questions
DL JFK T4B: Leading Edge Or Just Better Than T2/3
Mon May 20, 2013 6:03 pm
It's a few days before the much hyped T4B opens. We all know it will not be an architectural marvel. And we all know it will be a big improvement over the current T2/3 terminals.
However to what degree will it be a world class facility?
My sense is it will be better than the current state and will for the most part get the job done, but that most people expecting leading edge in airport terminal design, amenities, and wow factor will be a bit disappointed.
Will it even be the best terminal at JFK?
Thoughts?
FoxBravo
RE: DL JFK T4B: Leading Edge Or Just Better Than T2/3
Mon May 20, 2013 6:41 pm
I guess we'll know soon enough, but I think (and hope) that it will at least be in the same league as T8 and T5, which I would argue are the current "state of the art" at JFK, in different ways. Neither has much of a "wow factor" compared to other airports around the world, but they both work quite well for what they do. T8 is much more striking and impressive in scale, but T5 was very thoughtfully laid out and has great food and shopping despite being somewhat bare-bones. My prediction is that T4 will be somewhere in between. The check-in area should look more like T8 architecturally (though the original sense of space as you descend towards the gates has been compromised by the much-needed relocation of the TSA checkpoint) and I'm excited about some of the concessions, e.g. Shake Shack and Blue Smoke. My concern is that the B concourse may feel a bit narrow and crowded at peak times, although I understand the extension is a bit wider than the original part, which should help.
Common sense is not so common. -Voltaire
Ezra
Mon May 20, 2013 11:11 pm
Funny, I flew in and out of T4 last week and purposefully allowed myself plenty of time for a lookabout on both legs of the journey. The DL portion of the check-in area is looking pretty sharp, although they're still putting the finishing touches on it. DL has also spruced up the existing gates on the T4B concourse with new seating and carpeting, and I'm excited for the reveal of the new construction. I hope that the ceiling height in the new portion is higher than the existing portion; the lower ceilings contribute more to the claustrophobic feel along the existing concourses than does the relatively narrow width. (The existing concourse doesn't feel much narrower than the A or B concourse in ATL, in my opinion. But the ceilings are low!) Lots of new shops and restaurants are going into the mall below the new, consolidated security area. All in all, much improvement is visible all around, although the building doesn't have the same integrated feel as T5 or T8 -- it's clear that it's a retrofit.
It's also abundantly clear that the building has been used hard since its opening and not always maintained in tip-top shape -- the arrivals hall is dingy, cracked floor tiles abound throughout the building, the non-DL check-in areas are in rough shape. The wire mesh used to cordon off the new security area is an unfortunate necessity. The terminal is no architectural masterpiece and the spatial experience is underwhelming and not particularly inspiring, but it's a major, major improvement over T3, which is what really matters. Hopefully DL will continue to spruce up the cosmetics as they get their mitts on more and more of the terminal...
My personal take is that T5 and T8 are on the top rung, followed by T1 and T4 on the second rung, then T7, and T2 at the bottom. (Leaving out the soon-to-be-dead T3.)
MesaFlyGuy
Mon May 20, 2013 11:17 pm
I'm hoping this new temrinal will live up to the hype. I flew out of T3 in January and I have to say it wasn't horrible, but it felt like a few temrinals had been linked together like extensions on a house.
The views I express are my own and do not reflect the views and opinions of my company.
727LOVER
Mon May 20, 2013 11:22 pm
Quoting FoxBravo (Reply 1):
"wow factor"
What terminals around the world have a WOW FACTOR?
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
jfklganyc
Mon May 20, 2013 11:27 pm
I think DL is taking a page out of the B6 playbook with T5. Delta is even calling it T4.
Airy, glass, spacious, lots of amenities.
People rave over T5...look around...not much in terms of architecture.
What DL did is very smart...the terminal was already built. They did minimal expansion to the head house, redid the interior and stapled on 9 gates while taking over the rest of the concourse.
