom
Tue Dec 25, 2012 12:19 pm
The answer is para-dropping.
Go to 04:27 in the following video:
http://www.youtube.com/watch?v=9s6aZqRrfSU
flightsimer
Tue Dec 25, 2012 1:04 pm
Quoting Spacepope (Reply 10):
Actually, I believe all US transports capable of paratrooper drops have been out doors from behind the wing.
C-46, C-47, C-123, C-130, C-141, C-17
The C-123 was the first cargo plane that featured the rear cargo ramp. It required that the side doors be removed completely prior to flight for paratrooper dropping. There is an escape hatch in the floor just behind the cockpit on the main floor for use by people from the front of the plane in ditching because if you jump out the front side door, your going right into the prop.
Commercial Pilot- SEL, MEL, Instrument
Spacepope
Tue Dec 25, 2012 4:11 pm
There are orders for 65 of them: 5 for Volga Dnepr, 60 for RuAF. This prototype just started flying again in September after a massive upgrade program (avionics to reduce crew to 4, propellers for noise: see the new engine nacelles int he photo)
rfields5421
Tue Dec 25, 2012 8:56 pm
The AN-70 is another case of an aircraft appearing at the wrong time. It first flew right as the Soviet Union collapsed and the design customer - the Soviet Air Force - suddenly collapsed.
Which also put hundreds of AN-12 aircraft on the market, cheap, very, very cheap.
Given the birthing problems of the AM400, going back to make the AN-70 a potential competitor is probably a good business decision. Only time will tell.
But there are a lot of old AN-12 transports what need to be replaced by something.
MD11Engineer
Tue Dec 25, 2012 9:52 pm
Actually in the 1990s the Germans were interested in a joint venture with Antonov to produce a NATO compliant version of the AN-70, but the French government insisted on some old contract for what would now be the A400M and insisted that Germany would have to pay a huge fine if they would leave the project.
Jan
747to380to787
Tue Dec 25, 2012 11:04 pm
Quoting Wisdom (Reply 19):
Good video. Explain it all.
Just curious- those door hinges must be strong and there must be some drag due to distortion of aerodynamic shape of plane. Wouldn't it make sense to have that door opens inside ? Like what SOFIA does.
[Edited 2012-12-25 15:12:11]
rfields5421
Tue Dec 25, 2012 11:34 pm
Quoting 747to380to787 (Reply 24):
The purpose of the door opening out is to provide realtively low airflow for the exit point. Otherwise the troops would have to fight their way out the door. Since the aircraft is designed to have troops drop from the front doors and the rear ramp at the same time -air would inflow from the front doors at a rate possibly too high for the troops to get out safely.
One of the eternal problems with dropping paratroops is the need to avoid spreading the troops out over a large area. The troops need to all get out of the aircraft very quickly and at near the same time. Otherwise they will be scattered over a large area - maybe even a couple KM.
Both doors are opened at the same time so the drag is balanced. Even if it was only on one side, that would be well within the capacity of the flight controls to correct for in maintaining a straight flight path.
747to380to787
Wed Dec 26, 2012 4:37 am
Quoting rfields5421 (Reply 25):
Thanks rfields5421.
FYODOR
Thu Dec 27, 2012 7:17 pm
Quoting francoflier (Reply 18):
That is an answer, mate. Who nowdays care on cheap projects?   Always think about the beneficiaries if you talk about state money, never about tax payers.
Fyodor
