LAXintl
New Istanbul Airport Tender Awarded
Fri May 03, 2013 3:48 pm
A joint venture of Turkish companies have won the tender for Istanbul's new airport.
The Cengiz-Kolin-Limak-Mapa-Kalyon Consortium offered the government €22.1 billion for a 25-year franchise to operate the airport commencing in 2017.
Cengiz-Kolin-Limak-Mapa-Kalyon Consortium beat out the other finalist which were IC-FRAport, TAV Holdings(current IST operator), and another Turkish firm Makyol.
The BOT (build-operate-transfer) project, will be built in four stages, with the government guaranteeing minimum amount of passengers and tariff levels for the operator.
The first phase of construction is set to take 42 months, to be completed in 2017, and provide an initial capacity of 90 million passengers a year. Once all phases are complete the airport will feature 6-runways, and 165 gates at the terminal.
Story:
http://www.worldbulletin.net/?aType=haber&ArticleID=108069
and
http://www.hurriyetdailynews.com/con...38&nID=46153&NewsCatID=344
Clydenairways
RE: New Istanbul Airport Tender Awarded
Fri May 03, 2013 4:08 pm
The expansion of Aviation in Turkey in recent years is quite phenomenal.
mercure1
Fri May 03, 2013 4:46 pm
The growth in Turkey in general - both economic and political has been impressive.
So does this mean airport construction will begin imminently?
kaitak
Fri May 03, 2013 5:16 pm
Quoting mercure1 (Reply 2):
It will have to be fairly soon; 2017 is only for years ago and that's very ambitious for a project of this size.
I assume that the design of the airport has already been finalised, so it's really a matter of moving in the bulldozers and construction equipment.
Are there any plans/diagrams available online?
ImperialAero
Fri May 03, 2013 5:24 pm
Quoting kaitak (Reply 3):
HA! Nope.
Proposed configurations will have been investigated, but no final decision made...remember they designed, built and constructed a ~25Mppa Terminal at SAW in around 18months. The site of the new airport has a massive amount of earthworks required before they can even begin to start building anything so that's a good 18 months of time to do the masterplanning and design before they can start laying concrete, the critical thing to decide though is what the levels of the runways, and hence the required amount of earthworks need to be.
ICURFC - Who Is Sylvia?
United787
Fri May 03, 2013 5:39 pm
Have they planned for a rail link between the new airport and the city?
toxtethogrady
Fri May 03, 2013 5:44 pm
Quoting ImperialAero (Reply 4):
HA! Nope.
I tried to do a Google search on the consortium partners. They don't appear to be big airport operators the way TAV is, so I wonder if they are going to have to import or recruit some airport planning and design expertise to their team. You have to start somewhere, but a 22 billion Euro airport is an incredible gamble.
LAXintl
Fri May 03, 2013 6:07 pm
Some more info out from the tender:
Stage 1 = 2017:
- Main terminal with 680,000sq meter
- Additional satellite building 170,000sq meter - the total capacity of both terminals will be 90mil passengers per year
- 88 jetway contact gates
- Car park for 42,000 cars
- three independent runways
- 3.1mil sq meter apron
Stage 2 = 2019
- additional terminal - 200,000 sq meter
- additional runway + additional high speed taxiways for existing runways
- additional 1mil sq meter apron
Stage 3 = 2021
- additional runway + taxiway systems
Stage 4 = 2025
- additional terminal - 250,000 sq meter
- additional runway + additional taxiways
- Additional 0.9mil sq meter apron
Key facts:
- 1.5mil sq terminal space area
- Capacity of 150mil passengers per year
- 6 runways (4 parallel + 2 crosswind parallel) all VLA capable
- 165 jetway contact gates
- intra-terminal rail connection
- 3 separate maintenance hangar areas
- 8 cargo ramp areas
- Apron space for 500 aircraft spread over 6.5mil sq meters
- Direct airport auto parking lots for 70,000 cars
- Additional adjacent facilities including hospital, hotels, mosque, congress center, waste recycling and water treatment facility.
Image from news paper.
