KarelXWB
Crew
Boeing Shows 787-10X Details
Wed Feb 13, 2013 9:03 pm
Randy Tinseth's today's briefing shows the 787-10X details for the first time.
(picture uploaded by http://twitter.com/jonostrower)
No word yet on EIS or first customers.
[Edited 2013-02-13 13:04:36]
Stitch
RE: Boeing Shows 787-10X Details
Wed Feb 13, 2013 9:09 pm
The 787-9 is a 6m stretch of the 787-8 and it added four LD3 positions forward and 4 LD3 positions aft (going from 28 to 36). A 5.5m stretch should offer at least another 6 LD3 positions, not 4. I wonder if Boeing is leaving space aft for a larger Section 45 to support larger gear with a future HGW model?
Zkpilot
Wed Feb 13, 2013 9:20 pm
Quoting Stitch (Reply 1):
Or it has added belly fuel taking up space
57 types. 38 countries. 24 airlines.
ikramerica
Wed Feb 13, 2013 9:23 pm
Or for weight, balance and structural integrity they are "blocking" the most forward and rear positions to decrease on moment? Simple stretches are not simple when it comes to added flex and moment.
Stitch
Wed Feb 13, 2013 10:26 pm
Quoting Zkpilot (Reply 2):
I would expect the 787-10 to have the same fuel capacity as the 787-8 and 787-9 (~126,000 liters) for, like the 787-8, the 787-10 will be fuel-weight limited at MTOW so it won't be able to load that much fuel, anyway.
I would expect Boeing will extend Sections 43 and 46 for the 787-10 just as they did for the 787-9, so I would think they'd be able to get a similar number of LD3 positions from said stretch.
[Edited 2013-02-13 15:06:17]
behramjee
Thu Feb 14, 2013 1:05 am
Too few passengers for my liking versus B789...B781 should be increased to 340-350 at least !
rj777
Thu Feb 14, 2013 1:16 am
I heard that the 7810 might have a 777 style 6-wheel landing gear truck. Anybody know anything about that?
Stitch
Thu Feb 14, 2013 1:26 am
Quoting behramjee (Reply 5):
The step change from the 787-8 to the 787-9 is 40 passengers, so another 40 from the 787-9 to 787-10 seems appropriate.
Quoting rj777 (Reply 6):
As the various weights are the same as the 787-9, a triple-axle bogie is unnecessary.
However, if Boeing increases those weights, then yes, a triple-axle bogie may be necessary or desirable.
[Edited 2013-02-13 18:16:50]
Dash9
Thu Feb 14, 2013 4:19 am
Well, LD3 are side by side, they go in pairs. A new fuse section is added on both ends of the wingbox so I assume they could either fit in 2 extra LD3 per section (single pair, side by side), or 4 extra LD3 (two pairs). Both sections gives you either a total of 4 extra LD3, or 8. Can't have 6, that would mean a pair of half-LD3 in each section.
Thats the way I see it!
-Dash9
thegeek
Thu Feb 14, 2013 4:40 am
Range for payload then. Hmm. History hasn't looked too kindly on such a plane except for 747 Classic vs 747SP.
Perhaps the extra length is long enough for 1.8 LD3s forward & aft, left and right. What I'm trying to say is maybe it falls just short of the required length, and they are unwilling to shuffle the extension forward/aft due to balance issues.
Andrensn
Thu Feb 14, 2013 4:47 am
Quoting Stitch (Reply 7):
It will also give the 777-8x a better business case because there will be a bigger seat count difference
[Edited 2013-02-13 20:49:05]
swallow
Thu Feb 14, 2013 7:25 am
Quoting Stitch (Reply 4):
My understanding is that all 787 variants are fuel-weight limited at MTOW, but the 789 can tank more fuel than the 788 (higher MTOW) and 7810 (lower MZFW). Correct?
The grass is greener where you water it
ferpe
Thu Feb 14, 2013 7:31 am
The cargo capacity change with 1 additional row of 2 LD3s in the forward and back holds can be explained as follows:
- the forward fuselage is stretched 6 frames compared to the -9 or 12 frames compared to the -8. Frame spacing is 24''. Normally that would allow 2 additional rows of LD3, here apparently only 1 row of 60.4'' lenght LD3s. The most plausible reason would be that the air conditioning "snake pit" in front of the center wingbox needs to be expanded to cater for the additional pax capacity, this is very tight on the -8 and -9.
