jlbmedia
Will Boeing Have To Stop The 787 Line For Now?
Mon Jan 28, 2013 3:42 am
http://www.forbes.com/sites/petercoh...y-fix-could-ground-787-until-2014/
An M.I.T. professor has several possible fixes for the 787 battery problem, which are explained in the above article. These fixes could delay the 787s from flying until 2014.
Could this cause Boeing to close the 787 line down temporarily? They can't even fly the new planes until the no fly has been lifted. How much room do they have to store 787's at both of their facilities? Can they keep paying salaries etc. to produce planes without the fix, that can't fly and store them?
JLB54061
tdscanuck
RE: Will Boeing Have To Stop The 787 Line For Now?
Mon Jan 28, 2013 3:51 am
Quoting jlbmedia (Thread starter):
I'm going to go out on a limb and bet that Boeing's not going to pursue any technology that doesn't get them flying for a year unless they have no other option.
I'm also baffled how an MIT materials professor could claim that the elctrolyte in a lead-acid battery is "relatively harmless" or that he thinks an main aviation battery can be had for $1000. I'm hoping this was editorial license on the part of the reporter.
A one year delay? Yes.
That's currently true but likely to change; the regulations around production tests are quite a bit different than scheduled commercial flight.
Quite a bit; more at Charleston at the moment.
Yes. As noted on other threads, Boeing could cancel the entire program tomorrow and not go bankrupt (although it would be one heck of a stock hit).
Tom.
lightsaber
Crew
Mon Jan 28, 2013 4:11 am
Even with a one year delay, Boeing has too many commitments to vendors to just shut down the line.
Let's do a thought game. What if the line is shut down for a year? That means vendors and sub-vendors suddenly are not delivering per contract without a hard restart date. Some will thus lay off staff. Thus, once production starts back up, the vendors won't be ready and Boeing's ramp rate will be at the mercy of hundreds of 'little guys.' Their engineers, technicians, and other skilled employees will have moved on.
I suspect in a long delay Boeing would slow the line, but not stop it. Restarting a line is very difficult and expensive. That is one reason, despite the issues, Boeing kept building 788s despite a backlog of them on the flight line.
Quoting tdscanuck (Reply 1):
Agreed. But this problem isn't that insurmountable. Worst case is that the 787 is pulled down to ETOPS 135 with a temporary fix (substitute battery).
I went out on a limb and early on predicted a multi-month grounding of the 787. We remain on track for that, a multi month (not a year or even a half year) grounding. There are options to certify new batteries for short replacement intervals. Costly?    But cheaper than grounding the fleet for so long.
I feel for the engineer's families who are assigned to solve this issue...
Any news on the fuel leaks? IMHO a forgotten about issue, but part of the reason the 787 was grounded. I suspect a drawing revision to keep the mistakes from happening again.
Lightsaber
bristolflyer
Mon Jan 28, 2013 4:33 am
We've all seen the lines of 787s parked up, however I'm sure this wouldn't be a reason to stop building them. I would imagine that they could design a quick, short term fix that would allow them to fly planes to another storage facility.
Fortune favours the brave
tdscanuck
Mon Jan 28, 2013 5:51 am
Quoting lightsaber (Reply 2):
All quiet on that front as far as I can tell...I heard conflicting claims (all unsubstantiated) that it was a maintenance error or a software error and nothing more. However, unless the FAA is being very coy, I don't think the fuel leaks figured into the grounding.
Tom.
frmrCapCadet
Mon Jan 28, 2013 6:36 am
So if it really got down to it could Boeing and the airlines have batteries that did not need charging, and switch them out as needed? Kludgey, no?
gihanjaya380
Mon Jan 28, 2013 6:46 am
According to the news I have heard so far is that Boeing is still manufacturing the aircrafts until the problem is fixed, but there are no new deliveries being made until the battery problem is fixed. Since they have so many orders for the 787, any delay will take a bite out of the revenue. They have to keep building these aircrafts and when the problem is fixed, they will have to implement these changes to the existing aircrafts as well as the current line up.
