FlyingBattery26
The Future Of Civil Aircraft Propulsion
Thu Mar 28, 2013 7:13 am
I hope this is the right forum... I was just wondering, what is the probability that open rotor engines will replace jet turbofans in the future? I have been doing a lot of reading on the subject, and from my understanding they are more fuel efficient but also slower and noisier than conventional turbofan engines.. they're also quite hideous looking in design. I personally don't like them, and would hate to see them replacing the turbofan jet engine that we all know and love. Would anyone care to comment on this?
For those of you who don't know about these engine types, here's a link: http://www.sustainableaviation.co.uk...en-rotor-engine-briefing-paper.pdf
What they look like:
AA737-823
RE: The Future Of Civil Aircraft Propulsion
Thu Mar 28, 2013 9:44 am
Well, I think the chances WERE good, up until recently.
The open rotor, as you're already aware, offers some distinct advantages, and Rolls Royce was rumors to be kicking the idea round again. But there are also distinct challenges to this design; otherwise, in the thirty years since this idea debuted, we'd have seen the technology employed.
BUT- now, with Pratt & Whitney's geared turbofan design, I think that the wave of the near future will be in designs like this. That is, a decoupled fan, maybe even two stages if engineers find it attractive, geared to the low pressure turbine or perhaps their own turbine stage.
We shall see!
FlyingBattery26
Thu Mar 28, 2013 1:55 pm
The geared turbofan has a much higher bypass ratio, resulting in more fuel efficiency. Surely then it's just a case of increasing the bypass ratio in future designs without resorting to the use of those loud and ugly open rotor engines. I know the new geared turbofan engines on the Bombardier C-series and A320neo will be about 12% more efficient, so hopefully they'll keep updating these engine types until the open rotor has no advantages over the turbofan anymore. Besides the obvious design challenges of the open rotor, I don't think it would bode too well with the flying public, who are comfortable with the current turbofan design, and have been for decades.
Revelation
Thu Mar 28, 2013 3:07 pm
Quoting FlyingBattery26 (Reply 2):
Not necessarily a higher bypass ratio. The main feature is the gear allows the turbine spin much faster than the fan (3:1 on the current PW designs IIRC) so that both spin at more efficient rates and thus require less turbine stages to turn the fan (and in turn less compressor stages too). Because the fan spins slower it's easier to make it bigger too (blade tip clearance is easier to maintain, etc).
There is a limiting point where the weight of the bigger blades and containment system and longer/stronger landing gear doesn't earn its keep.
However we're in the early days of GTF and there were various conservative steps taken to get it to market.
It should be interesting to see where things end up.
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
planemaker
Thu Mar 28, 2013 3:52 pm
Quoting FlyingBattery26 (Thread starter):
Quite frankly, who knows? Even under the best situation we are still at least 10 years out before OR's are "practical" enough to be ready for consideration for commercial use. And, even then, they would need a purpose designed airframe... and if that airframe were to be the two major OEM's next all-new NB then we are looking at an EIS not earlier than 2030.
Much more realistic are the earlier described GTF dominating the mid-term engine market. Both PW and GE will pour money into design improvements, some of which will only be available in 5-10 years.
Further enhancing GTFs is the probability of some form of hybrid propulsion. Boeing last year came out with their Sugar Volt" design for NASA and Aviation Week unveiled some older Boeing patents utilizing hybrid propulsion (they also patented a design for OR powered aircraft with an upper mid-fuse engine placement.)
So, to sum up... still way to early to specify "future" propulsion system (though we may speculate).
Nationalism is an infantile disease. It is the measles of mankind. - A. Einstein
rampart
Thu Mar 28, 2013 6:01 pm
Quoting Revelation (Reply 3):
So, is this essentially the modern incarnation of a turboprop?
this illustration makes sense to me:
http://en.wikipedia.org/wiki/File:Turboprop_operation-en.svg
Except perhaps that with a GTF, the fan is shrouded or cowled. (always?)
In gear configuration, the fan can be displaced (like the turboprop), so that could afford more ground clearance, or more (or less?) aerodynamic prop wash.
