Kiwinlondon
CZ Flights From China To South America Via AKL?
Tue Dec 25, 2012 8:03 pm
CZ seem to be building a bit of a presence in AKL. There has been some speculation that CZ (and possibly other Chinese airliines) might be interested in routing flights to South America via AKL.
We of course know that LA have a codeshare with CX to HKG from SCL via AKL.
Does anyone have any information on any of this?
Kiwinlondon
[Edited 2012-12-25 12:06:52]
EddieDude
RE: CZ Flights From China To South America Via AKL?
Tue Dec 25, 2012 9:12 pm
Interesting. What airplane would CZ use? Could the 77W do, say, AKL-EZE? I am choosing EZE because it is a SkyTeam hub like CAN.
Upcoming AM MEX-LAX 73H, VA LAX-MEL 77W.
nickofatlanta
Wed Dec 26, 2012 12:53 am
Yes I believe the 77W could make AKL-EZE and they could codeshare with AR who recently eliminated the AKL stop from their SYD-AKL-EZE route.
legacyins
Wed Dec 26, 2012 1:16 am
Quoting EddieDude (Reply 1):
The only issue is that CZ does not operate the 77W. Their primary long haul aircraft are the A380, 772ER and A332.
EddieDude
Wed Dec 26, 2012 1:22 am
Haven't they ordered it? Maybe I am confused.
legacyins
Wed Dec 26, 2012 1:28 am
Quoting EddieDude (Reply 4):
Yes, you are correct. I believe they ordered 10-777-300ER in February of this year.
Fuling
Wed Dec 26, 2012 1:51 am
Would ETOPS be a problem for this sort of route on a 772ER or 77W?
ZKSUJ
Wed Dec 26, 2012 2:01 am
Quoting Fuling (Reply 6):
Yes it would. NZ did a 77W charter flight to EZE this year and I was reading about it in the staff magazine. The routing they took to remain within ETOPs restrictions was quite different to what the 340's take. Adds a fair whack of time as well if I'm not mistaken
nickofatlanta
Wed Dec 26, 2012 3:36 am
Quoting ZKSUJ (Reply 7):
Sounds not dissimilar to the issues VA had in operating MEL-JNB with their 77Ws.
IndianicWorld
Wed Dec 26, 2012 3:48 am
Quoting nickofatlanta (Reply 8):
Yep. Unless CZ deploy their A380, none of the options they have expressed interest in would really work. The A380 is too big for it though, and with no other 4 engined aircraft, they dont have much to offer.
It hasn't been just AKL they have looked at apparently, it is also SYD and MEL that also are in the mix.
justinlee
Wed Dec 26, 2012 3:56 am
Rumor says because NZ wants the traffic right between PVG-LHR. For exchange, CZ wants the traffic right from AKL to somewhere in South America. But CZ doesn't have a suitable plane for that route actually.
RJ_Delta
Wed Dec 26, 2012 12:58 pm
The plan for CZ is cooperate with Aerolineas Argentinas to extent its services to South America. CZ operate the CAN-AKL route and AR AKL-EZE. Part of this plan was informed in August when AR joined to SkyTeam. However for this plan AR needs to relaunch its flights to AKL.
Best Regards,
[Edited 2012-12-26 05:01:00]
PETRHSR
Wed Dec 26, 2012 7:56 pm
330 minutes ETOPS on the 77W and 77L. NZ was the first airline to buy-in. Puts AKL-EZE well within capabilities. In fact, 330 minutes puts SYD-GRU in range.
First class isn't a seat, it's a lifestyle.
aerorobnz
Wed Dec 26, 2012 9:57 pm
Quoting petrhsr (Reply 12):
They maintain to that EDTO330 standard yes,but are not currently endorsed above EDTO 240 - this will come once the standard has been maintained for a predetermined length of time. Incidentally the 77Es are also now undergoing the same maintenance transition from EDTO180 to EDTO 240. Bare in mind that the NZ charter to EZE was operated within EDTO240, so NZ 77Es will be able to reach South America easily.CZ have expressed interest in some kind of partnership with NZ. I believe that if it was implemented that it would be on a routing like this.
The CZ 77Es currently are old and tired with very dated interiors, you may as well fly AR 342a..
Flown to 128 Airports in 48 Countries on 81 Operators. Visited 56 Countries and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
sunrisevalley
Wed Dec 26, 2012 11:59 pm
Quoting aerorobnz (Reply 13):
So the FAA appears to be close to appoving > EDTO 180 minutes on RR/PW powered 77E's. It has long been my postion that NZ need the FAA to issue this approval before they can operate to and from South America with anything other than a 77W.
airbazar
Thu Dec 27, 2012 12:05 am
Quoting justinlee (Reply 10):
AKL-SCL should be well within the range of the A332/B772ER with ETOPS 240, but that's about it. Both LIM and EZE are a bit too far.
nickofatlanta
Thu Dec 27, 2012 12:00 pm
Quoting RJ_Delta (Reply 11):
Could they not just have the partnership through SYD not AKL?