Boeing will not wait for one year, as Tom mentioned, to fix these issues.
Gihan
KarelXWB
Crew
Mon Jan 28, 2013 8:43 am
Boeing should be able to store around 50-60 Dreamliners at Paine Field.
Funny, runway 29/11 is finally getting empty again but in this way it's doomed to stay full.
http://paineairport.com/images/kpae8983.jpg
[Edited 2013-01-28 00:43:43]
This server is powered by a lemon and two electrodes.
ADent
Mon Jan 28, 2013 8:56 am
They won't be grounded for a year.
Boeing needs the planes rolling off the production line to make up time for the 3+ year delay to the program, and this is not a program killing problem.
They need to wait a couple of weeks to see where this is heading - then jump on a solution.
There are teams at Boeing looking at using an existing battery retrofitted - even if it kills ETOPS. There are also teams looking at a better containment system (say 1" thick steel, titanium, high temperature nickel based alloy, etc). Non-rechargeable solutions. Jet-A powered Honda generators. What EVER it takes to get the fleet airborne in under 90 days.
The plans for the most likely solutions are being worked now in parallel, so when Boeing makes its decision and announcement they will hit the ground running with the chosen fix.
Any idea on how long it takes to certify a new build of flight software? My guess is that will take longer than rigging up some replacement batteries and re-wiring.
Francoflier
Mon Jan 28, 2013 9:25 am
The article in the OP is strange. I'm not sure I can rely much on it.
Basically, it sounds too simplistic. It makes it sound as if Boeing chose the least safe technological solution and simply forgot to think about battery heating and how to cool it down.
It might be down to dumbing down the technical level for the masses or simply poor journalism.
Still, the solutions offered by this professor are to either switch ti NiMH or find a way to cool down the whole battery, which apparently heats up and enters thermal runaway due to the lack of proper cooling for the cells stuck in the middle of it.
I don't know what to make of that. It can't be that simplistic, can it?
rwessel
Mon Jan 28, 2013 9:28 am
Quoting frmrCapCadet (Reply 5):
Not really, unless you increased their capacity considerably. There are loads on those batteries when the airplane is powered down (for example, the parking brakes), and the battery capacity is sized to meet the requirements of a worst case power failure for a required amount of time. So the system assumes the batteries are mostly charged.
While (incorrect) charging is the most common time for Li-Ions to fail, it's not the only time. They can fail while discharging, and also just sitting there (although in the absence of mechanical damage, that's pretty rare). So I'd think they'd have to prove that whatever is wrong with the batteries won't cause excessive failures in non-charging conditions.
jayunited
Mon Jan 28, 2013 11:06 pm
I don't think Boeing would need to stop the entire 787 line because even if they fill up Paine Field they still have their new plant in South Carolina. So the only way I see Boeing shutting down the 787 line is if a major rework or major design changes have to take place. So although this guy at MIT thinks he has all the answers figured out I think Boeing will wait till the experts finish their investigation and present their findings and recommendations before they shut down the entire 787 production line.
If this is simply a battery and electrical problem then it might be in Boeing best interest to continue building the fuselage of the planes, the wings, stabilizers and install the hydraulics and the landing gear and the wiring bundle and just role the planes out and store them then once the problem is fixed they can install the batteries connect all the electrics and go forward with all the test wit deliveries taking a minimal delay. However if they shut down the line completely that will push all deliveries even further back another delay Boeing can't take right now. So as long as no major rework needs to happen I think Boeing will continue to build 787's just without the batteries.
phxa340
Mon Jan 28, 2013 11:38 pm
Simply put - they can't. It would absolutely destroy the supply chain that Boeing has propped up for the last 3 years. If Boeing stops sending payments to their suppliers because of stalled production, the suppliers that Boeing rely on now go out of business. Boeing is in a big time pickle here but that's where having a ton of cash on hand comes in big time handy. Boeing will be fine in the long run but the fiscal 2013 year for them is going to be ugly.
mrocktor
Tue Jan 29, 2013 3:08 pm
Production does not stop due to in service issues. They can build planes and (in most cases) fly them around between their facilities (may require putting an experimental number on the plane). They cannot put a Certificate of Airworthiness on a plane and therefore cannot deliver new planes until the issue is resolved in some way (may be a modification, a temporary mitigation measure, change to procedures, etc.). If they have undelivered airplanes which already have CofA, those are grounded with the rest of the fleet.
