tommy767
Insane Headwinds Jan 25th: 7 Hours BOS-SFO
Fri Jan 25, 2013 4:30 am
Some of the BOS-SFO flight times are reaching 7+ hours. That's really long for transcon -- but it makes sense since it's about 11 degrees here in NJ with the Canadian cold front coming through. Here are some examples:
BOS-SFO:
UA 1796, 7 hours: http://flightaware.com/live/flight/U...6/history/20130124/2250Z/KBOS/KSFO
UA 1057, 7 hours: http://flightaware.com/live/flight/U...7/history/20130124/2135Z/KBOS/KSFO
B6 633, DIVERTED 6hrs 7min to LAS: http://flightaware.com/live/flight/J...3/history/20130124/2119Z/KBOS/KLAS
EWR-SFO:
UA 1054, 6 hrs 36 min: http://flightaware.com/live/flight/U...4/history/20130125/0005Z/KEWR/KSFO
RDU-SFO:
UA 1629, 5hrs 51 min: http://flightaware.com/live/flight/U...9/history/20130124/1200Z/KRDU/KSFO
ATL-SEA:
DL 109, 4hrs 57 min: http://flightaware.com/live/flight/D...9/history/20130124/2250Z/KATL/KSEA
EWR-LAS:
UA 1284, 5hrs 45min: http://flightaware.com/live/flight/U...4/history/20130124/1550Z/KEWR/KLAS
Some crazy examples! See if you can find any others out there
PS: Is there a reason why some of these UA 737s on BOS-SFO are 7hrs flying time but the 757s are a little over 6hrs 30mins?
"KEEP CLIMBING" -- DELTA
gdg9
Fri Jan 25, 2013 4:36 am
So how much shorter were the eastbound flights then?
@dfwtower
PHX787
Fri Jan 25, 2013 4:38 am
Sounds nuts. Did they anticipate this and load more food on board? I'd be really hungry
Quoting tommy767 (Thread starter):
B6 633, DIVERTED 6hrs 7min to LAS: http://flightaware.com/live/flight/J.../KLAS
Did they not put enough gas in the plane in anticipation ?
http://flightaware.com/live/flight/J...7/history/20130124/2212Z/KBOS/KPHX
Looks like flights to here in PHX were routed southerly today instead of northerly.
MAH4546
Quoting gdg9 (Reply 1):
I flew LAXMIA a few weeks ago with extreme tailwinds - 3 hours, 29 minutes take off to touchdown.
[Edited 2013-01-24 20:39:16]
a.
tommy767
Fri Jan 25, 2013 4:41 am
Quoting PHX787 (Reply 2):
Probably not but damn being on a UA 737 for 7 hours -- that has to be torture. Hopefully they still have food and drink after 6 hours!
IAHFLYR
Fri Jan 25, 2013 4:47 am
From your post and links I don't find a 757 flying BOS-SFO, only 738/9. Could be the 73's are using more of an ECON speed while the more fuel capable 75'7 is simply running along at .82. In any event glad I am not on any of them as I've had my but in airplane seats for 13 hours already this week.
questions
Fri Jan 25, 2013 4:54 am
Quoting tommy767 (Reply 4):
Are you kidding? Do you think they would anticipate anything like this? Even if they did, do you think they would think through the implications to the customer? Of course not. They simply don't care.
Always pack snacks. Always pick up water in the terminal. Regardless of class of service.
Never depend on an airline to take care of you. The concept of service and hospitality left the airline business years ago.
StarAC17
Fri Jan 25, 2013 4:56 am
Probably pushing to exceeding the MTOW of an A320 if they had a full load and full fuel. I recall from an earlier thread about strong winds that the fuel stop is planned from before departure as it is still the most economical option.
Difference in cruising speed I would think.
IIRC the 757 cruises at Mach 0.80 and the 737 cruises at Mach 0.78, may only be a few knots but it adds up over 2000 or so nm.
Engineers Rule The World!!!!!
