CiC
Boeing Certified Dreamliner By Themselves?
Mon Feb 11, 2013 4:37 pm
http://seattletimes.com/html/localne...g.recommends%22}&action_ref_map=[]
Am I right? The FAA outsourced parts of the certification of the 787 to Boeing, so "Boeing did the certification by themselves"...?
How can this happen???
phxa340
RE: Boeing Certified Dreamliner By Themselves?
Mon Feb 11, 2013 4:55 pm
This is far more common than you would think - they didn't certify the entire process, just some processes within the overall certification.
flight152
Mon Feb 11, 2013 5:02 pm
Quoting oldeuropean (Reply 2):
That's capitalism.
Do you honestly think it's any different with airbus? I'll be the first to tell you it's not. The FAA does not have the manpower to oversee the certification and testing of every small component on every aircraft certified.
okay
Mon Feb 11, 2013 5:08 pm
Quoting flight152 (Reply 3):
It is nowhere said Airbus would not have similar practices.
As flight 152 points out, this is more or less standard procedure nowadays. I am, however, surprised FAA did not pay closer attention to the battery-based design. They did at one point raise questions about it, did they not? I am surprised they did not then decide to keep a closer eye on the development. Now, the milk is spilled, all over the table!
Stitch
Mon Feb 11, 2013 5:16 pm
Quoting CiC (Thread starter):
It is standard practice in multiple industries across the world. Government regulatory agencies do not have the budget or manpower to be experts in everything.
That being said, it should not be construed as the FAA did nothing and just accepted whatever Boeing sent them. FAA personnel were present for a fair bit of the flight testing and certification process so there was direct FAA oversight of the process. Boeing was also allowed to self-certify certain parts of the plane because they have proven to the FAA's satisfaction that they are competent to do so to the level that the FAA would have done so if they had the manpower and expertise to do it themselves.
Quoting okAY (Reply 4):
That the FAA did raise questions and set up a list of special conditions for their use in the 787 looks to me that they did pay attention to the design. Perhaps not as much as they should have, but it certainly doesn't look like they just told Boeing to do whatever they wanted with the batteries.
[Edited 2013-02-11 09:18:02]
PGNCS
Mon Feb 11, 2013 5:34 pm
That's capitalism.
Because corruption doesn't occur under socialism or communism? Please.
Stitch is exactly correct:
Quoting Stitch (Reply 5):
citationjet
Mon Feb 11, 2013 5:54 pm
Quoting phxa340 (Reply 1):
Agreed. Boeing has been delegated by the FAA to find compliance to aviation regulations consistent with their Organization Designation Authorization (ODA). For details, read FAA Order 8100.15A. Most OEMs have delegation to approve items on behalf of the FAA. Boeing, Cessna, Gulfstream, Bombardier, Hawker-Beech, etc.
http://www.airweb.faa.gov/Regulatory...B6F?OpenDocument&Highlight=8100.15
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
dtw2hyd
Mon Feb 11, 2013 6:39 pm
Self-Regulation is the norm in every sector here. FAA treats Airlines as customers and FAA Inspectors serve Airlines. It appears same philosophy is extended Aircraft Manufacturers.
ukoverlander
Mon Feb 11, 2013 7:37 pm
What does Airbus have to do with it??????
dfambro
Mon Feb 11, 2013 7:38 pm
It's fine for this to happen, and there is nothing wrong with the process. The manufacturer does the testing and regulator reviews the results.
I'm not in avaition, I work in pharmaceuticals. All the pharmaceutical and biotechnology companies are responsible for their own testing, and clinical trial results supporting drug approval are submitted to the regulator (the FDA here in the US). In addition, the regulator provides general guidance for its requirements and, through an on-going structured dialog, specific guidance for the approval requirements of a specific product.
If a company mis-reports, deliberately misleads or disobeys the regulator, they are committing a criminal act. That's a very rare occurrence, in part because the industry fosters a culture of integrity. I would assume a similar culture of integrity is at work in aviation as well.
