davidho1985
KE 739 Overrun At Niigata, Japan
Mon Aug 05, 2013 1:47 pm
A KE 737-900, reg # HL7599 over-run the runway when landing at Niigata, Japan at 19:40 (GMT+9).
Fortunately, no one was hurt.
Photo from Weibo http://weibo.com/sinaair
PHX787
RE: KE 739 Overrun At Niigata, Japan
Mon Aug 05, 2013 2:49 pm
There's two threads open so I'll use this one.
Saying on tv there was some brake troubles. On tv looks like the front gear collapsed too.
Niigata was closed for a bit.
(Good job guys. I was gonna be taking a break from airliners for 5 days while I travel but this brought me back for now. )
Okie
Mon Aug 05, 2013 3:08 pm
Quoting PHX787 (Reply 1):
Speculation only, but I believe the airport would be closed more than a bit if there was serious damage to the NG.
I do not see any slides deployed from pic and only a few meters off the end. Looks like it will probably be classified as an incident.
Okie
bennett123
Mon Aug 05, 2013 4:07 pm
Looks as if the engines could be touching the ground.
Especially the one this side.
CO764
Mon Aug 05, 2013 6:30 pm
It was operating flight KE 763 from ICN.
Norcal773
Mon Aug 05, 2013 6:34 pm
Is it not too early for anyone to know that brakes failed at this point unless the pilots said so? The gear looks to be intact on this pic provided by Davidho1985 at least!
If you're going through hell, keep going
HeeseokKoo
Mon Aug 05, 2013 6:58 pm
Quoting Norcal773 (Reply 5):
And the speed-reducing panel on the wing (what's its name?) seems also intact in this pic. Unless pilot put it back, it may not have ever folded up. Too early to say anything, though.
DocLightning
Mon Aug 05, 2013 7:14 pm
Quoting HeeseokKoo (Reply 6):
Flaps are also retracted. Looks as if the flaps and spoilers (the word you were looking for) were stowed after the aircraft came to rest.
-Doc Lightning-
-Carl Sagan
HeeseokKoo
Mon Aug 05, 2013 7:37 pm
Quoting DocLightning (Reply 7):
I see. I hope it doesn't come out to be another "unprofessional" Korean pilots' miscarriage (the myth that prevails here in a.net after the Asiana's accident.)
RussianJet
Mon Aug 05, 2013 7:46 pm
Quoting HeeseokKoo (Reply 8):
To be fair, it's not a 'myth'. It's an opinion on the facts as they're currently known, pending the outcome of a full inquiry. If the investigators conclude otherwise and people continue to hold to the theory in ignorance of the facts, then you might have some grounds to label it a myth.
As for this case, whatever the cause - thank God nobody was hurt.
✈ Every strike of the hammer is a blow against the enemy. ✈
HeeseokKoo
Mon Aug 05, 2013 8:30 pm
Quoting RussianJet (Reply 9):
Some of them might be unprofessional, but majority of Korean pilots should be fine. We cannot judge all of them from one accident. But if pilot-error incidents happen again and again, then I'll stop calling it a myth.
Well, whatever you guys think, let me believe it's a myth - me, my friends, and my family take KE and OZ frequently and there's no other option
RussianJet
Mon Aug 05, 2013 8:41 pm
Quoting HeeseokKoo (Reply 10):
Absolutely not, I wouldn't disagree on that point for a second.
Take it easy. Even the best airlines have had bad days. You've nothing to worry about.
flight152
Mon Aug 05, 2013 8:51 pm
Apparently you haven't had a chance to read a former United pilot's experience teaching KE and OZ pilots in Korea and what he said to say.
HeeseokKoo
Mon Aug 05, 2013 9:47 pm
Quoting RussianJet (Reply 11):
Take it easy.
Thanks for understanding.
Quoting flight152 (Reply 12):
I actually read it. And I just had another "believe whatever you want to believe" moment to the biased myself. Most Koreans didn't leave KE or OZ even in the dark days (late 90s) and those left quickly came back. There's something in between, hard to explain, and I guess that "belief" puts those airliners even more in danger.
wjcandee
Mon Aug 05, 2013 9:57 pm
As long as they don't have to actually take control of the aircraft by using the stick, rudder and throttles.
Or shoot a visual approach with a working PAPI on a clear, windless day.
