ordpark
BOS Terminal Realignment
Sun Feb 03, 2013 4:28 am
Don't post that often, folks, but curious as to how the new terminal for UA and the subsequent move of B6 are coming along?
AlnessW
RE: BOS Terminal Realignment
Sun Feb 03, 2013 8:30 pm
I'd check the Massport website for details:
http://www.massport.com/logan-airport/Pages/Default.aspx
I don't see any recent news there, but I am pretty sure that the combined UA/CO operation will move to the former American Eagle gates in B2. I am not sure of this though.
B6 however is definitely not going anywhere. (Why do you think Massport did that $62 million dollar renovation and built a new security checkpoint?) B6 will eventually have all of Terminal C to themselves.
Another long-term plan I've heard of is to connect ALL terminals post-security.
jcarv
Sun Feb 03, 2013 8:50 pm
I believe scheduled opening of the new United concourse is Fall 2013. Construction is ongoing.
flyby519
Sun Feb 03, 2013 10:00 pm
It looks like quite a ways until completion. They have removed all the gates from the ex-Eagle area, but no new construction has begun for the actual connector portion.
These postings or comments are not a company-sponsored source of communication.
EWRkid1990
Sun Feb 03, 2013 10:39 pm
If they're taking the old eagle gates, that means there isn't enough room for more than 5-6 mainline aircraft, seeing as almost all UA stations from BOS are on mainline except for CLE. Maybe they can re-arrange the gate spacings to fit more large aircraft ie. 737-757?
-EWRkid1990
tommy767
Sun Feb 03, 2013 10:42 pm
Quoting EWRkid1990 (Reply 4):
they are supposed to have 8 gates so it will be on the tighter side but it should work.
"KEEP CLIMBING" -- DELTA
AlnessW
Sun Feb 03, 2013 10:54 pm
Quoting jcarv (Reply 2):
...In B2?
Quoting flyby519 (Reply 3):
Which gates were these, do you remember? I know that AA mainline is B27-B29 and B30-B36.
mbk1999
Mon Feb 04, 2013 1:50 am
Perhaps they slowed down the construction timetable to see how the possible AA/US merger unfolds. Also as AA's presence in BOS continues to shrink, gates B27-B29 could become flex gates.
flyby519
Mon Feb 04, 2013 2:21 am
Quoting AlnessW (Reply 6):
Testing my memory, but was it B22-26 for the ex-Eagle gates?
BOStonsox
Mon Feb 04, 2013 2:24 am
I don't know when the Terminal B connector is going to be finished, but B6 will have all of Terminal C to themselves by Spring 2014: http://blog.jetblue.com/index.php/20...rminal-news-for-jetblue-in-boston/
2013 World Series Champions!
AlnessW
Mon Feb 04, 2013 3:48 am
Quoting flyby519 (Reply 8):
That sounds right. Wasn't NK there for a while as well? Or is NK over in B1 now?
Quoting BOStonsox (Reply 9):
icelandair75w
Mon Feb 04, 2013 3:49 am
They broke ground on the Terminal B project a few months ago and are working on it mostly everyday (pounding the beams into the ground, preparing both the US and AA terminal edges for the connector). Essentially they will be able to use the gates they build and then some of the US gates when not in use.
tharanga
Mon Feb 04, 2013 11:28 am
what do the signs on the approach roads, and the signs/recorded messages on the silver line/shuttle, say to explain to UA pax where they should go?
jcarv
Mon Feb 04, 2013 12:26 pm
United operates in 2 terminals currently: A & C. Operations are separated by destination city. Essentially old CO & old UA. United runs flights to EWR, CLE, & IAH from A and runs flights to IAD, ORD, DEN, SFO, & LAX from C. With the current cross fleeting however, one could arrive at either terminal from any city.
dwcontroller
Mon Feb 04, 2013 12:28 pm
Quoting tharanga (Reply 12):
Something along the lines of "Terminal A for United Airlines flights serving Cleveland, Houston-Intercontinental and Newark" "Terminal C for United Airlines flights serving Chicago-O'Hare, Denver, Los Angeles, San Francisco and Washington-Dulles"
Best phrase to hear at the airport - "All standbys have been cleared and may board at this time"
BOS2LAF
Mon Feb 04, 2013 3:17 pm
It was initially going to be Nov-Dec 2013, but the last I heard from a reliable source was "early 2014" with their old gates starting to come online for B6 around March.
