DTWLAX
LAX To Have Taxiway Between The North Runways
Wed Feb 06, 2013 5:58 am
http://www.latimes.com/news/local/la...20130206,0,1182044.story?track=rss
The article also talks about terminal additions and a transportation center, though that may happen closer to 2025 as mentioned.
There is also talk about a people mover around the terminals. If it goes through that is one hell of an improvement over taking the shuttle for terminal changes. Also hope they plan for building that after security, guess they have to since there is no space for a people mover outside the terminals (before security).
LAXintl
RE: LAX To Have Taxiway Between The North Runways
Wed Feb 06, 2013 6:13 am
Still has to be approved by the full City Council, and likely face a few nice lawsuits along the way.
Also does not help that LA County top administrator came out only yesterday to fault LAWA for failing achieve their 2006 legal commitment to push traffic away from LAX towards other regional airports, and if they had done so these proposed projects might not even be required.
Long way from a done deal in otherwords.
[Edited 2013-02-05 22:14:16]
ikramerica
Wed Feb 06, 2013 7:32 am
Quoting LAXintl (Reply 1):
Agreed.
And when the legal challenges come, it's going to be difficult for LAX to demonstrate why both the north and south complex require accommodations for A380s when there is no conceivable way that there would be enough VLA traffic to ever require that even 50 years into the future.
Considering many major airports operate with only 2 runways in use at any time, LAX has the luxury of 4, and the vast majority of flights at LAX are 757 and smaller, so if safety is a concern re: VLAs passing in the night, operations can and SHOULD be altered to move 200ft wingspan and larger to the south complex and call it a day.
The current proposal is a massive waste of money for a theoretical problem that need not exist in the first place. Runway incursions happen at all airports, even those with massive taxiways, because pilots are human and sometimes they don't listen. This won't change with a center taxiway.
ldvaviation
Wed Feb 06, 2013 11:42 am
Quoting ikramerica (Reply 2):
It is not just about accommodating A380's on the north side.
There is a safety issue that has nothing to do with A380's. The taxiways/runways (I forget which) are too close to the terminals.
This is not a "theoretical" problem.
BN747
Wed Feb 06, 2013 3:56 pm
This has been planned since work started on the 25s centerfield taxiway.. it brings with it good news and bad news for spotters and photogs.
The Good...
24R - 6L will be shifted a few hundred feet north - displacing Lincoln Blvd and making spotting from the northside..esp. from the bridge a huge attraction as 'the Hill' is for the southside.
The Bad...
In-and-Out Burger just most has to go (as Lincoln Blvd is also shifred northwards... it and it's little park does reside on LAWA property technically, I believe.
From some blue prints I've seen, it's gone but the Westchester Parkway did remain.
BN747
"Home of the Brave, made by the Slaves..Land of the Free, if you look like me.." T. Jefferson
Rbgso
Wed Feb 06, 2013 5:05 pm
Quoting BN747 (Reply 4):
No In-N-Out at LAX to spot  Wow! ? This certainly can't be allowed to happen....
[Edited 2013-02-06 09:46:38]
apodino
Wed Feb 06, 2013 6:12 pm
Given the whole mess that ONT has become under LAWA, there is a strong argument for this. With Inland Empire politicians putting the pressure on LAWA over ONT, you could see some strange bedfellows on this one as those guys and the LA County top Administrator could be on the same side, even though the motivations are different.
highflier92660
Wed Feb 06, 2013 6:40 pm
I love the argument of the NIMBYS that the A380 isn't selling well so there will never be a need to improve the northern runways. These people have taken a deliberately myopic vision of LAXs future ten, twenty or thirty years from now. There is a magnificent international terminal with Sydney Opera House like scallop shells nearing completion and the reality is a vast majority of passengers destined to the Los Angeles metro area are not going to fly in to ONT or LGB or any other satellite airport. One only hopes the political will can cut through the lawsuits...fast.
Is there any firm plan on the eventual length of 24L-6R? From the graphic depictions it looks as if it will extend east about 2,000 feet, so 12,285 feet should be correct?
studedave
Wed Feb 06, 2013 7:03 pm
I disagree. The room to grow is to the North.
It might make the neighborhood I'm typing this from noisier, but there's less 'stuff' in the way on this side of the airport.
I'd sure hate to see that In-n-Out go away though.
For the record- when in LA I stay at my Grandparent's place on 85th St. They moved here in 1962.
StudeDave
Classic planes, Classic trains, and Studebakers~~ what else is there???
JAAlbert
Wed Feb 06, 2013 9:00 pm
Quoting apodino (Reply 6):
Its a shame the OC voters rejected El Toro as a major new international airport. An airport in that area would have been a top facility.
ontime
Wed Feb 06, 2013 9:17 pm
Quoting rbgso (Reply 5):
No In-N-Out at LAX to spot ? This certainly can't be allowed to happen....
