KarelXWB
Crew
Boeing Shows First 777-9X Rendering
Wed Feb 13, 2013 8:43 pm
Live from #PNAA: Randy Tinseth (vice president marketing at Boeing) quietly shows first public rendering of 777-9X with folding wing.
(picture uploaded by http://twitter.com/jonostrower)
Note: this is only a rendering, no final decision on the 777X design has been made.
[Edited 2013-02-13 13:02:07]
Close, but no cigar http://vine.co/v/OjqeYWWpVWK
Prost
RE: Boeing Shows First 777-9X Rendering
Wed Feb 13, 2013 8:54 pm
Any idea how much additional weight the folding wingtip would have vs. the benefit a longer wing provides the aircraft?
AA737-823
Wed Feb 13, 2013 9:01 pm
I love how they've parked the plane next to the 787-10...
Hopefully, both planes will come into existence, and will both have adequately different mission strengths, so that they can both become viable products in a competitive product portfolio!
Stitch
Wed Feb 13, 2013 9:11 pm
Quoting prost (Reply 1):
Since the tips do not contain any control surfaces and will be CFRP, I expect they should be relatively light. Whatever it is, the weight penalty will be less than the aerodynamic gain (otherwise Boeing wouldn't bother).
KarelXWB
Crew
Wed Feb 13, 2013 9:21 pm
The folding wingtip should also let the 777X fit into the existing 777 airport gates.
N14AZ
Wed Feb 13, 2013 9:23 pm
Quoting KarelXWB (Thread starter):
Thanks very much. Great rendering.
with folding wing.
Boeing offered the folding wingtips for the current T7 as well but not a single T7-operator implemented this option. Now that the wing span will be even higher, I am very curious if we will see the folding wingtips in reality.
Quoting AA737-823 (Reply 2):
At first, I thought it's a VN 787 but then I realized it's a "10" on the tail fin.
FriendlySkies
Wed Feb 13, 2013 9:33 pm
Quoting N14AZ (Reply 5):
IIRC, the original folding wingtip was a much larger section that included all or part of the aileron. This would have been much heavier than the proposed folding tip for the 777-X, and was intended to allow the 777 to fit into the same gate as a DC-10 or 767.
connies4ever
Wed Feb 13, 2013 9:40 pm
Not much since it will be composite, but that's not the point of a folding tip.
Quoting KarelXWB (Reply 4):
Exactly. For every airliner, the 'footprint' it takes up on the ramp slots it into a particular aircraft class, with corresponding fees. Higher the class, the more it costs. Which is one reason you see smaller aircraft use winglets to effectively increase span and efficiency, while larger ones like the 777 use raked wingtips, which are more efficient, and don't have a class impact. For the 777-9X I must conclude that the increased span puts it into the same class as a 380. I believe current projections for the -9X wingspan is 71m or about 247ft. The 380 is a shade under 80m or about 267ft. For the raked wingtips on existing -200LRs and -300ERs, the raked wingtip adds about 3m or 10ft, to 64.8m or about 212.5ft.
justloveplanes
Wed Feb 13, 2013 9:41 pm
Quoting FriendlySkies (Reply 6):
What mechanics to move this?
perhaps they can use some of the control surface acutators via a clutch to move the wingtips and save weight?
or maybe just a hydraulic line to both sides of a control piston, one to move up and the other down?
Maybe just a small light electric motor with very high gear ratio?
Revelation
Wed Feb 13, 2013 9:50 pm
Quoting justloveplanes (Reply 8):
Yep, with a lightweight Li-Ion battery to power it!
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
PW100
Wed Feb 13, 2013 10:00 pm
Quoting Stitch (Reply 3):
How would you get aerodynamic gain from a folding wingtip, that a fixed wingtip can not produce? That would be an interesting set-up, wonder what angle it will have in-flight . . .
Off course just having a little fun here. I'm sure you mean that the extra wingspan the folding technique allows, will bring aerodynamic advantages that outweigh the extra weight of the folding mechanism.
The again, one could also argue that the customers just have to live with the extra wingspan, have the airports adapt their gates, and let the airlines enjoy the extra benefit of the wingspan, without the weight penalty of the folding mechanism.