I'm not. Academics being out of touch with the real world is the norm, not the exception.
strfyr51
Tue Jan 29, 2013 4:42 pm
the Lithium Ion battery problem is not so insurmountable that it can't be fixed in a timely manner, EVEN if Boeing would have to resort to Proven battery technology. this might Seem like a big deal but it's really NOT.
7BOEING7
Tue Jan 29, 2013 5:24 pm
Quoting mrocktor (Reply 13):
All the airplanes Boeing has built and is building have an AD against them. Even in a production/experimental mode they will have to get together with the FAA and come up with an "alternate means of compliance" (AMOC) or a fix before the feds will let them back in the air.
mrocktor
Tue Jan 29, 2013 6:13 pm
Quoting 7BOEING7 (Reply 15):
The AD applies to "all The Boeing Company Model 787-8 airplanes, certificated in any category", see item (c) of the AD. This means it applies to all delivered aircraft (obviously) and all undelivered aircraft with a Certificate of Airworthiness. It may or may not apply to 787-8 prototypes and production aircraft not yet certified and flying as experimental aircraft. Legally those aircraft are not certificated under the "Model 787-8" type.
Obviously the manufacturer coordinates with the authority when deciding whether to continue flying their experimental fleet (in the cases where it is legal to do so). The manufacturer obviously does not want to take unreasonable risks with their own personnel and property either.
Type-Rated
Tue Jan 29, 2013 11:22 pm
Saw a note on the news yesterday that Boeing is in full production of the 787 while the investigations are going on and even later in the year Boeing plans to "step it up" with production due to so many orders.
Fly North Central Airlines..The route of the Northliners!
catiii
Wed Jan 30, 2013 7:29 pm
Quoting type-rated (Reply 17):
That was reiterated on the earnings call as well.
135mech
Wed Jan 30, 2013 8:12 pm
Quoting KarelXWB (Reply 7):
http://paineairport.com/images/kpae8...3.jpg
Great photo, thanks for sharing! Anyone know what the "lone" 727 on the right is, is it part of their use or parked as "heritage"?
135Mech
135Mech
7BOEING7
Wed Jan 30, 2013 8:52 pm
Quoting 135mech (Reply 19):
That's the Museum of Flight area. It's the first 727 that is in the process of being returned to flight -- hopefully in the next few years.
tdscanuck
Wed Jan 30, 2013 8:57 pm
That's the Museum Of Flight's restoration center.
Tom.
PW100
Wed Jan 30, 2013 10:15 pm
Quoting catiii (Reply 18):
Still, something does not seem to add up.
Apparently, Boeing is at around 5 per month right now**, should hit 7 per month by mid-year, and 10 per month by year's end**. That equates to a pretty good average of say 7 per month over the whole year, or 80+ for the full year. And that is not counting any additional frames currently in, or waiting for change incorporation.
At the 2012Q4 earnings session, Boeing's latest forecast now shows plans to deliver at least 60 787s in 2013.
That is an average rate of just five per month for the full year (again not counting any additional frames currently in, or waiting for change incorporation) . They are already practically at five per month right now, so where is the ramp-up . . . . ??
Off course they may deliver more than the forecast, but 60 is very low, when compared to 2012 totals, considering the anticipated aggresive ramp up.
http://www.flightglobal.com/news/art...fall-despite-19-sales-jump-381656/
**as suggested per http://www.nyc787.blogspot.nl/2013/0...king-back-and-looking-forward.html
phxa340
Wed Jan 30, 2013 11:52 pm
Quoting PW100 (Reply 22):
It adds up to 60 when you are taking into consideration there are going to be zero deliveries in Jan (not sure if any delivered in jan before the grounding) and probably Feb and maybe March.
