bdak
BA A318 Damaged At JFK
Mon Feb 04, 2013 3:49 pm
The BA Source www.thebasource.com is reporting that the BA1/2 Club World London City Service is cancelled for a second day in a row, after the a318 aircraft used to operate the service was damaged at JFK. Does anyone have any idea what happened? Or any pics?
MesaFlyGuy
RE: BA A318 Damaged At JFK
Mon Feb 04, 2013 4:25 pm
I wouldn't be surprised if it was damaged during pushback. The space over by T7 around gates 1-3 isn't very plentiful
The views I express are my own and do not reflect the views and opinions of my company.
vv701
Mon Feb 04, 2013 4:30 pm
Here is the full The BA Source report dated 3 February:
"British Airways A318 G-EUNA sustained damage to its tailfin whilst under scheduled maintenance at New York JFK resulting in the cancellation of BA2 New York JFK – London City today."
jfk777
Mon Feb 04, 2013 7:51 pm
Where is the second A318 used for ths LCY to JFK flights ?
MesaFlyGuy
Mon Feb 04, 2013 8:01 pm
Quoting jfk777 (Reply 4):
G-EUNA is probably operating club World flight 3/4
Eagleboy
Mon Feb 04, 2013 8:20 pm
Maybe down for MX over the winter. I assume they don't refit it (with those 32 F seats) just for the summer schedule?
ssteve
Mon Feb 04, 2013 8:29 pm
Quoting VV701 (Reply 2):
I can't help imagining someone being insistent that A320s fit through a certain hanger door, so an A318 must too.
fca767
Mon Feb 04, 2013 8:48 pm
Quoting SSTeve (Reply 7):
A318's are smaller/same size
hOMSaR
Mon Feb 04, 2013 8:50 pm
Quoting fca767 (Reply 8):
A318 has a taller tail.
The plural of Airbus is Airbuses. Airbii is not a word.
There is no 787-800, nor 787-900 or 747-800. It's 787-8, 787-9, and 747-8.
A321neoLR is also unnecessary. It's simply A321LR.
Airplanes don't have isles, they have aisles.
audidudi
Mon Feb 04, 2013 8:53 pm
Quoting mesaflyguy (Reply 5):
Then that would be G-EUNB, as G-EUNA is the aircraft involved the mishap.
robbb
Mon Feb 04, 2013 8:55 pm
A319/A320/A321 tail height is 11.76m
A318 tail height is 12.51m
ssteve
Hopefully not said just before shortening one.
rampbro
Mon Feb 04, 2013 8:57 pm
That is exactly how this incident occurred.
bthebest
Mon Feb 04, 2013 9:03 pm
Quoting EagleBoy (Reply 6):
I thought it was a year round twice daily? (except Saturdays)
MesaFlyGuy
Mon Feb 04, 2013 9:37 pm
Quoting audidudi (Reply 10):
Whoops, you're right. Got distracted when I was typing
fca767
Mon Feb 04, 2013 9:59 pm
Quoting hoMsar (Reply 9):
Ohhh...that's funny...i would never have thought that...sorry to ssteve for doubting...
Quoting rampbro (Reply 13):
They need a warning Label on the hanger or aircraft, warning tail may be taller than they appear
jumpjets
Mon Feb 04, 2013 11:25 pm
Quoting bthebest (Reply 14):
Yes except normally in August when it goes down to one a day while more heavy maintenance is performed.
This year I believe it is also only operating once a day during some of April - but I don't know why.
Eagleboy
Tue Feb 05, 2013 12:27 am
apparently the taller tail is to compensate for the shorter body, not sure but I assume it's a centre of gravity issue?
rwy04lga
Tue Feb 05, 2013 12:31 am
The taller tail is probably for better directional stability.
Just accept that some days, you're the pigeon, and other days the statue
Continental
Tue Feb 05, 2013 12:46 am
Quoting robbb (Reply 11):
What kind of hangar are they using? We're talking a difference of 0.75 m (2.46 ft). Is the hangar entrance really that tight?
ezalpha
Tue Feb 05, 2013 1:16 am
Quoting rwy04lga (Reply 19):
I believe that's true. Of all 747s, the 747SP has the tallest tail.
kjfk527
Tue Feb 05, 2013 1:45 am
The aircraft is currently parked in American Airlines Hangar 10, Bay # 4. It was in Bay # 6 yesterday and was repositioned today. Their is plenty of space for the A318 in both Bay #4 and Bay # 6 with more than enough clearance for the tail.