Much better than the AA palace in terms of economics.
So will it be the nicest terminal at JFK? No.
AAs will be nicer.
B6s will be nicer simply because it is solely controlled by B6 where T4 will still be run by JFKIAT and have a whole bunch of airlines in it.
Will it be better than what they have?
Yes and no. Yes for obvious reasons. No because the connections between T2 and T4 are gonna stink. A short walkway will now be replaced by a bus ride.
Will T4 international be nicer than what CO/UA have at Terminal C?
Yes. Only because it will be brand new.
Mir
Mon May 20, 2013 11:40 pm
Quoting 727LOVER (Reply 4):
LHR Terminal 5
CDG Terminal 2F
DXB Terminal 3
PEK Terminal 3
PVG
BKK
ICN
HKG
Those are the ones that come most readily to mind.
The closest thing the US has to a world-class terminal would be DTW's McNamara terminal. Others may be functional, but you tend not to see great architecture.
-Mir
jfk777
Mon May 20, 2013 11:44 pm
Its just an expansion of a 10 year old terminal, its a big Delta deal. Anything is better then the "worldport", T4 makes things better for DL but about the same for all the other airlines at T4.
ldvaviation
Tue May 21, 2013 12:13 am
Quoting jfklganyc (Reply 5):
I am not so sure about that. For what Schiphol, the PA, and Delta are spending on the expansion of T4, AA got much more.
Remember though Delta committed only $15 million or so of its own money, it is nonetheless covering the total cost (plus profit) with the rent it pays Schiphol.
There was no such middleman in the AA transaction. Plus, it has been almost 7 years. The debt on T8 is most likely lower now than it is on T4, which already had $300 million or so in debt outstanding even before Phase 1 of the expansion. And, there is still a Phase 2 to fund.
As to the OP's question, I wonder if in 20 years or so one of the parties to this transaction will recognize how flawed the layout of the extended pier is and tear both piers down to build a concourse parallel to the headhouse.
questions
Tue May 21, 2013 1:13 am
Quoting LDVAviation (Reply 8):
Please say more.
Like this?
Big version: Width: 720 Height: 540 File size: 153kb
[Edited 2013-05-20 18:56:23]
n7371f
Tue May 21, 2013 1:19 am
Unless the new extension is remarkably better than the current concourse at Terminal 4, I'd say this new operation is just better than T2/T3. I've never found anything all that remarkable about Terminal 4. I was just there a few weeks ago and found plenty of wear and tear.
jfklganyc
Tue May 21, 2013 2:09 am
The original IAB had a concourse like that. The reason why this terminal has concourses the other way is to accomodate the operation of the old IAB while the IAT was under construction. That was only in 1999.
There's always history behind current circumstances
FSDan
Tue May 21, 2013 2:21 am
Are other airlines being shifted around at all with DL moving into T4? It sounds like DL will have 9 new gates and 7 renovated ones. Are these all exclusively DL's, or will they be sharing? If so, they will be losing gates overall, at least until further phases are complete.
I guess they will probably at least share their gates with alliance and JV partners KL, UX, CI, and soon VS.
This is my signature until I think of a better one.
gaystudpilot
Tue May 21, 2013 2:46 am
From a passenger experience and operations perspective, T4B will be better. Compared to T2/3, passengers will have a clean, "modern" terminal with a roof that doesn't leak.
Will it blow your socks off? Doubt it. Narrow concourse, low ceilings. And, just read the DL Flyertalk thread re changes to the Sky Club alcohol policy -- that "flagship" Sky Club in T4, the one with the fancy deck, will be serving Bud Light and Gordon's Gin for free and charging 7USD for a measured shot of Baileys in your morning coffee.
To the vast majority of passengers it will be much better. As far as premium travelers, even within T4, it will be interesting to see where they go in a year or so... for example, JFK-LHR, DL BusinessElite or VS Upper Class.