XFSUgimpLB41X
Fri Jan 25, 2013 5:03 am
Quoting StarAC17 (Reply 7):
That depends on the cost index they are flightplanned for. The 757 can cruise faster, but for the most part runs around at .78 or .79 just like the other fleets at my airline.
Chicks dig winglets.
mercure1
Fri Jan 25, 2013 5:06 am
The 737 and 757 planned on the same route?
Mir
Fri Jan 25, 2013 5:09 am
I'm sure they put on all the fuel they could. Wasn't enough.
-Mir
ikramerica
Fri Jan 25, 2013 5:15 am
Quoting mah4546 (Reply 3):
I was expecting this on LAX-MCO-LAX last week, but the jetstream has moved north and the southern US has almost no wind aloft. We had no speedy east bound flight nor did we have a slow west bound. On the east bound, the moving map said tail wind of about 30 mph most of the way. Nothing much.
tommy767
Fri Jan 25, 2013 5:18 am
Quoting mercure1 (Reply 9):
Quoting IAHFLYR (Reply 5):
You both need to dig deeper
BOS-SFO UA 297 757:
http://flightaware.com/live/flight/U...7/history/20130124/1306Z/KBOS/KSFO
6 hrs 29 mins.
A half hour is a big difference. Is it really just a few numbers off on cruising speed?
iowaman
Fri Jan 25, 2013 5:30 am
Quoting tommy767 (Reply 12):
BOS-SFO UA 297 757:
6 hrs 29 mins.
Does a 757 gain altitude and speed quicker (anyone)? Maybe explains part of the difference if so.
7 hours on BOS-SFO has to be pushing it on a 737-900 if it's near MTOW I would think? Of course it if wasn't a full or near full flight that greatly helps.
Caryjack
Fri Jan 25, 2013 5:37 am
ATL-SEA:
This one dosn't seem that bad, but it was a B-767 and maybe should have got along quicker. Looks like they left a half hour late and arrived a few minutes early.
I didn't think a B-737 in revenue service could stay in the air that long. I certainly wouldn't want to be there. I sometimes fly between SEA and MIA on AS B-737s and expect to be in the air 5 1/2 hours or so.
Cary
tommy767
Fri Jan 25, 2013 6:11 am
Quoting Caryjack (Reply 14):
Cary
A point of correction: flight aware usually does a poor job of distinguishing a 739 or 738 with United. I believe the BOS-SFO routes are 738s, which happen to be listed at 739.
IMHO, I don't think the 739ER can do 7 hours in the air with full payload. I believe at the max it can do is 6hrs to 6hrs 30mins at the most.
seabosdca
Fri Jan 25, 2013 6:47 am
Quoting tommy767 (Reply 15):
If "full payload" is a low-density configuration like UA's, it shouldn't have any trouble with 7 hours, but that's the limit.
MSPNWA
Fri Jan 25, 2013 7:44 am
Yep. Even a couple hundredths faster makes the difference in the long run. The 757 has that little extra speed over a 737.
toobz
Fri Jan 25, 2013 10:24 am
I'm with you! I don't find DLs ATL-SEA to be that off at all. 4h57mins sounds about right..maybe a few mins more than average. Can't tell you how many times I've sat on a flight over 5hrs flying PDX-ATL.
warreng24
Fri Jan 25, 2013 12:41 pm
Correct. BOS-SFO is primarily B752 and B738. No 739 has been scheduled westbound. Occasionally A319 westbound, rarely A320.
UA has previously scheduled a B739 eastbound SFO-BOS though.
laca773
RE: Insane Headwinds Jan 25th: 7 Hours BOS-SFO
Fri Jan 25, 2013 1:11 pm
VX's BOS-SFO flights were also 7 hours. They downgauge the a/c to a A319 so they don't run into issues with needing to divert.
http://flightaware.com/live/flight/V...7/history/20130124/2355Z/KBOS/KSFO . There are several days this month where this flight was on the verge of 7 hours which I'd still consider being that considering boarding, taxing times.