This is a Massport construction project after all. Expect it to be behind schedule and over budget.
jcarv
Mon Feb 04, 2013 3:31 pm
Funny, their last few projects were finished ahead of schedule and under budget.
tommy767
Mon Feb 04, 2013 3:39 pm
Quoting bos2laf (Reply 15):
I'm guessing they are going to cram into A temporarily? Also any update on the United Club in B?
airbazar
Mon Feb 04, 2013 3:47 pm
Why? If it happens it will be fairly unusual if we consider recent Massport projects at Logan. DL's new Terminal A opened ahead of schedule and under budget. The recent terminal B garage project also completed ahead of schedule. The centerfield taxiway was also completed in 2009 ahead of schedule and under budget. I can't find any details about the recent terminal C remodeling project but I suspect it was at least on time and on budget or somehting would have showed up in a google search. I believe the Terminal E expansion was behind schedule and over budget but that was a long time ago and I suspect that they learned a thing or two from that project, which is probably why subsequent projects have been far better managed.
flyby519
Mon Feb 04, 2013 4:52 pm
Quoting AlnessW (Reply 10):
Yes, NK would use gate B25 or 26 when Eagle used to handle their ground services. They have since moved over to the US side of Terminal B
apodino
Mon Feb 04, 2013 5:06 pm
Years ago the footprint of the current project was actually slated to become an FIS for AA and US. This is when both carriers had significant Intl Ops, with US to the Caribbean and AA to both Europe and the Caribbean. If 9-11 hadn't happened, this project would have been built. Fast forward to today, and it seems kind of silly doesn't it?
I wonder exactly how many gates AA actually needs in BOS anymore? Eagle is gone, only flights left are to the cornerstones (MIA, DFW, ORD, LAX, and JFK) with LHR even being dropped in favor of BA operating the flight. You would think only B29-B36 would be needed to handle AA ops in that sense. So B25-28 could go to UA, maybe even for RJ's, with the new gates going to them, and possibly a couple of the existing US B gates, mainly B22-24.
flyby519
Mon Feb 04, 2013 7:20 pm
This may be helpful as well, it is the massport Terminal B Construction plans.
http://www.google.com/url?sa=t&rct=j...6OSkv5nscRIA&bvm=bv.41642243,d.dmg
AlnessW
Tue Feb 05, 2013 5:40 am
Quoting jcarv (Reply 13):
jcarv has it correct. Former-CO flights depart out of A, actual UA flights depart out of C.
Quoting dwcontroller (Reply 14):
   This info can also be found on UA's website.
Quoting tommy767 (Reply 17):
What United Club in B?
Quoting flyby519 (Reply 19):
Thanks flyby519. I remember first learning this last March when my motorcoach driver announced airlines by terminal as we approached BOS. I assume that the move was because of the construction? Who handles NK in B1 now? US?
Quoting apodino (Reply 20):
Wow, AA really has cut back in BOS!
Did AA drop LHR?
Don't forget that VS (and DL?) also do LHR.
Quoting flyby519 (Reply 21):
Thanks for sharing that link.
tharanga
Tue Feb 05, 2013 11:33 am
OK, good - the signs list the cities - so they don't count on pax knowing what was CO and what was UA.
I wonder how many pax end up in the wrong place anyway.
apodino
Tue Feb 05, 2013 4:07 pm
Quoting AlnessW (Reply 22):
Probably the one that is being constructed as part of this project.
Did AA drop LHR?
I haven't forgotten. I specifically mentioned BA because of One World and the JV. Other carriers on the route are irrelevant. But AA is ending LHR this summer and thus the JV is using BA for all the BOS service. I believe BA is adding a frequency this summer as well.
Quoting tharanga (Reply 23):
I am sure some do so its not really a big deal. If the Pax end up in the wrong place by mistake, Massport runs a shuttle bus serving all terminals that a Passenger could use.
It is US now. I would expect NK to move to A to be handled by DL after the Terminal B project is finished.
zrs70
Tue Feb 05, 2013 4:28 pm
In the early to mid 80's, Northwest (Orient) flew out of the former Eagle gates in B. (This was prior to NW moving to E).
At the time, NW often had two 747's at the gates, one for LGW and one for SNN. They Leo had daily DC-10's to MSP, DTW, IAD, and a couple others.
