Thenoflyzone
Transaero To Send 773 (non ER) To LAX
Thu Feb 14, 2013 2:22 am
http://airlineroute.net/2013/02/13/un-dme-s13/
For 3 weeks beginning in April, UN will schedule the 773 (non ER) into LAX. To my knowledge, this will be the longest scheduled flight for a non ER 777-300. 9800km +
This will be right up there in terms of capabilities for a 773. Probably explaining why the 744 is back on the route as of 22 april. Could it be one of the 744's is due for heavy maintenance?
btw, for anyone who is interested, current record holder for the 773 distance wise is TG from BKK to OSL. 8600 km.
Thenoflyzone
us Air Traffic Controllers have a good record, we haven't left one up there yet !!
LAXintl
Thu Feb 14, 2013 2:28 am
Korean did non-ER 773 to LAX for a couple years before its 77W fleet - some 5900miles.
Viscount724
Thu Feb 14, 2013 2:32 am
Quoting thenoflyzone (Reply 1):
DME-LAX is 110 nm further than ICN-LAX.
DME-LAX 5319 nm
ICN-LAX 5209 nm
mel
Thu Feb 14, 2013 3:29 am
FYI, Korean flew the non-ER 773 on ICN-NRT-LAX not ICN-LAX.
NO URLS in signature
Thu Feb 14, 2013 4:21 am
Hi !
UN has had the 773 at LAX several times since they started service so not too surprising.
Still, perhaps they take a weight restriction?
Always nice to see another 777 carrier here at LAX!
Thenoflyzone
RE: Transaero To Send 773 (non ER) To LAX
Thu Feb 14, 2013 12:56 pm
Quoting The777Man (Reply 4):
Well let's see. UN has RR engines on its 773. Meaning on the link below
http://www.boeing.com/commercial/airports/acaps/7772sec3.pdf
We need to look at the payload vs range chart with 90K rated engines. (not much difference anyways ref. the 98K chart)
DME-LAX is 5319 nm great circle, but in reality you're looking at 5700-5800 nm....if not more.
At that distance, a 773 can carry 75,000 lbs of payload. With 371 seats, and a heavy 4 class cabin, you can bet top dollar that there are weight restrictions on this flight, as 75000 lbs doesnt even cover all the passengers and baggage.
The return leg should have no problems, with the tailwind and all.
Thenoflyzone
[Edited 2013-02-14 05:03:40]
Pacific
Thu Feb 14, 2013 1:08 pm
Pretty amazing - it's as believable as flying an A330-300 DME-LAX! While 75,000lbs would cover pax + luggage at 200lb standard weight (on the high, but realistic side), there's the crew, the seats and the catering to add, then factor the winter headwinds. As the OP speculated, perhaps just a stop-gap due to performance limitations.
Flying Belgian
Thu Feb 14, 2013 1:40 pm
There must some serious weight restrictions on the outbound leg.
Don't forget GCM always mentions a certain mileage considering you take a straight route, which isn't obviously the case in real life ops.
Life is great at 41.000 feet...
san747
Thu Feb 14, 2013 11:30 pm
Quoting Pacific (Reply 6):
And SU has done SVO-LAX on the A330-300 actually. Always amazing to see it when it comes in.
Scotty doesn't know...
captainstefan
Fri Feb 15, 2013 2:22 am
Quoting san747 (Reply 8):
If there's any time an airplane is figuratively gasping for breath, I assume it's that A330 on final to LAX.
Long Live the Tulip!
gigneil
Fri Feb 15, 2013 2:29 am
A new A330-300 has a fair bit more reach than a standard 777-300.
NS
Newark727
Fri Feb 15, 2013 2:30 am
Why wouldn't they use the 777-200ER like they have in the past? Have they already done advance bookings or committed the fleet elsewhere or something? I know they've subbed in a 777-300 once in a while before but it does seem on the long side for it.
gigneil
Fri Feb 15, 2013 2:32 am
Yeah TBH, a 777-200ER would be able to heft the same payload on the route.
NS
Thenoflyzone
Fri Feb 15, 2013 3:53 am
Quoting gigneil (Reply 10):
Not quite. At least not before 2015.
http://www.airbus.com/aircraftfamili...engeraircraft/a330family/a330-300/
Current highest MTOW on offer for the A333 is 235 tonnes. max range being around 5500nm.
The 773 has a 6005 nm range full loaded.
The 240 ton and 242 ton A333's dont come online until mid-2015, only then will the range of the A333 exceed that of the 773, and by only 100nm, so no, not a fair bit more.....
http://www.airbus.com/presscentre/pr...ability-to-extend-market-coverage/
Anyways, all of this is academic. The A333 and 773 do not compete directly. The A333's direct competitor is the 77E.
Thenoflyzone
[Edited 2013-02-14 19:59:47]
Fri Feb 15, 2013 4:23 am
Quoting captainstefan (Reply 9):
Quoting san747 (Reply 8):Always amazing to see it when it comes in.
Is that the longest scheduled A330-300 flight?
cedarjet
Fri Feb 15, 2013 10:45 am
If it's such a stretch (pardon the pun) for the 777-300 non-ER, perhaps they do actually tech stop it somewhere? Would only add an hour to the journey and they could go with full cabins and lots of cargo. Then again some posters say they've done LAX with the 773 before so obviously it can do it somehow without bankrupting UN.
As an aside, man are there a lot of Russians in LA.
Thenoflyzone
Fri Feb 15, 2013 3:13 pm
Quoting B747forever (Reply 14):
No, since the aircraft in the schedules is an A332 i believe. They sub an A333 on occasion.
Longest scheduled A333 is SS from RUN to ORY, 9337 km, 5042 nm.
Thenoflyzone
Thenoflyzone
Fri Feb 15, 2013 5:56 pm
correction: even SS has the A332 scheduled. They just got 2 brand new A333's a few months ago, and they sub them occasionally to RUN.
So the next longest A333 flight is TK from SIN to IST. 4682 nm.
Thenoflyzone
Viscount724
Sat Feb 16, 2013 12:34 am
Quoting thenoflyzone (Reply 17):
LH begins A333 seasonal service YVR-MUC in May, 4517 nm, not much shorter.
Sat Feb 16, 2013 3:37 am
Quoting thenoflyzone (Reply 16):
Didnt know that SU had the A332.