Here's an even longer VX BOS-SFO flight clocked @ 7.33: http://flightaware.com/live/flight/V...1/history/20130116/1335Z/KBOS/KSFO
caljn
Fri Jan 25, 2013 1:39 pm
Quoting iowaman (Reply 13):
I haven't been on a UA flight that wasn't full in years. Years!!
I also do the EWR-LAX run monthly and always dread it....need to gird myself just before boarding as those coach seats, even E+ are torture for 6 hours. Approaching 7 hours would be extremely unpleasant...the nonstop lavatory traffic in the aisles, the aroma and heat from all that humanity pervading the cabin. Ugh!
SRT75
Fri Jan 25, 2013 1:53 pm
Um, I'm obviously missing something here . . .
LAS seems like a very out-of-the-way fuel stop for BOS-SFO. Why not SLC? DEN? Something more on the way?
DualQual
Fri Jan 25, 2013 2:12 pm
The general wag is 1 minute per hour per mach. So if the 757 is doing .82 and the 737 is doing .78 that is about 4 min per hour which over the course of 5 hours is 20 minutes. Also are these block times? The 757 might have gotten lucky and gotten right out at a dead time in BOS, gotten into SFO at a dead time so no vectors on arrival, didn't have to wait on a gate, etc. A lot of seemingly little things can add up in a hurry.
There's no known cure for stupid
gdg9
Fri Jan 25, 2013 2:41 pm
Impressive!
@dfwtower
tommy767
Fri Jan 25, 2013 3:04 pm
Quoting seabosdca (Reply 16):
I honestly don't think so. How is a UA 737 low density in even the least? A few years ago I saw on flight aware 739s diverting on CLE-LAX because of head wind.
Quoting DualQual (Reply 23):
ah, gotcha that makes sense. I never knew the 737s were that much slower than the 757.
seabosdca
Fri Jan 25, 2013 3:42 pm
Quoting tommy767 (Reply 25):
167 or 173 passengers is low-density for a 737-900ER, which is certified for 215 passengers.
A Lion Air 737-900ER with all seats full couldn't stay in the air for seven hours. United's actually do it from time to time (like yesterday).
Mir
Fri Jan 25, 2013 4:06 pm
Quoting SRT75 (Reply 22):
If the route you're going to fly to avoid winds takes you closer to LAS anyway, that's where it makes most sense to stop.
-Mir
threeifbyair
Fri Jan 25, 2013 4:21 pm
It was bad on Wednesday too.
ASA3 (DCA-SEA) took a southern routing flying over the KY-IN border, 6h05m in the air. My mother was none to happy about that.
http://flightaware.com/live/flight/A...3/history/20130123/2335Z/KDCA/KSEA
airproxx
Fri Jan 25, 2013 4:28 pm
An A320 without ACT can carry 18,7t of fuel (without any payload consideration).
With an average fuel flow of about 2,5t/hour for both engines, it can hardly fly more than 6/6,5 hours with standard fuel reserves (a final reserve is about 1t on this type)...
So they probably put as much fuel as they could, considering a decent payload, and "planned" a diversion in LAS.
If you can meet with triumph and disaster, and treat those two impostors just the same
flyer737sw
Fri Jan 25, 2013 4:55 pm
I was looking at the winds yesterday via NOAA's site and the winds aloft at FL 380 was 150kts. The direction of the jet stream would have affected flights more on a northern course, heading west with the wind right on the nose. Would of been a good day flying easterly routes.
kc135topboom
Fri Jan 25, 2013 5:00 pm
Well, it is the middle of winter here in the Northern Hemisphere. Having headwinds (westbound) in the 125-150 knot range is really not all that unusual.
tommy767
Fri Jan 25, 2013 5:05 pm
Quoting seabosdca (Reply 26):
they were 738s, not 739s. Again, I'm pretty sure a strong headwind on BOS-SFO with a 739 wouldn't make it without diverting
usairways85
Fri Jan 25, 2013 5:18 pm
On the reverse my ORD-PHL flt last night had some nice tail winds and was in the air 15 minutes less than normal. That is a pretty big difference for a shorter stage flight.
