KLAXAirport
SNA Airport Thread
Wed Mar 06, 2013 9:13 pm
Anyone have any news about SNA?
How are Interjet and WestJet doing?
How is AirTran on its INTL flights?
Any new flights coming?
KLAXAirport
[Edited 2013-03-06 13:17:30]
FWAERJ
RE: SNA Airport Thread
Wed Mar 06, 2013 9:16 pm
IIRC, WN is discontinuing their MDW-SNA service (again), and US is going from 7x to 5x daily on PHX-SNA.
"Did he really need the triple bypass? Or was it the miles?"
jporterfi
Wed Mar 06, 2013 9:22 pm
Quoting FWAERJ (Reply 1):
This is probably due to competition with WN on the route.
I flew WN from SNA-PHX, and then from PHX-SNA. IMO, it's a good alternative to LAX for people in OC. There has been talk on A.net about WN starting SNA-ATL. Personally, I don't think this is going to happen, because WN already has same-plane service SNA-PHX-ATL, and I don't think that the route has enough demand for WN to directly compete with DL's nonstop service.
LAXintl
Wed Mar 06, 2013 9:43 pm
For new flights, the next formal slot shuffle is not until the fall and effective January 1st, 2014.
Airport will likely release a few temporary slots in June again based on activity numbers if it looks like slots are not being used fully as allocated.
For Interjet - they have been only operating for about 3 full months now but GDL seems to be definitely the stronger of the two destinations they serve.
KLAXAirport
Wed Mar 06, 2013 9:51 pm
Quoting LAXintl (Reply 3):
Do you know how WestJet is doing?
KLAXAirport
BoeingGuy
Wed Mar 06, 2013 10:07 pm
I'd still like to see AS or QX start SNA-SJC flights. LAX-SJC has like 7 carriers now, but SNA-SJC is a WN monopoly on that well trafficked high-tech route.
I would think AS could do well on SNA-Hawaii if they had the equipment. The 738s can't do it westbound without some restrictions and AS's 737-700s aren't ETOPS capable.
I flew an AS 737-700 out of SNA last week and you can barely notice the noise abatement procedure. I noticed that climb power was a little less than normal climb power, but a non-airplane person probably no longer even notices the difference. AS doesn't even announce what they are going to do anymore, like they did on the MD-80s and 734s.
LAXintl
Wed Mar 06, 2013 10:13 pm
Considering WestJet dropped YYC and now only serves YVR and returned a slot we can assume WJ hometown Calgary was not doing too hot for some reason.
I guess kinda interesting as they manage 2x daily to YYC from LAX, plus a YEG nonstop. In addition PSP and SAN also can support service YYC.
PHXFlyer16
Wed Mar 06, 2013 11:29 pm
I was on the 7:15 last night from SNA to PHX. Only about 40 people on the flight. Everyone had their own row. Strangely I did not get upgraded though. I suspect it was because nearly everyone on the flight was traveling for business like I was.
BoeingGuy
Wed Mar 06, 2013 11:48 pm
Quoting PHXFlyer16 (Reply 7):
Lucky you. I was on the 8:10pm AS flight to SEA last Wednesday and it was the "Disneyland Special". Not only was it completely full, but it was a plane full of screaming children the entire flight, especially pre-takeoff. It was one of the most miserable flights I've ever been on from that standpoint (not that AS's crew wasn't great, as usual, and the flight was perfectly on-time and well run).
KLAXAirport
Thu Mar 07, 2013 1:59 am
It would be great to have a SNA-Hawaii flight yet again. Also, Toronto would be great again but I remember being on that flight and the FA said it was unsuccessful. O well...
KLAXAirport
TWA772LR
Thu Mar 07, 2013 2:12 am
Quoting KLAXAirport (Reply 9):
SNA-Hawaii
I think WN is the best hope for that. And I can see it as one of the first 5-7 routes when they start. With UA or DL popping up seasonally every now and then.
And for the sake of the airport itself, I really think the voters should've voted to have El Toro be the new SNA when they had the chance. Many more opportunities with the longer runways and just all-around larger air field.
[Edited 2013-03-06 18:25:16]
Eat 'em up Kats!
LAXintl
Thu Mar 07, 2013 4:19 am
Quoting TWA772LR (Reply 10):
And the community clearly felt the other way, buy a significant majority. (60-40)
Anyhow - even if El Toro was to become a commercial field, its location was bad.
Not only is it located South and inland from the bulk of OC populance as compared to SNA which at the end would have made LAX yet again the preferred alternative for many, studies showed El Toro would have performance restrictions on commercial ops as it sits at the base of hills limiting both ILS operations, and also take-off performance.
FedExFlyerPHL
Thu Mar 07, 2013 4:47 am
With US cutting back on their PHX frequencies from 7 to 5, I wonder if they could/would use those other two to run a SNA-PHL and SNA-CLT daily. I had heard in the past that there was talk of a n/s flight to PHL. If timed right, they could connect to PHL European flights (if an early morning flight) and CLT Caribbean flights (if a red eye). Any thoughts.
