hannahpa
When Is The 787-9 First Flight?
Tue Jul 23, 2013 10:03 pm
Did a search, couldn't find answer. Apologies if it has already posted. I know that it is supposed to be late this year, but does anyone know exactly WHEN it is scheduled for???
Thanks in advance....
817Dreamliiner
RE: When Is The 787-9 First Flight?
Tue Jul 23, 2013 10:15 pm
Should be either next month or early September If I remember correctly.
I'll wake from the dream, To keep and relive, Now life it is a dream, And dream's on a... BREAK!
Sooner787
Wed Jul 24, 2013 3:42 am
Any idea when they'll roll her out of the paint shop?
tortugamon
Wed Jul 24, 2013 4:48 am
Quoting Sooner787 (Reply 2):
It went into the paint hangar on the 18th and usually takes about a week. This is a new paint job and a new aircraft size so it may take a little longer. In other words: late this week or early next week.
tortugamon
zkncj
Wed Jul 24, 2013 7:25 am
Its first passengers flight will be June 2014, and will likely be one of the following NZ101 AKL-SYD / NZ123 AKL-MEL / NZ136 AKL-BNE
PHX787
Wed Jul 24, 2013 9:34 am
So is this the start of the 789 first flight thread
Are they coating it in that livery shown on the 7810 models at PAS13, or the dreamliner livery on the 788?
817Dreamliiner
Wed Jul 24, 2013 10:34 am
Quoting PHX787 (Reply 11):
From what I understand, it should be painted like the first 787 ZA001. The only difference should be the tail withe the 9 on it.
[Edited 2013-07-24 03:55:45]
frigatebird
Wed Jul 24, 2013 10:53 am
The big '9' was already on the tail so I expect it will be like the livery shown at PAS13:
146,318/19/20/21, AB6,332,343,345,388, 722,732/3/4/5/G/8,9, 742,74E,744,752,762,763, 772,77E,773,77W, AT4/7,ATP,CRK,E90,F50/7
Ronaldo747
Wed Jul 24, 2013 11:49 am
From what I heard and read, the 787-9 is doing quite well so far and seems to be ahead of the schedule. I would not surprised if we already see the first flight in the next 3-4 weeks instead end of August or early September.
atlflyer
Wed Jul 24, 2013 4:55 pm
Quoting frigatebird (Reply 13):
That is one beautiful airplane!
hannahpa
Wed Jul 24, 2013 6:28 pm
If I am not mistaken, the GenX engine for the -9 is about 75,000 lbs of thrust, Right???
tortugamon
Wed Jul 24, 2013 6:45 pm
Quoting hannahpa (Reply 28):
I believe the Trent 1000 Package C (what is currently hanging from ZB001's wings) is rated at 74,000. Wiki says 71k.   Trent Ten (787-10) is supposed to be 76k with the capability to go to 78k. I assume GEnx is similar in all accounts.
http://www.rolls-royce.com/news/pres...ases/2012/120508_new_milestone.jsp
tortugamon
Stitch
Wed Jul 24, 2013 7:24 pm
Per the EASA TCDS, GE offers a couple of engines for the 787-9 (thrust figures are maximum continuous):
GEnx1B74/P2 at ~68,500 pounds of thrust
GEnx1B75/P2 at ~68,800 pounds of thrust
GEnx1B78/P2 at ~68,500 pounds of thrust
Quoting tortugamon (Reply 29):
Per the FAA Trent 1000 TCDS (thrust figures are maximum continuous):
Trent 1000-C at 69,523 lbs thrust
Trent 1000-D at 69,523 lbs thrust
Trent 1000-G at 64,722 lbs thrust
The EASA TCDS also shows a Trent 1000-Z at 69,523 lbs thrust
[Edited 2013-07-24 12:35:15]
tortugamon
Wed Jul 24, 2013 7:55 pm
Quoting Stitch (Reply 30):
So when RR says: "The Trent 1000 Package C programme will provide 74,000lb thrust for the 787-9 Dreamliner aircraft," this is a maximum thrust for TO and its really the 69.5k figure for cruise? That is a larger difference than I expected. I always thought the 74k figure was 'continuous' and there is a couple thousand available for temporary burst for hot/high if necessary/purchased.
tortugamon
dynamicsguy
Wed Jul 24, 2013 8:13 pm
Quoting planeadmirer (Reply 21):
Yes and no, unfortunately. Yes to the current schedule. No to the original schedule and probably a couple of revisions of the original schedule.
787-9 development has been way more disciplined than -8. The last schedule slide was nearly 3 years ago due to having to wait on flight test data. The release of engineering data was essentially on time - we didn't miss a single one of our hundreds of releases, and from what I hear this was typical of the program as a whole.
DocLightning
Wed Jul 24, 2013 9:13 pm
The GEnX -74 and -78 offer the same thrust. The Trent -C and -D offer the same thrust. What is the difference between such models, then?
-Doc Lightning-
-Carl Sagan
Stitch
Wed Jul 24, 2013 10:25 pm
Quoting tortugamon (Reply 31):
Yes. TO thrust (5 minute limit) for the C and D are 74,511 pounds and 77,826 for the Z.
Quoting DocLightning (Reply 33):
Per the EASA TCDS, each RR model has it's own Drawing Instruction Sheet that defines the build standard, so it might reflect different PiPs?
Per the EASA TCDS, GE appears to append a Px at the end of the GEnx1B depending on the PIP. So a GEnx-1B64 is the original engine. The GEnx-1B64/P1 includes PiP1 and the GEnx1B64/P2 includes PiP2.
The GEnx-2B for the 747-8 family shows a GEnx-2B67 and a GEnx-2B67B. The engine entered service on the 747 with the features incorporated in the GEnx-1B PiP1 so I don't know if GEnx-2B67B is the upcoming PiP2 engine or not.
KC135R
Sat Jul 27, 2013 5:01 am
And here is the first image of the painted 787-9:
http://www.flickr.com/photos/theboeingcompany/9375872988/ [/url]
[Edited 2013-07-26 22:07:32]
PHX787
Sat Jul 27, 2013 5:15 am
Damn, looks spiffy
tortugamon
Sat Jul 27, 2013 6:15 am
That will work. This close up view makes it look longer than the other pictures/video. The front landing gear looks longer than on the 788. I assume it is not higher off the ground but it sure does look like it. Also, the angle of the cockpit fuse looks more pronounced/steep then on the 788 but I assume that has not changed. Looks lean and mean.
tortugamon
zkncj
Sat Jul 27, 2013 6:44 am
Quoting KC135R (Reply 17):
All that paint for less than 12 months is crazy, unless NZ is planning to operate it in the dreamliner colours
tortugamon
Sat Jul 27, 2013 6:55 am
Quoting zkncj (Reply 20):
This will not be the first 787 delivered to Air New Zealand. That will come later in the year and I am not sure its livery during flight testing has been decided.
tortugamon
NAV20
Sun Jul 28, 2013 3:51 am
Quoting Ronaldo747 (Reply 8):
Certainly likely to be no later than early September, provided the system checks and ground tests go smoothly. Airbus probably just set a 'world record' by getting the A350 flying within five weeks of rollout, and succeeded in getting in that demo flight over Paris. I don't expect that Boeing will see any need to better that, but they certainly won't want to be too far behind.
"Once you have flown, you will walk the earth with your eyes turned skywards.." - Leonardo da Vinci