The aircraft normally RONs over the weekend on AA hardstand number 3.
I will try and snap a picture of the bird in the hangar tomorrow if it is still there.
N243NW
Quoting EagleBoy (Reply 18):
Sort of. It's not for adjusting the location of the center of gravity, if that's what you're suggesting. The shorter fuselage means the stabilizer and rudder are farther from the aircraft's CG and therefore has less of a moment arm to counter any yawing tendency. Without a larger rudder area to compensate, the 318 would be less directionally stable than its larger variants.
ikramerica
Tue Feb 05, 2013 2:19 am
Quoting fca767 (Reply 16):
Shortest 737NGs have taller tails. 747SP has taller tail. It's to combat yaw do to wingspan v length being greater.
BryanG
Tue Feb 05, 2013 2:25 am
N243NW is exactly correct, from a physics standpoint. It's a moment arm issue. It's not uncommon for shortened airframes to have taller tails in a line of aircraft, and vice versa.
For example the A340-600 has a shorter tail than the A340-500, because of the longer fuselage, therefore a different moment arm.
rojo
Tue Feb 05, 2013 2:32 am
Didn't F9 also learned the difference in tail height between A319 and A318 the hard way?
I remember some news about their A318 not being able to clear DEN's bridge ...
Spacepope
Tue Feb 05, 2013 2:43 am
Quoting N243NW (Reply 23):
Actually the rudder is CLOSER to the CG, and has less moment arm.
Speedbird741
Tue Feb 05, 2013 3:43 am
Quoting ezalpha (Reply 21):
It is correct, yes. The A330-200 also has a taller vertical stabilizer than the A330-300 and A340-300 due to it's shorter fuselage, and also has a shorter vertical stabilizer than the A340-200, which has 4 engines and therefore is more stable and has better directional control
Speedbird741
Boa noite Faro, Air Portugal 257 climbing flight level 340
Viajero
Tue Feb 05, 2013 4:27 am
Quoting rojo (Reply 26):
They did indeed. Now the remaining A318s In Frontier's fleet have a placard in the cockpit concerning the DEN bridges. I believe the bridge itself has signs on it as well.
BN747DFWHNL
Tue Feb 05, 2013 6:04 am
Quoting Viajero (Reply 29):
Yes; it does.
platinumfoota
Tue Feb 05, 2013 7:20 am
Hmmm... Does the 777-200 have a taller tail than a 777-300??
Never forget United 93
PlymSpotter
Tue Feb 05, 2013 10:50 am
Quoting platinumfoota (Reply 31):
Not exactly, only the -200LF and -200F, but I believe that the tail itself is the same size and that the variation is due to other factors. Design shrinks often have the taller tail, hence the A318, B747-SP and early A332s. However there are also exceptions, like the A310, which is shorter.
Dan
flyinTLow
Tue Feb 05, 2013 11:13 am
It is not about the "normal" directional stability, but about being able to compensate the yaw momentum in case of an engine failure. With the same or at least similar engines attatched, you need the same yaw momentum compensation by the tail fin.
Now as momentum is force x arm, when shortening the arm, you have to increase the force somehow. You can do that by increasing the aerodynamic area.
Looking at the A320 family, A319/20/21 all have the same tail fin, but the rudder of the A321 does not deflect as far as the A319 one. On the A318, the deflection was not sufficient, hence the "taller" tailfin with increased "deflectable rudder area".
- When dreams take flight, follow them -
Eagleboy
Tue Feb 05, 2013 11:19 am
Quoting ikramerica (Reply 24):
Quoting BryanG (Reply 25):
Thanks for the clarification.....I knew the shorter body needed the taller tail but didn't know the physics of it.
gkirk
Tue Feb 05, 2013 11:22 am
Quoting PlymSpotter (Reply 32):
Same thing is it not? Or do you mean the 200LR?
skipness1E
Tue Feb 05, 2013 11:24 am
The B777-300 is a stretch whereas the taller tail comes into play with a shrink of the baseline model, like the B747SP, the A330-200 and the A318. It's not just early A332s that have the taller fin, they've all got it.
The B737NG has a bigger tail and wing across all models.
