Revelation
A320neo: PW 1100G Vs. CFM Leap-1A
Fri Mar 22, 2013 3:09 am
We read in Flight Global: How to power A320neo is tough choice for airlines that:
In two years, Airbus has signed 54 contracts for 1,864 A320neo-family aircraft. Each deal is another opportunity for a referendum on the different engine options. So far, the orders almost evenly split between the Leap-1A (35%), the PW1100G (31%) or a selection yet to be made (33%). The CFM option enjoys a clear lead on the smaller of the two variants, including by far the most popular version with the A320neo. P&W is the strong favourite so far on the A321neo, but the number of undecided customers remains strong enough on the A320neo and A321neo to easily tip the lead towards either side.
This on its own would suggest that the PW has favorable characteristics for the A321 and its missions, but is that the case or is it a statistical quirk that will change once the 33% of undecided customers decide?
The article also goes on to point out that airlines face a problem dealing with unknown future maintenance costs with either product, either with PW the unknown cost of maintaining the additional gearing, and with CFM the unknown cost of how durable the new CMC materials will be and the fact that they are using an additional turbine stage that will increase maintenance costs.
It mentions that P&W has recently received Transport Canada certification for a smaller variant of the PW1100G which powers the Bombardier CSeries. Has this resulted in any data that could help us figure out if the PW1100G is meeting its performance targets?
Edit to add that I like the idea that Airbus is adding what I think is "disruptive technology" to the market with the PW GTF. It's not clear if this the reason why RR sold its share of IAE to PW and is now partnering with PW on some future GTF type projects, but still, it's mighty disruptive, especially if the GTF ends up with better performance on the 'neo' than the LeapX.
[Edited 2013-03-21 20:12:22]
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
lightsaber
Crew
RE: A320neo: PW 1100G Vs. CFM Leap-1A
Fri Mar 22, 2013 4:32 am
Quoting Revelation (Thread starter):
Pratt has hinted they're doing 3% better than promise. The NEO engine has a higher pressure ratio and the variable fan nozzle which will both improve TSFC.
But don't write off the GE. I'm a Pratt fan and twice as much a GTF fan. I think the GTF is disruptive technology (I worked on it a decade ago), but that doesn't mean GE doesn't have some of the same in terms of several technologoes:
1. The CMC high turbine. A risk, but that has been a goal of gas turbines since the 1980s...
2. A series of other improvements that improve fuel burn (scalloped compressor).
Airbus adding? The GTF is on the:
1. C-series
2. MRJ
3. NEO
4. MS-21
5. E-jets
And the core is going into the PW800...
Lightsaber
strfyr51
Fri Mar 22, 2013 2:56 pm
The Gearing for the turbofan is right behind the fan disk and will allow the gearbox can be repaired or replaced without removing the engine. The gearing is same principle as Pratt's PW120 series Turboprop engines and a variation of the Rolls T56 engine. It remains to be seen whether the maintenance costs and repair costs are lower as the engine yet in commercial service. but with a Bypass of 12:1?? what's pretty hard to BEAT if it's efficient as they claim. What remains to be seen is whether Pratt up gages the GTF to Large airframe Installation as they have a number of very excellent Cores to draw from in their Fighter engines. and even the PW 2000 and 4000 series cores, This will get interesting pretty quickly.
LH707330
Fri Mar 22, 2013 4:29 pm
I've read that the GTF is slightly heavier but more efficient, so all else equal you should see the GTF dominate on longer range and the LEAP used on short hops.
lightsaber
Crew
Fri Mar 22, 2013 6:44 pm
Quoting LH707330 (Reply 3):
I've read the opposite on weight, however GE is trying to reduce the fan weight.
http://airinsight.com/2011/01/31/the-foundation-behind-the-leap-x/
GE is trying to reduce the weight 1,000lbm, which should give them the advantage, but Pratt will reduce weight to stay competitive. But the LEAP's low turbine has a tremendous number of stages which is going to make it tough to reduce down to the PW1400G's weight.