[Edited 2013-05-20 19:49:02]
Mir
Tue May 21, 2013 3:48 am
Quoting gaystudpilot (Reply 13):
So long as they're not connecting between T2 and T4. Then the extra hassle and time spent might well cancel out the benefits of T4.
But if you can stay within T4, then it will be much better.
-Mir
commavia
Tue May 21, 2013 4:00 am
And the T8 bonds are, if I'm not mistaken, facility revenue bonds that are backed by the financing of the government agency the PA, and at fairly low interest rates. Not to mention - much of the criticism of T8's economics has long been that it's a white elephant. But I do not think that is really the case any longer. Sure, T8 is still underutilized (in terms of turns per day per gate), but that's true of most terminals at JFK which are used most intensively at peak times. But with more AA traffic moving through the terminal from more slots and more mainline over the last several years, plus the addition in that same period of TAM, LAN, Qatar, etc., T8 these days is a fairly well-used place. That surely helps its economics.
[Edited 2013-05-20 21:01:52]
staralliance85
Tue May 21, 2013 4:50 am
Back in the early stages of AA's CH11 days. Delta should of made AA an offer they couldn't refuse for T8. Delta Terminal T4B is No terminal 8, terminal 5 or EWR Terminal C because they do not dominate it to themselves. At T4 Delta has to share the space with other Star Alliance airlines. Terminal 8 is almost a Oneworld powerhouse, T5 is dedicated to Jetblue.
UA has had a very strong hub at EWR Terminal C for over 25 years.
brad Fitzpatrick
laca773
Tue May 21, 2013 5:18 am
[quote=staralliance85,reply=16]Back in the early stages of AA's CH11 days. Delta should of made AA an offer they couldn't refuse for T8. Delta Terminal T4B is No terminal 8, terminal 5 or EWR Terminal C because they do not dominate it to themselves. At T4 Delta has to share the space with other Star Alliance airlines. Terminal 8 is almost a Oneworld powerhouse, T5 is dedicated to Jetblue.
UA has had a very strong hub at EWR Terminal C for over 25 years.[/quote
What Star carriers are going to be using T4B?
How many more OW carriers may move into T8?
spacecadet
Tue May 21, 2013 5:19 am
Quoting n7371f (Reply 10):
There was wear and tear on it as soon as it opened! I remember visiting literally a week after it opened and already finding water damage in the baggage claim area. There was a leak somewhere, which had damaged the roof and caused cosmetic damage to a wall, one column and had pooled on the floor, causing a stain. I didn't see any evidence of this being cleaned up. I can't say it was still like that when I flew in there last month, but it didn't look like a brand new terminal, that's for sure.
This is the way things are in NYC, unfortunately, although I feel like T5 has weathered its passengers a bit better, and it's no less heavily trafficked. I was just coming back after flying through NRT and HND (both T2 and the Intl. Terminal) and those airports are immaculate by comparison, and they sure don't get fewer passengers than any of JFK's terminals.
jfklganyc
Tue May 21, 2013 12:41 pm
Quoting spacecadet (Reply 18):
Stop crapping on the NY airports already a.net. It gets very very old.
T1, T4, T5, T8 and even T7 are world class facilities.
Stop making them sound like Detroit Metro 10 years ago.
JFK is in better shape now than it has been since the 60s.
Also, keep in mind that T1 and T4 opened when JFK handled 35 million passengers a year. It now handles 50 million passenegrs per year.
Things are crowded, things have been updated to handle that and many people dont necessarily like it:
The T1 food court was ripped up and the sculpture taken away to make a bigger food court.
The T4 headhouse was cut in half by a central security checkpoint.
jetlanta
Tue May 21, 2013 1:26 pm
There are sure a lot of opinions here from people who haven't even been in the "new" T4 yet.
While I agree that T4 has generally looked far shabbier than it should for its age, I expect that to change dramatically now. with the exception of the current dilapidated JFK facility, Delta's hubs are very well-maintained. Being the primary tenant in the facility will give Delta a significant amount of input into the maintenance and cleanliness of the facility. Expect its spaces to be pretty pristine.