So with a bit of reshuffling, those gates can certainly handle large mainline aircraft. Seeing that Massport is building out the footprint, it won't be difficult to create space for 7-10 mainline gates.
18 year airliners.net vet! 2000-2017
ScottB
Tue Feb 05, 2013 5:27 pm
Quoting zrs70 (Reply 25):
In the late 1980's, before they consolidated into the old Terminal A with EA, CO used those gates along with PA. So to some degree this is a return to that corner for the airport for that piece of UA.
RobertS975
Tue Feb 05, 2013 10:33 pm
OK, assuming UA vacates their gates at Terminal A, who gets to use those? Does DL have any interest in reclaiming them, maybe restarting some the point to point service to Florida, LAS, LAX that it once had?
NWBOS
Wed Feb 06, 2013 4:28 pm
Quoting RobertS975 (Reply 27):
Unless it is being kept secret, there hasn't been any information like that communicated to us on the frontline. We have been told that Massport will probably put someone else into that space. I hope I'm wrong and we do see more expansion.
apodino
Wed Feb 06, 2013 5:18 pm
I am not sure who can really go into those spots. WN is pretty secure with where they are at....only thing I could possibly see is with the other part of the project linked on the sterile side that WN ends up with the existing UA ticket counters. Unless B6 is going to get those gates as well, and then with E being linked you eliminate the need for a tow job. So WN is one possibility, but I don't see it immediately.
All the other legacies are locked up in B, so that won't happen either. Air Canada will stay put with a star alliance thing. VX is likely staying put. The only thing I could possibly see would be for NK to move and be handled by Delta, which would make sense.
One Wildcard could be for a company like WestJet to start BOS service. They would need gate space and since most of their flights would be precleared, they could use Terminal A in theory.
icelandair75w
Wed Feb 06, 2013 7:21 pm
Rumours in the grapevine say that WN will move to the pm-UA gates at Terminal A, giving jetBlue the opportunity to take the E1A-E1E gates as well. This makes sense, with the plans of a connector between Terminal C/E1A-E1E gates post-security. According to the construction plan linked above somewhere they said that this will not be linked post-security (as of now) however this could be a future plan.
flyby519
Wed Feb 06, 2013 7:37 pm
Quoting icelandair75w (Reply 30):
Ive heard this as well.
Has anyone heard of plans to build a connector between Terminal B and C? Through the area between AA/VX and B6 where they have that long hallway with the rocking chairs and the view of the ramp.
airbazar
Wed Feb 06, 2013 8:29 pm
I don't understand why BOS doesn't build a post-security people mover linking all terminals (like DFW), and be done with all this construction once and for all. They would do themselves, the passengers and the airlines a huge favor.
flyby519
Wed Feb 06, 2013 8:40 pm
Quoting airbazar (Reply 32):
Thats what I thought the ultimate plan was going to be from rumors ive heard, but havent seen any plans published to confirm it.
deltairlines
Wed Feb 06, 2013 8:54 pm
Why? Boston is an O&D city, not a connecting hub like DFW is.
Yes, there are some connecting interline passengers that would have to go through security twice, but is the number sufficient to build what would likely be a billion-dollar project? I doubt it. The common interline transfers are between Delta and Air France/Alitalia, which is a 5-7 minute walk, JetBlue to American which again is a 5-7 minute walk, United to US Airways (which will be behind the same security checkpoint) and JetBlue to some of their international partners (which will be behind the same security checkpoint eventually). I doubt there's going to be a ton of AA-BA interline activity, given that LAX, JFK, ORD, DFW and MIA (the only cities AA has left out of BOS) all have multiple frequencies between BA/AA to Heathrow as it is.
Dalmd88
Wed Feb 06, 2013 9:24 pm
I think they screwed up when they did the landside road improvements. They should have done a consolidated rental car center and connected all the terminals and the T station with a people mover system to eliminate a ton of bus traffic.
