Delta777Jet
QF To BER?
Sun Feb 03, 2013 1:52 pm
I was wondering , with the current EK/QF Alliance and the fact that EK cannot fly to more destinations in Germany (EK urgently wants to fly to BER) could Qantas fly SYD/MEL - DXB - BER (TXL/SXF) vv. ! That would give EK direct access to Berlin via QF! Any thoughts ?
B-717/722/737-200/300/400/500/600/700/800/900/B-747-100/200/400/SP/8i/B-752/3/B-762/3/4/B-772/LR/300ER/B-788/DC-10-10/30/L-1011-1/500/MD-81/82/83/90/A-319/320/321/AB6/312/313/332/333/342/343/346/359/388/TU154/IL-18/ATR-42/72/DH4/DH3/E145/E170/190/CR2/7/9
Fuling
RE: QF To BER?
Sun Feb 03, 2013 2:02 pm
I thought the same too. Not thinking frame numbers it would use, but an A332 from PER - DXB - BER would be alright wouldn't it?
rutankrd
RE: QF To BER?
Sun Feb 03, 2013 2:12 pm
Quoting delta777jet (Thread starter):
Its been proffered before however i don't think EK could put their code on the DXB- TXL sector of a potential QF flight without route authority.
The big if - Were QF5/6 rotations retained and transferred lies around potential AB connectivity within Oneworld rather than EK ?
I would suggest that currently it would just add cost (Retain loses incurred of the FRA operation).
behramjee
RE: QF To BER?
Sun Feb 03, 2013 2:15 pm
DXB based carriers cant fly to BER as they have used up all of their entitled capacity to Germany. The same applies to AUH based ones too hence why you see Air Berlin operating TXL-AUH versus EY.
Quokkas
RE: QF To BER?
Sun Feb 03, 2013 2:33 pm
I have attempted to find what changes there have been made to the Germany - Australia bilateral but without success. I have found references that state changes in an MOU but that they were not ratified and are not in force. Under the original bilateral agreement signed between the two countries the only access a designated carrier from Australia has in Germany is FRA. If someone has access to an in force later agreement, please could they post a link?
If the points of access for Australian carriers has not been changed then QF is limited to FRA. The original agreement does provide for routing via points in the Middle East, so SYD-DXB-FRA would be permissible. But there is no suggestion that QF could simply swap FRA for BER in that agreement (not surprising given the four-power status of Berlin at the time the agreement was signed.) Nor, in any of the statements to date, has QF indicated a willingness to introduce new routes to Europe in the short to medium term.
The other question is, if QF could not make money on the most attractive destination (in aviation terms) in Germany, how can they expect to make money operating services into what many Germans regard as a low-yield destination? EK might because of their lower cost base. Could QF do the same while still claiming to be an Australian carrier with flights originating in Australia? To benefit from a lower cost base they would have to operate out of DXB (or some other Asian port) but if they do that will they still be regarded as Australian by the German authorities?
Given opposition to EK increasing the number of destinations served, can we imagine the German authorities approving a back-door to QF?
DolphinAir747
RE: QF To BER?
Sun Feb 03, 2013 4:23 pm
Better option: QF should have made an alliance with QR, which flies to TXL, instead of with EK. All-around it would have been a better deal anyways.
flyingalex
RE: QF To BER?
Sun Feb 03, 2013 4:59 pm
[Out of the box idea]
If the Germany/Australia bilateral really does limit QF to FRA, and EK desperately wants to serve Berlin while being limited in the total number of gateways in Germany, then maybe they could stop serving FRA and start flying to BER instead, while letting QF connect FRA to DXB with increased frequencies?
[/Out of the box idea]
The above will never happen, of course, but it probably would be within the scope of the existing bilaterals. The problem is that EK are only interested in traffic on their own metal, and there is no way they'll leave FRA.
Public service announcement: "It's" = "it is". To indicate posession, write "its." Looks wrong, but it's correct grammar
FlyCaledonian
RE: QF To BER?
Sun Feb 03, 2013 5:02 pm
Could QF operate Australia-DXB-FRA say twice daily, with EK switching it's authority from FRA to BER or another German port? (I'm assuming QF/EK can operate as a JSA in such a scenario)
Let's Go British Caledonian!