- the rear fuselage is stretched 3 frames compared to the -9 or 7 frames compared to the -8. As that is 72'' and a LD3 row takes 60.4'' it only allows one additional row to be loaded, even with the present landing gear being untouched.
Non French in France
ferpe
Thu Feb 14, 2013 7:43 am
Quoting swallow (Reply 11):
You are correct, all have about the same tank volume (126.000 l or 101t) and they all get fuel limited well north of 8000nm if you load them so you can start with the tanks full, ie they are all weight limited in their practical payload-range usage. The rest is a matter of MTOW, MZFW and DOW/OEW, where the -9 has the best range cards and the -10 the most MSP. The -8 is limited in both MZFW and MTOW, expect new weight variants once things settle down.
KarelXWB
Crew
Thu Feb 14, 2013 8:42 am
Quoting ferpe (Reply 13):
The 787-8 should benefit from the weight savings made for the 787-9. We might see new weight variants after LN126.
maxter
Thu Feb 14, 2013 9:08 am
Mmmmmmm, call me cynical, but does this look like a hastily contrived smokescreen to you?
Maybe not, but then again, maybe yes...
maxter
SeJoWa
Thu Feb 14, 2013 9:57 am
Quoting maxter (Reply 15):
The presentation itself may be hastily contrived, but not the underlying data.
Jack
Thu Feb 14, 2013 10:05 am
Quoting SeJoWa (Reply 16):
Due to the 787-8 issues I assume you mean?
It is also a picture taken from an iphone of a presentation, not a copy of the presentation itself. That doesn't help the look of the information.
[Edited 2013-02-14 02:06:45]
CXB77L
Thu Feb 14, 2013 12:06 pm
Quoting KarelXWB (Thread starter):
No real surprises there, it appears to be quite similar to the many rumours of the 787-10 before.
I don't agree. I think Boeing has it just right by positioning the 787-10 in between the A350-900 and A350-1000 in capacity. It is also a shorter ranged (compared with the other members of the 787 family) aircraft aimed at providing maximum fuel efficiency as a medium hauler and is an ideal A330-300 replacement.
Boeing 777 fanboy
UAL777UK
Thu Feb 14, 2013 12:12 pm
Whilst this is all great and i looking forward to many variants of the 787 in the skies, would it not have been more appropriate to keep this under wraps (not go public) until they get the current issues resolved? just my
CXB77L
Thu Feb 14, 2013 12:26 pm
Quoting ual777uk (Reply 19):
It may be that this presentation was planned long before the 787 was grounded, so I don't think this was deliberate timing on Boeing's part. But even if it is, I think it's about time we had some positive news about the 787 family.
Boeing 777 fanboy
garpd
Thu Feb 14, 2013 1:38 pm
According to those details, here is a rough idea of the 787-10 compared to the the 8:
arpdesign.wordpress.com
Stitch
Thu Feb 14, 2013 3:23 pm
Quoting thegeek (Reply 9):
Depends on the competition.
The 777-200 carried more people and cargo farther than the A330-300, but burned more fuel doing so. The market spoke and the A330-300 has outsold the 777-200 by a tremendous factor.
The 787-10 will carry more people and cargo then the A350-900 and should burn less fuel doing so. So for RFPs for medium-range missions (those currently dominated by the A330-300), I expect the 787-10 to be a very strong - and successful - competitor. (The A350-900 will be the vehicle of choice for long-haul missions.)
JerseyFlyer
Thu Feb 14, 2013 4:42 pm
Quoting Stitch (Reply 22):
I agree. It will be interesting to see how Airbus responds. I think there is scope for a "simple stretch" A359 to A3510 length or thereabouts with A359 engines, wing, landing gear etc.
columba
Thu Feb 14, 2013 6:14 pm
or first customers.
From what I read we will likely hear from a customer around the third quarter of 2013
[Edited 2013-02-14 10:15:28]
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
astuteman
Thu Feb 14, 2013 6:39 pm
This is true. That said, the difference in size and weight between the 772 and A333 is very large compared to that between the 787-10 and A350-900, which are only about 6% apart in terms of MTOW.
