What's Your Opinon On The Regional Jet Craze?
Mon Oct 23, 2000 6:23 am
I'm doing a paper on Regional Jets and would like to know what everyone out there thinks of this current regional jet mania that has occured since 1993? What do you feel are the positives and negatives?
philb
RE: What's Your Opinon On The Regional Jet Craze?
Mon Oct 23, 2000 6:30 am
Positives:
Access to smaller airports and thinner routes made easy for airlines and passengers with the plus of jet travel.
Added frquency on routes gives travellers more choice.
Flexibility to operations managers to downsize one more step when medium size jets are underbooked.
Negatives:
Slow in climb and block airspace at medium jet altitudes.
Added number of flights are not sustainable in the long term either environmentally or in terms of ATC and gate congestion.
To many airlines will be tempted to add frequency by using them on sectors that are too long for pax comfort.
I know these cancel each other out but they are the factors the industry is/will have to face.
Already the major airline agencies and ATC authorities are concerned with the trend.
Best of luck with the paper
VH-OJO
Mon Oct 23, 2000 6:39 am
Incidently, just today I visited the Greenville, SC, Airport (GSP) and was amazed to see nothing but regional jets. There were two CRJs of United Express, one of DL Connection, three ERJs (NW Airlink, AA Eagle and CO Express), plus a Dash-8 and Do-328 of US Airways Express. This was the first time ever, I could only see all regionals, although I do realize GSP is a small airport.
As you mention, there really is a regional jet mania going on right now. I never realized all these carriers even had RJs in their respective fleets. Five years ago they were all turbo props.
ny-jfk-lga
Mon Oct 23, 2000 8:58 am
I'm so into the RJ craze! I prefer the CRJ over the ERJ, but the ERJs are still cool. The RJs are all just too cool!
Bring back McDonnell Douglas & T W A!!
N202PA
Mon Oct 23, 2000 9:11 am
Add to the negative list that they are essentially flying buses. I've been on 8 RJ flights in the last six months, and they are no better than Greyhound--in fact, Greyhound at least gives you a restroom that's actually usable. The restroom on the CRJ is so cramped, it's literally impossible to stand up and use it.
One of the major downsides to the CRJ is that it seems to have been made for people who are shorter than 5'3". The windows are *way* too low (forcing normal-sized peole like me to crouch over to look out), the restroom's too small, the seats are short and too thin, and you have to watch your head for the bins if you're standing up. The CRJ's a beautiful plane outside, but inside, it's less than comfortable; a 737 or a DC-9 would be much more comfortable.
BH346
Mon Oct 23, 2000 9:18 am
Advantages
Smaller plane, more frequency fits in to be flexible.
Hey, its better than a DC-9-15
Quiet
Modern
I find the Avro RJ85 comfy
Avro RJ85 is my fav
Disadvantages
Smaller legroom
Sometimes used on medium-range flights. (Too uncomfortable for a long flight)
BH346
Northwest Airlines - Some People Just Know How to Fly
DCA-ROCguy
Mon Oct 23, 2000 11:58 am
Mostly good, with some bad. Anytime an RJ replaces a turboprop, that's a good thing for the passenger. The turboprop is a substandard product. Passengers have told airlines such resoundingly both in surveys, and with their dollars. Comair and Continental Express are cleaning up with regional jets, as is Atlantic Coast.
However, RJ's are sometimes used to replace full-sized narrowbodies, which may be undesirable to the markets affected. For instance, Delta pulled 722s this summer from Grand Rapids and Dayton and replaced them with RJ's. The 722s, according to Delta's press releases, went to "more lucrative transcontinental routes." GRR and DAY got more frequency with Comair and ASA RJs, so if frequency is your criterion they didn't do badly.
Full-size narrowbodies generally are more comfortable than any regional aircraft, including the RJ's which at least offer jet speed and quiet to their passengers. But I'll take an RJ over ANY turboprop, any day, where available.
Jim K.