The process works very well in pharmaceuticals. But of course, nothing is entirely perfect and there are occasional problems with specific products. And that's what it appears we have here with the battery isse, one of those occasional problems. It does not mean that the regulatory system is broken. It may, however, point to ways to further improve the system.
Maersk737
Mon Feb 11, 2013 7:41 pm
Quoting ukoverlander (Reply 9):
Quoting flight152 (Reply 3):Do you honestly think it's any different with airbus?
Not much when it comes to the 787.... But who do you think tested most of everything regarding the A380?
Peter
I'm not proud to be a Viking, just thankfull
ikramerica
Same is true in construction. An engineers stamp means that the engineers are certifying they have calculated what needs to be calculated and checked their work. Then the review takes place, where SOME of the data is checked, the major components are examined, etc. Small things are not always checked, nor is every change over the course of the product necessarily checked with the scrutiny you might want, and sometimes it's the small things that kill people.
roseflyer
Mon Feb 11, 2013 7:49 pm
Boeing is responsible for determining if the airplane is compliant with many of the federal regulations. The regulations keep expanding every year. The certification process is more robust than ever. Part of the reason for outsourcing it to Boeing was that the regulations were becoming so intense that the FAA and independent observers did not have the expertise or knowledge to approve that the designs actually conformed to the regulations. The FAA has found that when they try to manage things that they don't have the expertise for, what happens is the whole certification process grinds to a halt and nothing can ever get certified.
In the 1960s, airplanes were certified using engineering judgment and basic safety assessments. Certification safety assessments were pages for each system. Nowadays, they are about 500-1,000 pages per discipline. The amount of work going into fault trees, functional hazard assessments, certification plans, etc is far more robust than ever.
People see the title of the article indicating that the FAA outsourced certification compliance determination to Boeing and immediately think it is less safe. In reality, I think the system is more safe than it was 30 years ago.
Personally I am more worried about COMAC than Airbus or Boeing. Both the big players understand the certification process and have the expertise in house to demonstrate compliance. Boeing kept the certification work in house for the 787 even though much of the design was outsourced. COMAC is outsourcing the Authorized Representatives to suppliers because they don't have the internal expertise. That's two removed from the FAA/EASA, and the implications on COMAC could be severe if they try to get FAA or EASA certification.
[Edited 2013-02-11 11:53:03]
ER757
Mon Feb 11, 2013 8:02 pm
Quoting dfambro (Reply 10):
Very good analogy - in both industries, false reports or negligence in testing/certification could result it people dying.
The moral ramifications of falsifying results to bring a product to market, to say nothing of the financial ones are too great for a reputable company to even think of doing so.
LHRXXXLHR
Mon Feb 11, 2013 9:02 pm
Every check airman (substitute your airline's term here) is doing the exact same thing. He/she is an airline employee doing the regulator's job.
The title of the Seattle Times article is a bit disingenous as well since those faulting Boeing are an ambulance chaser and a former FAA official with an ax to grind. I'm willing to believe that mistakes were made but find some more credible sources.
Francoflier
Mon Feb 11, 2013 9:27 pm
I don't think any manufacturer would take the certification process, internal or external, in anything other than the most serious way.
Whenever an accident happens and, god forbids, lives are lost, they know too well that the full power of the public-opinion-and-politics-backed hammer of the law will land on them with all the fury one can expect, not to forget the complementary mediatic shitstorm... Stakes are too high to play with that.
This is a hyper-regulated environment where every mistake is tracked down to the last detail and where punishments are extremely severe. Plus, civil aircraft manufacturers don't tend to have powerful lobbies in the government.
This is not the pharmaceutical industry, thankfully.
This, to me, is a case of the implementation of a new technology on which no one had any relevant operational experience to back up the certification standards. They were thus likely mostly based on theoretical knowledge.
One could argue that the certification of Li-ion batteries was too lenient in light of the lack of operational knowledge, but there has been no major accident, and prompt actions were taken, so then again, maybe it wasn't.
