JoePatroni707
Will QF Go All A380 @ LAX?
Thu Feb 28, 2013 8:44 pm
I seem to remember some time ago that QF had plans to go all A380 at LAX, have not heard anything more. Seems to me that running 2xA380 LAXSYD and 1X LAXBNE A380 and 1x LAXMEL A380 is a bit over kill, also if they did what would become of LAXJFK?
I know that later this year QF will move its LAXBNE flight from T4 back to TBIT to consolodate its operations.
MesaFlyGuy
RE: Will QF Go All A380 @ LAX?
Thu Feb 28, 2013 8:49 pm
Personally, I think if this happens LAX-JFK will remain, just as an a380. It might be cheaper to run it with a 380 making less money, than to have the aircraft sitting at LAX for 14-5 hours.
The views I express are my own and do not reflect the views and opinions of my company.
Sydscott
Thu Feb 28, 2013 9:38 pm
Quoting JoePatroni707 (Thread starter):
There are no plans for this to happen. QF doesn't have any more A380's coming into the fleet for a number of years, their remaining 8 were deferred, and the 12 they currently have are fully utilised on SYD-DXB-LHR, MEL-DXB-LHR, MEL-LAX, SYD-LAX and SYD-HKG. So you'll be seeing QF 744's at LAX for many years to come.
JoePatroni707
Thu Feb 28, 2013 9:39 pm
Too bad one cannot fly on the LAXJFKLAX leg   That would be an awesome A380 trip!
Gemuser
Thu Feb 28, 2013 9:50 pm
I don't believe there was ever a plan to go all A380 at LAX. There were, AFAIK no public statements to that effect.
It is unlikely that AKL-LAX & BNE-LAX were ever planned to be A380. AKL-LAX has since been discontinued, of course, leaving only BNE-LAX & the second daily SYD-LAX with the B744.
With the B744ERs scheduled to around for the rest of the decade I think the second daily SYD-LAX flight will remain B744ER until around 2020 (this is of course the flight extended to JFK).
As for BNE-LAX, who knows? But it won't likely happen until QF get more A380s which is not until the 2016/2018 time frame. It is more likely that you will see B789s operating into LAX before then.
Gemuser
DC23468910;B72172273373G73873H74374475275376377L77W;A319 320321332333343;BAe146;C402;DHC6;F27;L188;MD80MD85
EK413
Thu Feb 28, 2013 10:05 pm
There never have been any plans for ALL US of A flights to be up graded to an A380...
The next delivery of the deferred A380 have been scheduled for 2016 which I believe will enable QF to operate SYD-DFW-SYD without the need of the BNE tech stop... The current frames are capable but not in their current configuration considering QF don't offer F/C to DFW...
EK413
Good evening, ladies and gentlemen. We are tonight’s entertainment!
777STL
Thu Feb 28, 2013 11:06 pm
Quoting mesaflyguy (Reply 1):
It's cheaper to have it sitting on the ground if it's losing money in the air on the JFK tag. Considering that in recent history, the route has fluctuated between the A330 and the 744 - I'd venture to guess that the 380 is probably too much lift for this route. Anecdotally, I've heard the route is buoyed by cargo as the pax loads are typically rather low.
I could see 107/108 go 380 at some point in the distant future, but not 175/176(BNE).
PHX based
Sydscott
Thu Feb 28, 2013 11:53 pm
Quoting gemuser (Reply 4):
I'd say you will see BNE-LAX, SIN and HKG all go to 787 as soon as QF has enough of them in the fleet.
RyanairGuru
Fri Mar 01, 2013 12:01 am
Quoting 777STL (Reply 6):
175/176(BNE).
You mean QF15/16
Quoting sydscott (Reply 7):
The other two definitely, but QF15/16 has been completely full every time I've been on it. While going back to daily will partially make up for the lost capacity, I think that this will remain a 747 route.
Worked Hard, Flew Right
StarAC17
Fri Mar 01, 2013 12:56 am
Does QF still operate LAX-AKL??
IIRC the LAX-JFK route has been operated with a 332 that comes in from AKL so that is an option.
Engineers Rule The World!!!!!
Sydscott
Fri Mar 01, 2013 1:49 am
Quoting StarAC17 (Reply 9):
No. It was dropped last year.
American 767
Fri Mar 01, 2013 2:07 am
Quoting JoePatroni707 (Reply 3):
Even if they were flying the A380 from LAX to JFK you wouldn't be able to do that unless your trip originates or terminates in Australia. Because QF doesn't have traffic rights inside the United States. I don't think you can buy a Qantas ticket just to fly between JFK and LAX.
QF still flies the 744 to JFK, I saw one not long ago.
Ben Soriano
Ben Soriano
RyanairGuru
Fri Mar 01, 2013 2:09 am
Quoting american 767 (Reply 11):
Yep, when they dropped AKL-LAX the JFK tag reverted back to a 744
qf002
Fri Mar 01, 2013 2:40 am
I doubt it will ever happen.