T4 is not going to be a Taj Mahal facility. But it will it will be more than nice enough. There will certainly be no NYC gateway facility that is superior enough to drive a revenue premium. That is definitely NOT the case with the current situation.
The other comment I'd make is that Delta is doing its best to emphasize the amenities for SkyPriority passengers. The dedicated Check-In lounge and security checkpoint, along with a mega-SkyClub are going to be very welcome additions.
JAAlbert
Tue May 21, 2013 2:05 pm
ANYTHING will be better than the old T3. I will never forget the birds roosting inside, the dangling wiring, the buckets catching leaks, the carpeting that had been worn to shreds. Oh, and the crowds. Many third world terminals were in better shape than that sorry facility.
SAN's new terminal is almost complete and is quite impressive. The portion already open is stylish, with high ceilings, large windows and attractive finishes. Most airports put a lot of design attention into the departures area of the airport and leave the arrivals hall as an after thought (low ceilings, blank walls, no windows, etc.) What is nice about San Diego's new terminal is that the arrivals hall is as attractive as the rest of the facility, with soaring ceilings, glass walls, and art. I think a model of the Lindbergh's plane hangs over the luggage carousels.
Now if SAN would deal with the astonishingly outdated older terminal. Transiting through that facility is a nightmare, particularly if your flight is delayed. My understanding is that SAN has no intention of replacing that facility at present.
AwysBSB
Tue May 21, 2013 2:55 pm
Quoting jetlanta (Reply 20):
In other words, that does not bring the advantage Diamond Medallion passengers deserve and is quite inattentive to Umbrella Terminal, which could become dedicated to highest value passengers of Sky Team as lastly discussed.
[Edited 2013-05-21 08:01:35]
ldvaviation
Tue May 21, 2013 4:22 pm
Quoting questions (Reply 9):
All terminals have wear and tear; the important this is whether or not they have "good bones." Look at T8, for example. It is well known that after it ran into financial trouble AA did not build one half of the headhouse/main concourse and skimped on the interior finishes, but the structure as a whole has an ideal layout that will serve AA well should it decide (in the near future) to go back and redress the interior and complete the building. (When AA does that, I hope it lifts the low ceiling at the top of the escalators as one rises out of the tunnel. That is my biggest pet peeve.)
On the other hand, T4's issues are more than wear and tear. Expanding the B pier was not the best solution. It may have been the most convenient and economical, but it is not the best use of the available space and it will result in long walks for passengers to and from baggage claim/customs.
Quoting jfklganyc (Reply 11):
Whatever the circumstances, it was shortsighted. Look at Reply 9. How many more gates could have been built in the same space? Even if Delta did not need all those gates now, that layout would have given them room for expansion. Moreover, the customer experience would have been better in a terminal with that layout.
jfklganyc
Tue May 21, 2013 4:58 pm
Quoting LDVAviation (Reply 23):
Easy for you to say shortsighted.
They kept a 16 gate terminal running while they built a new 16 gate terminal over it.
That was a monumental feat and there were several articles about it.
Hardly short-sighted especially if you saw the garbage they replaced.
jetlanta
Tue May 21, 2013 5:05 pm
Quoting AwysBSB (Reply 22):
What on Earth are you talking about? The Diamond Medallions don't get a separate plane. I happen to be a DM. If you think that I have any desire to check in at T3 when my plane is parked at T2 or T4, you are crazy.
Your idea makes no sense. I want to check-in as close to my gate as possible. Delta is setting up a completely separate check-in facility for SkyPriority passengers at T4. They will also have their own dedicated TSA entrance. Plus they will have a giant SkyClub with an outdoor deck. What on Earth could T3 provide that would top that? There is not even space in the rotunda for a proper TSA checkpoint, much less adequate check-in facilities and a proper lounge.