Quoting United787 (Reply 6):
Yes.
lightsaber
Crew
Fri May 03, 2013 6:29 pm
Quoting LAXintl (Reply 8):
Where do runways #5 and #6 go? And that image should be oriented about South. (Please correct if that's off.) I'm assuming the two other runways are to the left (I assume East)?
Its also a slightly different layout than expected. I thought we would see pairs of runways near the terminals with other runways 'further out.' Although, this layout will be easier to expand...
Nice start!    Just about right IMHO for the time frame.
Stage 2 = 2019
Wow.. I was going to comment that Stage 1 wasn't ambitious enough until I noted Stage 2 completes only two years later!    Now that is good planning. Assuming the 20% growth per year continues (or restarts with the new airport capacity).
How is that ratio of auto parking to number of passengers per year compared to other international airports? I respect the new IST will hub quite a bit, but I expected a few more parking spots.
Lightsaber
radiopolitic
Fri May 03, 2013 7:07 pm
Quoting LAXintl (Thread starter):
Yes.
Are we still expecting the 15mins from airport to Taksim as was once claimed?
[Edited 2013-05-03 12:08:18]
northstar80
Fri May 03, 2013 7:27 pm
Quoting radiopolitic (Reply 10):
We're probably looking at 1 hour + 15 minutes   with the fastest possible transportation as the new airport is way far away from the city center.
€22.1 Billion is downright craziness, there is no way they can make €1 billion a year to pay the rent on top of the construction and operating costs. This will turn out to be a disaster - and will probably be financed by the taxpayer later on during the project when government will bail out the crazy consortium.
LAXintl
Fri May 03, 2013 8:09 pm
Quoting toxtethogrady (Reply 7):
Well Limak built Istanbul SAW airport which everyone seem to praise so they are not novices to the airport business.
Anyhow, I am sure the consortiums can bring in subcontractors or subject matter experts as needed.
Quoting lightsaber (Reply 9):
Found this published diagram but it only shows a single crosswind runway, so there was probably a subsequent change.
http://i.imgur.com/46GYQOc.jpg
They say 70,000 airport specific parking spots, so I suppose they also probably envisage off airport lots run my private companies that acquire their own land.
But in Turkey many will reach the airport via rail, bus, or taxi as well.
mercure1
Fri May 03, 2013 8:36 pm
Quoting Northstar80 (Reply 11):
Under BOT model, the airport will become the governments eventually (25-years in this case) anyhow.
So i the consortium defaults a few years early the government simply gets the airport earlier.
I don't forsee problems with running the facility by even the government as long as it gets built without issues first.
So as long as Cengiz-Kolin-Limak-Mapa-Kalyon builts it first, whatever happens to them after probably not end of world. Also once built, I bet there would be a 100 companies that would be happy to manage terminals day to day.
radiopolitic
Fri May 03, 2013 8:58 pm
Of course we are. The 15min offered was a ridiculous standard to try towards.
I still think this is a horrible location for the airport but I guess it's a reality now.
[Edited 2013-05-03 13:59:26]
JoeCanuck
Fri May 03, 2013 9:03 pm
Quoting LAXintl (Reply 12):
In cities where I've had the option, direct rail connections to the airport are fantastic...for me, easily the best way to get to get there.
You don't hear much about Turkey but it's a place that's quietly growing at a fantastic rate...and the same goes for TK. It's just going to keep growing and getting the new IST going shows some good forward thinking. There will be the inevitable delays so the sooner started, the better.
I think TK is the real competition for the Gulf 3. With the huge amount of O&D traffic to Turkey, and an ideal transfer location, they really have a hard to beat combination to really kick some airline butt in a few years.
For now, they are flying under the radar...but I suspect not for long.
What the...?
TK787
Fri May 03, 2013 11:45 pm
Wow, 22 million euros...
Now the real work starts.
Quoting JoeCanuck (Reply 15):
Current fleet of 217
Orders for another 214
Options for 68, All this will in by 2020.
TK carrying 46million pax this year with this fleet size, could be carrying 90million by 2020.
Someone start building now!
JoeCanuck
Sat May 04, 2013 1:44 am
Quoting TK787 (Reply 15):
...and a very balanced fleet from both manufacturers...picking exactly the right plane for the job without worry about playing favourites.
