United Airline
UA's Overnight B 747-400 In HKG
Sat Dec 29, 2012 4:21 am
UA has 1 B 747-400 sitting in HKG overnight (SFO-HKG-SFO). Should/will they use it to open up new intra-Asia routes? Let's say HKG-TPE or HKG-BKK or HKG-DEL (They have done the later two)?
UA787DEN
RE: UA's Overnight B 747-400 In HKG
Sat Dec 29, 2012 5:04 am
I have no good info here, but is it possible they rotate aircraft through HKG for down time and maintenance? Also, add flights, and there is a higher chance of everything getting screwed up. Done right, an Asian destination could work. A problem is timing-dead of night departure times. United is starting TPE-SFO and already has BKK-NRT, so HKG traffic would rely on Asian pax, who are more likely to take a daytime flight on a very highly served HKG route. UA operates DEL-EWR. Same there, but there might be a bit of a market. The question is, is it profitable to fly an old 744 in the middle of the night to Airports you already serve more conveniently? I think in this case the answer is No.
TWA772LR
Sat Dec 29, 2012 5:13 am
How about HKG-CGK? CGK is a hole in UA's pacific network that can be filled, why not from HKG?
And for my next miracle, I'm gonna turn water into funk!
UA787DEN
Sat Dec 29, 2012 5:48 am
I agree CGK is a hole in the network. I don't know if UA could make it work to HKG.The thing is, Asia is big. Real big. HKG-CGK is a tad bit longer than LAX-DTW or MIA-PHX. It couldn't be done with reasonable turnaround times and profitability. We are talking about flying 3500 nm and turning a 744 3 times in an overnight stay to compete at bad times on a high capacity route with multiple other carriers.
warreng24
Sat Dec 29, 2012 5:15 pm
Quoting United Airline (Thread starter):
IIRC, before the start of the HKG-SGN tag-on, PMUA always had a B744 sitting overnight in HKG. It came in handy as a "spare" if the HKG-SIN tag-on B744 went MX.
Once the HKG-SGN tag-on started, there was no B744 RON's in HKG.
Then after the merger with CO, there was 2 x B744 RON's in HKG. I believe they were rotated in/out for overnight MX. The HKG-SIN and HKG-SGN tag-on's were operated by PMCO B738's (in a COMIKE configuration).
During Mid-2013, B744 operations will be consolidated to SFO. Therefore, the B744 on ORD-HKG will revert to a PMUA B772. I'd imagine that UA will continue to have a B772 or a B744 RON at HKG. HKG-SIN is currently scheduled to remain as a B744, but I'd imagine that scheduling will rotate in the B722 as loads/demand permit.
IIRC, the PMCO 772 that operates EWR-HKG-EWR has always RON at HKG.
luv2fly
Sat Dec 29, 2012 5:21 pm
It could also be possible that the aircraft that over night get a good cleaning while on the ground.
AA94
Sat Dec 29, 2012 9:19 pm
If I'm looking at the schedule right, I believe the flight pair in question is UA869/862. The aircraft arrives into HKG at 1900 local, and departs the next day for SFO at 1230 local. That leaves around ~15.5 hours in between, and even less if you account for the time it takes to deplane and service the aircraft after UA869, and the time it takes to service and enplane the aircraft for UA 862, not to mention servicing/enplaning/deplaning for a tag flight.
With a flight time of ~5 hours on HKG-CGK, it simply doesn't seem possible that UA could turn an aircraft during the overnight. Even if it were possible, when you add in the factors that UA787DEN touches upon, there's really no case for adding a flight simply to utilize the aircraft.
If you can't take the heat, you best get out of the kitchen
flyingdoc787
Sun Dec 30, 2012 2:38 am
How about HKG-MNL-HKG? Flying time between HKG and MNL is around 2 hours, so that will give enough time for the flight to arrive and depart MNL at a decent time, and still keep within the current HKG arrival (1900) and departure (1230). The plane can RON in MNL, just as DL's 744s do. MNL has capabilities for MX as well.
Possible schedule:
dep. HKG 2015 arr. MNL 2215 (RON)
dep. MNL 0900 arr. HKG 1100
UA already has operations in MNL from GUM, so resources on the ground are there. The Philippines-USA market is huge, albeit mostly low-yield VFR, so I don't think opening this route would conflict with UA's current GUM operations; they might even complement them.
However, I don't know about current restrictions on flights operated by US-based carriers to/from the Philippines. In any case, one can always dream! It would be great to have UA's 744 in Manila!
UA787DEN
Sun Dec 30, 2012 3:01 am
MNL is the best idea I've seen so far. But a UA 744 needs more than an hour or hour and a half for an international turn, and if it needs MX they would be screwed. I honestly don't know how it would do. CX operates 744s on the route. KA, 5J, and PR also operate it, and probably with lower costs simply because they are Asian carriers. Also, foreign carriers pay a king's ransom to fly MNL. I think that a 772 might make it work, leaving HKG at 2100 at leaving MNL at 0700. But an old 744 just wouldn't work. Airlines don't add routes for the hell of it. They add routes to make money, and UA on HKG-MNL won't.
FI642
Sun Dec 30, 2012 3:39 am
HKG is a perfect place for a spare any MX issues. Additional capacity to another market certainly has been explored and
isn't worth the effort.
737MAX, Cool Planes for the Worlds Coolest Airline.
UA787DEN
Sun Dec 30, 2012 3:47 am
There is a difference between could and would. Could UA serve MNL or TPE from HKG? Barring MX or cleaning I don't know about, yes. Would they? No. No. No.
FI642
Sun Dec 30, 2012 3:57 am
Quoting UA787DEN (Reply 10):
Agreed. Do they even have Traffic Rights to do this? Probably not.
VC10er
Sun Dec 30, 2012 7:39 am
I know when United down guagded to a 737 from HKG to SIN, there was a huge cry of anger and I was #1 on that rampage. Now they have gone back to the 747. United's premium product (especially First) was very good (not nearly as good as most of it's Asian rivals- but in a UA contex very good). All that said, United 737's are very nice birds and can they feed other smaller Asian cities with them out of NRT or HKG? Hanoi perhaps or KL? Also..can a Singapoian buy a ticket from SIN to HKG (on the 747) only?
Last: the Denver to Tokyo 787, will that 787 just turn and go back to Denver or could it tag?
[Edited 2012-12-29 23:42:06]
The world is missing love, let's use our flights to spread it!
COSPN
Sun Dec 30, 2012 7:43 am
Just because you have a car in your drive way overnite, that is no reason to go on a "Road Trip"
AeroWesty
Sun Dec 30, 2012 7:49 am
Quoting VC10er (Reply 12):
Yes.
International Homo of Mystery
