voodoo
787 Delivery To Air India Snagged By Electrical Pr
Wed Jul 31, 2013 11:06 am
Apologies if this news is already hidden amongst other threads,
http://www.livemint.com/Companies/9O...reamliner-delay-for-Air-India.html
` Yeaah! Baade 152! Trabi of the Sky! '
speedbored
RE: 787 Delivery To Air India Snagged By Electrical Pr
Wed Jul 31, 2013 11:18 am
Another power panel failure. Not having much luck with them, are they?
Can't help wondering whether it's a quality control issue (of either the panels themselves or components within), or some part of the design has been under-spec'd and needs beefing up a bit.
MSYtristar
Wed Jul 31, 2013 11:46 am
Boeing 787 = Quality you can count on!
At least this problem came to light before the plane entered revenue service.
Honestly I woke up this morning and figured it's been a few days so we're due to hear about another 787 issue.
Stitch
Wed Jul 31, 2013 1:48 pm
Quoting Speedbored (Reply 1):
Possibly a mix of both.
s5daw
Wed Jul 31, 2013 2:01 pm
What is so hard about designing a power panel?? What does it do?? Isn't it just a bunch of wires and stuff??
voodoo
Wed Jul 31, 2013 2:19 pm
Makes me wonder if each issue and its solutions then creates further issues down the line.
speedbored
Wed Jul 31, 2013 2:28 pm
Quoting s5daw (Reply 4):
Yes. It's the 'stuff' that's causing all the trouble.
Stitch
Wed Jul 31, 2013 2:30 pm
The 787 uses electrical power for significantly more functions than previous families of commercial aircraft. The electrical system is therefore significantly more complicated and powerful then the systems on other families of commercial aircraft.
speedbored
Wed Jul 31, 2013 2:39 pm
Quoting Stitch (Reply 7):
And I suspect that it also uses a lot of newer generation components than in previous aircraft. So more solid state switches instead of relays, more switch-mode power conversion instead of transformers, etc. etc.
Although a lot of this technology will have been used in other industries for some time, I suspect that in other places where it's been used before, weight has not been an issue so more margin will have been built in. On aircraft, weight is a big issue so I suspect that many of the components have been sized so that they are operating pretty close to their spec. limits. Maybe too close in some cases.
JBirdAV8r
Wed Jul 31, 2013 7:40 pm
Well, a TRU (transformer rectifier unit) is more complicated than that. It converts the AC electrical power from the aircraft's various generators (engine-driven gens, APU, RAT) and converts it to DC power for the systems that need it. All transport-category aircraft that I know of utilize them. Sometimes they go bust. That's the point of a customer acceptance flight--develop a squawk list and have it fixed before taking possession. Think of it as a walk-through with your building contractor before getting the keys to your house.
PITingres
Wed Jul 31, 2013 9:53 pm
I was intrigued by the comment in the linked article about "electric/electronic systems requiring a dust free environment." My 5 year old desktop Mac Pro will be fascinated to learn that it requires a dust-free environment...
I can only think of a handful of plausible reasons for such a statement, very generously assuming that we discount "bogus" or "ignorant" or "blame diverting":
- metallic dust would obviously be a problem, but I've not heard of any excess metallicity in Indian dust;
- cooling fans and air paths can obviously be blocked by dust, but it's hard to imagine an aircraft power panel being designed to a dustless cooling standard;
- CRT high voltage circuits can attract extra fine dust particles, which are more or less hygroscopic (water attracting), which leads to leakage paths via the humid dust. However we're talking about 10K volts or more; I've no idea what the maximum voltage seen in the 787 power panels is, but I'd be amazed if it were more than 440 volts. I don't know if that is enough to provoke dust-borne humidity leakage problems or not.
Does anyone have factual information in response to the "dust free" claim in the article?
Fly, you fools! Fly!
sankaps
Wed Jul 31, 2013 10:15 pm
Quoting PITingres (Reply 10):
Dust and electronics do not mix well in general (though "dust free" is an unrealistically extreme expectation), but leaving that aside I would discount what government bureaucrats say in that part of the world, they tend to shoot their mouths off.
Reminds me of the early A320 days in India in the late 1980s, when the media was full of reports from "experts" saying highly "computerized" aircraft like the A320 require air-conditioning and therefore were doomed to fail in India.
[Edited 2013-07-31 15:28:38]
tortugamon
Wed Jul 31, 2013 10:23 pm
The problem has evidently been fixed.
http://flightaware.com/live/flight/B...2/history/20130731/1930Z/KPAE/KMWH
tortugamon
speedbored
Wed Jul 31, 2013 10:31 pm
Sounds to me like the government safety council spokesman is trying to make the failure sound a bit more serious than it really is.
Electronic circuitry is pretty resistant to the levels of environmental dust that it will come across in normal use. The layer of dust I have in my PC is probably thick enough to peel it off like a sheet of fabric and it's not causing any issues.
After all, normal dry dust is not particularly conductive so it's unlikely to significantly affect anything until considerable amounts of dust accumulate. These power panels are not being left out in the open trailing along in the dust behind the undercarriage; they're in their own enclosures, in enclosed parts of the fuselage. I'm sure it would take a few years before any noticeable amounts of dust accumulate on the circuit boards. And I'm sure that the panels will all run more than warm enough to evaporate off any potential moisture due to the humidity.
TheRedBaron
Wed Jul 31, 2013 11:45 pm
You know a certain product has real issues when the media can and will identify, failing parts by their name.... guess those P panels ( 100,200 300 and such) will be under big scrutiny by the media.
Now, where is the problem or will they carry a Spare panel "just in case"... as long as Boeing doesnt squat the bugs... they are going to have their hands full....
TRB
The best seat in a Plane is the Jumpseat.
dtw2hyd
Thu Aug 01, 2013 12:40 am
Quoting JBirdAV8r (Reply 9):
Is there a redundant TRU or if it is a SPOF by design what happens to all loads on 28 volt DC. Looking at the Electrical Systems Overview, quite a few loads including Flight Deck Displays are on 28 Vdc.
JBirdAV8r
Thu Aug 01, 2013 12:59 am
Quoting DTW2HYD (Reply 15):
I can only speak for the airplanes I've flown, but there are always multiple TRUs, nominally responsible for different buses for redundancy. One has five TRUs, the other four.