-Rampart
lightsaber
Crew
Thu Mar 28, 2013 7:38 pm
Cruise speeds:
Turbofan: Mach 0.78 to 0.84
Open Rotor: Mach 0.7 to 0.75
Turboprop: about Mach 0.6
So open rotors have a future, just not on widebodies. They are most attractive in the 300nm to 1000nm missions. On missions longer than that, the added flight time adds costs and detracts from the experience. On shorter missions, the turboprop has cheaper (lighter, simpler) economics. So there is a market. But not for all missions. No one will be flying LAX-JFK on an Open Rotor. But STN-HHN is a very ideal route.
Quoting AA737-823 (Reply 1):
Pratt is now developing 4.5:1 ratio gearboxes (PurePower so far have all been 3:1 ratio gearboxes) which will compete with Open rotors in many markets.
Ugly has nothing to do with it. Loud is the concern, which is why there will be a cruise Mach speed limit. But without the shroud, the Open rotor is much lighter than the GTF. The shroud does help cruise efficiency, but the Open rotor has a tremendous climb fuel burn advantage. So it will all come down to the market and 300nm to 1000nm is a HUGE fraction of narrow body flights. It will depend on each airline's flight distribution. e.g., B6 wouldn't consider an open rotor by U2 and FR should.
I'm a huge fan of the GTF. It has its niches. But so does the open rotor.
Quoting rampart (Reply 5):
Yes, the concept always has a shrouded fan.
Lightsaber
planemaker
Thu Mar 28, 2013 7:55 pm
Besides fuel cell concepts, Airbus also has an all electric concept: VoltAir...
DocLightning
Thu Mar 28, 2013 8:03 pm
Quoting lightsaber (Reply 6):
There's also a safety issue. A blade-off event in a turboprop can crash the entire aircraft. An open rotor spins even faster and a blade-off would be absolutely devastating to anything in its path. The engine itself can be designed to separate from the aircraft in the event of an unbalance event, but that's also a huge can of worms (sucks to be the poor schmuck under the engine when it comes down). Almost certainly, certification will require that the rotors be aft of any critical aircraft components.
The noise is really the big issue. At a speed of M=0.75, one only need add M=0.25 to the tips (and they're rotating, so that's easy to do) and shockwaves will form. Supersonic propellers have been tried and were immediately abandoned because they would blow peoples' ears out and cause seizures. (Google the XF-84H).
-Doc Lightning-
-Carl Sagan
rampart
Thu Mar 28, 2013 8:15 pm
Quoting DocLightning (Reply 8):
What an epic fail! Why did they even bother? Even back in 1955, one would think that engineers would have anticipated the problems, or at leasted tested the turboprop before installing it??
-Rampart
discovery1
Thu Mar 28, 2013 8:47 pm
How would a blade separation for an open rotor be worse than an uncontained engine failure in a normal turbine? Far as I know all large civil airliners are designed assuming that the blades have essentially infinite energy, and systems placed and designed accordingly. At least they are now.
planemaker
Thu Mar 28, 2013 8:57 pm
On paper, certainly... but realistically? Which OEM and when?
Except in concepts such as MIT's where the fans are buried and the fuse structure further reduces shroud weight.
Then you'll like Boeing's 2010 patent...
http://www.aviationweek.com/Portals/AWeek/TWW/GrahamW/Boeing%20quiet%20open%20rotor-2.jpg
http://www.aviationweek.com/Portals/AWeek/TWW/GrahamW/Boeing%20quiet%20open%20rotor-3.jpg
BMI727
Thu Mar 28, 2013 9:01 pm
Quoting discovery1 (Reply 10):
An uncontained failure in a normal engine is going to go one of two ways: out the front or out the back. The nacelle will hold in a blade that gets tossed. Open rotor of course has no nacelle and therefore nothing to stop a blade that decides to leave.
discovery1
Thu Mar 28, 2013 9:07 pm
Quoting BMI727 (Reply 12):
Isn't that a contained engine failure?