And since the cause of the problem seems to remain elusive, it seems regulators and engineers would have had a very hard time to foresee it happening.
a380900
Tue Feb 12, 2013 3:43 am
If one wants the regulator to check everything, the regulator must overshadow almost every move of each of Boeing's workers. They lack the man power and the expertise to do so.
I'm not surprised certification works like that and I tend to agree that the guy has an ax to grind. Yet, I think the 787 has been a particularly messy program and I would not be suprised if here and there the FAA had been a little looser than usual. The pressure to get this plane in the air and the production moving has been bigger than on standard program because of the unprecedented delays. That is why I would not be surprised it the battery issue was only the first in a series of problems that will occur on this plane. Starting with the Potemkine roll-out, I think there was something fishy about this program from the beginning. I'd be surprised if the battery issue was all there is to it in the hidden defects department.
robsaw
Tue Feb 12, 2013 3:49 am
A more surprising storyline would have been "FAA Directly Supervised All Aspects of 787 Certification".
Of course if that truly had been the case, does the "blame" shift for the sensationalizers?
flyorski
Tue Feb 12, 2013 3:29 pm
All we know is that the way the aircraft got its airworthy certificate was inadequate. Had testing been more vigorous it is likely the battery problems would have appeared sooner. Boeing could have delayed initial deliveries a few months and avoided the fiasco of grounding the fleet worldwide for weeks.
"None are more hopelessly enslaved, than those who falsly believe they are free" -Goethe
7BOEING7
Tue Feb 12, 2013 3:51 pm
Quoting flyorski (Reply 18):
Based on the fleet vs flight test flight hours it could have been years until Boeing duplicated the ANA/JAL events, if ever. You can't catch everything. Until they determine the cause, if they ever do, we won't know what other testing would have been necessary to find this issue prior to passenger service.
Kaiarahi
Tue Feb 12, 2013 3:58 pm
So what would you have done differently? Development and testing took 7 years.
Empty vessels make the most noise.
r2rho
Tue Feb 12, 2013 5:35 pm
Boeing as well as Airbus have a ODA/DOA - design organization approval, EASA part 21J, which is mentioned in the article. As well as a POA (for production - same thing from a manufacturing point of view, EASA 21G). It is not easy to obtain, and you have to work to maintain it as you are regularly audited for it.
For example, strictly speaking, Boeing/Airbus would have to obtain a new Permit to Fly from FAA/EASA for each prototype test flight with a new non-certified aircraft configuration. During a flight test campaign for a new type such as the 787 or A350, with multiple daily flights, that would be a nightmare for all. But as DOA's, A&B can approve those test flights themselves (with exceptions in case of major changes of course).
And it's not just A&B... various companies have various degrees of ODA's/DOA's granted to them by th authorities:
http://easa.europa.eu/approvals-and-...-approvals/docs/lists/easa_doa.pdf
http://www.faa.gov/other_visit/aviat...ignee_types/media/ODADirectory.pdf
robsaw
Wed Feb 13, 2013 7:17 am
No, "we' don't know that at all. You are making an assertion without any supporting evidence. The number of battery problems in no way suggest a high probability of more vigorous testing showing anything "sooner" within the timeframe of a few months. The batteries (in fact, the entire battery system) were tested as vigorously as any regulations and engineering standards deemed sufficient. When a Boeing engineer comes out and makes your statement with evidence of some known battery issue then you may have a point.
Bongodog1964
Wed Feb 13, 2013 7:48 am
Lets be clear, Boeing did not "certificate the Dreamliner by themselves" The certificate was stamped by the FAA. The FAA will have looked at Boeing's procedures/methodology and come away satisfied that everything had been correctly designed, reviewed, checked etc.
This is how approval works in all industries now. If the FAA was to investigate and individually certify every component, sub assembly and then the plane, they would have then have so many staff and facilities that they might as well design the plane themselves !
