CO764
UA 744 N118UA Been At PEK For Nearly Two Months?
Fri Feb 22, 2013 5:22 pm
Hello all,
I just noticed on Flightaware that N118UA, a 14-year-old UA 747 in the Tulip livery has been stored at PEK for nearly two months, having left San Francisco on January the 3rd. However, planespotters.net still lists the frame as 'Active'.
I would assume that it's maybe getting a new paint job into the globe livery, but doesn't 1.5 months seem a bit excessive for that?
Thanks for any info,
CO764
Stitch
RE: UA 744 N118UA Been At PEK For Nearly Two Months?
Fri Feb 22, 2013 6:19 pm
UA performs their heavy maintenance for 747s and 777s in PEK so that is probably the case here.
SonomaFlyer
Fri Feb 22, 2013 9:43 pm
It could be a paint job and a "D" check. They also might be installing the "streaming WiFi" that is supposed to be introduced to the 744s. Even with all of that, two months is a long time for this work.
jayunited
Fri Feb 22, 2013 9:50 pm
Quoting SonomaFlyer (Reply 2):
How long would a 744 be held out of service for a "D" check what would be the normal amount of time given to maintenance before they would have to have the plane back in service?
SonomaFlyer
Fri Feb 22, 2013 9:53 pm
There are videos out there showing a BA "D" check on a 744 which I believe lasted eight days. That didn't include anything other than the check which in itself is extensive.
Its possible it could last a couple of weeks but eight weeks sounds like they are doing other things to that a/c.
virgin747
Fri Feb 22, 2013 10:05 pm
http://www.youtube.com/watch?v=x_yHtfGH0nI
I guess the answer is at 7:25.... 5 Weeks for a D check.
I'd also watch this video
http://www.youtube.com/watch?v=qqZKpCJEqNE
I counted 5 nights for this repaint of a NWA 747....
So 6 weeks altogether.
jayunited
Fri Feb 22, 2013 10:15 pm
Quoting SonomaFlyer (Reply 4):
I thought a "D" check requires maintenance to strip the entire interior of the aircraft clean so they could inspect every inch of the aircraft looking for things like corrosion, metal fatigue and other things shouldn't that take longer than 8 days for a 744?
trex8
Fri Feb 22, 2013 10:24 pm
Quoting jayunited (Reply 6):
Welshmen (at least those working for BA) work quicker than Chinese!
calpsafltskeds
Sat Feb 23, 2013 12:46 am
I've been following this aircraft, wondering when it would exit PEK. Maybe something was found that requires extra work or that work is not done 24/7 to save money. I had estimated it out of PEK a week ago. There have been other UA aircraft in heavy maint for long periods. 763ER N663UA was in GSO 2months and 5 days, N651UA was in GSO 2 moinths and 3 days.
From following the fleet, paint has not been done off shore, but in VCV, FTW, GLH, and AMA. Same thing so far with WiFi installations (IND, SFO).
sites.google.com/site/unitedfleetsite/
DarkSnowyNight
Sat Feb 23, 2013 1:17 am
Five weeks is about right, providing that many D check items have been taken care of progressively during B, A, & C checks. A real D check on a 747 without these provisions would be more in line with about 11 - 12 weeks. Eight days would be somewhere between a C & B check. Of course, there is nothing like that in real life, with full B's running about 3 - 5 days & Cs running over 2 weeks.
Nobody really does that as most items have their own time/wear limits and can be taken care of progressively or on the line.
Be A Perfectionst, You're Nothing If You're Just Another; Something Material, This Isn't Personal...
strfyr51
Sat Feb 23, 2013 1:29 am
8418, Is in PEK for the Overhaul and Wi-Fi mod. It takes almost 10 days to refit an Aairbus, so it must take considerably LONGER to refit a 747. Y'think??