The LEAP-X and PW1400G had to promise the same fuel burn to enter onto the NEO. Pratt is attempting to beat promise. So is GE.
Quoting strfyr51 (Reply 2):
Pratt recently has started dropping hints the next GTF family will have a gear ratio of 4.5:1 (up from 3:1 of the current GTFs). The only reason to do so is for a larger/slower fan with a tremendous bypass ratio. That only makes economic sense on a widebody. But it also implies Pratt is 3 years from announcing an engine and thus 7 to 10 from entry into service.
   GTF cores scale well to non-geared twin spools, but dedicated twin spool cores are not ready for the compressor pattern factor a GTF produces nor the end of climb heat put onto the high turbine. Those cores are out of date anyway. They would burn another 5% more fuel. Pratt would design a custom core with MTU doing quite a bit on the compressors.
Lightsaber
PW100
Fri Mar 22, 2013 7:23 pm
Quoting lightsaber (Reply 1):
I'm very much intrigued by the CMC. However I'm quite sceptical on CMC rotating HP Blades. As I understand it, GE expects to have CMC HP Shrouds ready for LeapX, but I'm not seeing anything on the Blades. Given the relative huge increase in ITT, they will also have to something on the Blades. That is the real holy grail . . . do you have any insight to share?
And I do share your faboyism on the GTF
Not quite correct. The PW120 (and every PW100 series, including PW150A for that matter), has a relatively simple and straight forward two stage Reduction Gearbox (RGB), with stage 1 having around 5:1 reduction, and stage 2 around 3:1, combing in around 16:1 total reduction. The Power Turbine spins at 20000 rpm, with the RGB output (= prop rpm) at 1050 - 1200 rpm.
The GTF will have a single stage planetary system, pretty much like a PT6A reduction gearbox.
Rgds,
PW100
LH707330
Fri Mar 22, 2013 9:24 pm
Quoting lightsaber (Reply 4):
That article say the Leap will be heavier than the CFM56, but per this article the Leap should be lighter than the GTF. I think the carbon fiber fan and case more than compensate for the additional LPT stages:
http://www.flightglobal.com/news/art...-than-existing-a320-models-350465/
hannahpa
Fri Mar 22, 2013 9:43 pm
What are the thrust ratings for all of the engine choices: CFM, Leap, P&W.
I know the Current Engines:
319: 2 x 24,000 lbs thrust
320: 2 x 27,000 lbs thrust
321: 2 x 33,000 lbs thrust
What are the NEO ratings?
Revelation
Fri Mar 22, 2013 10:12 pm
Airbus adding?
I think the disruption will be felt most keenly in the A320 market as opposed to the others, especially given the dollar value of that market. Look what we've already seen, RR selling off its share of IAE and not having any skin in the narrowbody game, Airbus bringing the NEO to market years earlier and forcing Boeing's hand on the MAX, CFM having to come up with a competitive answer years earlier than they would have liked to thus taking on more risk than they would like to, etc. The other markets are important but in my mind they are precursors to the big shootout over the narrowbody market, IMHO.
If Pratt should over-deliver and CFM should under-deliver in terms of efficiency and maintenance costs, there could be even more disruption.
Good time to make the popcorn!
Lufthansa
Sat Mar 23, 2013 12:52 am
Quoting Revelation (Reply 8):
I'm waiting for this too! Now if pratt succeed (fingers crossed) and manage to significantly outperform the CFM engine
it's going to be ganbusters time for the A320. I'd look for both the US and chinese lines to be expanded in that case. It does sound like CFM are taking the risker option technology wise?
queb
Sat Mar 23, 2013 2:42 am
Quoting hannahpa (Reply 7):
For PW engines:
A319neo = PW1124G = 23,500 lbs thrust
A320neo = PW1127G = 26,250 lbs thrust
A321neo = PW1133G = 32,100 lbs thrust
http://www.pw.utc.com/Content/PurePo...e/pdf/neo_pw1100g_product_card.pdf