I think we're likely to see existing 744 services to LAX cut back to 789s in favour of a greater focus at DFW, which appears to be going berserk. The 787 will also make SFO a strong possibility again, and would give JQ the range to reach the mainland as well (YVR? LAX at peak times to add Y capacity?).
That said, the focus would then turn to where else QF would use the aircraft. Using 789s to LAX from SYD/BNE would free up 4 aircraft to use elsewhere. Perhaps to DXB/Europe?
Web500sjc
Fri Mar 01, 2013 3:18 am
You can always buy a ticket from JFK to SYD and forget to get on the flight to Sydney...although I imagine that would be a waste of money.
Boiler Up!
MesaFlyGuy
Fri Mar 01, 2013 4:48 am
Yes, that is what he said.
Also, while the 744 is a beautiful sight to see every day from my back yard, there was just soomething about seeing an Aussie a330 flying over into JFK.
cedarjet
Fri Mar 01, 2013 5:36 am
Any chance DFW will go A380?
Sydscott
Fri Mar 01, 2013 6:10 am
Quoting cedarjet (Reply 16):
In 2016, probably. Until then with no new A380's coming into the fleet, no.
EK413
Fri Mar 01, 2013 6:25 am
Quoting EK413 (Reply 5):
EK413
qf002
Fri Mar 01, 2013 6:40 am
Quoting sydscott (Reply 17):
It would be possible with the existing fleet, but it would mean dropping SYD-HKG back to 744s, which seems unlikely.
Alan Joyce has spoken about sending 789s to DFW on numerous occasions in the past, but they aren't due to start arriving till 2016 either. I guess we'll have to wait till then and see what they decide to do.
EK413
Fri Mar 01, 2013 6:51 am
Quoting qf002 (Reply 19):
He fully the issues which grounded the B787 are resolved otherwise QF is going to be in an extremely difficult position with the aged B763's... QF really gambled taking on 2 x NEW aircraft (A380 & B787)...
EK413
SKAirbus
Fri Mar 01, 2013 2:30 pm
Quoting EK413 (Reply 20):
BA are in a worse position... They are receiving both new aircraft around the same time and are the launch customer for the HGW version of the A380.
Next Flights: LHR-OSL (738), OSL-CPH (320), CPH-LHR (321), LHR-HEL (359), HEL-LHR (359)
qf002
Fri Mar 01, 2013 3:45 pm
Quoting SKAirbus (Reply 21):
I disagree. The late arrival of these aircraft hasn't sent BA into meltdown like it has QF, and they have enjoyed a far more flexibile position in covering the gap (ie lots of 77Es, the ability to slip a few 77Ws into the fleet without major training/handling costs, a younger 767 fleet etc).
The A380 will be an easy and smooth transition for BA. The 787 is a far more critical lynchpin in QF's future than BA's, and will have massive ongoing impacts if they don't start arriving this year.
777STL
Fri Mar 01, 2013 5:42 pm
Quoting RyanairGuru (Reply 8):
You mean QF15/16
Sure, whatever. It used to be 175/176 the last time I flew it.
PHX based
EK413
Fri Mar 01, 2013 11:12 pm
Not really as qf002 quoted...
BA have the flexibility within their fleet to introduce B777's as a gap filler with minimal training required while at QF it would mean introducing a totally new type to the fleet...
I just hope the B787 troubles are resolved as I can't imagine what plan B is at QF with another delay of EIS...
EK413
LAXintl
Fri Mar 01, 2013 11:18 pm
Considering the JFK flight rarely goes out with over 200 folks, even the 744 is overkill.
The A330 was the right plane, but with the loss of the AKL route, the feeder was dropped.
To me we likely could see QF drop JFK entirely and send folks on their JV partner AA before we see a mega A380 run LAX-JFK even emptier imo.
a36001
Fri Mar 01, 2013 11:40 pm
Those 747 tags to JFK are full of cargo no?, so with minimal passenger revenue, the cargo revenue makes up for it. The impression I have got over the years from reading here is that passenger revenue is just icing on the cake. Plus it puts hours on the books for the crew, lessens parking charges at LAX, and provides brand awareness to NYC for QF and Australia.
travelhound
Fri Mar 01, 2013 11:42 pm
Quoting LAXintl (Reply 25):
EK send one of their A380 flights (Dubai - Brisbane) from Brisbane to Auckland often half empty. In the early days the flight was lucky to be 25% full. The logic behind the flight is even though the flight might be marginal / loss making, the extra passengers (from New Zealand) who then take the Brisbane - Dubai leg make the economics of the flight work.
It might be a similar case for QF.
RyanairGuru
Fri Mar 01, 2013 11:46 pm
Quoting travelhound (Reply 27):
DXB-BNE-AKL is a 77W not A380, but you are right about half empty A380s from SYD and MEL to AKL.