Rgds,
PW100
Edit: typo
[Edited 2013-02-13 14:14:19]
FriendlySkies
Wed Feb 13, 2013 11:09 pm
I would expect an actuator similar to those used for the spoilers. The wingtip is not that heavy.
wingman
Thu Feb 14, 2013 12:16 am
Is that the new airport where Boeing parks its delayed delivery jets? If you zoom in on Google Earth you can see what appears to be the Qatar Airways Sheik ranting and raving at the customer service counter, top down view between the 777 and the 787.
Nice looking terminal at least.
SOBHI51
Thu Feb 14, 2013 1:52 am
Quoting wingman (Reply 12):
Me think that JAL, NH, UA and others must be ranting as much, after all they have few planes grounded.
bkircher
Thu Feb 14, 2013 3:07 am
I still don't see the point in an upgraded 777.
Stitch
Thu Feb 14, 2013 3:23 am
Quoting bkircher (Reply 15):
Competition from the A350.
divemaster08
Thu Feb 14, 2013 4:59 am
While i can understand the benefits of the folding wingtip, may i play devils advocate here and ask an interesting question perhaps.....
So we understand the reason for the larger wing and raked wingtips, the folding mechanism to allow it to use smaller gate spaces (same as current T7 gates) but what about maintenance costs? It would surely require some strong locking mechanism to support it when inflight and (here is the devil), what effects could it bring forth if said mechanism was to fail in flight?
While there would be increased drag on one side, could it affect the aerodynamic flow enough to cause some serious troubles? Or at least divert the flight?
Ok enough bad thoughts, Go Boeing!
My dream, is to fly, over the rainbow, so high!
ferpe
Thu Feb 14, 2013 5:53 am
Quoting divemaster08 (Reply 17):
The plane is full of surfaces that are not allowed to fail in flight, this would just be another one. Further if the locking mechanism would fail the tip would fold up, as the ailerons are not affected the frame would still be OK, a bit of aileron trim and that is it. For landing you need to increase the approach speed a bit. Plane has landed without wingtips for decades where even the aileron is gone. Slats, flaps, ailerons, spoiler would all be intact, ask an experienced pilot and he would say there are greater worries.
The folding wingtip being the a dead piece of CFRP with the most active component being the (LED) positioning light is a smart idea solving a lot of problems and causing few.
Non French in France
PIEAvantiP180
Thu Feb 14, 2013 7:18 am
Probably none what so ever, we have seen plenty of pictures with 747, and A330-340 missing a single winglet on one side due to ramp damage and still fly its mission till they can put on a replacement.
XT6Wagon
Thu Feb 14, 2013 7:28 am
Quoting ferpe (Reply 18):
I suspect that if it is implemented Boeing will design it such that it is positively locked in flight, and the failure of it on the ground will be a cost issue, not a safety issue. If it fails to fold or unfold it will be safely on the ground where MX can deal with it.
rotating14
Thu Feb 14, 2013 7:46 am
Remember that Boeing builds F-15's and F-18's, both of which have folding wings to fit beneath the flight deck of aircraft carriers. Equally I have never heard of an instance when a fighters wings being compromised during dog fighting exercises/missions so my guess is that it should be just fine.
KarelXWB
Crew
Thu Feb 14, 2013 8:33 am
Aspire Aviation has an excellent analysis on the 777X.
- 800lbs weight penalty for 777X folding wingtip, compared to 3,200lbs for 777-200 study in 1995
- Folding wingtip contains no moveable parts, to be operated electrically
- 777X has same wing span as 777-300ER on the ground & stay as ‘Code E’ aircraft, ‘Code F’ on runway & in the air
- Folding wingtip to be certified in ‘folded up’ position
- 777X wing boasts ’4th-generation’ CFRP wing, 12% better L/D than -300ER
- No engine decision being made for 777X, originally due in December
- 21% lower block fuel burn per seat and a 16% lower cash operating cost (COC) per seat over today’s -300ER
Full article: http://www.aspireaviation.com/2013/0...87-10-unfazed-by-787-battery-woes/
[Edited 2013-02-14 00:34:12]
flyingturtle
Thu Feb 14, 2013 8:34 am
Looks like variable-sweep wings...
...wait, this is the Boeing color scheme...
This picture doesn't show the folded wingtips, does it?
David
TP313
Thu Feb 14, 2013 9:31 am
If/when launched, this would be the perfect 744 replacement.