Have you ever actually been to T3? Because your idea makes absolutely no practical sense whatsoever. The only plausible use for T3 in terms of airline operations in a 21st Century environment would be a regional jet concourse. It is never going to be a "terminal" again. And shouldn't be.
[Edited 2013-05-21 10:06:49]
[Edited 2013-05-21 10:07:05]
ldvaviation
Tue May 21, 2013 6:38 pm
Quoting jfklganyc (Reply 24):
And, how many gates did AA/MIA keep working, while they built a 45-gate linear concourse in place of piers A, B, C, & D? Now, that was monumental. AA/MIA even had the great idea to build a train on top of the terminal to facilitate passenger movements.
BTW, I did see the garbage it replaced. Just think how easier it would have been back then to build a midfield concourse. There was even a precedent for it in the US, the C/D Concourses at Dulles.
Back then, I also transited quite often through what was considered close to state of the art for the time, United Terminal 9. It had the same basic layout that T4 has now. Its concourses were also as wide and as high as T4's are now. SOM effectively designed a more contemporary T9. Groundbreaking!
csavel
Tue May 21, 2013 6:50 pm
a couple of thoughts.
1. I wouldn't be surprised if a veeeery long series of moving walkways is somehow built between t2 and t4. Yeah difficult, but can be done. Maybe not for a decade or so.
2. T4 has got to be better than T3 but that is not a large hurdle to jump over. I think everyone is pleased to see that terminal in their rearview mirrors. However even it T4 is "meh", Delta is smart in that most people are like in point 3.
3. Most people, other than A.netters don't care too much about terminals or the wow factor therein. This sort of makes sense as most people want to *spend as little time in the terminal as possible.* The best terminals in most people's minds are the ones that get you into the plane and out on the street the fastest.
4. That being said, what with security delays, and flight delays, and weather, people often have a lot of time to kill. Thus the best, wowiest terminals for most people are ones that have amenities for people with time to kill,; *not* necessarily stores to get a whole bunch of stuff.
They've already checked in, and how much extra do people want to lug in their carry on, especially since most of it can be got at home? (Duty-free excepted but that is really only price and I never really understood the concept anyway)
People want free or low cost WIfi, restaurants, plenty of 'em, and good gourmet ones, not typical chain store airport food. People want a lot of comfortable seats since they're waiting. Maybe a book store or magazine store since people still read dead-tree material. For long delays a place to get shut-eye. Why can't other airports do the schiphol concept of lounge chairs???
So I think wow factor is nice. Pax will be impressed - for about five minutes. I mean, has anyone known someone who was NOT an airline freak who chose a flight based on terminal wow rather than price, service of airline, terminal efficiency, or schedule?
I may be ugly. I may be an American. But don't call me an ugly American.
AwysBSB
Tue May 21, 2013 7:06 pm
Quoting jetlanta (Reply 25):
According to what is discussed in another thread about it, the umbrella building has enough space to work like any premium terminal. Its rotunda even has similar dimensions of First Class Terminal Frankfurt, Premium Terminal Doha or JetQuay CIP Terminal Singapore.
By the way, LH, QR or JetQuay were not crazy when building them, even with no jet bridge. Rather, those terminal are very profitable. Why for DL it would totally different? NYC is the market for such a terminal, believe it!
Mir
Tue May 21, 2013 7:54 pm
Quoting csavel (Reply 27):
It wouldn't be difficult at all, and it could be done relatively quickly once the T3 rotunda was out of the way. It's just a matter of cost.
-Mir
spacecadet
Wed May 22, 2013 2:26 am
Quoting jfklganyc (Reply 19):
Sorry, no. I will continue to provide my opinions, despite your commands otherwise. You are not the boss of anybody here. New York's airports are not even close to "world class". If you don't like people crapping on NYC airports, I would suggest writing a letter to the Port Authority. It couldn't hurt.
Read the comments from many others here, and elsewhere.
goldenstate
Wed May 22, 2013 2:56 am
This is entertaining. You obviously do not understand the concept of time value of money.
