apodino
WN Opening ATL Crew Domicile
Wed Jan 02, 2013 7:51 pm
This was in another thread so I don't have a link to it. Anyways....WN is going to open a Crew Base for the WN side in ATL, and the plan is going to be to eventually transition the 737-800's out of the FL fleet into the WN fleet, as that happens, the FL guys will be displaced and will be replaced by WN guys who can now bid ATL, until the SLI happens. (This is the way I understand it). Once the 737's have been converted and the 717's shipped off to DL, WN is going to build up the ATL domicile into a domicile much like others in its system.
I only mention this because this should dispel the rumors that WN is going to greatly reduce ATL. It is certainly going to be no DL obviously, but I think a better comparison may be the WN operation at LAX for a relative size that we are looking at.
sdoyon
RE: WN Opening ATL Crew Domicile
Wed Jan 02, 2013 7:56 pm
Interesting tidbit!
Quoting apodino (Thread starter):
I'm assuming you mean 737-700, which would leave the 717 as FL's sole aircraft.
Where will they be displaced to? Are they being converted to WN slowly, or must they bid at other FL bases (I have no idea what they are...BWI/MKE/MCO?)
iowaman
Wed Jan 02, 2013 7:58 pm
Huh?? There are no FL branded 737-800's?
If WN is opening a base in ATL I think we all can expect a decent sized operation there now. LAX sized is probably a good bet, or similar to SAN/OAK.
ouboy79
Wed Jan 02, 2013 8:37 pm
Quoting sdoyon (Reply 1):
Crews are being transitioned to WN already. So they aren't being left behind in the FL system. The process has them all going through WN training, including the typical new hire stuff (FLY class).
Quoting iowaman (Reply 2):
I'm sure it was just a typo.
SAN is roughly 20 departures smaller than OAK, so might not be a good example. I would think somewhere between OAK and HOU would be a good bet.
enilria
Wed Jan 02, 2013 8:49 pm
I'm not sure the 717s are staying in ATL. If you look at their recent schedule changes, they have been moving more and more FL flying into Florida non-stops even if it means converting WN routes to FL. I think we will see more of that and we might even see ATL cutover to all WN in early 2014 (except for some Florida stuff), leaving FL flying Florida point-to-point.
Atlwest1
Wed Jan 02, 2013 9:37 pm
Quoting enilria (Reply 4):
Everything should be done by Jan or very early 2015. The last things left will be International and more then likely a hand full of markets to connct to that
Quoting ouboy79 (Reply 3):
The crews are transitioning over at a very very slow pace. It will not be till 2014 that their should be a mass cross over of crews. As for the cabin crew side will be done by Jan 2. 2015.
ALL views, opinions expressed are mine ONLY and are NOT representative of those shared by Southwest Airlines Co. or Airt
ouboy79
Thu Jan 03, 2013 12:04 am
Quoting Atlwest1 (Reply 5):
Yeah I knew it wasn't extremely fast, but I just wanted to point out that it was already in progress (and has been for at least a year now).
deltal1011man
Thu Jan 03, 2013 12:33 am
two things, its not a rumor. FL/WN has cut back in ATL. Thats a fact. IIRC FL peaked in ATL at ~230 flights and they are down to around 160. Pretty good cutting.
and If it were to become LAX size then your talking about cutting ~60 more flights(WN has ~110 flights from LA and ~160 from ATL) which i would call a pretty big cut.
I don't understand why this site even has moderators anymore.
ouboy79
Thu Jan 03, 2013 1:51 am
Quoting Deltal1011man (Reply 7):
If the latest fact sheet is correct, we are looking at 169 departures from ATL. Also have to add into that the 28 flights now operated directly on WN metal. So if we are going to correctly and accurately compare numbers, that would put it at 197 flights a day. Considering the number of cities that have been dropped from the FL network and not transitioned, that isn't too bad. I still see it coming down a bit more as it is transitioned to a more traditional WN focus operation.
LAX size is way too drastic IMO. Between OAK and HOU are better bets and possibly closer to HOU in those numbers. Which if that's the case, still looking at a 40 flight reduction. Of course we really don't know (publicly) where the chips will fall with existing FL ATL flights and how WN markets might be connected to ATL post-transition.
deltal1011man
Thu Jan 03, 2013 1:54 am
Quoting ouboy79 (Reply 8):
pretty much WN isn't going to cut into profitable flying.
not idea how much they have of that in ATL....
