2008matt
What Is Wrong With This A380?
Thu Dec 27, 2012 1:18 pm
Does anyone have any idea what happened to the paint on the tail of this Korean A380? Did they just run out of paint? Looks like a bit of an unprofessional paint job.
Photo © Yunjin Lee - Korea Aero Photo
[Edited 2012-12-27 06:17:41 by SA7700]
Keep calm and up your game!
aztrainer
RE: What Is Wrong With This A380?
Thu Dec 27, 2012 1:22 pm
It seems to be a optical illusion from the glare of the sun. To me it seems to simply be the reflection from the horizontal stabilizer. The lighter color is just being reflected on the vertical stabilizer. If you look at the other A-380 in the background you can see a smaller "dot" on the tail also.
2008matt
Thu Dec 27, 2012 1:36 pm
Now you mention it I can see what you mean, still, does look like it has been half painted haha.
peterjohns
Thu Dec 27, 2012 6:28 pm
Quoting 2008matt (Reply 2):
You're absolutely right! The whole bottom part hasn't been painted blue......
barney captain
Thu Dec 27, 2012 10:21 pm
Reflection from the horizontal stab - nothing more.
Southeast Of Disorder
Stitch
Thu Dec 27, 2012 10:37 pm
This is the next to latest picture of this airframe from LAX on 2 December 2012, and it clearly shows the tail is painted, so a reflection is indeed the most logical explanation for the bright spot.
Photo © Jonathan Morgan
Eagleboy
Thu Dec 27, 2012 10:47 pm
Quoting peterjohns (Reply 3):
Great snap of the 3 A380 in a line though....
B737900
Fri Dec 28, 2012 3:54 am
Although it could be a reflection, it does look like primer. The bottom left edge looks too straight, cut-off to be a reflection. However, if you check A.net photos of Korean Air HL 7614 no white paint is shown. It looks like someone took a paint roller dipped in white paint to the tail. IMO.
Sounds like a Beaver on floats..........we're saved!!
lightsaber
Crew
Fri Dec 28, 2012 4:30 am
Quoting EagleBoy (Reply 6):
Excellent snapshot.
What is the peak number of A380s in a row in the a.net database? Ideal in operation, but I'll take TLS too.
Lightsaber
3DoorsDown
Fri Dec 28, 2012 5:25 am
They could have had a repair in the past week, in that area, and due to management forcing the plane back into the air in the shortest time possible, didn't have time to finish the topcoat. It could be a reflection, anything is possible, but it looks to me like primer. My
soon7x7
Fri Dec 28, 2012 5:54 am
Quoting aztrainer (Reply 1):
That's what it is...just the horizontal stab throwing light on the rudders topcoat. Photographer at just the correct position to view this.
afterburner
Fri Dec 28, 2012 6:11 am
I don't think it was a reflection. The top edge is too jagged, the left edge is exactly at the leading edge of the rudder, and the right edge is parallel to the trailing edge of the rudder.
bill142
Fri Dec 28, 2012 7:48 am
Quoting 3DoorsDown (Reply 9):
There's a fair lot of blue amongst that primer. That to me suggests it's a reflection rather than a repair.
azzazzazza
Fri Dec 28, 2012 7:52 am
Surprised this is being discussed really... Open it in large view and to me that is quite clearly a reflection!
Kinda symbolic with the 747 going the other direction in the background... The new A380 replacing the retiring old 747... Like a substitution... Or maybe thats just the old English student in me, making something out of nothing!
wellies
Fri Dec 28, 2012 7:57 am
Don't rudders have to be very finely balanced to fly efficiently?
rwessel
Fri Dec 28, 2012 11:10 am
Quoting wellies (Reply 14):
It's not efficiency, but rather flutter avoidance that requires careful adherence to the balance limits of a rudder.
avrich
Fri Dec 28, 2012 11:26 am
Been a pro photog for 12 years. Its a highlight caused by reflection. No doubt about it at all.
"Time....the fighter pilots enemy" Flt Lt CJW Roscoe Tanner 1962-1991
neutrino
Fri Dec 28, 2012 5:35 pm
Quoting avrich (Reply 16):
Weighing in with you as a pro in the photo industry for the past 28 years - from technicial to shooting to final image production (and also as a aircraft maintenance specialist for 12 years prior) - it is in all probability ascribable to reflection. The unevenness of the patch is all due to both the reflecting and reflected-upon surfaces which are far from being flat in the first place. Reflected lights from and on curvy surfaces can and do play tricks on the eyes.
Potestatem obscuri lateris nescitis
soon7x7
Fri Dec 28, 2012 5:47 pm
Quoting afterburner (Reply 11):
I have been commissioned to photograph over 2,000 aircraft in the last 25 years...I can assure you it is just highlights on a fresh topcoat of paint. Blue paint...(I also paint aircraft). The irregularity is from the internal structure of the rudder and H/stab, and the "oil canning" of the composite skin. Can't believe this is even debatable as an issue at least for those that chase planes with a camera?!
tp1040
Fri Dec 28, 2012 6:03 pm
If it is not a reflection, the second ship has the same problem. Just a little smaller.
maxter
Sat Dec 29, 2012 12:02 am
Of course it's a reflection, and that's coming from someone who has never taken a professional photo in his life... so there
maxter
Silver1SWA
Crew
Sat Dec 29, 2012 12:13 am
Quoting azzazzazza (Reply 13):
Seriously! I can't believe this is actually being debated.
Clearly a reflection. PERIOD.
dragon6172
Sat Dec 29, 2012 12:38 am
Quoting Stitch (Reply 5):
Clearly in your picture the unpainted spot has been moved to just above the aft lower door. And now it flows over the horizontal tail in the slipstream!! What kind of paint are they using at Korean Air!! Unbelievable.
Phrogs Phorever
capri
Sat Dec 29, 2012 2:46 am
http://www.airliners.net/photo/Korea...d=2379ee131956dcc007a567c05633a6da
Try to study all reflections you want in this photo
the blue that KAL uses is quite interesting
wellies
Sun Dec 30, 2012 2:11 am
Quoting rwessel (Reply 15):
Thank you for the correction! I shall do some further studying...
vegas005
Sun Dec 30, 2012 7:58 pm
There is a reflection on the A380 in the middle and on the 747 (what a beauty) just entering the picture as well.
No doubt about it being a reflection.
Kiwirob
Sun Dec 30, 2012 9:14 pm
Surprised that nobody thought to contact the photographer
That is reflection from horizontal tail and not unpainted area or spot. If you want I can share sequence photos before and after reflection.
KE has their own painting plant at PUS and they can do various paint job including special livery,wrapping and even other airlines livery.
So I can't think they made such a big paint error!
Yunjin Lee
you're welcome KiwiRob
Francoflier
Sun Dec 30, 2012 9:17 pm
Quoting 2008matt (Thread starter):
Yes, they've polished that paint waaaay too much. Look at all the light it reflects now.
CM
Sun Dec 30, 2012 9:36 pm
True for the 747-400s, that's for sure. However, I think the incoming 747-8s will end up being the newest sub-fleet at KAL.
ikramerica
Sun Dec 30, 2012 10:58 pm
"Melanoma, carcinoma, some kind of anoma."