Wisdom
Thu Jan 31, 2013 12:19 am
Quoting phxa340 (Reply 23):
That doesn't make sense. If the deliveries restart in April after a fix is implemented, the aircraft not delivered in January through March would be delivered in April together with the planned April deliveries.
The fix should be quite easy to install, a set of new batteries, a set of new control systems, some wiring. 1 to 3 days per airframe should be achievable and ideally this would use additional resources so that all the January to March aircraft can be retrofitted at a rate of 10-30 a week using resources other than the regular production resources.
7BOEING7
Thu Jan 31, 2013 12:44 am
Quoting Wisdom (Reply 24):
Boeing is always very conservative in their outlook. I think McN is just hedging his bets and we'll see a better number (quality not necessarily quantity) in 3 months when there might be a better handle on the battery issue.
ikramerica
Thu Jan 31, 2013 1:39 am
There are only so many aircraft that can be test flown and certified at a time, even if there are more waiting.
mrocktor
Thu Jan 31, 2013 10:52 pm
Quoting ikramerica (Reply 26):
Production != delivery.
There is a lot that goes on between production and delivery: outfitting, testing, acceptance procedures, etc. Ramping up the furnishing and delivery process is its own task.
txjim
Thu Jan 31, 2013 11:36 pm
This may be self-serving given my profession, but there is a reason that engineers are used to design products. Professors tend to have poor track records with schedules and practical applications.
servantleader
Thu Jan 31, 2013 11:59 pm
We've all heard of cars that have had mysterious "electrical" problems that even experienced mechanics couldn't quite trace to a definitive root cause -- Boeing went electric on the 787 and it is now faced with the prospect that a definitive root cause may not be found -- if that becomes the case the FAA will have no other choice but to order a complete redesign of the current lithium ion battery system -- and if that happens the Boeing Dreamliner will rank right up there with the greatest corporate bungles of all time.
rotating14
Fri Feb 01, 2013 12:15 am
Quoting ServantLeader (Reply 29):
With all do respect explain how a battery defect on the 787 ' ranks up there with the greatest corporate bungles of all time'?
7BOEING7
Fri Feb 01, 2013 12:29 am
Quoting mrocktor (Reply 27):
True, however if the airplanes are continuing to be built and they are completed up to the B-1 flight, including all "travelers", the only tasks left are the "battery fix" modifications and appropriate ground tests followed by the B and C flights. Except for the initial "battery fix" certification flights (on one airplane in the flight test inventory) most if not all of the remaining airplanes would only require the B & C flights. If the airplanes fly relatively clean it wouldn't be more than 6-10 days from the B-1 flight thru the final C flight and I can easily see 10 or more airplanes a month getting delivered. If and I mean IF there is a fix by midway thru this year they should be able to get 60 frames out.
servantleader
Fri Feb 01, 2013 12:56 am
If you believe that a defective battery is the extent of Boeing's 787 problems then we have nothing further to discuss.
tdscanuck
Fri Feb 01, 2013 3:00 am
The 787 has already undergone a total redesign of the electrical system, the wing-to-body joint, the IFE system, the supply chain, and a boatload of sub-components. Whether you think the 787 is one of the greatest corporate bungles of all time, that status will NOT depend on a battery redesign.
Tom.
7BOEING7
Fri Feb 01, 2013 5:11 am
Quoting tdscanuck (Reply 33):
A total redesign of the electrical system?--if you're talking about the ZA002 issue it was probably 10% or less.
lightsaber
Crew
Sat Feb 02, 2013 4:11 am
Quoting tdscanuck (Reply 4):
I should have written better, I meant the Japanese grounding which was due to 7 incidents in 8 days of which 2 were the fuel system. If it was just an error... correct the process and move on.
Only starting. I count but two less than the peak on that runway.
FWIW, many more images for runway 11-29.
Quoting phxa340 (Reply 12):
Exactly. Boeing has committed to a ramp up. Even slowing the ramp would hurt the vendors. The next ramp would be far slower.
Lightsaber