FriendlySkies
Sat Feb 23, 2013 3:30 am
Quoting strfyr51 (Reply 10):
Why? They aren't adding wifi in the seats, just the antenna, repeaters, and streaming servers.
n515cr
Sat Feb 23, 2013 4:06 am
Quoting FriendlySkies (Reply 11):
streaming servers
That part might be the culprit (I don't recall if the domestic aircraft are getting the streaming servers...assuming no).
calpsafltskeds
Sat Feb 23, 2013 5:09 am
N656UA , 763ER has been in GSO since 12/20/12 , over 2 months.
[Edited 2013-02-22 21:11:18]
B-HOP
Sat Feb 23, 2013 5:15 am
Is this jet the first one to re-fit with wi-fi
? If so, every changes would have to be certified which takes longer, when Cathay re-fit their 744 with the fishbone seats, the first one took 2 weeks longer, as they need every single changes to be certified, once the first one is done, the others would be quicker.
Live life to max!!!
777ord
Sat Feb 23, 2013 12:12 pm
Quoting B-HOP (Reply 14):
No. This will be the second one being fitted with said features. The first one- reg I can't recall-. Is currently doing the SFO-FRA runs. Additionally, two Airbus (4002,4003) are running around with the WiFi and bigger bins. Granted, over 50% of the Airbus fleet has them now.
And, as a side note. UA 744's are now based in SFO, save for the SYD and HKG from LAX and ORD respectively.
tootallsd
Sat Feb 23, 2013 12:28 pm
Don't forget that Chinese New Year happened in the middle of this time span. That could add another week as well.
CALTECH
Sat Feb 23, 2013 1:40 pm
N118UA is in a Heavy Maintenance Visit #2. Had some skin corrosion, skin panel was to be removed and replaced with Boeing approval. All work was halted until the corrosion issues were fixed. ETR was adjusted and it took about 3 weeks to repair the corosion. Her new ETR is FEB 25th if all goes well.
N656UA also had some corrosion issues during it's C15 check. Also there was some repairs that needed addressing. Her ETR is FEB 24th if all goes well.
Heavy checks are that, they are very heavy maintenance. Corrosion finds and repairs add to the ETRs. 8 days for a "D" check ? Maybe just for the inspections. With open up, repairs and close up, no way.
UNITED Would Be Nice
calpsafltskeds
Sat Feb 23, 2013 3:10 pm
N118UA is sked to exit PEK 6864/25Feb
CALTECH, thanks for the detailed info.
777fan
Sat Feb 23, 2013 4:04 pm
Quoting CALTECH (Reply 17):
Is this the time to quip about how their extended stay in PEK (and the toxic smog that envelops it) may compound any preexisting corrosion issues?!
777fan
DC-8 61/63/71 DC-9-30/50 MD-80/82/83 DC-10-10/30 MD-11 717 721/2 732/3/4/5/G/8/9 741/2/4 752 762/3 777 A306/319/20/33 AT
Norcal773
Sat Feb 23, 2013 4:14 pm
Quoting 777fan (Reply 19):
Hahaha.. That's a good one.
If you're going through hell, keep going
LAXintl
Sat Feb 23, 2013 8:32 pm
One more point - just because a plane heads to PEK does not mean the work commences immediately.
Last couple of years, UA essentially has parked aircraft in China for several weeks to even a month or more before any work commenced. This was the case with 744 IPTE mods for example.
quiet1
Sun Feb 24, 2013 9:07 am
I thought I read that UA was also installing AC power ports in the Y seats when they installed the WiFi system on the 747s?
steinberger45
Mon Feb 25, 2013 3:07 am
I worked heavy mx for UAL back in the early 90's on the 747 classic's. 60 days on a heavy visit was not that rare. Corrosion finds always slow down a visit. Requiring parts also takes time. If Boeing didn't have the parts they had to be made or ordered from a vendor. The acft being serviced in China probably make any parts issue difficult.
DTWPurserBoy
Mon Feb 25, 2013 10:20 am
I thought that I had read that more airlines had done away with D checks as they have incorporated these heavy items into C checks and are done as they come up for them.
Qualified on Concorde/B707/B720/B727/B737/B747/B757/B767/B777/DC-8/DC-9/DC-10/A319/A320/A330/MD-88-90
