brucek
FX B763F's On Order - New Or Converted Pax Frames?
Sun May 26, 2013 12:27 am
I'm reading the June 2013 issue of Airways, with a directory of US cargo carriers. FX shows 46 B763F's on order (2014-2018). Are these new aircraft from Boeing, or converted pax airline birds?
If they're new, is Boeing fitting the B777-style panel to these, or the older/original semi-glass panels?
Thanks....
AeroWesty
Sun May 26, 2013 12:37 am
Quoting brucek (Thread starter):
Fedex Orders Additional 767s (by LAXintl Jun 29 2012 in Civil Aviation)
International Homo of Mystery
NWAROOSTER
Sun May 26, 2013 12:45 am
I have read that FedEx has ordered 27 new 767-3S2ER freighters.
They also have deferred 11 777-FS2 freighters.
Procrastination Is The Theft Of Time.......
7BOEING7
Sun May 26, 2013 9:10 pm
I believe they're getting the same cockpit as the tanker which is similar to the 787 -- see previous discussion.
Fed Ex 767F Cockpit (by Max Q Feb 19 2012 in Tech Ops)
http://www.ainonline.com/sites/ainon...om/files/uploads/KC-46_cockpit.jpg
wrenchon727
RE: FX B763F's On Order - New Or Converted Pax Frames?
Mon May 27, 2013 10:37 pm
Fedex has 50 767-300 freighters on order.
http://seattletimes.com/html/busines...ogy/2019938911_boeingfedexxml.html
The first three aircraft will have the original designed diplays and the fourth aircraft will be used for STC of Rockwell Collins 15 inch displays & hud.
http://www.rockwellcollins.com/sitec...CS/FY12CSNR35-767_Flight_Deck.aspx
atlengineer
Mon May 27, 2013 11:41 pm
Quoting wrenchon727,reply=4
With the downturn in the air freight market and FX contracting for belly space on other airlines, do you think FX might want to defer deliveries which might create a hole in the assembly line that someone (like maybe Delta) might jump on to place a top off order where they could get early delivery of 10-20 frames?
ATLengineer
Stitch
Tue May 28, 2013 2:06 pm
Quoting atlengineer (Reply 5):
DL is rumored to be buying additional A330s - RUMOR: DL To Order 30 A321 + 10 A330 (by Triple7Lr May 25 2013 in Civil Aviation)
atlengineer
Tue May 28, 2013 2:51 pm
Quoting Stitch (Reply 6):
I know that rumor is on-going, but I was posing a question and responding to Reply 4 which was in regard to 767's. Not sure I understand your reply to my post. DL could do a top off order for 767's and still order A321's and A330's if they had an opening in the 767 line and chose to.
ATLengineer
Stitch
Tue May 28, 2013 3:00 pm
Quoting atlengineer (Reply 7):
I find it unlikely DL would place a large 767 order when they're rumored to be placing a decent A330 order and they have a large 787 order on the books.
Plus the 767s for FX are to replace MD-10s so FX may still take the 767s on schedule due to their superior operating economics which would mean no available slots for DL - at least not in a significant number.
atlengineer
Tue May 28, 2013 4:31 pm
Quoting Stitch (Reply 8):
Stitch:
Thanks. I think you are probably right.
ATLengineer
Hamlet69
Tue May 28, 2013 6:51 pm
While certainly nothing is set in stone, I think it would be more likely that FX would keep their delivery schedule and merely accelerate the MD retirements. The 767 order / MD retirement allows FX a nice flexibility to match capacity with demand.
Hamlet69
All gave some. Some gave all.
