chieft
PIA B737 Landing Gear Failure In Muscat / Oman
Mon Feb 11, 2013 1:16 pm
A Pakistan International Airlines B737 passenger plane crash-landed on the runway of Oman's main airport in Muscat today:
http://www.emirates247.com/pia-crash...airport-closed-2013-02-11-1.494619
[Edited 2013-02-11 05:16:58]
http://avherald.com/h?article=45d93bd3
[Edited 2013-02-11 05:18:13]
[Edited 2013-02-11 05:19:11]
Aircraft are marginal costs with wings.
TK787
Mon Feb 11, 2013 1:24 pm
Sounds like it happened after landing and then the front landing gear collapsed.
teneriffe77
Mon Feb 11, 2013 1:35 pm
If you look at he picture from avherald you can see it's not the nose gear but the left main landing gear and the plane is now resting it's left engine. As far as damage goes you've got the left engine, left main gear and possible left wing due to the stress of dragging the engine along the runway.
comorin
Mon Feb 11, 2013 1:36 pm
Please, what are the main reasons for a landing gear collapse?
Thanks in advance.
TK787
Quoting teneriffe77 (Reply 2):
My bad, I didn't see that second link.
tk1244
Mon Feb 11, 2013 1:52 pm
Good to hear no one was injured
"The future is in the skies. For any nation that cannot defend its skies will never be confident of its future." Atatürk
na
Mon Feb 11, 2013 1:59 pm
Crash-landing sounds a "bit" exaggerated. PIA might be disappointed to see that this hit the only 733 in the fleet which isnt so old its not worth repairing. All other 733s they have are very old, only this one is from 1992.
Still, it could be a write-off as PIA is retiring the 733 in the coming months and dozens of age-mates have been scrapped or retired recently, among them many LH birds, and the whole fleets of Batavia, Webjet, Aerosvit etc.
[Edited 2013-02-11 06:07:15]
migair54
Mon Feb 11, 2013 2:42 pm
I can´t see the slides, how did they leave the plane?? interesting if after that crash landing they didn´t evacuate the plane... engine has fuel, hyd, electrics... plus sparks and heat from the friction with the runway, really dangerous situation.
according to the metar and runway 26L they landed with tail wind from the left, so this could be another factor, a hard landing with the left main gear can create this kind of damage, specially variable and gusty wind, excessive banking to correct a change or a gust, and impact the runway not fully align.... that´s hard for the L/G.
to know if it will be a write off we have to wait but usually the problem with this accidents are the structural damage in the wing, but with a 21 years old plane i see it difficult to spend too much money to fix.
UK_Dispatcher
Mon Feb 11, 2013 2:53 pm
My most recent flight was on this aircraft, on 29th January from KHI to AUH.
Knowing that most of the PIA B733s were early build ones, I was surprised to see this one was a 1992-build ex-Government aircraft when I checked afterwards. I said to my friend/fellow aircraft nutter when we flew it that despite this aircraft not being the main 'aviation attraction' of our trip, I was actually glad to get on a PIA B733 since they wouldn't be around for much longer. Little did I know this aircraft had less than 2 weeks to go!
Ian
Revelation
Mon Feb 11, 2013 3:03 pm
Ahh, another 737 classic bites the dust...
Not sure how bad a "crash" it is.
Glad there were no injuries.
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
Pihero
Mon Feb 11, 2013 3:10 pm
Please stop the sensationalism
1/- The wind was variable, from 030° to 160°, probably caused by a small frontal passage.
2/- Pilots don' t have anything to do with the ATC choice of runway in use. Apparently everybody was satisfied with the choice of runway.Otherwise, they would have requested 08R.
3/- The most glaring aspect of the incident is that the collapse of the left main gear happened after landing, quite some time after touchdown, as the deployed reverser shows in the picture
4/- Landing gears are buit to take a lot of abuse - for instance, no de-crabbing on strong cross winds on landing, so I do not think the failure came frrom a botched landing... my money is more on a gear-down latching problem
5/- "excessive banking", as you said would have caused the left engine to scrape the runway... there doesn't seem to be any traces on the pavement.
Contrail designer
RussianJet
Mon Feb 11, 2013 3:11 pm
Quoting clydenairways (Reply 7):
It's hardly a crash.
Maybe, but it's hardly a typical landing either. It's a life-threatening thing to have the gear collapse on landing.
Quoting Revelation (Reply 10):
Yeah, a real shame to see.
✈ Every strike of the hammer is a blow against the enemy. ✈
rfields5421
Mon Feb 11, 2013 4:37 pm
Quoting Pihero (Reply 11):
I've seen a lot of photos over the decades of landing gear collapses, however, only a few of those look like this one where the gear folded inward toward the stowed position.
Some issue with the latching seems quite likely.
FltMech747
Mon Feb 11, 2013 8:56 pm
Looks like a Damper Assy failure which causes the wheels to twist "shimmy" followed by the down lock failing.
Just saying...
Pihero
Mon Feb 11, 2013 10:12 pm
Looking back at the photo, there's something hanging from under the wing, apparently from the wheel well. Some people think that's the diagonal brace... no wonder the gear collapsed, then.
Another remarked that the tyres didn't show any sign of a blow up or destruction, which confirmed that the collapse happened near the very end of the roll-out.
What do you think, rfields5421 and FltMech747 ?
Contrail designer
ZBBYLW
Mon Feb 11, 2013 10:56 pm
You're joking right? If I don't like the runway of choice I will be requesting otherwise. If one runway has a strong tailwind would you just happily shoot the approach and land? How about a strong crosswind with an icy runway? If for what ever reason you do not feel that it's safe to land on a particular runway you don't.
Keep the shinny side up!
Pihero
Mon Feb 11, 2013 11:56 pm
Quoting zbbylw (Reply 17):
...and that's EXACTLY what I wrote, one sentence further :
Stress is mine on this post.
Contrail designer
rfields5421
Tue Feb 12, 2013 12:07 am
Quoting migair54 (Reply 8):
This collapse wasn't a crash. There was not indication of fire or additional danger.
Using the slides to get people off the aircraft is a GUARANTEE OF INJURIES - easily possible for serious injuries to occur. Even more so in today's world when people insist upon carrying dangerous objects onto the slides.
Slide evacuation is a precaution when it is critical to get people off the plane immediately due to imminent danger.
I see nothing in the pictures to indicate an imminent danger.
As to how the folks get off the plane - a stair brought to the rear doors.
Quoting Pihero (Reply 16):
It is obvious that this was a relative low speed failure of the gear. Not to pre-judge - but this really looks like a mechanical failure. I'd hate to be the last mechanic to work on that gear.
roseflyer
RE: PIA B737 Landing Gear Failure In Muscat / Oman
Tue Feb 12, 2013 3:48 am
Landing gear components wear over time. On the 737 the landing gear must be overhauled every 10 years where all the moving parts are taken off the airplane for restoration. It is normal for cracks to develop. The looks like a down lock, retract actuator, drag brace, etc could have broken. These components do not support the weight directly but rather support any side loads. That can explain why the fear deployed and didn't buckle immediately upon landing.
I personally would be curious when the gear was last overhauled. Since th plane is 21 years old it may have just been overhauled or it could be due for one soon and is not make it.
Tue Feb 12, 2013 8:29 am
Quoting na (Reply 6):
I had a deja vu - same kind of accident happened back in 2011: http://avherald.com/h?article=444461f4&opt=0
This was a write-off, so I assume the same for PIA.
speedbird128
Tue Feb 12, 2013 2:49 pm
Pretty far off the side of the runway too...
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