SWALUV
Thu Feb 14, 2013 8:12 pm
This looks like very, very similar to the 767-400. Is the 787-10 going to replace those as well.
Stitch
Thu Feb 14, 2013 8:50 pm
Quoting astuteman (Reply 25):
At an OEM OEW level, pending "final numbers" for production frames, their looks to be around the same 8-12% spread between the 787-10 and A350-900 as there is between the A330-300 and 777-200. The A350-900 is still going to have the payload over range advantage, but it will be interesting if future variants of the 787-10 can close the gap to the A350-900 as the various MTOW boosts to the A330-300 have allowed it to perform more and more of the same missions as the 777-200ER / A340-300 (Leahey now says the 240t A333 can perform some 95% of the missions of the 77E). (And yes, I am sure the A350-900 will see improvements just as the 77E did).
Quoting SWALUV (Reply 26):
The 787-8 is the direct replacement for the 767-400ER in Boeing's lineup.
[Edited 2013-02-14 13:01:54]
sunrisevalley
Thu Feb 14, 2013 9:23 pm
I have played around with a number of different payload /range options in PIANO-X and I cannot get a fuel load greater than 88t. Seems to me there is an opportunity to increase the MTOW in the future. It takes a MTOW of ~267t, max passenger load and a range of ~7800nm to use max fuel capacity.
panam330
Thu Feb 14, 2013 9:41 pm
Quoting Stitch (Reply 27):
The 'typical' 3-class seat count (according to wikipedia) on the 787-8 is 210. A.net says that the 764's typical 3-class count is 245, with the 763 at 218. The 787-8 more directly replaces the 763, and the 787-9 will replace the 764/77E more directly, at least in terms of typical 3-class pax count.
sunrisevalley
Thu Feb 14, 2013 10:11 pm
Quoting panam330 (Reply 29):
The Boeing ACAP sheets for the 788 show 242 seats in a 3-class layout.
PW100
Thu Feb 14, 2013 10:20 pm
What the 767-400 lacked, was range. So let's see . . .
767-300ER range: 6300 nm*
767-400ER range: 5500 nm*
787-10 range: 6500 - 7000 nm**
* per WIKI
** per John Ostrower tweet
The 787-10 easily outranges the 767-300ER quite comfortably, let alone a 767-400ER.
I think the 8000nm market is getting somewhat over served now. I see a lot of potential for a plane with 767-300ER range +, but with considerable more payload potential, and much much lower seat cost.
Not everybody needs 8000nm+ range, which is just too much plane for many many routes. I'm very confident that Boeing have a winner here!
The problem is not whether the market is there or not, it's more a matter of when Boeing can start deliveries at reasonable rate (they first have to clear a very considerable backlog, and get the 787-9 in service - not to mention the current small 787 issues and production ramp-up.
My 0.02 cents . . .
PW100
SCAT15F
Thu Feb 14, 2013 10:56 pm
I think the biggest problem with a HGW version of the 7810 is the engines. I can't see how there is much more room for thrust growth beyond the 76-78K range without some major modifications per the Trent XWB for the A3510...
lutfi
Fri Feb 15, 2013 1:51 am
Agree with others who say that this looks like a suitable A330-300 replacement.
panam330
Fri Feb 15, 2013 1:56 am
Quoting sunrisevalley (Reply 30):
   Corrected I will stand, then. Thank you.
thegeek
Fri Feb 15, 2013 3:08 am
Don't know how you can say "a tremendous factor". 777-200A + 777-200ER sold 515, while the A333 sold 618. The difference is more than made up by 77F, and there are a few 77L too.
I think the 787-10 is worth doing and will sell some, in the sense that freighters are worth building. Perhaps tech improvements will see its range extended and make it more competitive, as has happened with the A333.
Stitch
Fri Feb 15, 2013 3:22 am
Quoting thegeek (Reply 35):
I was specifically referring to just the 777-200, not the 777-200ER. The sales ratio is 7:1 in favor of the A330-300 (618 to 88), which is tremendous in my book.