[Edited 2013-02-05 03:25:44]
Clydenairways
Tue Feb 05, 2013 11:25 am
How is BA coping with one of these aircraft out of service? It's a problem when you have a very small sub-fleet, you have nothing that can replace it directly.
skipness1E
Tue Feb 05, 2013 11:27 am
Is this right? I thought they were identical. Is the eight inch (seriously?) difference in height not accounted for by the nose down attitude of the shorter body?
[Edited 2013-02-05 03:29:19]
[Edited 2013-02-05 03:29:43]
gkirk
Tue Feb 05, 2013 11:30 am
Quoting clydenairways (Reply 37):
Presumably sending folk in and out of LHR?
vv701
Tue Feb 05, 2013 12:43 pm
The frequency of the LCY-SNN-JFK-LCY rotation is reduced from twice daily to daily during the holiday period in August each year.
In 2012 BA003/04 - the rotation 'NA was operating before it was damaged - did not operate from 29 July to 31 August inclusive. 'NA was at LGW undergoing routine maintenance from 29 July to 8 August. and 'NB followed on 17 August returning to LCY on 3 September.
In 2011 the last BA003/04 rotation was on 31 July and the next 0n 31 August. That year 'NA was undergoing maintenance at LGW from 29 July until 8 August while 'NB was at LGW from 6 to 31 August.
The gap between 8 and 17 August in 2012 when neither aircraft was under maintenance but BNA003/04 did not operate strongly suggests that operating the second flight in August would not be justified by demand. However data published by the CAA for 2011 - full year 2012 numbers have not yet been published - shows that in August 2011 passengers carried on this route (1,234) were significantly more than half the number carried on average in the other elven months of that year (1,853). So unless the August figures are boosted by a weakening in average per passenger yield that month looks to be operationally more profitable.
BA did say when announcing this service that routine maintenance would be carried out in "bite sized chunks" at LGW. These "chunks" are not all in August. It is not unusual for either aircraft to visit LGW for maintenance at other times. For example in 2012 'NA was ferried into and then out of LGW on the following day on six occasions, most usually arriving there on a Saturday and retuning to LCY on the Sunday. However in addition to the August visit there was another longer visit from 5 to 10 April. But this also looks as if it was for planned maintenance as it was from the Thursday before to the Tuesday after the Easter holiday weekend.
BryanG
Tue Feb 05, 2013 3:47 pm
Quoting gkirk (Reply 39):
Is this right?
No, I was incorrect, and I stand humbly corrected. Vertical stabilizers on the 340-500/600 have the same dimensions.
After further research, this post addressed that issue in detail: A340-500/-600 Vertical Stabilizer? (by GearDownPlease Oct 28 2008 in Tech Ops)
Mir
Tue Feb 05, 2013 3:53 pm
Quoting BryanG (Reply 41):
Airbus took the vertical stabilizer off the 330-200 and put it on the 340-500/600 - they could have put a different size on the -600 because it's longer, but since they already had a stabilizer that was designed and tested and certified, the cost/benefit analysis just didn't make sense.
-Mir
PlymSpotter
Tue Feb 05, 2013 8:13 pm
Quoting gkirk (Reply 35):
It's a special low fat variant of the LR
sralfalo
Crew
Thu Feb 07, 2013 2:20 pm
G-EUNA is back in service, currently operating BA001 to JFK
image of fixed tail fin: http://t.co/uRSMnuFw
TC957
Thu Feb 07, 2013 5:41 pm
See - nothing a bit of tape can't fix...
vv701
Thu Feb 07, 2013 5:45 pm
Quoting sralfalo (Reply 44):
It was returned to service on 6 February operating JFK-LCY (B A002).
ssteve
Thu Feb 07, 2013 7:35 pm
I started the jokes about it being assumed to be no taller than an A320... do we know what actually hit the tail?
axelesgg
Sun Feb 10, 2013 11:44 pm
A Privatair 737-700 seems like a good replacement, if only LCY were certified for that model
Fly Draganair
skipness1E
Mon Feb 11, 2013 12:36 am
Quoting axelesgg (Reply 47):
Given BA operate seven daily flights from LHR they're not likely to need that.
Devilfish
Mon Feb 11, 2013 3:17 am
What about an all-premium configured CSeries or Emb-NG? By now, the historical load factors on this service could indicate the optimal seat number and aircraft model.