redzeppelin
Fri Jan 25, 2013 5:36 pm
You may have heard that SLC was shut down for several hours yesterday due to an ice storm. The B6 flight in question landed at LAS just a little after SLC re-opened. The track of flightaware looks like they flew just south of DEN before turning toward LAS over southern Utah. It really doesn't look like LAS was too far off.
rampbro
Fri Jan 25, 2013 6:02 pm
How do airlines mitigate the added costs associated with strong headwinds such as these? Is there a 1:1 with the savings of flying with a tailwind in the opposite direction? Or is it a 'grin and bear it' type of situation?
9w748capt
Fri Jan 25, 2013 6:15 pm
On the flipside looks like they're making great time eastbound. Look at VX 1358 - 4:32 SFO-BOS yesterday - sure beats 7h going the other way! Most EB flights are pushing (if not exceeding) 500 knots too.
http://flightaware.com/live/flight/V...8/history/20130124/2105Z/KSFO/KBOS
roseflyer
Quoting rampbro (Reply 35):
High headwinds overall are added costs. The late arrivals into the west coast airports cause delays and missed connections. The early arrivals into the east coast airports cause gates to stack up, and some tarmac arrival delays. Overall, the total fuel burn is sometimes less. The headwinds cause a lot more fuel to be burned, but the tail winds make up for it. They fly longer routes to avoid headwinds, but in total when you add up the total round trip flight time, it tends to be less with some winds.
The real costs are when west coast arrivals are more than 15 minutes late. That forces missed connections. Fuel stops cause everyone to miss connections and subsequent delays. You can’t depart early to make up for an early east coast arrival, but you will depart late to make up for a long inbound flight. If flights only flew east west it wouldn’t be as bad, but airplanes are often routed BOS-SFO-LAX, which hurts west coast operations.
It’s just a cost of doing business.
highflier92660
Fri Jan 25, 2013 6:28 pm
During the height of the annual mid-winter transcontinental jetstream battle one has to think of JetBlue and their range-challenged A320s.
http://flightaware.com/live/flight/B...3/history/20130124/21192/KBOS/KSFO
idlewildchild
Sat Jan 26, 2013 3:05 am
Tell you what, 8 hrs 15 mins LHR-EWR on 27DEC in chronic turbulence was no picnic either. I was up front and can't imagine what it was like in the full Y cabin. Nightmare.
DalDC9Bos
Sat Jan 26, 2013 8:51 pm
Hey Tommy,
I worked Ops at JFK for a couple years and these types of winter headwinds and the delays for westbound flights is very normal during the winter. My last flight JFK to SFO during the winter took more than 7.5 hours on the 757.
Jetblue and the airline that I worked for had diverts daily sometimes for our westbound transcons flights. The A319 can make the flight with these headwinds, but the A320 cannot. The usual divert city would be SLC or LAS. The decision on divert city is decided by company flight planning/dispatch before the flight leaves the gate and usually is along the original flight path. Most westbound transcons east coast to SFO or LAX fly near SLC and LAS and not a more northernly path.
Will
haggisman
Sun Jan 27, 2013 5:01 am
Dunno if it's related but we flew on Alaska Airlines SEA -> LIH on Jan 24th and we were serenaded to the tune of a 6hr 20min flight with ugly moderate to heavy chop for most of the way. Normal average time is mid 5hr range.
It smoothed out on the last 90 mins or so, and they even found time to squeeze in the complimentary Mai tai's to soothe the frazzled nerves. Thanks AS!
Scotty
e pluribus Scotsman
usxguy
Sun Jan 27, 2013 10:43 am
I remember USAirways decision to start parking the 757s used on the transcons and replacing them with A321s... FlyerTalk was lit up for MONTHS about all the west-bound diversions... even on USAviation pilots called it a "pig"..
xx