Also related to that boeing patent, check out the 7J7.
http://airchive.com/html/museums/boe...-at-boeing-archive-mid-1980s/19048
lightsaber
Crew
Thu Mar 28, 2013 9:21 pm
Understatement.
Quoting planemaker (Reply 11):
Which OEM and when?
Based on customer mission profile, it is very unlikely for Boeing. However, Airbus has a chance. Will they do it? Obviously not before 2018 (Airbus engineering is too stretched until then.)
But there is a market the Open Rotor will have an advantage. While I *really* like the GTF, I'm not going to dismiss a competitor that has 'legs to walk on.'
I believe that is a bad assumption on MIT's part. The containment shroud must flex a considerable amount and that is not compatible with being part of the fuselage structure.
That is considered a contained failure as discovery1 noted.
Lightsaber
DocLightning
Thu Mar 28, 2013 9:32 pm
Basically must. not. happen. Uncontained fan failures are not permitted and they are part of the design certification process.
Rotors and turbine blades must be designed and maintained so that they will. not. fail. The few cases in which they have done so have often been devastating (UA 232). That QF A380 had a guardian angel watching it. If one of those disk fragments had gone through the fuselage...
...at least it would be a quick and painless way to die.
-Doc Lightning-
-Carl Sagan
planemaker
Thu Mar 28, 2013 9:38 pm
Quoting lightsaber (Reply 14):
Aside from an OR not being ready by 2018, IMO, I do not see A nor B going for OR... whenever OR is ready for "primetime". As you pointed out, They are most attractive in the 300nm to 1000nm missions. So A or B would have to develop a separate program alongside their next all-new NB design... not something that is really feasible.
Don't forget, PW was the engine partner on the design.
PITingres
Thu Mar 28, 2013 9:50 pm
I think you're confusing blade events and rotor failures. An individual blade-out is containable and as far as I know, must be contained to certify. There's a *lot* more energy in the rotor disks; a rotor burst is not reasonably containable, so a disk failure must be improbable to the point of almost-never-happening.
Fly, you fools! Fly!
ChicagoFlyer
Thu Mar 28, 2013 9:52 pm
Is this really true about being aft? I would think that blade-out from an on-wing installation of open rotor, piercing the fuselage may be (relatively speaking) not as bad a blade-out from a rear installation taking out a part of the tail. I.e., it's not component damage but structure damage that is more devastating in the aft installation. (Aircraft is basically crashing in the later scenario)
Quoting planemaker (Reply 4):
The technology has been "10-years away" basically from inception in late 1980s. I am still skeptical. Safety is crucial, and so is the noise in many parts of the world. The fact that RR moved to cooperate with PW on future geared fan projects speaks volumes of the fate of that technology.
planemaker
Thu Mar 28, 2013 10:02 pm
Quoting ChicagoFlyer (Reply 18):
Yes, they've always been just around the corner. BTW, the concept was developed by Hamilton Standard in the mid-70's.
And increasingly so.
I agree. It is too much of a cost and op change for the narrowing benefits.
DocLightning
Thu Mar 28, 2013 10:08 pm
If it's mounted such that it extends aft of the tail, then there is no problem. A blade off will travel forward of the engine very briefly but very quickly find itself aft of the aircraft.
-Doc Lightning-
-Carl Sagan
planemaker
Thu Mar 28, 2013 10:26 pm
Quoting DocLightning (Reply 20):
Or before the tail as per this Airbus patent...
FlyingBattery26
Fri Mar 29, 2013 9:12 am
Pratt & Whitney will offer developed versions of the PW1000G series instead of going down the Open Rotor route. Found this interesting article where they've more or less dismissed OR's, though it's from 2010: http://www.ainonline.com/aviation-ne.../open-rotors-brushed-pratt-whitney
planemaker
Fri Mar 29, 2013 3:22 pm
In the AIN article PW VP states that they will be able to increase the ratio to 5:1 from the 3:1 that you recalled correctly.
In addition, PW will catch up to GE on the materials side. So, as PW VP said, why go into the OR arena when they match the benefits with GTF without any of the considerable drawbacks.
