jfklganyc
JFK: LOC 22L OTS, ILS 13L, Major Delays
Wed Apr 24, 2013 11:41 pm
Once again, the Localizer to 22L is out of service. With fog off the water and southerly winds, the VOR 22L will not cut it.
All traffic being thrown to ILS 13L.
Couple with ATC issues, major delays and mounting cancellations at JFK this evening.
airportugal310
RE: JFK: LOC 22L OTS, ILS 13L, Major Delays
Wed Apr 24, 2013 11:53 pm
When it rains, it pours.
Good thing our flight shows up nice and early and leaves nice and early!
[Edited 2013-04-24 16:55:19]
I sell airplanes and airplane accessories
flyby519
Thu Apr 25, 2013 12:01 am
Thats an ugly configuration. Good luck to anyone going through NYC tonight
These postings or comments are not a company-sponsored source of communication.
dolinja777
Thu Apr 25, 2013 12:03 am
Ah... I live in Brooklyn Heights and there's been lots of abnormal low flying traffic around. I noticed Air France and Fedex and figured that wasn't something going into LGA!
MesaFlyGuy
Thu Apr 25, 2013 12:18 am
Quoting flyby519 (Reply 2):
My dad's friend is sitting at LGA right now not knowing when his NK flight to MYR is going to leave (BTW he shoudl already be in MYR).
The views I express are my own and do not reflect the views and opinions of my company.
B6JFKH81
Thu Apr 25, 2013 12:25 am
Well, this should make for an interesting night at JFK, good thing I get off at 9pm LOL. Is this causing an impact at EWR/LGA as well? I know when they use ILS 13L at JFK, the aircraft are pretty much going all the way to the tip of Manhattan before turning final. Taking a look at the online tracking for JFK, it looks like it would be quite the beautiful approach if it were nice outside....going over the Verrazano, clipping the tip of Manhattan, etc.
http://www4.passur.com/jfk.html
jfklganyc
Thu Apr 25, 2013 1:58 am
Anyone know if they are still landing that way? Metar shows 4R RVR so I am thinking not.
But 180/15 means a good tail wind for 4R
flyby519
Thu Apr 25, 2013 2:09 am
Quoting jfklganyc (Reply 6):
Flightaware still shows aircraft on vectors for 13L
http://flightaware.com/live/airport/KJFK
planesarecool
Thu Apr 25, 2013 3:00 am
I understand enough about JFK to realise that a 13L ILS is abnormal, I know it affects normal operations at LGA, EWR and TEB. But if they still have two runways in use, one for arrivals and one for departures, why does this cause delays at JFK (more so than usual)?
jfklganyc
Thu Apr 25, 2013 3:23 am
The sharp turn to final and the lack of space to manuever aircraft around the final approach area.
Main problem though is that is messes with LGA and EWR and shuts down TEB
FlyDeltaJets
Thu Apr 25, 2013 4:41 am
Quoting planesarecool (Reply 8):
Normally JFK uses 2 runways for arrivals and 1 for departures during the arrival bank and then 1 runway for arrivals and 2 for departures during the departure banks with scattered arrivals on one of the departure runways when flow requires. Even when using the 13's 22L will usually be used for arrivals in addition to 13L.
As of 0037lcl the runway config has switched to the 22s.
The only valid opinions are those based in facts
metsfan1
Thu Apr 25, 2013 1:33 pm
Well from my area (Riverdale/Yonkers) area I could see LGA arrivals going straight out over the Hudson from East to West then making a left over NJ before making another left just south of the George Washington Bridge and landing on runway 13.
I have lived in that area 7 years and have only seen something akin to this landing config maybe 5-6 times. I am sure it happens in bad weather but then the cloud base is so low I can't actually see the airplanes coming in. Was definately interesting.
The strangest I've ever seen was aircraft coming straight down the hudson at about 2000-3000 feet on a clear day (some already gear down) and then making a hard left right around the George Washington Bridge and going into 13 at LGA.
corinthians
Thu Apr 25, 2013 2:05 pm
Quoting metsfan1 (Reply 11):
That’s the River Visual approach. I remember they used that a lot on the weekends about ten years ago when Runway 4/22 was closed for maintenance. I haven’t seen them use it for a long, long time.
ANITIX87
Thu Apr 25, 2013 5:21 pm
Quoting corinthians (Reply 12):
The River Visual is used all the time (and is a route up the Hudson with a right to 13). What MetsFan1 mentioned was planes coming down the Hudson (not up) and turning left into Runway 13. I've never seen this in 22 years in the NYC area.
TIS
jfklganyc
Thu Apr 25, 2013 8:27 pm
On a quiet Saturday, they can make a left to final.
Yesterday was unique.
Because JFK is by the water, it had foggy conditions with somewhat lower ceilings and a south wind 180/15. This would call for ILS 22L. Because, ILS 22L was OTS, they had to throw it to ILS 13L.
Ironically, ceilings were rather high elsewhere so we got to see a good show.
This setup usually only happens in very bad weather with the crosswind component being exceeded on 22L. Maybe 2 to 3 times a year.
N353SK
Thu Apr 25, 2013 9:44 pm
This is a rumor that I can't substantiate, but apparently the only person at JFK qualified to fix the localizer was out on a furlough day.
LAXintl
Thu Apr 25, 2013 9:48 pm
Quoting N353SK (Reply 15):
Such equipment should be the responsibility of the airport, not FAA.
Here at LAX, LAWA handles all such airfield equipment. PANYNJ should do the same at JFK.
Only thing FAA does is calibrate and the required certification test.
metsfan1
Thu Apr 25, 2013 10:53 pm
Just to confirm, yes the aircraft were flying from north to south on that one day. I had never seen it before and have never seen it since (I live on the river).
Come to think of it, it may have been during the U.S. Open this year but I really don't remember exactly when. All I know was that it was a perfectly clear day and I looked out my window and saw that. At first I thought maybe it was a one time thing such as a go-around. However it lasted about 2 hours with one after the other.