What the...?
AirlineCritic
Sat May 04, 2013 2:52 am
Wow. I guess this settles the question of the A380 order...
bill142
Sat May 04, 2013 3:00 am
Dear United Kingdom,
This is how you solve your airport capacity problems.
Signed
Turkey
JoeCanuck
Sat May 04, 2013 3:49 am
Quoting bill142 (Reply 18):
You owe me a new keyboard.
What the...?
ASA
Sat May 04, 2013 6:26 am
lol - i'm sure it was a typo. Not an M but a B .... x1000
TK787
Sat May 04, 2013 8:10 am
Quoting ASA (Reply 20):
Yes, my typo, Billion.
From the news right after the tender; The construction might start by next year and first phase compilation by 2018.
Hope this works out, it is going to be a very challenging project.
The other part of the puzzle, who is going to build roads, mass transit to this airport which is miles away from population centers. When completed they are expecting 100,000 cars to travel to the new airport daily and they are expecting a total of 850,000kg of garbage daily.
lightsaber
Crew
Sat May 04, 2013 11:57 am
Quoting LAXintl (Reply 11):
Thank you. I agree, there probably was a change. I'm simply excited by the scale of the new airport. It seems neither too small nor too large.
Whenever I consider TK's growth, I wonder how they can manage with the current infrastructure. While Stage 1 will be needed earlier than its scheduled completion date, the growth stages seem at about the right rate.
   Well played sir. If only more economies took their airport capacity constraints as seriously as Turkey/Istanbul has.
Lightsaber
MeCe
Sat May 04, 2013 12:03 pm
Hope this project will not turn a nightmare. Do a simple math, OR-GI airport at blacksea requires 6.500.000m3 of landfill and they can't complete it in 2 years. This airport needs to a massive 2.500.000.000 m3 of landfill which is mostly in forests and water basin area of İstanbul's water supply area. Besides area is selection completely wrong, due to size of enormous landfill, it is nearly impossible to complete on time and budget this project. But never mind, taxpayers will pay happily this project because they have biggest airport. Kanal İstanbul and 3rd airport is only ego driven and completely wrong two projects may kill all development of 10 years
KaiTak747
Sat May 04, 2013 12:31 pm
We better start saving up!
TK105
Sat May 04, 2013 1:38 pm
Quoting MeCe (Reply 23):
I also did a small math for the financial side:
Franchise Cost
22.1 bn Euro
VAT (%18)
4 bn Euro
Construction Cost
10 bn Euro
Financial Cost of Construction (average 3% annual, 75% for 25 years)
7.5 bn Euro
Total Initial Cost
43.6 bn Euro
1.75 bn Euro for each year over 25 years
Annual Operational Cost (I checked TAVHL costs which incl IST+ESB+ADB and considered x2 for this larger airport)
1.8 bn Euro / year
Total Annual Cost
3.55 bn Euro / year
Considering that on average 120M passengers annually uses new airport over 25 years, Contractor will break even if revenue per passenger is 30 Euro.
radiopolitic
Sat May 04, 2013 1:53 pm
is only ego driven
northstar80
Sat May 04, 2013 7:41 pm
Quoting TK105 (Reply 25):
Good calculation! I wonder what is the current IST revenue per passenger, or other large airports..
Couldnt have said better. Waste of money/resources and most important, trees.
LAXintl
Sat May 04, 2013 8:23 pm
According to TAV presentation I have, they made 15.70 EUR per passenger at IST in 2010 just from sales commission fees from all the vendors at the airport.
So EUR 30 seems quite plausible via combination of ticket taxes, airline charges, rental fees plus the improved commission sales.
Also don't forget the government (as it does for TAV at ESB and ADB today) will guarantee a minimum level of revenue for the franchise operator regardless of what actual traffic figures produce.
leftyboarder
Sat May 04, 2013 10:44 pm
Quoting LAXintl (Reply 28):
And that guarantee sums up to 6.3bn euros for the first 12 years of operation, which falls way short of the bid value.
We all want a new airport for Istanbul, but a vanity project that may become a burden we do not... I wish tenders were not awarded solely on price.