Short to mid term GTFs will dominate... and then some form of electric hybrid propulsion (there are a couple of approaches being researched by OEMs) probably will be incorporated.
lightsaber
Crew
Sat Mar 30, 2013 3:09 am
Quoting planemaker (Reply 16):
Obviously not the A-team.
Quoting planemaker (Reply 23):
I happen to believe that. But if Pratt ignores the OpenRotor, it will estabilish itself. Aircraft and engines are a marathon, not a sprint. Perhaps more like a death march... One has to look at the serious potential of disruptive technology and address the advantages of your technology, or one will lose the advantage.
Eventually, I believe we'll have fuel cells in the cargo hold powering electric propellers. But that is quite a few decades in the future.
Lightsaber
planemaker
Sat Mar 30, 2013 6:16 am
Quoting lightsaber (Reply 24):
None of the OEM's, airframe & engine, are "seriously" looking at it. I just don't see the dynamic that will enable it to establish itself.
Well, you would know.   I believe the GTF was a 22 year effort... and one could make the case that if PW didn't jump on board the CSeries the GTF still wouldn't be hitting the market.
Absolutely! And that is the thing... over the next 5, 10, 15 years there will be advancements in materials science, modelling, manufacturing, etc. But, right now, I believe that PW is holding the best hand going forward.
Electric propulsion, and there are several routes it could go including fuel cells that you highlighted, could be much sooner than we would anticipate at present. I believe that in less than 10 years there will be a societal shift that will take climate change seriously and that will force major, and disruptive, changes to the carbon economy.
woodsboy
Sat Mar 30, 2013 7:38 am
There have been a number of instances where a fan blade was ejected through the nacelle and into the fuselage, it does happen. I believe the total containment has been something that is as new as the development of the engines for the 777 in the mid 90s with use of what I expect was carbon fiber in the nacelle areas that would be next to the fan blades. Back in the early-mid 90s a Rich International L-1011 here in Fairbanks was taxiing for takeoff at FAI when on of its RB211s had what can only be called an uncontained engine failure and threw fan blades through the nacelle and into the fuselage in many more than one spot both into the cargo area and passenger cabin but luckily nobody was injured.
Also the Delta MD88 engine failure in Jacksonville killed a passenger seated in the rear of the cabin next to the engine.
zippyjet
Sun Mar 31, 2013 8:17 pm
See some of my comments on the 90 seat turboprop thread. I find the UDF design novel and still get a kick at seing the works spin (I'm ommitting the P word here). IN the past 30 years technology has vastly improved so I can imagine a UDF design matching the performance of the jets we know and love. This is going out there but I could imagine an HSCT with the massive wing mounted jet engines and these things mounted aftward for subsonic flight including climb and descent.
I'm Zippyjet & I approve of this message!
DocLightning
Sun Mar 31, 2013 8:46 pm
Quoting planemaker (Reply 25):
The big issue that electric propulsion is going to need to get around is weight. There are electric motors today powerful enough to drive a large turbofan. Here's one of them:
They're so big that right now they are used in ships. Now, new materials, advances in new low-resistance conductors, etc. will bring the weight now, but as long as electric motors need huge windings and magnets...
-Doc Lightning-
-Carl Sagan
Burkhard
Sun Mar 31, 2013 8:57 pm
The major criteria for future designs will be significant noise reductions compared to todays engines - and open rotor is just in the other direction...
planemaker
Mon Apr 01, 2013 8:07 pm
Quoting DocLightning (Reply 28):
I believe that we'll see intermediate steps before we see a fully "pure" electric turbofan for the reason you state. First up could be a hybrid along the lines of this GE hFan concept that can operate in just gas turbine, all-electric or combined modes. It would takes off and climbs in combined mode and then cruise in either mode depending on mission profile.
http://sitelife.aviationweek.com/ver1.0/Content/images/store/8/2/289c2826-0fc4-4bcd-b2fd-0a4021b2f666.Full.jpg
Of course, GE has a large electric motor division and is doing a lot of R&D. Last July they unveiled a prototype electric motor for hybrid cars that was half the size for the same energy output but 3-5% more efficient. So we can expect continuing advancement in all areas over the next 10 20 years.
