AA77W
Possibility Of A380 & 747 As Tri-Jets?
Tue Mar 19, 2013 9:11 pm
Would it be possible and/or cost effective to design a 4-engine aircraft (ie. 747 or A380) as a Tri-Jet (2 wing-mounted engines and 1 tail-mounted engine)? Many airlines point to the number of engines as an area of significant cost, so seemingly if 4-engine aircraft could be redesigned as a 3-engine aircraft that would reduce maintence and potentially fuel cost?
I realize that there are many factors involved: weight, effiency, fuel-burn, maintence, range, etc. Certainly Airbus and Boeing must have considered a Tri-Jet option when designing the aforementioned aircrafts and deemed it not cost and/or mission effective, but why?
Facts, figures, and productive thoughts are welcomed.
Eljonno
RE: Possibility Of A380 & 747 As Tri-Jets?
Tue Mar 19, 2013 9:23 pm
I seem to remember this coming up in a thread a few years ago.
I think the consensus was that since ETOPS, most twinjets can't do anything that a quad can't : so trijets are pretty much obsolete.
Quoting AA77W (Thread starter):
Additionally having tail-mounted engines makes regular maintenance and checks more complicated from an access perspective (in contrast to wing-mounted engines).
[Edited 2013-03-19 14:25:26]
[Edited 2013-03-19 14:33:06]
Stitch
Tue Mar 19, 2013 9:27 pm
Back in the early-1970s, Boeing considered a three-engine 747-300 as a competitor to the DC-10 and L-1011.
747-300 Tri-Jet Concept
Eljonno
Tue Mar 19, 2013 9:30 pm
Quoting Stitch (Reply 2):
And it looked totally AWESOME!!!! Thanks for sharing!
mjoelnir
Tue Mar 19, 2013 10:09 pm
I think tri-jets have gone the way of inside the wing mounted engines, obsolete.
The only reason for a trijet was the 60 or 90 minutes rule for twins.
American 767
Tue Mar 19, 2013 10:17 pm
It looks awesome I agree. Did any airline show an interest in it? I'm sure Pan Am has, or at least Boeing approached them with the proposal. Back then Pan Am was one of Boeing's most important customer. It would have looked neat in Pan Am's then blue cheat line livery.
Ben Soriano
[Edited 2013-03-19 16:12:15]
Ben Soriano
SpaceshipDC10
Tue Mar 19, 2013 10:19 pm
Although a trijet may reduce fuel costs, regarding maintenance, an engine in the tail could represent more costs than benefits with the way it has to be installed there and all the tooling necessary to reach it compared to under-wing engines. At least that's what I think.
Stitch
Tue Mar 19, 2013 11:40 pm
Quoting American 767 (Reply 5):
That I do not know. However, Boeing determined that the proposal required too much re-design of the 747 platform and did not go forward.
[Edited 2013-03-19 16:41:59]
RussianJet
Wed Mar 20, 2013 12:09 am
Quoting mjoelnir (Reply 4):
Is that really true? Were there powerful enough engines around when the DC-10 and L1011 came into being that could reasonably power a craft of that weight and size as a twin?
✈ Every strike of the hammer is a blow against the enemy. ✈
Stitch
Wed Mar 20, 2013 12:39 am
Quoting RussianJet (Reply 8):
Douglas did consider a twin-engine DC-10 called the "DC-10 Twin" as a response to the Airbus A300. Development studies continued through the 1970s, but the program was shelved when the Japanese (who were approached to help fund the project in exchange for work-sharing) chose to support Boeing's 767 proposal.
LH707330
Wed Mar 20, 2013 3:14 am
The maintenance issues are a big problem, and the design is also suffers from a structural inefficiency by having the engine back there. The #2 engine is heavy, which means you need to move the wings further aft to keep it balanced. Now you've got to have a larger stabilizer to maintain authority because your lever is shorter.
American 767
Wed Mar 20, 2013 3:32 am
Quoting LH707330 (Reply 10):
I believe that was the issue with the design of the MD-11. The stabilizer was a bit too small thus it would be more difficult to control the airplane on landing. I recall two or three Fed Ex MD-11F's that crashed upon landing, one of them in Tokyo because of a wind shear, another in Newark NJ.
Ben Soriano
LH707330
Wed Mar 20, 2013 3:41 am
Quoting American 767 (Reply 11):
That and the high wing loading meant they had high approach speeds and lower margins for error.
thegeek
Wed Mar 20, 2013 4:44 am
I've actually never thought of this limitation. I guess that applies to rear engined aircraft as well.
windy95
Wed Mar 20, 2013 12:50 pm
If it was feasible or cost effective do you not think that they would of done it?