NWBOS
Wed Feb 06, 2013 9:45 pm
Quoting flyby519 (Reply 33):
For many years, I've heard the popular rumor in BOS that Massport did want to build one, but the airlines didn't want to pay for it.
airbazar
Wed Feb 06, 2013 11:57 pm
Quoting deltairlines (Reply 34):
Yes if it made BOS a more attractive international gateway and brought more airlines and more passengers in. Yes, BOS is predominantly O&D for the domestic carriers but it's already a significant international gateway with a lot of intl-domestic connections. I've heard that on some days as much as 30% of LH traffic is connecting traffic for example. A lot most likely from US and UA flights. If every international carrier has similar numbers, that's nothing to sneeze at. Now we're hearing that the reason for the C-E post-security connector is because of the B6-JL transfers. Another example of intl/domestic connections. You can't tell me that AA is not feeding passengers to JL too, or to BA, or to IB, and that DL is not feeding passengers to AF. Also, this patchwork of terminal projects are very costly in the long run as Massport can't predict the future of the domestic airline landscape. What if JL stops flying to BOS? All of sudden there's no need for that connector anymore. But if there was a people mover connecting ALL terminals then it wouldn't matter because it would serve all airlines and all connecting passengers.
Quoting NWBOS (Reply 36):
There was a landside monorail that was planned as part of the old "Logan 2000" renovation project. But as things got delayed and over budget it was scraped. It was supposed to link all terminals with the T station. I never heard about a post-security connector tho.
STT757
Thu Feb 07, 2013 12:18 am
Local media in Dallas is reporting the AA/US merger will be voted on by the board next week, there's a thread covering that news, that will start another round of gate juggling Nationwide. My guess would be AA would move their BOS operations to the US side of B.
BOS2LAF
Thu Feb 07, 2013 12:59 am
No, they would remain a split operation until the new gates are complete in B. I was originally hearing that UA would vacate C around December, but now that looks to be pushed back a month or two.
ordbosewr
Thu Feb 07, 2013 1:07 am
I am not a big fan of the people movers. There are good implementations and bad ones. If it is done like EWR then it would be a huge failure. I mean EWR or ORD (two airports that have people movers that I have lived in) are awful. Now I know people will say those are pre-security and it is different, I will say yes but not really that much different.
Heck, here are EWR they are now saying how they will replace the airtrain because it can't support the volume of traffic it has too.
adamh8297
Thu Feb 07, 2013 1:31 am
Quoting airbazar (Reply 37):
Not the only reason!
For B6 international interline transfers you also have
LH EI FI VS +
Hopefully soon EK TK +
Maybe someday QR CA KE JJ/LA
LH and JL do put their code on B6 flights from BOS and EK will too if they come.
The potential is pretty big for B6 to feed a lot of international traffic out of BOS as they now do in JFK.
Airlines flown: A3, AA, AC, AF, AM, BA, B6, CO, DL, EA, EL, IB, LH, MI, MQ, NH, NW, NZ, OU, PE, QF, S4, SQ, TP, UA, US, VS, WN
tommy767
Thu Feb 07, 2013 2:09 am
Quoting bos2laf (Reply 39):
I should have been more clear, my bad. I meant is there any plans for a new UA club in B when the construction is done?
cloudboy
Thu Feb 07, 2013 2:39 am
There are always all sorts of rumors about gate changes in Boston. I think much of this is based in various scenarios the planners have about "what-if's". Right now I think there are too many changes likely to come about in the next several months for them to really commit to anything. That I think is one of the reasons they are dragging their feet - it seems every time they make a change, something new and unexpected comes along that makes that change the wrong one.
"Six becoming three doesn't create more Americans that want to fly." -Adam Pilarski
AlnessW
Thu Feb 07, 2013 5:11 am
Quoting apodino (Reply 24):
I wasn't aware of this but I suspect you're right.
Ah, I see.
I think a good number of pax probably do, and I blame it all on the merger.   But like apodino said, taking Massport's shuttle bus from terminal to terminal is not that difficult.
Interesting to know.
I never knew NW was ever in E (except for international arrivals). I always thought they were in A.
Quoting NWBOS (Reply 28):
How many gates did CO have in A? (and which ones?)
Quoting apodino (Reply 29):
Definite possibility indeed.
Remember that these airlines (AC and VX) also have their own group of gates in Terminal B. (With separate security checkpoints and are not connected to the rest of the terminal.) AC has gates B1, B2, and B3 in Terminal B1, and VX has gates B37 and B38 in Terminal B2.
How do you mean? So US can have more space?
Yes, in fact I don't think there are any AC flights into BOS that aren't precleared?
Quoting flyby519 (Reply 31):
Yes, didn't B6 take over FL's old gates as well? (C40-C42)
I believe that Massport's long-term plan is to connect ALL terminals post-security.
