INFINITI329
Republic, UEX And The Q400
Fri Jan 25, 2013 2:06 pm
I've read in several forums on a.net in the past few days that in nutshell that Republic's Q400 flying for United Express is an on going disaster.. Can anyone get into more detail about whats really going on with Republic and the Q? How is United contributing to problem or solution?
Thomas_Jaeger
RE: Republic, UEX And The Q400
Fri Jan 25, 2013 5:01 pm
Does anyone have a complete list of the tail numbers operated by Republic at this point already?
Swiss aviation news junkie living all over the place
yyztpa
Fri Jan 25, 2013 5:41 pm
Quoting infiniti329 (Thread starter):
Could you provide links to the posts?
flyboy80
Fri Jan 25, 2013 6:18 pm
Do these Q400s have first class?
INFINITI329
Fri Jan 25, 2013 6:40 pm
Quoting yyztpa (Reply 2):
Republic Airways Order 47 Embraer E175 (by queb Jan 24 2013 in Civil Aviation)
This is where the majority of the posts are , in relation to republic picking up E-jet flying for Eagle
floridaflyboy
Fri Jan 25, 2013 6:41 pm
Quoting flyboy80 (Reply 3):
Right now, some do, some don't. But eventually, they will all have it.
Good goes around!
slider
Fri Jan 25, 2013 6:42 pm
Certainly the Q400 is and has been a maintenance pig, but the issues for YX flying as UAX with them are largely driven by crew issues.
The wind-up was too rapid, crew availability is a big problem and there were some related issues.
Italianflyer
Fri Jan 25, 2013 6:52 pm
From what I gather (FWIW) it is an intersection of the Q's integral mx complexities and RAH's absence of 'hands on' Q mx complexities. Other operators reported a pretty steep learning curve with this plane...to the point where SAS rejected the type. One would assume that is whats going on here.
geg2rap
Fri Jan 25, 2013 6:58 pm
Quoting ItalianFlyer (Reply 7):
Also, based on experience at my station, if you get a former Lynx plane, on time has been ok. If you get a former Colgan plane, you might as well have the mechanics waiting.
Italianflyer
Fri Jan 25, 2013 7:13 pm
Quoting GEG2RAP (Reply 8):
Ive heard that too LOL....heres the list according to airfleets.net
http://www.airfleets.net/flottecie/Republic%20Airways-active-dh8.htm
MSN Type Delivery date Registration Remark
4168 DHC-8 402 23/03/2011 N502LX
4182 DHC-8 402 22/04/2011 N508LX
4186 DHC-8 402 13/09/2012 N510LX
4188 DHC-8 402 07/09/2012 N188WQ
4196 DHC-8 402 07/09/2012 N196WQ
4202 DHC-8 402 29/10/2012 N202WQ
4208 DHC-8 402 12/10/2012 N208WQ
4209 DHC-8 402 12/10/2012 N209WQ
4214 DHC-8 402 17/10/2012 N214WQ
4323 DHC-8 402 01/10/2012 N323NG
4328 DHC-8 402 01/10/2012 N328NG
4339 DHC-8 402 01/01/2013 N339NG
4340 DHC-8 402 07/09/2012 N34NG
4342 DHC-8 402 12/10/2012 N342NG
4346 DHC-8 402 15/10/2012 N346NG
4356 DHC-8 402 07/09/2012 N356NG
4380 DHC-8 402 12/10/2012 N380NG
flyboy80
Fri Jan 25, 2013 9:58 pm
Anyone been inside these airplanes, or regularly work on them? I'm curious about their configuration. Is there only one forward LAV still, and do they have a forward galley for first class provisioning?
jetmatt777
Crew
Fri Jan 25, 2013 10:14 pm
Quoting flyboy80 (Reply 10):
1 Lav up front, galley in the back...
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
slider
Fri Jan 25, 2013 10:46 pm
RAH and F9 had experience with the type via Lynx. It's not like they jumped into this blind.
And you better believe RAH put the screws to Bombardier because they knew what the scoop was with these aircraft.
Italianflyer
Fri Jan 25, 2013 11:13 pm
Quoting slider (Reply 12):
I had a chance to do some more research and you are correct. Looks like RAH is is doing the line mx while Bombardier is doing all heavy MRO work on the fleet through June 2021. So much for my learning curve theory.
http://www.avionics-intelligence.com...-turboprop-regional-airliners.html
GZIP: Off