MesaFlyGuy
Wed May 22, 2013 1:00 pm
Quoting spacecadet (Reply 30):
I agree that you can make youropinions known, but you make it sound like New York is that only city i the world with aging teminals. There are worse terminals that I have been through
jfklganyc
Wed May 22, 2013 1:34 pm
Im not commanding anything.
You have your opinion. I think it is wrong...that's my opinion.
9 runways
3 new control towers
14 different terminals
2 airtrain systems
Hub for DL, AA, UA, B6
Several 380 flights a day
Home to longest flight in the world
Over 100 different airlines
Any city would DREAM of the JFK/LGA/EWR airport system
Most a.netters dream of it!
Revelation
Wed May 22, 2013 1:54 pm
Quoting jfklganyc (Reply 33):
I think the key disagreement is over what "world class" means. One can say that McDonald's is a world class restaurant, some would agree, some would disagree.
Personally I think their dreams would more be along the lines of HKG, where they get to make their own island and put on it whatever they want, and get to build out the highways and the high speed rail to get there. Too bad there isn't a few dozen square miles of Long Island that we can start all over on.
Note that in dreams you don't worry about what it costs!
Same goes for the island sinking - that only happens in nightmares!
The gun is NOT a precious symbol of freedom
It is a deadly cancer on American society
Those who believe otherwise are consumed by an ideology
That is impervious to evidence
FlyASAGuy2005
Wed May 22, 2013 1:57 pm
That is a stretch. The NYC airport system as it is set up is a complete mess.
What gets measured gets done.
ldvaviation
Wed May 22, 2013 4:29 pm
Quoting goldenstate (Reply 31):
Here is what is amusing. That wasn't the point at all. LOL.
You obviously do not understand the concept of a timely investment.
Here's a history lesson. Delta was contemplating a renovation of their terminal facilities as far back as AA was. Delta just kept stalling for a number of reasons. By the time Delta finally had to do something, it ended up spending more for less.
dartland
Wed May 22, 2013 5:38 pm
I think the new T4B will be great for DL and it's passengers. And while not architecturally different, certainly provide a great airport experience due to the new check-in and security flows, the high-end concessions, the new Sky Club concept, etc.
However, I think DL is taking a big risk trumping up T4 to the extent that they are for 1 main reason: Likely half (maybe more) of DL's JFK passengers will be going through T2. They are communicating to the world that T4 revolutionizes the DL experience in NYC, but many of their customers will experience the same old JFK thing.
And not only is T2 a poor experience relative to what they're marketing about T4, they are making things worse with the bus transport transfer between the two. I took it a few weeks ago and it was AWFUL. Hot, slow, long, crowded. Additionally, the AirTrain connection from the T2/T3 stop to T2 is extremely bad, as you have to walk outside and across the street in open air.
An airline has to be careful about marketing an experience they can't deliver, and DL is playing with fire given the extent they're going to talk about T4 as a revolutionary new terminal for NYers.
BN747
Wed May 22, 2013 6:00 pm
What's being missed here is the 'expectations of New York'...
It is expected of anything NYC is to be exceptional and yes, a WOW factor.
Thus...
Please say more.
Like this?
...would have certainly been a huge wow factor albeit much more expensive and still in the works - but much more forward thinking while anticipating future expansion. I advocated this very layout when DL announced the T4 extension and we went to war discussing it here. Now that it is a reality...it would be long before people really start to resent it, and I do mean passengers.It's simply not efficient and given reports on current problem issues..this is only going to increase.
Totally agree.
LAX my home airport has been paralleling construction/expansion of it's largest international facility along with JFK's T4.. and it looks like the TBIT will far out perform T4 when it is fully completed. TBIT will deliver a wow factor..it's already coming into view.
JFK/DL could have done better..much better but chose to settle for quick and mediocrity over practical, cutting-edge and long term resolution. Sure it would have cost more and still far from complete.
But would it have been worth it?