Jeff
Home base: SNA, LGB, LAX
PlanesNTrains
Thu Mar 07, 2013 7:27 am
Quoting KLAXAirport (Reply 9):SNA-Hawaii
I might be wrong but I thought only the 738's would be ETOPS-certified? I might be remembering wrong. Regardless, if the 73G's aren't ETOPS, they likely won't be doing this route either.
-Dave
-Dave
TWA772LR
Thu Mar 07, 2013 8:00 am
Quoting PlanesNTrains (Reply 13):
Aloha made it work, even using SNA as a mini-hub to serve CA, NV, and I think even PHX. Are the Air Tran 737s ETOPS certified? If so, they can use those with their business cabin to HNL and maybe even OGG. I really think SNA can support at least 1 daily in the summer/winter to HNL, and 3-5x weekly in the off season.
Besides CO and Aloha, has any other airline at least attempted SNA-Hawaii?
Eat 'em up Kats!
chrisair
Thu Mar 07, 2013 8:29 am
Quoting TWA772LR (Reply 14):
Well, let's look at a few things: WN does not serve Hawaii. WN has not announced Hawaii. Now, considering WN is converting the AirTran 73Gs to WN 73Ws, and they're converting FL routes to WN routes, this is highly unlikely. In fact, I'm going to go out on a limb and say it won't happen.
No.
I assume you took the US flight? WN's PHX-SNA flights are generally pretty full.
PlanesNTrains
Thu Mar 07, 2013 9:20 am
Quoting PlanesNTrains (Reply 13): Regardless, if the 73G's aren't ETOPS, they likely won't be doing this route either.
Aloha made it work
Aloha made it work with 73G's. Unless WN does ETOPS on the 73G's in their fleet, they won't be doing SNA-Hawaii.
-Dave
-Dave
wwtraveler99
Thu Mar 07, 2013 1:59 pm
Quoting LAXintl (Reply 11):
Yes you are correct but it took 3 votes in oder for them to be convinced they didnt want an airport. Many scare tactic were used. If memory serves me correctly the fisrt vote was 60/40 for the airport. Second was just a bit of 50%. The third vote....well we all know what happened. As far as all the performance issuse I am not familiar enough with that in order to comment.
WW
LAXintl
Thu Mar 07, 2013 4:05 pm
Not to rehash the El Toro debate, but it was not just the public that voted against it but OC county supervisors also had a divided voice and could not reach the super majority needed to authorize certain things.
Additionally the airport became a rather messy North vs South battle in OC, with North being far away and pushing for the airport, and the South county residents who passionately opposed the airport as it was in their midst. It was a toxic mess.
Also don't forget, in addition the actual airport vote itself, County residents also strongly approved another ballot measure that required 2/3 vote for approval land use projects including prisons, waste dumps and yes airport. This would have been another hard hurdle to overcome.
Anyhow - in hindsight, I suspect even the pro-airport folks might be thankful they did not build it today. Post 9/11 changed the landscape of the industry, and the El Toro airports business case was very much built around assumption that demand for flights will double by 2010, and triple by 2020. The 7.8mil OC baseline passenger number they were using has barely budged, now sitting at 8.9mil almost 15-years later. Facility might truly have been a costly white elephant.
wnflyguy
Thu Mar 07, 2013 6:34 pm
I just went thru WN's over water/near International training two weeks ago.
During the class we were trained on life raft evacuations for BOTH 737-800 and 737-700.
Questions were asked during class about the 737-700 life raft training.
We were told that Airtran has 12 737-700's that have life rafts.
WN planning on converting them to ETOPS because The current all 175 coach layout makes the 737-800 to heavy for Hawaii Socal ops because of seasonal head winds.
LAS and PHX are out of the question because of weights.
But a sub fleet of 12 737-700 ETOPS will have no restrictions and this also opens the door for BUR and SNA for Hawaii.
The Sub fleet also gives WN the legs to reach central and north south America with ETOPS 737-700 from SNA.
But there also been a lot of talk about WN now switching some 800's orders for 2016 to 900ER to operate Hawaii service also.
wnfg
my post are my opinion only and not those of southwest airlines and or airtran airlines.
USAirALB
Thu Mar 07, 2013 7:16 pm
Quoting FedExFlyerPHL (Reply 12):
There was talk of this last year as well. I am really surprised US doesn't fly SNA-CLT/PHL.
E135, E140, E145, E70, E75, E90, CR2, CR7, CR9, 717, 732, 733, 734, 735, 73G, 738, 739, 752, 753, 762, 772, 77W, 319, 320, 321, 332, 333, 343
LAXintl
Thu Mar 07, 2013 9:05 pm
US Airways already tried SNA-PHL twice and SNA-CLT once.
Did not last long.
US To Fly PHL-SNA (by ContinentalEWR Feb 5 2003 in Civil Aviation)
US Airways At SNA And LGB. (by wnflyguy Sep 2 2011 in Civil Aviation)