Has anyone here estimated how the CASM numbers of the 388 do against the 779X CASM?
Maybe it is time for Airbus to start seriously working on an A389...
I don't even talk about the 748i, because the minute the 779X is launched the 748i is dead.
OTOH it don't see much of a market for the 778X...
neutrino
Thu Feb 14, 2013 9:52 am
Quoting rotating14 (Reply 21):
Nitpick:
1) F-15s are not naval fighters and do not need/have folding wings. A version for the navy was proposed but it got nowhere.
2) The reasons for the folding wings of carrier-borne aircraft are multifold; they save space in the tight confines of both the flight deck and the hanger bay, and to better fit in the elevators between the flight deck and hanger. The last is of utmost importance as the lifts' dimensions dictatate what it can physically accomodate.
Potestatem obscuri lateris nescitis
RubberJungle
Thu Feb 14, 2013 10:04 am
No six-wheel bogie on the 787-10 main gear either.
Jack
Thu Feb 14, 2013 10:11 am
Quoting KarelXWB (Reply 22):
How much of this is due to the increased size/number of passengers that can be carried and how does this compare to the A350-1000?
If, and I guess a big if, Airbus can do a A350-1100 then the 777-9X could turn out to be the next A340-600. A great plane but undone by an even better one.
[Edited 2013-02-14 02:15:04]
ferpe
Thu Feb 14, 2013 10:19 am
Quoting Jack (Reply 27):
I have modeled both, I prefer to compare their fuel burn per 1000nm and m2 to get by the hazzle of seating. In such a case the 350-1000 is at 41.3 kg/knm/m2 and the 779X at 39.5 kg/knm/m2. Pretty damn close. They are both in the 8400nm - 8500nm spec range, one in detailed design and the other in ppt design = your mileage may vary  (for both  Wow! ) .
The attractive part with the 779X is that it seats 50 pax more and more LD3s, ie it will be the true gap filler to the A380 in the market (the 748 is dead then). I think part of McNerneys playing down the availability of the 779X was to give the 748i a second chance to close some sales campaigns, seems to not have worked thus the re-vindication of the 779X availability now. Todays A380 is at 50 kg/knm/m2 so it will feel the heat of the 779X as well come 2020.
[Edited 2013-02-14 02:27:01]
TP313
Thu Feb 14, 2013 11:17 am
Quoting TP313 (Reply 23):
Quoting ferpe (Reply 27):
Well, that addresses my doubt...
garpd
Thu Feb 14, 2013 11:30 am
Quoting neutrino (Reply 24):
Nitpick:
In this case, it doesn't matter why the wings fold. I think what rotating14 was trying to impress upon is us that Boeing has experience with folding wings which endure far higher G-Forces than a passenger jets wings should ever encounter. Therefore they should know what they are doing.
In fact, I'm willing to bet the mechanism involved will probably be identical to that on the F18 (with a few teaks and extra fail safes.)
[Edited 2013-02-14 03:33:35]
arpdesign.wordpress.com
SASMD82
Thu Feb 14, 2013 11:39 am
Quoting bkircher (Reply 14):
Actually me neither. With the 77W still selling as hot cakes and with a backlog of so many frames, is it really feasible to go for a 777NG before 2020? I see a point of restarting the Y projects (or starting to think about a new 150-220 seats air frame).
travelavnut
Thu Feb 14, 2013 11:55 am
Quoting KarelXWB (Reply 21):
Does this mean they will actually fly with them folded up? That must look really awesome
Live From Amsterdam!
something
Thu Feb 14, 2013 12:11 pm
Can someone with greater insight to the intricacies of engineering explain to me why those wingtips would fold up instead of down? I would imagine that the mechanism required to move them would be equal, but that it'd require less reinforcement of the wingarea if the tips folded downwards because their ''hinges'' would prevent them from snapping upwards once airborne. No?
By the by... 2/3 of the rendering are boring aircraft. The other third doesn't sell.
..sick of it. -K. Pilkington.
CXB77L
Thu Feb 14, 2013 12:22 pm
The original proposal was a far heavier and far more complex version of the one proposed for the 777X. There are no control surfaces in the section that is being folded up.