I think so..we expect the best from New York, it is America's flag ship city. So should it be..it's airport.
BN747
"Home of the Brave, made by the Slaves..Land of the Free, if you look like me.." T. Jefferson
jfklganyc
Wed May 22, 2013 6:39 pm
Quoting dartland (Reply 37):
This post really hits Deltas problem right on the head. For half their passengers...nothing has changed. For connectors, it will get worse!
cokepopper
Wed May 22, 2013 7:00 pm
Do you really think 1/2 of the customers Delta serves out of JFK will really experience T-2?
I really don't know but asking. I would think the Majority will just experience T-4?
goldenstate
Wed May 22, 2013 11:17 pm
Quoting LDVAviation (Reply 36):
I don't see how you can judge someone else's understanding of a topic you know nothing about, so you'll have to save the faux erudition for another audience. Your claim of "spending more" is factually incorrect when measured on the basis of construction cost inflation-adjusted project price tags.
I won't even bother asking how you are measuring return on investment, since AA's declining competitive position in NYC and overall financial performance following T8 completion precludes any analytically minded person from arguing that the T8 investment has resulted in any incremental value creation for AMR's shareholders.
Mir
Wed May 22, 2013 11:54 pm
Quoting cokepopper (Reply 40):
I'd say the 1/2 number is pretty accurate. Not only do you have all the RJ passengers using T2, but you'll have some domestic mainline there as well. If DL wants JFK to be an international hub, that'll mean they need plenty of domestic-to-international transfers, and that will probably involve T2 in some way.
-Mir
jfklganyc
Thu May 23, 2013 2:53 am
Delta was never building their own terminal.
Delta wanted to be in T4. Schipol USA wanted them in T4. The PANYNJ wanted them in T4. This has been going on for over a decade.
Delta didn't miss the boat...they are doing exactly what they always wanted to do...just a bit late courtesy 9/11.
On another note, one of the best articles I ever read on JFK from the late 1990s.
Google "a new kennedy takes wing" and read the NY Times article. Great read. And great history behind the current redeveloped "terminal city." The redevelopment started in 1994 and the Delta piece is really the final piece.
New T1, New T4, new T5, expanded T7, new T8, AirTrain, new Tower, new roadways, lots replaced with garages.
In 1997, they reconfigured everything for 45 million pasengers a year. That day has already come
FlyASAGuy2005
Thu May 23, 2013 4:36 am
Quoting jfklganyc (Reply 43):
They put expanding T4 West on hold as early as 2000 so it was pre-9/11.
questions
Thu May 23, 2013 4:58 am
Quoting BN747 (Reply 38):
I'm still curious as to "current problem issues." What are they?
BN747
Thu May 23, 2013 6:03 am
Quoting questions (Reply 45):
Are you not reading the posts in this thread?
Even your design would have been more advanced than the current 'long fingered pier' designs from the 1950s (back then they thought that was design of genius - every airport did it, from NYC/BOS/PHL, etc)
but the western course would curve in alignment with the taxiways. Just a ton of ramp space to work with there. Even more so.. I'd think like the Japanese, use all available space. Meaning, do you see that huge low level car lot area next to large parking garage - push the Tower and the main T4 Terminal complex back into that area (kinda like what TBIT is doing with the gates) - thus yielding even more ramp space. Outrageous? Yes, at first.. but upon completion ... a massive complex that stands as a gleaming premier entry point to the USA. That look would enhance then entire airport's appearance - making T1 and T8/9 'feel obsolete'.
BN747
boswashsprstar
Thu May 23, 2013 5:22 pm
Quoting Mir (Reply 6):
LHR Terminal 5
CDG Terminal 2F
DXB Terminal 3
PEK Terminal 3
PVG
BKK
ICN
HKG
-Mir
I actually think the new terminal at DCA is quite nice. Unfortunately it gets very overcrowded in the post-security sections, and the lack of airside connections between the piers is annoying, but strictly from an architecture standpoint the main hall is pretty spectacular.
