waly777
A350-1000; 4 Doors Only. 5th No Longer An Option.
Sat Jun 08, 2013 7:21 am
A350 programme chief Didier Evrard tells Flightglobal that the doors were considered as an option for customers wanting higher-density seating arrangements with a 10-abreast cabin.
But he says that Airbus has since backed away from the concept. "The A350-1000 will only have four [pairs of] doors," he says, stressing that these will be sufficient for evacuation.
http://pro.flightglobal.com/news/art...t-have-fifth-pair-of-exits-386849/
What will be the evacuation limit with 4 doors? I can't remember this correctly but is the 777-9X coming with 4 doors as well?
In other news, Tunisair appears to cancel A350-800 order......
http://www.flightglobal.com/news/art...s-to-cancel-a350-800-order-386812/
The test of first-rate intelligence is the ability to hold 2 opposed ideas in the mind concurrently, and still function
Stitch
RE: A350-1000; 4 Doors Only. 5th No Longer An Option.
Sat Jun 08, 2013 7:32 am
Quoting waly777 (Thread starter):
440.
The 777-8 will have four doors (440 seat EL) and the 777-9 will have five (550 seat EL).
AA737-823
Sat Jun 08, 2013 7:22 pm
I was similarly surprised to see the 787-10X rendering with four pairs of doors as well. The 787-8 has four. The 787-9 has four. I really expected the stretch -10 to have five.
Now Airbus has gone the same way... does this mean no 10-abreast? Is that what the article meant with the quote?
Flaps
Sat Jun 08, 2013 7:26 pm
An attempt perhaps to keep high density versions of the A350-1000 from eating into potential A380 sales?
AR385
Sat Jun 08, 2013 7:29 pm
Quoting AA737-823 (Reply 2):
European carriers operated 747s for a few years with the door over the wing disabled, effectively rendering them a 4 pair of doors aircraft. The reason for this was to actually carry MORE people so I don´t think it will affect it being 10 abreast or not.
brilondon
Sat Jun 08, 2013 7:32 pm
I believe that it would be wishful thinking. The trend seems to be to make the aircraft be configured at 10 abreast. I would say that Airbus is not going to be any different as the manufacturers are going to sell aircraft to airlines that want to maximize their ability to make money and that means getting as many butts in the aircraft for as little money possible. By having 10 abreast that would be giving the airlines what they want or Airbus and Boeing would not offer it.
Rush for ever; Yankees all the way!!
KarelXWB
Crew
Sat Jun 08, 2013 7:34 pm
10-abreast will still be possible in a typical 3-class configuration. An all Y 10-abreast configuration however will not be possible because this will exceed the 440 seat limit.
[Edited 2013-06-08 12:34:39]
Close, but no cigar http://vine.co/v/OjqeYWWpVWK
DTWPurserBoy
Sat Jun 08, 2013 9:15 pm
I remember Airbus got into an argument with the FAA and pilots/flight attendant unions when they built the A340-600. They wanted to get a waiver of the maximum distance a passenger would have to travel to an exit in an evacuation. In the end, IIRC, Airbus prevailed.
Qualified on Concorde/B707/B720/B727/B737/B747/B757/B767/B777/DC-8/DC-9/DC-10/A319/A320/A330/MD-88-90
Polot
Sat Jun 08, 2013 9:26 pm
Quoting DTWPurserBoy (Reply 7):
No they didn't. They tried to argue that the maximum distance (either 50 or 60 feet, can't remember) between exits was unnecessary and that the dual aisles, wider slides were sufficient for evacuation, therefore the overwing exits were not necessary (although I believe they were still offering them as an option). However they were unsuccessful and were forced to keep the overwing exits. The first one was built with out them, and IIRC was never installed with them- an exit is painted on the aircraft to make it look like the regular production aircraft:
Same plane: No exit, and with an "exit":
Photo © Charles Falk
Photo © OlivierG
Edit: A good comparison where you can see that the A346 prototype overwing exit is just paint and covered windows vs an actual door:
Photo © Eurospot
Photo © Stuart Haigh
[Edited 2013-06-08 14:28:18]
[Edited 2013-06-08 14:53:27]
DTWPurserBoy
Sat Jun 08, 2013 11:40 pm
Quoting Polot (Reply 8):
Thanks for the clarification. There are a few airplanes out there with exits in odd places--find a picture of DanAir's 727-100--it had a 727-200 type galley service door installed on aft right side so they could cram more seats into it. To the best of my knowledge, they were the only ones to do that mod.
There are numerous A319's with 4 overwing exits instead of the normal 2--for those airlines that like "intimate" seating arrangements.
Stitch
Sat Jun 08, 2013 11:50 pm
Air Asia X does have Business Class, so that keeps them at 425 seats on the A350-900 at 10-abreast in Y.
RickNRoll
Sun Jun 09, 2013 6:53 am
Quoting Flaps (Reply 3):
Manufacturers sell goods. They are happy when you buy their goods.
DTWSXM
Sun Jun 09, 2013 7:54 am
I read on another thread where Boeing was undertaking a redesign of either the main doors or exit doors of the latest 737 to increase the opening by six inches. This was to allow a faster egress and therefor more seats. I did a quick search and couldn't find the thread for an exact reference.
My questions. Could eight wider doors provide an evacuation rate comparable to a ten door configuration thus allowing for denser seating? Are the engineering hurdles of making bigger doors equally difficult to placing more doors (if indeed those are the issues)?
Thanks in advance,
Chris
Sláinte
Stitch
Sun Jun 09, 2013 8:06 am
Quoting DTWSXM (Reply 12):
Boeing subsequently denied the report.
Probably, but the Type A door used on the A350 is already the largest door category. So a new, wider door would need to be certified and I expect Airbus does not want to go through that effort.
DTWPurserBoy
Sun Jun 09, 2013 4:54 pm
Boeing uses the exact same door in 2013 that they used on the 737-100 in 1966. The slide pack is a different shape but the door is the same.
Widening the door by 6 inches MIGHT allow for a dual slide raft to be installed but IMHO would be tight. The wide-body exits have lots of room for the dual-track.
WNCrew
Mon Jun 10, 2013 1:26 am
Quoting DTWPurserBoy (Reply 14):
It's dreadful and clumsy to operate. Also it was never designed with a slide originally (because it's ORIGINAL to the 707)... so it has no power assistance, and cannot accommodate a slide/raft.
anrec80
Mon Jun 10, 2013 1:34 am
So does this mean A350 won't have cramped 3-4-3 configuration a-la some carriers 77W?
Stitch
Mon Jun 10, 2013 1:44 am
Quoting anrec80 (Reply 16):
Air Asia X will be 3-4-3, but so far I believe they are the only customer to announce that configuration. Everyone else seems to be 3+3+3.
KarelXWB
Crew
Mon Jun 10, 2013 9:20 am
Quoting Stitch (Reply 1):
440.
So if JL orders the A35J it will not be for domestic usage, unless they're happy with the fewer seats.
