96adrian
Early A380s Not Built
Tue Dec 25, 2012 2:10 pm
When I looked at an A380 production list, I noticed that there are several airframes with an early MSN which are not built.
http://www.planespotters.net/Production_List/Airbus/A380/index.php
I see that there are some freighters to FedEx and Emirates with MSN 37, 53 and 60, but there are also some for Malaysia with MSN 18, 24 and 32.
My question is: will we see these MSNs in the air?
rj777
RE: Early A380s Not Built
Tue Dec 25, 2012 2:25 pm
The freighters will not see the light of day (for now). The program was cancelled after FedEx & UPS cancelled their orders.
Stitch
Tue Dec 25, 2012 2:46 pm
Quoting 96adrian (Thread starter):
I do not believe so.
Airbus delayed MH's deliveries due to production delays, which likely explains why MSN 16, 24 and 32 were never built / Not Taken Up.
While I personally believe the A380-800F won't happen, even if at some future date should Airbus choose to offer the plane again, the positions assigned to FX (MSN 37, 53) and EK (MSN 60) will remain Not Taken Up.
AustrianZRH
Tue Dec 25, 2012 3:01 pm
Quoting rj777 (Reply 1):
Now I wrote a lengthy post about how the program was not cancelled according to the Airbus website, which still counted the A38F as active type two or three months ago. Now it's gone! Does anyone know if and when such a formal cancellation of the freighter program happened?
WARNING! The post above should be taken with a grain of salt! Furthermore, it may be slightly biased towards A.
Stitch
Tue Dec 25, 2012 4:07 pm
Quoting AustrianZRH (Reply 3):
As I have not seen a Press Release stating the model has been cancelled (i.e. - Airbus formally stating they will never build one), I expect it's no longer formally on offer and that is why Airbus has removed it from their website.
[Edited 2012-12-25 08:07:58]
EMBQA
Tue Dec 25, 2012 4:24 pm
No you will not. Manufactures do not go back and use old serial numbers. They will just go down as Not Built.
Tangomaniac
Wed Dec 26, 2012 10:23 am
The A380F is still on offer on Airbus' website. You only have to look at the freighter-pages, not on the passenger-plane pages. That has changed with the last restructuring of Airbus' website.
MEA-707
Wed Dec 26, 2012 10:33 am
Quoting EMBQA (Reply 5):
exactly. Also the 320, 300/310 and 330/340 production lists have spots open due to cancelled or delayed orders and such.
It would all be confusing to finally use these low numbers now. Technically it's possible as the 380 MSN's are not exactly built in that number following order. Say Malaysian tops up it's order, everyone would rather want them to have c/n's like 170, 185 and 202 for example, as finally filling up the low numbers 18, 24 and 32 would suggest it are already older and less able frames and people including mortgagers and brokers of aircraft would later wonder why these numbers are so low while already more then 100 are built etc.
nobody has ever died from hard work, but why take the risk?
SEPilot
Wed Dec 26, 2012 10:48 am
Quoting MEA-707 (Reply 7):
If line numbers are correlated to serial numbers it would cause unbelievable confusion to use those numbers. You will find AD's and service bulletins applying to serial number ranges, and to insert older serial numbers into later production would throw all of that into a cocked hat. Things move on, and if a number does not get built, so be it. Numbers are cheap; there is an endless supply of them.
TC957
Wed Dec 26, 2012 11:24 am
What happened to MSN97 ?
KarelXWB
Crew
Wed Dec 26, 2012 11:26 am
Nobody knows but it probably was a freighter.
kc135topboom
Wed Dec 26, 2012 1:55 pm
Quoting Stitch (Reply 4):
UPS waited until after Airbus "delayed" the A-380F program to cancel their order, which was originally a conversion from their A-300-600F order. So, UPS got their deposits back. They then ordered 8 new build B-747-400Fs from Boeing.
FedEx did cancel their A-380-800F order, as did EK, before the program was officially delayed to try to catch up on the pax model.
But, I believe that within the last few months Airbus quitly changed the staus of the A-380F model from "delayed" to "canceled".
N14AZ
Thu Dec 27, 2012 5:30 am
Someone from XFW explained me that they had already started to work on the detailled design for outfitting , e.g. for MSN 018. So there are already specific design features for a wave 1-MH-380 "in the system". If they now would use MSN 018 again all these specific design features would popp up again, which is of course not helpful and that's why they Don't use these old numbers.
jfk777
Fri Dec 28, 2012 12:55 pm
What about the Virgin Atlantic birds, they ordered 6 A380 way back in 2000. They should have been flying by now. Seems unlikely VA will ever fly them, seems that A350 are more likely at VA.
Stitch
Fri Dec 28, 2012 1:18 pm
Quoting jfk777 (Reply 13):
VS continues to defer their delivery.
FI642
Sun Dec 30, 2012 3:56 am
Once an MSN is skipped, it normally remains that way. I cannot imagine Airbus going back to skipped numbers and using them. Several reasons for this, One the number was assigned to a specific customer, and two, it makes the frame look older. Remember NW wanting the DC-10-20 changed to the DC-10-40 because it made it look like the latest greatest thing? Same here.
737MAX, Cool Planes for the Worlds Coolest Airline.
WingedMigrator
Sun Dec 30, 2012 7:16 am
Quoting KC135TopBoom (Reply 11):
If that were indeed the case, why would they not remove it from their newly redesigned website?
breiz
Sun Dec 30, 2012 3:24 pm
Quoting Stitch (Reply 2):
MSN 16 was allocated to Emirates from scratch and delivered in May 2008. You are referring to MSN 18.
Quoting N14AZ (Reply 12):
The parts planned for MSN 18 are said to have been re-used for MSN 45, delivered to Emirates in September 2009.
Unflug
Mon Dec 31, 2012 10:21 am
That makes sense.
They'll only use the missed low numbers after they have run out of larger numbers, which won't happen that soon