Anecdotally, and from what people have said on here before, BNE-AKL seems to generate better loads for EK than SYD or MEL
EK413
Fri Mar 01, 2013 11:47 pm
You must be referring to SYD-AKL-SYD which is an A380... EK haven't introduced the A380 on the BNE leg & I doubt we'll see it for a while considering SYD will go double daily A380 come 2nd of June...
EK413
LAXintl
Quoting A36001 (Reply 26):
No not at all. I pulled up the cargo numbers in a thread last year. The LAX-JFK-LAX turns are not heavy with cargo.
QF carriers the bulk of the JFK cargo on its 747 freighter services.
QF parks for free. They have hangar bay at LAX.
a36001
Fri Mar 01, 2013 11:50 pm
Quoting LAXintl (Reply 30):
O well I learnt something today.... haha thanks
LAXintl
Sat Mar 02, 2013 12:01 am
Quoting A36001 (Reply 31):
Yes in 2006 they got into the maintenance business here and got a hangar. They can house 2 744s or a single A380 at a time inside and about 3-4 more on the ramp outside.
Apparently this was first maintenance base outside of Australia.
QF Opens LAX Mx Line @ AA/TW Hangar (by Aaway Feb 1 2006 in Civil Aviation)
EK413
Sat Mar 02, 2013 12:04 am
Quoting LAXintl (Reply 32):
I'm curious as to how cost effective this has been from a maintenance perspective...
EK413
wstakl
Sat Mar 02, 2013 12:39 am
What would the chances be of OF ever reinstating the AKL-LAX route? I always preferred OF over NZ when heading up to the States (mainly due to price) I wonder with the QF/EK deal we may see something happen regarding the rebirth of this route.
thegeek
Sat Mar 02, 2013 1:01 am
Are you sure? I struggle to believe that an A380 would make more money for QF on SYD-HKG than on SYD-DFW-SYD if the latter would be unrestricted for passengers year round. The only conclusion I can draw is that must hit restrictions sometimes.
I expect that what we will see is some flights operated by 747s and others by 787s, as capacity demands. The 747s would ultimately be replaced by A380s when the former is retired. Growth could see A380s sooner though, particularly if they can regain their monopoly on the route.
How full are they regarding cargo? Particularly on the westbound leg.
EK413
Sat Mar 02, 2013 1:31 am
Quoting thegeek (Reply 35):
I'll do some digging around, from memory there was an article hinting the DFW service will receive A380 equipment once the 3 class frames arrive... Today's A380 is capable just not in their current configuration offering...
I've done digging...
Qantas says it will continue to fly Boeing 747s on the Sydney-Texas route and may even introduce the Airbus A380 as demand grows, rather than switch to the smaller but long-range and more fuel efficient Dreamliner when the first of the next-gen jetliners arrives in 2015-2016.
http://www.ausbt.com.au/qantas-consi...a380-for-dallas-fort-worth-service
EK413
[Edited 2013-03-01 17:39:47]
Gemuser
Sat Mar 02, 2013 2:39 am
The reason for the A380 on SYD-HKG is First class yields or so I've been told many times.
Gemuser
thegeek
Sat Mar 02, 2013 3:12 am
Quoting EK413 (Reply 36):
The A380s they are referring to are 573t MTOW versions but the first 12 A380s they received are 560t MTOW versions I think. Open to correction on that, but I'm sure the 13th and 14th A380s which were to fly to DFW are more capable aircraft than all previous A380 deliveries QF have received.
Quoting gemuser (Reply 37):
Interesting. The revenue would have to be fantastic to compensate for restrictions, which actually require more flights on SYD-LAX by 747s to carry the same number of people network-wide.
LAXintl
Sat Mar 02, 2013 4:02 am
Here are the load factors and average cargo tons per DOT reporting released so far for 2012.
I only did the Westbound leg, but time permitting at later stage can do the Eastbound if anyone cares.
JFK-LAX
Month - Pax LF - Avg Cargo LBS
Jan - 54.6% - 6605
Feb - 51.3% - 11785
Mar - 52.1% - 10116
Apr - 68.3% - 9163
May - 52.5% - 8763
Jun - 63.5% - 8778
Jul - 73.5% - 6538
Aug - 55.2% - 10284
(note switch from A332 back to 744 was made in May12).
Btw here is a comment attributed to Alan Joyce about JFK...
"One downside is that, by cutting capacity into Los Angeles, the Los Angeles – New York tag loses about 15% of its feed. Joyce stated that the Los Angeles – New York tag was marginal, so how does reducing its feed by 15% whilst concurrently putting on more capacity (LAX-JFK moves to a B747) add up?"
Also apparently back 2010 QF said there was insufficient feed via LAX even for the A330 operation to JFK.
thegeek
Sat Mar 02, 2013 8:17 am
Cool, thanks for the figures. With an OEW of around 184t and MZFW around 250t and 18t of pax+bags, that revenue cargo is well short of maxed out.
The pax loads then aren't as tragic on LAX-JFK as some have suggested. Seems a loss leader of course.