Then why bother with connecting the terminals via walkways?
Why would they need that if they already have shuttle buses?
Quoting STT757 (Reply 38):
Is there room for AA over there?
Quoting ORDBOSEWR (Reply 40):
How do you mean?
BOStonsox
Thu Feb 07, 2013 5:28 am
I've read here on a.net that BOS is the second largest connection point for interline traffic. It does see a lot of it, especially on B6.
That's a safe guess, the connector between both sides of Terminal B should be built by the time the merger is complete (if it does happen) and US's prop jet service would stay at their gates.
You've lived in people movers?
deltairlines
Thu Feb 07, 2013 5:41 am
Quoting BOStonsox (Reply 45):
And with the C-E connector being built, that would address most of that interline traffic. Given that AA and UA fly only to their hubs, and every spoke Delta has out of Boston has convenient options via JFK/ATL, that leaves JetBlue (who would be primarily interlining to the internationals and would have their hassle-free connections once C-E is built) and PenAir, who does not have the traffic to even consider running an airside shuttle to C/E, let alone a SkyTrain that would cost an exorbitant amount more.
apodino
Thu Feb 07, 2013 7:29 am
Quoting dalmd88 (Reply 35):
IMO that should still be built. Since the new Blue Line station was constructed the Massport Shuttle Bus has to take a longer route to get to the new station than before, which makes the Blue Line less attractive. Linking it to the consolidated rental car should be another priority. This would get a lot of the courtesy bus traffic off the roads, which has lead to a lot of curbside congestion (Particularly in Terminal B, which this project is still not addressing.) If you link it to the boat dock, it will really help a lot.
ORD isn't so bad. It is necessary because connecting PAX have to get from T5 to the other terminals. The only flaw with ORD is that it should be linked to a consolidated car rental facility, which I believe ORD still does not have.
EWR is one that was built with not enough capacity. Had it been done like JFK it would be awesome. But between the car rental traffic, and the train station, it has a lot of PAX thats for sure.
airbazar
Thu Feb 07, 2013 1:30 pm
Quoting AlnessW (Reply 44):
That was planned in a time when there was a lot of money but there are benefits. One of the biggest problems at Logan is roadway congestion. The central rental car facility being built should alleviate some of that. Another benefit is loading and unloading of passengers and luggage on buses is more difficult and time consuming because the bus floor is not at the curb level. Yet another problem is that buses are irregular and people have to pay attention so they don't get on the wrong bus. With a people mover you just get in and wait for your stop. There's not wrong car to get into.
And last but not least the capital investment costs are not as high as some people think. On average it's about $130 million per mile. The recently opened 1.5 mile people mover at MIA cost $270 million. That's about what it would cost to put one in BOS. Yes it's expensive but not the "billion dollar" investment that some people imagine.
Quoting deltairlines (Reply 46):
It doesn't. DL-AF, US-LH, AA-BA, do a lot of connecting at BOS. And with AA dropping their LHR flights and US joining OW there will be even more passengers trotting over to terminal E. There's a reason why Massport is spending money to link ALL terminals post-security. My suggestion was that they should have built a people mover instead of making the passengers walk. Althought a glass enclosed "catwalk" with moving walkways above the terminals would be really cool, but that's not what they're doing either
ordbosewr
Thu Feb 07, 2013 2:05 pm
Quoting apodino (Reply 47):
ORD isn't so bad.
I lived in Chicago for over 15 years and I can say yes it is. Most locals only know it because of going to long-term parking.
Have you ever been on this during the afternoon when all of the international flights arrive into T-5 and most to all the passengers are connecting to domestic flights?
The only reason it does not have a horrible reputation is because much of the traffic originates in asia and they are used to getting pushed into the cars (yes, that is how it is in S. Korea and Japan). I have been on trains going from T1 to long-term parking where people get on going that direction just to go to terminal 1 because they can at least get on.
I have seen it so bad that they close the escalators to get up to the tram. It is awful. There is no excuse for this.
Yes, it is for a specific time of day and then it could go under utilized the remainder of the day, but that does not excuse the mess that it is for that period of time.
I mean go and look at the thread that shows the international fligths for summer 2013 and I bet you can figure out when these times are.
I have connected from NRT to BOS via ORD and it was an awful experience on the connection. I now would choose to do that connection anywhere else, it is too hard and too easy to misconnect because of this. I now connect via SFO if I have too.
