EK413
Royal Brunei "special" Pushback In LHR?
Sat Apr 06, 2013 12:11 am
Hi All,
Was doing a search of the photo data base and stumbled across an interesting photo... What grabbed my attention was the fact the tug is underneath the B777 towing the aircraft...?
Is this a common practice in LHR while towing aircraft...?
Photo © Patrick Simon
Look forward to everyone's comments... It's a first for me to witness this form of towing...
EK413
Good evening, ladies and gentlemen. We are tonight’s entertainment!
JAGflyer
RE: Royal Brunei "special" Pushback In LHR?
Sat Apr 06, 2013 1:26 am
I don't believe it is possible to attach a towbar to the landing gear from the back. My guesses are either:
A) a tow bar is sitting on the ramp and the tug is not attached to it.
B) the tug and towbar are connected to each other but not to the aircraft. The tug is repositioning to hook up to the 777 or perhaps going somewhere else.
[Edited 2013-04-05 18:27:57]
Support the beer and soda can industry, your recycle old airplanes!
peterinlisbon
Sat Apr 06, 2013 1:39 am
I would guess that it is in this position because it is actually pushing the aircraft forward rather than backwards. I think that the so-called "tugs" don't actually tug, but push and so it couldn't pull the aircraft along behind it. Perhaps it needs to move from the maintenance area to the gate and doing it this way saves wasting a lot of fuel by starting the engines and taxiing.
B757Forever
Sat Apr 06, 2013 1:49 am
Quoting EK413 (Thread starter):
It is common practice when moving aircraft in close quarters, maintenance hangars etc. The aircraft must be equipped with a tow fitting on the aft side of the nose gear.
[Edited 2013-04-05 18:51:54]
The Rolls Royce Dart. Noise = Shaft Horsepower.
SpaceshipDC10
Sat Apr 06, 2013 1:56 am
Quoting jagflyer (Reply 1):
I have seen this several times, at least with 747.
Photo © Howard Chaloner
Photo © Ken Rose
Jetmarc
Sat Apr 06, 2013 5:28 am
Quoting peterinlisbon (Reply 2):
Tugs do tug... witnessed many times when repositioning an aircraft and the tug pulls a plane into the gate. So tugs don't always just push a plane back.
"Sucka, I'm gonna send you out on Knuckle Airlines. Fist Class!!" ~ Mr. T
LAXintl
Sat Apr 06, 2013 5:30 am
Not unusual. Done here at LAX for tight fitting gates.
EK413
Sat Apr 06, 2013 5:57 am
This was a first for me so its interesting to hear its commonly used at ports with tight fitting gates...
EK413
planesavvy
Sat Apr 06, 2013 9:03 am
Most large aircraft have tow bar connections on both sides of the nose gear for this purpose. Used in this case because the aircraft is a tight fit in the hanger and tug would have no space in front of the aircraft once it was inside and would need to get out. Some hangers have tug size doors to let the tug through the nose end when the aircraft is in. Manoeuvring aircraft in and out of hangars is precision and is a responsible skill.
hotplane
Sat Apr 06, 2013 10:43 am
BA often do it in tight spaces.
Lofty
Sat Apr 06, 2013 11:05 am
BA Engineering tugs and crew are allowed to tow underneath as said above to allow access into tight spaces and hangers.
m1m2
Sat Apr 06, 2013 3:03 pm
There is a time-lapsed video online of an AA 777 having an engine change. It shows the tug first towing the aircraft into the hangar and then being positioned as shown in this picture to push it further into the hangar. Sorry, I don't have a link to the video. It's quite interesting to watch though.
ChiGB1973
Sat Apr 06, 2013 3:42 pm
Quoting m1m2 (Reply 11):
http://www.youtube.com/watch?v=aOmCTehtFpI
It's at about 3:35.
M
flyingturtle
Sat Apr 06, 2013 3:52 pm
tonyban
Sat Apr 06, 2013 6:47 pm
Quoting SpaceshipDC10 (Reply 4):
During my college years, I worked part-time at LHR Terminal 3 doing aircraft cleaning. It was fairly common to see the Air India 747s towed in the manner. I witnessed many push backs like this.
Sun Apr 07, 2013 4:40 pm
On a side note, I realized that in CDG, I realized that narrow body planes are pushed back with a remotely controlled "tractor" which is attached to one wheel of the main landing gear:
http://www.youtube.com/watch?v=67G1A-Wsov0
Why is that, and also: are there other airports doing that? Never saw this before.
Interestingly, once the plane is pushed back, and the "tractor" detached, the actual human sits on the device and drives it back, instead of remotely controlling it.
m1m2
Sun Apr 07, 2013 5:03 pm
Thanks for the link guys.
Users browsing this forum: 9vswr, a380787, B777LRF, Baidu [Spider], barney captain, David L, Dutchy, Gemuser, malcolmtucker, notdownnlocked, SyeaphanR, The777Man, User001, usflyer123 and 258 guests