Isn't it obvious? It's two fold: First, to counter the threat from the A350-1000. Second, to cater to the increasing demand for larger long ranged twin jets than the 777-300ER. The fact that some airlines are beginning to cram as many seats as they can into a 777-300ER is an indication that a bigger plane is needed. As the A350-1000 is roughly the same length as the 777-300ER, and narrower, it doesn't fulfil that demand.
Quoting divemaster08 (Reply 16):
Presumably it will simply stay locked down and not fold up after landing.
Quoting Jack (Reply 26):
I think that's as unlikely as a further stretch to the 787 beyond the -10. There are limits to how far an airframe can be stretched before it begins to be compromised by weight.
Quoting SASMD82 (Reply 30):
Why not? The 777-300ER might be selling like hot cakes now, but that could change when the A350XWB enters service. For Boeing to stay competitive in this segment, they need to launch the 777X.
Boeing 777 fanboy
3rdGen
Thu Feb 14, 2013 12:26 pm
Quoting travelavnut (Reply 31):
Yup, maybe a new type of anti lift device!
But on a serious note: I can see a lot of airlines that will be hesitant to take them with folding wingtips. This is a serious leap in technology, and one that will be slightly uncomfortable for the less adventurous airline executive. Especially after whats happened with the 787. Not saying that its Boeing's fault or that the problem won't eventually be solved, but it just makes one risk averse. Why take an airplane which is using untested technology on a commercial jetliner when you can take another one which is far less "innovative" and sticks to the basic tried and tested formula, i.e. A350
Case in point, the current 777. As many have mentioned it has already been offered with folding wingtips in order to lower aircraft ICAO class, yet no one opted for it? Boeing needs to make this aircraft competitive with non-folding wingtips, i.e. as a class F aircraft so that those who are hesitant about taking it with the folding wingtip will still see a competitive cost effective aircraft.
لا اله الا الله محمد رسول الله
CXB77L
Thu Feb 14, 2013 12:32 pm
Quoting 3rdGen (Reply 34):
The two concepts are different. No one opted for folding wingtips on the original 777 because of the weight and fuel capacity penalty. The 777X folding wingtip mechanism weighs less (363kg vs 1,450kg for the original, according to the Aspire Aviation article linked to in Reply 21) and does not carry a fuel capacity penalty.
[Edited 2013-02-14 04:34:21]
Boeing 777 fanboy
KarelXWB
Crew
Thu Feb 14, 2013 12:34 pm
Quoting CXB77L (Reply 33):
   John Leahy already stated that there will be no further stretch beyond the -1000.
Revelation
Thu Feb 14, 2013 12:47 pm
Quoting Stitch (Reply 15):
Agree that A350 is giving the 777X the push it needs to be done sooner rather than later. A350 will have state of the art engines and the GE90s of the 777W are due for a re-do.
Keep in mind that Boeing's disappointment with 748 is shared with GE, who isn't shifting as many GEnX's as hoped.
Quoting something (Reply 32):
Would seem to be the best from the point of view of safety of ground handlers and to avoid dings from all the various vehicles scurrying around the ramp.
Also allows one to not worry about taking out runway lights, signage, etc whilst taxiing.
777sigfan
Thu Feb 14, 2013 1:49 pm
Impressive looking lineup there, sadly as many other have noted the launch of the 9X will render the 8i dead. However do you think the launch of the 787-10 will do the same to the 777W? Or is it aimed at a different market segment?
CXB77L
Thu Feb 14, 2013 1:55 pm
Quoting 777sigfan (Reply 38):
It's aimed at a different market. The 777-300ER will have roughly 1000nm more range than the 787-10, not to mention the fact that the 777-300ER is bigger - the fuselage is both longer and wider than the 787-10.
The 787-10 is a medium to long range A330-300 replacement. It is not as big nor as capable as a 777-300ER.
Boeing 777 fanboy
3rdGen
Quoting CXB77L (Reply 35):
OK Thanks for the clarification. But from my vantage point I still feel that there will be companies that are hesitant to take on this new technology regardless of costs, simply because of the risk averse nature of some companies (especially those in ME and Asia). So that's why I feel Boeing needs to ensure that this aircraft is still competitive if it operates in the Class F size category.
Quoting Revelation (Reply 37):
Might also be the case that with the wingtip folding upwards if the system failed it would cause the wing tip to naturally drop into the extended position, or mechanics may be able to release safety latches and lower the wing tip into the extended position which would allow for the continuation of operations, albeit at a slightly higher cost. With the wingtip folding downward there would have to be a system to keep it up, with undesirable consequences if it failed.
