audidudi
DL B764 Flies To Boeing Paine Field.
Wed Jan 09, 2013 8:45 am
DL B764 ship #1821 (N845MH) flew from SEA-PAE two days ago as DL #9936. Anyone know why it went there?
http://flightaware.com/live/flight/N845MH
ScarletHarlot
RE: DL B764 Flies To Boeing Paine Field.
Wed Jan 09, 2013 5:36 pm
Maintenance at Goodrich?
It flew right over my house - too bad that was after dark!
But that was when I ruled the world
maddogjt8d
Wed Jan 09, 2013 5:42 pm
Several DL 764's have done this over the past few months. Probably scheduled maintenance.
Cessna172RG
Wed Jan 09, 2013 7:07 pm
I've noticed this, too. I think a few weeks ago I had to do a double take when I saw one departing. If it's any consolation I also see Southwest and Alaska fly in, presumably for maintenance as well.
Save the whales...for dinner!!!
GSPSPOT
Wed Jan 09, 2013 7:20 pm
Is there a certain type of maintenance that can only be done at PAE? DL for one has quite extensive maintenance facilities/capabilities. They even do maintenance for other carriers. Just wondering about that.
Finally made it to an airline mecca!
jetmatt777
Crew
Wed Jan 09, 2013 7:30 pm
Quoting GSPSPOT (Reply 4):
Maybe they use Boeing for overflow when there facilities are filled up.
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
deltal1011man
Wed Jan 09, 2013 7:31 pm
Delta enjoys outsourcing......
be a good little boy and do as Demand Media tells you. sellouts.
flight152
Wed Jan 09, 2013 7:41 pm
Quoting audidudi (Thread starter):
Boeing Paine field? You know those are two different airports. PAE and BFI.
dlramp4life
Wed Jan 09, 2013 8:06 pm
Quoting Deltal1011man (Reply 6):
As well as insourcing
SEA Ramp, wettest place on earth
modesto2
Wed Jan 09, 2013 10:22 pm
An interesting statement considering DL's large TechOps facility. Among the legacies, it has chosen to do more of its maintenance work when compared with others.
mayor
Wed Jan 09, 2013 10:37 pm
Quoting modesto2 (Reply 9):
I'm sure there's more than enough work for everyone to do without having to worry about whether DL's outsourcing or not.
If you're not busy, Deltal1011man, I'm sure there's something you could be working on.
"A committee is a group of the unprepared, appointed by the unwilling, to do the unnecessary"----Fred Allen
IAHFLYR
Wed Jan 09, 2013 10:38 pm
Quoting flight152 (Reply 7):
Boeing Paine field?
I would agree that the title seems a little confused however; I'll give the OP the benefit of doubt and go with something like DL flies to Boeing Factory, Paine Field as the intended meaning!!
cargolex
Wed Jan 09, 2013 10:45 pm
Quoting jetmatt777 (Reply 5):
The MRO at PAE is not part of Boeing.
Aviation Technical Services does work on 737, 757, 767 and MD-80 products pretty regularly (they are also able to work on 747, 777, DC-10, L-1011, and A319/A320, but these are rarely seen at PAE). They have worked for a variety of airlines but AS, WN, 5X, and DL are the most regular visitors, though even North American and Hawaiian are not uncommon.
clickhappy
Wed Jan 09, 2013 11:00 pm
N845MH is currently at Paine Field.
Photo © Spencer Wilmot
michman
Thu Jan 10, 2013 12:01 am
A DL MD88 is on it's way there right now from DTW as flight 9931 http://flightaware.com/live/flight/DAL9931
flightsimer
Thu Jan 10, 2013 1:54 am
Might have forgot the 's as in Boeing's Paine field.
Commercial Pilot- SEL, MEL, Instrument
TZTriStar500
Thu Jan 10, 2013 3:26 am
Quoting flightsimer (Reply 15):
Its not. They do not own it.
35 years of American Trans Air/ATA Airlines, 1973-2008. A great little airline that will not be soon forgotten.
flightsimer
Thu Jan 10, 2013 4:55 am
Quoting TZTriStar500 (Reply 16):
I knew i should have left the second sentence i typed in my post. But i thought it was obvious Boeing doesnt own it as they dont own any airport including Boeing Field or Renton Municipal.
However Boeing does own the facilities they use at the airport so it is correct to use with facilities being implied as I and others thought based on the discussion. However, it has been said above that it did not go to Boeing itself, but another contractor based on field.
braniff722
Thu Jan 10, 2013 5:51 am
Maybe Delta and the others are trying to get their stuff fixed before all the 787's show back up and clog, or hog all the ramp parking at Paine Field!!!
Oh, we all know its coming!!!!
Living large in KSHV
simpilot459
Thu Jan 10, 2013 7:27 am
Quoting flightsimer (Reply 17):
Boeing does own an airport near Glasgow, Montana that is used for flight testing.
Back on topic, Detla, as well as other airlines and private operators, sends planes to Aviation Technical Services (formerly Goodrich) in Everett for major maintenance. Lockheed's Catbird test airplane arrived at ATS last week.
There is a lot more at Paine Filed than just Boeing.
Take off: Optional Landing: Mandatory
deltal1011man
Thu Jan 10, 2013 9:40 am
An even more interesting statement from someone I'm fairly sure has no idea what they are talking about.
Oh and even after the BK contract AA will still be doing more work in house than Delta. (When including TAESL)
Quoting mayor (Reply 10):
Fair point.
Revelation
Thu Jan 10, 2013 12:48 pm
Quoting simpilot459 (Reply 19):
Hmm, http://www.gcr1.com/5010web/airport.cfm?Site=GGW says it's publicly owned.
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
wedgetail737
Thu Jan 10, 2013 10:35 pm
The Seahawks have been using DL equipment for their away games.
simpilot459
Fri Jan 11, 2013 2:25 am
Quoting Revelation (Reply 21):
http://www.boeing.com/commercial/techsvcs/boeingtech/bts_flita.html
Polot
Fri Jan 11, 2013 2:34 am
And if simpilots459 link doesn't convince you that it is the airport, and not just a facility located at the airport, straight from the FAA:
https://nfdc.faa.gov/nfdcApps/airportLookup/airportDisplay.jsp?airportId=07MT