747-600X
Mon Aug 05, 2013 10:27 pm
Regardless of what happened, in the first photo in the opening post, the aircraft appears to be in quite good shape. There is no evidence of collapsed gear, and the engines don't seem to have made contact with the ground despite the sharp bevel in the terrain.
Norcal773
Mon Aug 05, 2013 11:22 pm
Ooh boy, might as well turn the title on this thread to 'OZ214 crash thread 11'. It is sad that every incident regarding OZ and KE will now turn into 'incompetent Korean pilots' thread.
Anyways, I am glad everyone walked away from this minor incident it looks like. Tow plane to the gate, load it and send it back to ICN.
HeeseokKoo
Mon Aug 05, 2013 11:44 pm
Quoting Norcal773 (Reply 16):
My bad. I can't track if that aircraft is already sent for ICN, but I can see another one is sent to Niigata next morning and the return flight (KIJ-ICN) is to be delayed only by 20 minutes.
wjcandee
Tue Aug 06, 2013 12:01 am
Sorry, this isn't a "no harm, no foul" deal. This is a serious incident. Another 20 feet and it's down that embankment with likely a very different result. Runway excursions don't happen every day, and when they do there are serious lessons to be learned.
RussianJet
Tue Aug 06, 2013 12:05 am
Quoting wjcandee (Reply 18):
Too true. We've seen them end in tears before. I guess we just have to remain thankful that in this case everyone walked away fine, including hopefully the plane.
lightsaber
Crew
Tue Aug 06, 2013 12:52 am
I'm glad no one was hurt. Any more information?
Hopefully not... But the OZ214 crash showed a 'Skygod complex' which increases the likelihood of crashes. This is an industry of continuous improvement and lets see what can be improved at KE and OZ.
Left unchecked, all pilot pools will develop "Skygod complex." Sadly, it takes issues to force through improvements in the training. Anyone who has studied networked ATC knows that the week link is poorly trained individuals at any part of the system. Pilots are given the most responsibility, thus their training must be kept up to date. Including teaching 'old school' tricks such as stick and rudder.
They are a 'near miss' or even, as looks like in this case possibly worse (if the engines hit the ground, that gets pricey fast).
Lightsaber
Carpethead
Tue Aug 06, 2013 3:20 am
Indeed, they would have ended up in the drink or mashed up the front of the plane because of the embankment.
flykal
Tue Aug 06, 2013 5:19 am
Plenty of non-Korean pilots flying the 737 at KE as well, so why don't we just wait and see on the official result before slanging off at various cultures and their supposed lack of flying ability.
One doesn't discover new lands without consenting to lose sight of the shore for a very long time
Tue Aug 06, 2013 6:04 am
Quoting flykal (Reply 22):
3 runway excursions in past week, this is the only one to get a mention.
aviatorcraig
Tue Aug 06, 2013 7:16 am
A.Net justice has been dispensed - they are all guilty until proven innocent
707 727 Caravelle Comet Concorde Dash-7 DC-9 DC-10 One-Eleven Trident Tristar Tu-134 VC-10 Viscount plus boring stuff!
PHX787
Tue Aug 06, 2013 9:16 am
Stop talking about the OZ incident here. This is not the place for it.
The KE plane suffered zero damage. The airport opened this morning and a handful were delayed.
The media is reporting the Japanese investigators are saying there may have been communication issues.....not sure what that implies. But they said this wasn't a serious incident.
They are also showing a video of an angry Korean guy pushing a pilot around. Guy was pissed but for no reason.
Unless this pilot touched down too late, it's too early to blame him.
A guy on TV also reconstructed the incident saying he touched down normally but the security footage shows the plane going a little fast....
Carpethead
Tue Aug 06, 2013 11:25 am
Quoting PHX787 (Reply 25):
A number of possibilities. Niigata is not a busy airport. The KE flight would have been approaching from the west for a straight in arrival to Rwy 10 but perhaps the winds weren't the best resulting in a higher approach speed. Next is the touch down point was a little farther down the runway than usual and the higher speed resulting in not being able to stop in time.
PHX787
Thu Aug 08, 2013 7:36 am
Quoting Carpethead (Reply 26):
Correct me if I misheard but I believe the winds were part of the problem, as of the latest news report.
