Quoting HermansCVR580 (Reply 3): If I remember Flying Tigers had a pretty big operation at ORD before FEDEX. We're they scheduled or ADHOC? |
Quoting HermansCVR580 (Reply 5): |
Quoting mayor (Reply 1): When I worked there, just before you got to the UA terminal was Butler Aviation and the GA ops. |
Quoting jcwr56 (Reply 6): It's used for storing of city and some ground handling equipment. In the event the T5 hardstands are full, we'll make arrangements with the city to park aircraft (usually narrow-bodies) over there. |
Quoting HermansCVR580 (Reply 10): So from the sounds of it Mayor Delta had a much larger operation at ORD than they have today. If the freight building I am thinking of that Delta had/has is a pretty big building for their freight ops. Heck I'd almost consider the Delta ORD ops of past almost a mini hub. |
Quoting HermansCVR580 (Reply 10): Heck I'd almost consider the Delta ORD ops of past almost a mini hub. |
Quoting mayor (Reply 11): Well, I've not seen the former NW building, so I don't know how that compares to the building I worked in. That building, as I have mentioned is on the corner of Bessie Coleman Drive and the cargo road. |