Ah sorry, thought I saw somewhere they were down to 160-170 total (for WN/FL)
ouboy79
Thu Jan 03, 2013 7:53 am
Quoting Deltal1011man (Reply 9):
Right. Which is why I think we won't see nearly as much Florida service as there has been under FL. Much more P2P connections with business centers.
UGA777
Thu Jan 03, 2013 3:04 pm
When is WN going to start bringing the 800s into ATL or at all?
Flytravel
Thu Jan 03, 2013 3:30 pm
Quoting ouboy79 (Reply 10):
I'm just curious how they are going to service on some of the medium haul ATL routes, where WN isn't the leading carrier in the market on the other side either:
ATL-LGA: DL has 16x daily, hourly, mainline and strong hub and focus on each side, plus offers EWR and JFK as a NYC alternative for business pax. AA serves also an alternative at LGA for business pax.
ATL-PHL: DL, and US
ATL-BOS: DL, and WN flying over BWI-PVD/BOS/MHT
And shorter, but also possibly weak one:
ATL-RDU: DL (strong), and RDU business pax typically loyal to DL or AA. Highest frequency WN offers at RDU is RDU-MDW at 4x daily but Chicago service maybe more fragmented across business travelers, and WN can offer more connections within its own network from MDW.
iowaman
Fri Jan 04, 2013 3:44 am
Quoting Flytravel (Reply 12):
ATL-PHL: DL, and US
I wonder about those markets too. It's fairly predictable the usual WN "focus cities" will be served, but these other markets are questionable. ATL-MSP, PIT, and IND are also questionable in my opinion as well.
SurfandSnow
Fri Jan 04, 2013 6:21 am
I don't think anyone seriously expected WN to shut down the whole ATL base and force virtually all the FL people to move to (or commute to) the WN bases. Such a move would sour employee relations and cause far more trouble than it would ever be worth.
Yes, hopefully this will end the talk of WN slashing ATL down to a mere 15-20 flight spoke. The delayed codeshare implementation may be causing new flights like ATL-SDF/ORF to struggle now, but even those should do fine when the merger is all said and done. It's not much different from the infamous FL DSM flights that preceded the much more successful WN flights..
ATL has or soon will lose service to smaller, weaker spokes - many of which were never commercially viable in the first place, relying on hefty local subsidies (ACY, ICT, BKG, etc.) or very low-yielding connecting traffic rather than more profitable O&D (BMI, FNT, ROC, etc.). Obviously FL-only routes to places like FLL, MCI, STL, and TPA won't be going anywhere, and redundant FL frequencies to the likes of MDW, DEN, BWI, etc. will eventually transition to WN metal as well. I would think most of the remaining FL routes out of ATL will continue, and who knows, we could even see more WN-only spokes added to ATL - BDL, LIT, SAN, CLE, etc. The operation will be much different than the FL days, where connecting traffic was king and the 717s were ideally suited for high frequency short haul ops. WN will offer fewer flights (typically on larger aircraft) targeted primarily at O&D.
Bottom line: ATL isn't going anywhere. WN bought FL for several reasons, and one of them was ATL - by far the largest domestic market they didn't serve before the acquisition.
OzarkD9S
Fri Jan 04, 2013 7:36 am
ATL for WN will be very different than ATL for FL. For one thing there is little to no need for ATL serving as a connecting point to Florida, as WN has been overflying ATL for YEARS. ATL will be a big station for WN, but it can't and wont be the important station it was for FL. Too many other options. Don't even think that ATL for WN will be as important as at least a dozen other stations.
Next Up: STL-MIA-GCM-MIA-STL. Fun in the December sun! :santahat:
Flytravel
Fri Jan 04, 2013 8:18 pm
Quoting iowaman (Reply 13):
Maybe it would hedge BNA in case ATL business routes don't work. Run a high frequency BNA-ATL for crew and connections, and add PIT, RIC, CLT, IAD, DAL, SFO, and maybe MKE, IND, PVD and BDL, and/or increase frequencies slightly to other major east markets from BNA.