Washington, DC
Need a new airline paint scheme? Better call Saul! (Bass that is)
IndianGuy
Mon Oct 23, 2000 12:13 pm
As a passenger what would you prefer for a 2 hr hop to a hub: a single widebody A300 service once a day, or 5-6 70 seat RJ flights spread out across the day.
I would definitely prefer the latter option. It gives pax more freedom to arrange their schedules.
Then again, the RJ revolution means services that were too long for a turboprop service, but too thin to warrant even a 320 run, can now be served with the RJ's.
Hence i think the ultimate beneficiary has been the customer.
desertjets
Mon Oct 23, 2000 12:15 pm
I am going to build off of PhilB's good arguement
Positives
Opens up new markets that were previously unserved
A better equipment choice on longer segments vs. turboprops
for the most part a superior product to turboprops
negatives
they are part of the problem of overcrowded airports (look at LGA's fight over new RJ flights)
for the most part their performance sucks when compared to full-sized jets
they often replace full-sized jet service
for the most part airlines can't/won't offer the same level of service on longer 90 min + flights
The lavs in the CRJ are TIGHT... and this is coming from someone who is 5'9" 140lbs.
Some try to sell the RJ as the end all be all in transportation... however me thinks efforts at high speed rail may be a more efficient means of transporting people.
caribb
Mon Oct 23, 2000 12:23 pm
Overall positive in my opinion.
Airlines have more flexibility by adding these jets. Air Canada for example can fly into smaller markets than it would have been able to with an A319 or DC-9.. thereby giving some cities in the US their first direct international jet service.. Comair's entire success has been based on the introduction of the CRJ. Brazil has developed a much stronger aviation industry because of the EMB-145.. they are also quicker and quieter than conventional turbo props.. I think if they were all taken off the market tomorrw a lot of people would miss them. The world has benefited from their introduction.
DCA-ROCguy
Mon Oct 23, 2000 12:29 pm
Hear hear DesertJets. In the Metroliner corridor, high speed rail would be a huge help, and the market to fund it is probably there. Amtrak says their Acela (whenever it finally starts) will do Washington Union Station--New York Central Station in 3 hours, down from about four on existing trains. They claim 5.5 hours DC-Boston, I think.
Three hours would just about cover driving-or-Metro to DCA, boarding, waiting to take off, flight, landing at LGA, disembarking and fighting crowds to cab stand, and getting to Midtown Manhattan. But air is still the clear winner on DCA-BOS.
The airlines could easily offer code sharing if they wished, and even coordinate schedules. I think ContinentalEWR suggested this for Metroliner Corridor pax getting to EWR for Co's international fights.
IF the market is there, and they can get the track upgraded, in the Northeast at least high-speed rail could be a big help in reducing airport congestion.
Jim
airmale
Mon Oct 23, 2000 6:24 pm
i love those RJs, wish PIA would introduce them in its fleet especially the 328jet
.....up there with the best!
RE: DCA-ROCguy
Mon Oct 23, 2000 6:38 pm
I believe the Acela train won't get off the ground for a while. The start date has already bennn repeatedly pushed back, and the current one is sometime in Dec. IMO; that will not be the final one.
AmtrakGuy
Mon Oct 23, 2000 9:15 pm
The Acela Express will be officially be available on Dec 11. But, it will be once a day each way. However, the next train set will be available in Jan and then more after that..we're expecting to replace all the Metroliner with Acela Express by next summer...better timing and choices.
Yeah, it been one year delayed. We're all are looking forward to see this go off in December. Amtrak is claiming that this will be a "model" for the rest of the country...who kows.
Dave
Mon Oct 23, 2000 11:47 pm
The CRJ700's have the floor lowered and the cabin widened slightly. Additionaly, the windows have been rasised about five inches so they are 'where they should be'.
My experience with the CRJ200 was that is was nice...but a big cramped....the windows, oddly enough, had a lot to do with it since I was bending my neck to see out...
I think we'll see much more favorable reports from the CRJ700 and 900.