The HGW models of the A330-300 have definitely allowed it to win RFPs that were formally only the realm of the 777-200ER (or A340-300). As such, if Boeing is able to create an HGW model of the 787-10 down the road, one wonders if it start winning RFPs that are currently only the realm of the A350-900.
thegeek
Fri Feb 15, 2013 4:02 am
Quoting Stitch (Reply 36):
Ok, but in that case the 777 carried a lot more dead weight to fly a little bit further. In fact, the current A333 flies a full pax load further than the 772A ever did.
rotating14
Fri Feb 15, 2013 5:03 am
Hello folks,
I scrolled the thread and didn't find the link I just posted. It sheds some light on the current topic. Thoughts?
http://www.aspireaviation.com/2013/0...87-10-unfazed-by-787-battery-woes/
astuteman
Fri Feb 15, 2013 8:48 am
Apologies Stitch.
This is all very nice and interesting.
However, the real point I was trying to make here is that the cost per seat difference between the 787-10 and A350-900 will almost certainly be trivially small, whereas the A330-300 had/has a very clear advantage
Ferpe's model in the Tech Ops threads shows the 787-10 with a fuel burn of 0.0393 kg/nm/m2 of cabin, and the A350-900 with 0.0397 kg/nm/m2 of cabin - a difference of 1% per useable area of cabin
godbless
Fri Feb 15, 2013 11:34 am
This is no fair comparison though - the 333 really first kicked off to after it's MTOW was increased which happened a few years after EIC. So it would be 777-200A vs. "A333A".
I guess it's the easiest to conclude though that both A and B came up with pretty awesome birds here
AA777223
Fri Feb 15, 2013 3:59 pm
How I see it is as follows, especially in light of new 777 and 787 info.
787-8 - Direct 764/A332 replacement
787-9 - bookends 77E/L/A333 on the low end of capacity and range, essentially upgrades all capabilities from these models
787-10 - bookends the 77E/A333 on the upper end of capacity, meets range and payload fairly evenly with less fuel burn. Smacks the A358 right on the forehead. Regional competitor, with less range and capability, but much better efficiency, due to being a double stretch, as opposed to a shrink. makes me think of the current relationship between the A333HGW and 77E. The A333 is a little less capable, but continuous upgrades have closed that gap much more than it used to, and leapfrogs the 77E in efficiency on missions within the envelope of their mutual capability.
777-8 - fills a similar capacity role was 787-10, but with much more range and payload, essentially the international aircraft to the regional 787-10. Upgauge 77E/A343/A333HGW replacement. Direct 77L/A345 replacement. Bookends current 77W on the low end of capacity, with upgraded range and payload with similar fuel burn. Goes head to head size and range with A359, but might be a little more capable, with slightly higher fuel burn.
777-9 - bookends 77W/A351 on the upper end of capcity. Delivers upgauge to current 77W missions in terms of capacity, payload and range with lower burn.
This is my armchair analysis, and how I see these aircraft competing in the market. It is not worth much, but I enjoy speculating on these things. Feel free to flame me.
A318/19/20/21, A300, A332/3, A343/6, A388, L1011, DC-9, DC-10, MD-11, MD-80, B722, B732/3/4/5/7/8/9, B743/4/4M, B752/3, B762/3/4, B772/E/W, B788/9, F-100, CRJ-200/700/900, ERJ-135/145/175/190, DH-8, ATR-72, DO-328, BAE-146
thegeek
Sun Feb 17, 2013 2:40 am
Quoting godbless (Reply 40):
Fully agree.
I don't know why the 772A was ever offered, but that's another story I guess.
ikramerica
Sun Feb 17, 2013 3:19 am
The 772 was offered for a few reasons:
Launch customer United wanted it
Japanese customers wanted it
It filled production slots and helped Boeing achieve ramp up by the time a 90k engine was going to be ready to certify on the wing.
The IGW would not be technologically ready in the same time frame, so Boeing wanted to lure customers with a package where they could invest in 772s and train crews and then take delivery of 77Es and 773s and incorporate them immediately into their fleets. This was to compete with the A330/A340 offering from Airbus that was to EIS earlier, and to make the MD11 less attractive because it was a one size fits all tri-jet that didn't fit a lot of missions.