The plans linked on the following LAWA website seem to show Lincoln Blvd at "below grade" at approximately the location of the In-N-Out and the parking garage next door. Any chance the In-N-Out survives? Or is it too tall to be in the runway path, regardless of where Lincoln Blvd winds up?
http://www.lawa.org/uploadedImages/S...Recommended20Alt20130110_72dpi.jpg
[Edited 2013-02-06 13:18:37]
studedave
Wed Feb 06, 2013 10:43 pm
Quoting Reply 10):
You're mixing up the new with the old runways.
In-N-Out would end up right under the flight path of the new runway.
StudeDave
flaps30
Wed Feb 06, 2013 11:26 pm
So what will happen to Lincoln Blvd? Will it disappear between Sepulveda and where it runs West and parallel to the North runways or will it become an underground Lincoln Blvd kind of like how Sepulveda runs under the South runways? Can Lincoln Blvd survive this renovation?
timz
Wed Feb 06, 2013 11:43 pm
Quoting LDVAviation (Reply 3):
It seems runway 24L isn't going to move north-- will the south parallel taxiway move closer to the runway? If not, how will anything end up farther from the terminal?
aklrno
Wed Feb 06, 2013 11:55 pm
Quoting Reply 10):
If you read the SPAS final report (laxspas.org), pages 2-10 to 2-12 lists all businesses affected. In-n-Out is not listed. There will be one less Burger King and Denny's in the area, but we can all relax about In-n-Out. I'm not sure if the park across the street goes.
Stabilator
Thu Feb 07, 2013 1:32 am
How will this new taxiway effect traffic at the airport? Is building it similar to the disruptiveness as re-paving a runway, etc?
So we beat on against the current, borne back ceaselessly into the past.
alphazulu
Screener
Thu Feb 07, 2013 1:41 am
Yes, It's good to hear the In-N-Out is on private property and will not be affected by the improvement made to the 24 complex. As for the park just across the street to the south, I see no reason to get rid of it. The approach lights will have to be moved, probably right to the edge of the street (W 92 St.) by the In-N-Out. But again, I see no reason to get rid of the park.
The benefit to this move will be the heavies flying right over the In-N-Out some 200ft above. Just imagine sitting out on the patio having a burger and a screaming 380 right on top of you! I'm looking forward to it!
In the shot below the AC will now be flying directly over the red / white topped tables, that is if the improvements are approved. I sure hope so!
lightsaber
Thu Feb 07, 2013 2:09 am
This move is overdue. Yes, there will be a legal fight, but this is a fight that must be done.
Transportation is the cornerstone a city builds wealth and LAX *needs* an expansion. The added flights, thanks to the taxiway, would be great!    Do people really not realize that not expanding is cutting future jobs?!?
The only way to push traffic to other airports is better automate the search engines to also compare ONT, LGB, SNA, and BUR.
Quoting aklrno (Reply 14):
   Yea! Even though I never made it there. (I used to work just south of LAX and would walk during lunch to view the aircraft.)
Lightsaber
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
murchmo
Thu Feb 07, 2013 10:49 am
Nah, right now the flight path is perfect. Super close and low and you barely have to look up to watch the planes, walk across the street and be right underneath. If the path moves Right above you will hurt your neck looking straight up while eating your burger.
to strive to seek to find and not to yield
baileyncreme
Thu Feb 07, 2013 6:48 pm
Would this affect the customer base of Inn N' Out?
Not everybody is airplane crazy as we are.
I'm not too sure many soccer moms with 3 kidlets would feel very
safe with a Qantas 380 zooming close over their heads while
ordering meals for their little mini-me's...
I myself would be in heaven though.
lightsaber
Thu Feb 07, 2013 7:34 pm
Quoting baileyncreme (Reply 19):
Agree on both points.
I hope the place stays open. They'll probably go more drive through.
Lightsaber
aklrno
Fri Feb 08, 2013 4:57 am
In-n-Out may not be safe after all. The list of properties to be bought for the LAX project just lists those that are needed for actual construction.
Reading the more detailed description, the Runway Protection Zone (RPZ) for 24R falls right on top of In-n-Out, the Parking Spot, and the office building just north of them. The LAX plan points out that the new displaced threshold will help, but takes no responsibility for the FAA's possible ruling on what can be in the RPZ. If, upon consideration by the FAA), the RPZ must be cleared, the FAA will make that a condition of its approval for the new runway location.
I'm not feeling good about this. The whole thing reminds me of the parking garage at the approach to RWY 27 at SAN that the ALPA used to complain about.
questions
Fri Feb 08, 2013 5:39 am
Quoting StudeDave (Reply 8):
Wow, that's awesome. It was a different place in 1962! What is the name of the development, "Tranquil Sea Breeze Acres"?
studedave
Fri Feb 08, 2013 5:48 pm
Quoting questions (Reply 22):
I have no idea- I was born 8-10 years later.
But 'Kentwood' rings a bell.
StudeDave