LJ
RE: QF To BER?
Sun Feb 03, 2013 7:09 pm
Quoting FlyCaledonian (Reply 7):
As mentioned previously, probably not within a QF/EK JSA. If you want to oeprate a route as a joint venture, both airlines must have traffic rights. If EK switches its authority to BER, than it cannot serve FRA (either with own metal or with a QF aircraft).
Delta777Jet
RE: QF To BER?
Sun Feb 03, 2013 11:26 pm
Well , EK used to put their Code on UL's flights fom SXF-DXZb-CMB in the early 2000's !
jsoprano
RE: QF To BER?
Sun Feb 03, 2013 11:55 pm
Quoting delta777jet (Reply 9):
They probably didn't fly to HAM at that time, so they were still within the 4 ports limit.
Although hell will freeze over before EK gives up FRA for BER, I think this is not possible unless EY vacates FRA as well, as the 4 port limitation applies to all UAE carriers combined. This is why Etihad cannot fly to BER either, because they are stuck with the 4 ports that Emirates elected in the first place.
Quokkas
RE: QF To BER?
Mon Feb 04, 2013 12:01 am
Quoting DolphinAir747 (Reply 5):
That assumes that BER is worth more than the current arrangement. For QF EK offers greater access not just to Europe but to the North and East African regions from a greater number of points in Australia. While QR serves MEL and PER, EK is able to serve SYD, MEL, BNE, PER and ADL, with additional room for expansion under the enhanced regional access programme. This gives far greater opportunity for code shares generating revenue for QF than an alliance with QR would.
I am sure that Alan Joyce and his team at QF would have looked at various alternatives but, with the information that they have and we might not, made the decision to go with EK as the best option.
Quokkas
RE: QF To BER?
Mon Feb 04, 2013 12:13 am
In a press release issue today QF has announced that
Qantas has also brought forward the end date for its loss-making Frankfurt services by six months to 15 April 2013.
Expansion is clearly focused on Asia with no plans of new routes in Europe being announced.
http://www.qantas.com.au/travel/airl...a-releases/feb-2013/5486/global/en
DolphinAir747
RE: QF To BER?
Mon Feb 04, 2013 12:43 am
Quoting Quokkas (Reply 11):
No, flying to TXL is only an extra benefit of what would have been a more cooperative arrangement in 1W. On the contrary, with the Australia-Qatar bilateral, QF could use its currently unsued frequencies to fly SYD-DOH and MEL-DOH, with QR flying DOH-PER and DOH-BNE. QR has a strong network in Europe, Africa, and the Middle East as well, including some points not flown to by EK. QF would also have been able to keep its close cooperation with BA, QR's sponsor in 1W.
JQflightie
RE: QF To BER?
Mon Feb 04, 2013 5:53 am
Quoting DolphinAir747 (Reply 13):
Now, now, that would just be the common sense approach now wouldnt it!!
Asia it is for us at QF! Maybe it has something to do with AB?What a Mess;
AB .....Sponsered by BA to enter OneWorld, who then gets a majority of it bought by EY who is in no alliance, then AB starts a heavy codeshare deal with AF/KL (of which im a FF and loyal customer to SkyTeam) ... maybe its safer that QF doesnt fly into BER ? But i would love to see PER-DXB-BER on A332's
Next Trip: PER-DPS-KUL-BKK-HKT-CNX-BKK-SIN-PER
flyingturtle
RE: QF To BER?
Mon Feb 04, 2013 8:17 am
When?
filler
filler
David
SKAirbus
RE: QF To BER?
Mon Feb 04, 2013 10:16 am
Sounds like another example of German protectionism damaging business!
Next Flights: LHR-OSL (738), OSL-CPH (320), CPH-LHR (321), LHR-HEL (359), HEL-LHR (359)
LH422
RE: QF To BER?
Mon Feb 04, 2013 10:30 am
Quoting jsoprano (Reply 10):
Yes, this is the case, and EY will surely not give up FRA in favor of BER.
QF have also moved forward the last flight into FRA by half a year. The last flight will now be April 16.
http://www.asx.com.au/asxpdf/20130204/pdf/42ctm8nyxl52zm.pdf