CXB77L
Thu Feb 14, 2013 2:04 pm
Quoting 3rdGen (Reply 40):
Why wouldn't it be? If Boeing produces a folding wingtip for the 777X so it can fit in Class E airports and gates, then the only penalty is a little weight and a little complexity. If Boeing do not offer a folding wingtip, it will be a little lighter. The difference in weight is almost negligible, thus the difference in performance is also going to be negligible.
Boeing 777 fanboy
3rdGen
Thu Feb 14, 2013 2:14 pm
Quoting CXB77L (Reply 41):
True. I think I simply thought that the difference in being able to operate the aircraft in as a class E aircraft within an airport would lower airport charges, but then its based on weight and not size, so it makes no difference. And in any case most major airports today are ready for Class F anyway after the A380s introduction. I guess Airbus better get it right with the 350-1000.
something
Thu Feb 14, 2013 2:17 pm
My understanding of physics is admittedly not in excess of the bare basics, but if such a wingtip were locked into ''flight'' position - wouldn't it be kept that way once airborne and conversely, be pushed upwards by the lift the wing generates back into somewhere between the ''flight'' and folded-up-resting position? If wings droop downwards, the lift will bend them upwards. If they were to be bent upwards, force would be required to keep them down during flight, no?
I understand the ground clearance argument and considered that possibility myself - it just surprises me that potential negligence of ramp staff is concerned in the design of airliners. If wingspan is only an issue at the stands, the wings could remain extended until entering the parking position.
Again, I have no idea what I am talking about here. I just assume (intuitively) that it'd require incredible force - ie, reinforcements of the wing - to keep that wing-tip from being pushed upwards during the flight. Even more so in heavy turbulence. That ''lock'' would have to be incredible strong (= heavy) if the leverage from the wingtip all the way to the lock inside the wing is considered. If the wingtips were to simply flap down, the force of the lift would be absorbed by the hinges of the wingtips. Those will exist either way.
It would be nice seeing this become a reality. Maybe even on an eventual A380-1000.
msp747
Thu Feb 14, 2013 2:48 pm
Why do you assume that a stretched A350-1000 would be so much more efficient than a 777-9X? The A350-1000 is already testing the limits as a stretch, and some airlines have spoken up about their unhappiness with the specs for its performance. If the A3510 is such a great airplane, then why are airlines like EK pleading with Boeing to launch the 779X? Do you really think stretching it again would be that simple, without running into weight and performance problems? Personally, I think the -1100 would be the A346 of the bunch, not the 779X. By trying to cover too much territory, Airbus would have 2 under-performing planes (A358 & A3511), an excellent one (A359) and a very good one (A3510)
vzlet
Thu Feb 14, 2013 2:56 pm
I'm always surprised at how simple and small most wing folding/locking mechanisms are. (And, in most cases, they're responsible for much more than just the tip.)
Photo © Mark Carlisle
"That's so stupid! If they're so secret, why are they out where everyone can see them?" - my kid
Stitch
Thu Feb 14, 2013 3:16 pm
Quoting 3rdGen (Reply 42):
The reason for folding wingtips is to allow the 777X to fit into the same gates as the 777 family does without airlines or airports needing to adjust the position of adjacent aircraft.
JAAlbert
Thu Feb 14, 2013 3:28 pm
Will the 777-x sport the new gtf type engines? I've read that the gtf engines are believed to become more efficient as they increase in size - if so, the 777-x would have a tremendous advantage using gtf technology.
Stitch
Thu Feb 14, 2013 3:32 pm
Quoting JAAlbert (Reply 47):
Pratt has stated they will not develop a GTF for the 777X. Rolls appears ready to bid, but I expect Boeing will sole-source with GE using the GE9X (or a derivative thereof).
3rdGen
Thu Feb 14, 2013 3:50 pm
Quoting msp747 (Reply 44):
Absolutely, didn't think about that.
Does anyone have any idea about the proposed lengths of the -8X and -9X? I have also read about a proposed Extend rang -8LX, that will have the longest range of any aircraft in service. Just wondering what differences Boeing will incorporate in the -8LX to give it the range advantage over the -8X?
[Edited 2013-02-14 07:52:39]