JBirdAV8r
Wed Mar 20, 2013 12:57 pm
Quoting eljonno (Reply 1):
Not to mention it's "expensive" from a weight/structure standpoint to have all that ducting through the tail.
strfyr51
Wed Mar 20, 2013 1:09 pm
If you'd ever had to Change that center engine? You'd know what it's like to NOT have to change one of those "Bad Oscars" the wing engines can be down and up in 6 hours, the Tail engine?? add 6-10 hours. they're not only Not Fun but Dangerous. The "S" Duct robbed efficiency. Not to mention the maintenance of it. better to have the GE90-115 or a GE90-150 than a tail mounted Engine
softrally
Wed Mar 20, 2013 2:07 pm
Very unlikely. As Stitch said, Boeing did consider a tri-engined 747. However, it turned out that too much re-engineering would be necessary that it would not be a viable option. If Airbus or Boeing wants to build a trijet, they will probably start from scratch.
Flown on: 738, 744, 762/763, 772, 77W, 788, A306, A318/319/320/321, A332/333, E145, E190, CRJ700
penguins
Wed Mar 20, 2013 2:19 pm
The Tri-Jets will not make a revival. The necessity for a third engine is no longer present. I even foresee the age of the quad-jet coming to an end as we see huge leaps in engine technology.
canemedicrn
Wed Mar 20, 2013 5:14 pm
What about the Dassault Falcon 7X or 900LX? I know it's a business jet, but it's still being produced. Wonder what the advantage is over a twin such as a Gulfstream IV, etc. A pilot I talked to at PDK in Atlanta compared it to flying a Learjet and said it was like driving a sports car vs family sedan.
I just think they're sexy!
Photo © Stewart K. Marshall
dergay
Wed Mar 20, 2013 5:46 pm
Thankfully they copied the elegant Lockheed for the third engine and not the ugly Dougling method of sticking it in as an afterthought! Fully agree though that beauty is in the eye of the beholder and others may not concur.....
Flown on A300,A310,A318,A319,A320,A321,A330,B707,B720,B727,B737,B747,B757,B767,L382,L1011,C5,DC-3,DC8,
RussianJet
Quoting strfyr51 (Reply 16):
Can you elborate on that? Do you mean dangerous to work on, or dangerous in terms of operating? Which ever one, how exactly is it dangerous? Not disbelieving you at all, just curious for more detail on that.
I can well believe that. What sort of percentages are we talking?
SpaceshipDC10
Wed Mar 20, 2013 5:52 pm
When McDonnell Douglas was still around, they first proposed a trijet MD-12. But around 1992, they changed their mind and proposed a whole new doubledecker quadjet resembling to today's A380. At least part of the reason for that change was the structural and weight problems regarding the rear engine that would have been of course larger than on their previous two trijets. With the MD-11 they used the same banjos as for the DC-10 to fit a larger engine.
AA77W
Wed Mar 20, 2013 7:29 pm
I didn't know about this. Thanks for sharing!!
Quoting windy95 (Reply 14):
Posting this topic is an effort to educate myself, not question the decisions or logic of the manufacturers. Per my original post, I said that Airbus and Boeing must have considered the tri-jet option but decided it wasn't practical -- but what I was really wanting to know was why . . . I certainly appreciate any information you may have to share on the topic!
Quoting penguins (Reply 18):
I agree. In fact, I was thinking while writing the OP that engine technology has advanced quite far, and could foresee a 747/A380 design with two engines down the road.
Quoting SpaceshipDC10 (Reply 22):
I've read about these proposed designs, and that's what sparked my question. Although, I didn't know the full details. Thanks for the info!
Thanks for everyone for the information and the productive/informative responses!
ajhYXE
Wed Mar 20, 2013 8:23 pm
Quoting Stitch (Reply 7):
I recall hearing one major issue had to do with the "hump" interfering with the air intake of the tail-mounted engine. To keep the entire project from going to waste Boeing took what they could of it and developed the 747SP.
If someone chooses to develop a BWB aircraft perhaps there will be a future for trijets. Otherwise I would honestly consider it a "dead" design.
GO RIDERS!
JakeOrion
Wed Mar 20, 2013 8:39 pm
Quoting ajhYXE (Reply 24):
Just thinking the same thing:
Also, there could be a possibility the next super sonic jet could be a trijet:
Every problem has a simple solution; finding the simple solution is the difficult problem.
DarkSnowyNight
Thu Mar 21, 2013 2:28 am
There are limited plausibilities for a trijet out there, but yes, I do not see any further development along quad-jet lines.
Quoting AA77W (Reply 23):
I'm sure that whatever replaces the 748i/779 will be a twin, yes.
Be A Perfectionst, You're Nothing If You're Just Another; Something Material, This Isn't Personal...
LH707330
Fri Mar 22, 2013 6:27 am
Quoting CanemedicRN (Reply 19):
On the Falcons they're low enough that access isn't too much of a problem, and they help with short field ops because of OEI issues (lose 33% vs 50% thrust). I think the Falcon 7 is the largest allowable bizjet out of London City that can make it to New York.
