MSJYOP28Apilot
De-Hubbed Airports
Mon Sep 09, 2013 3:05 pm
Recently, there has been talk in MEM about demolishing terminal buildings and mothballing others due to the massive cuts there by Delta. Other airports have large parts of their airport terminals empty such as PIT/STL/CVG.
For airports like PIT/STL/CVG that are former hubs and dont have a huge cargo presence like MEM does, could we possibly see permanent runway closures?
STL has 4 runways including one, 11/29, that rarely gets used. Now that the airport is no longer a legacy hub and unlikely to ever be one for the foreseeable future, is it more cost effective to abandon one or two of the runways in order to save the cost of maintaining runways that arent needed or rarely used? Same question can be asked of PIT and CVG.
You could possibly add BNA to the list. They have 3 parallel runways and one crosswind. While all three parallels get used, the airport volume is never anywhere near the available capacity. It could have two parallels and you wouldnt see any delays or difference as a result. BNA is a growing area but even it is kind of wasteful as an airport given how overbuilt it is for the size of its current operation.
At GSO, they built a second parallel runway in anticipation of the Fedex hub. This hub hasnt yet materialized and the airport isnt that busy of an airport. If Fedex completely abandons the idea of a GSO hub, could we see the airport close the crosswind runway and use it possibly as a taxiway?
At a place like CVG that is aiming to get more LCC service, could permanently closing runways lower costs at the airport and possibly help to make it more attractive to LCCs?
gsoflyer
RE: De-Hubbed Airports
Mon Sep 09, 2013 4:39 pm
GSO won't close the crosswind runway, they use it a ton in certain weather conditions. The new runway is hardly ever used. I think out of all my flights, we've used it once. It just takes so long to taxi in and out from.
What amazes me at GSO was building onto the North Terminal when almost all the traffic could be handled from existing gates and less. Heck, they dealt with a Continental hub with less space than what they have no for 48 commercial flights per day.
kpitrrat
Mon Sep 09, 2013 4:50 pm
I dont see PIT closing any of its 4 runways any time soon. All the runways get frequent use IMO. But more importantly, I think they will remain open as long as the ANG Refueling Wing is still on the premises. They often use a runway for training purposes.
BoeingMerica
Mon Sep 09, 2013 4:53 pm
CVG could stand to close or mothball some facilities, I believe they closed Concourse A in 2010? Regardless I do not believe they will take further steps. As a former resident of Southwest Ohio they are in, although not as great nowadays, a state of denial. I think a few of the leaders believe one day it will all come back and will continue to pay to upkeep the current airport size.
When it comes to actual pavement infrastructure, they wouldn't consider closing runways. There is still plenty of early morning cargo ops. However, they are clearly way below max capacity, and won't be returning back to 2000 traffic anytime soon.
I like my Barack like I like my vegetables, I hate vegetables
YQBexYHZBGM
Mon Sep 09, 2013 5:07 pm
There are solutions other than closing runways or demolishing terminals, such as converting surplus terminal space to non-revenue functions (office space, cleaning / maintenance, supplies and storage) for the airport, airlines or the municipality. Unless alternative uses can be found, it's important to save on heating and air conditioning costs, as well as maintenance, in the unused portion. When SYR lost its hub status, they simply walled off the ends of the concourses (and presumably cut off the HVAC system). Demolition is only the preferable option when the terminals are are old, have leaky roofs, or are costly to heat and cool, or if removing them would simplify aircraft movements.
As far as LCCs are concerned, in addition to airport fees, the main driver will be the market for service to the LCCs' limited number of destinations (Myrtle Beach, Florida, the Phoenix area or Las Vegas). If CVG or any airport under consideration has adequate demand for air service, but not necessarily in the point-to-point vacation travel market to these particular destinations, other carriers that offer a broader range of destinations are a better bet, albeit at higher cost.
Al
YQBexYHZBGM
roseflyer
Mon Sep 09, 2013 5:30 pm
STL could probably sell the land for runway 11/29 and earn a reasonable amount of money. The runway is a bit detached from the other 3, although noise from the other runways might make the land less valuable.
Cubsrule
Mon Sep 09, 2013 5:47 pm
Quoting YQBexYHZBGM (Reply 4):
   BNA turned part of Concourse D in to a USO, which I understand is pretty nice.
Quoting roseflyer (Reply 5):
11/29 is semi-useful for airlines operating at Concourse A on a west flow (departures) and on east flow (arrivals). It cuts taxi time down quite a bit.
Quoting MSJYOP28Apilot (Thread starter):
I have used all four runways at BNA in the past month. It may be more capacity than they need, but they use it.
AADC10
Mon Sep 09, 2013 5:50 pm
It is not that easy to close runways. Nearly all commercial runways in the USA were subsidized by the FAA so they are not allowed to simply close the runway and sell off the land. It is possible but the savings would be negated by the refund to the FAA. Terminals however can be mothballed or demolished, which may yield a cost savings.
itrade
Mon Sep 09, 2013 6:05 pm
DAY and BWI have walled up concourses. Not sure what they did in PIT.
FWAERJ
Mon Sep 09, 2013 6:08 pm
Quoting BoeingMerica (Reply 3):
CVG Concourse A was renovated and is again being used as of 2012, when Terminal 2 closed. Terminal 1 was recently reopened for charters, and continued to serve as the CVG administration building even after the initial closure for pax service.
Frankly, I could see Terminal 2 being bulldozed soon and T3 Concourse C being demolished shortly afterward. T3C was built for 50-seat RJs and is outmoded, plus CVG has plenty of extra gates on both Concourses A and B. And the unused gates on A could actually fit a sizable WN operation should they come to CVG (though they're currently happy serving Cincinnati through DAY, CMH, IND, and SDF, just look at F9's move from DAY).
"Did he really need the triple bypass? Or was it the miles?"
FWAERJ
Mon Sep 09, 2013 6:20 pm
Quoting itrade (Reply 8):
PIT has walled-up concourses as well, and DAY plans to wall up Concourse A soon in addition to Concourse D, leaving it with just B and C.
But given BWI's growth as of late for WN, I don't think that empty concourse there will stay walled-up for long.
itrade
Mon Sep 09, 2013 6:28 pm
Does "E" at PIT still exist?
dabpit
Mon Sep 09, 2013 7:04 pm
Quoting FWAERJ (Reply 10):
Concourse A & B are walled off at the end.
Quoting itrade (Reply 11):
The airport authority demolished part of E and the area around the former concourse is used for employee parking and the concourse itself is an alternative security check-point.
Carpe Diem
flyguy89
Mon Sep 09, 2013 7:35 pm
Well CVG is still a Delta hub, it hasn't been fully or officially dehubbed...yet. Although some members on here have indicated DL has stated CVG is currently profitable, who knows what could happen long term. CVG also actually is a major cargo hub, granted nowhere near the scale of MEM, but it's still DHL's North American hub with lots of heavies departing daily, so ironically the new runway CVG built for DL is actually getting some use.
chrisinbrasil
Mon Sep 09, 2013 7:38 pm
How many hub cities still exist and what airlines serve them? And yes this is speculation, but what city is next?
Southern, Eastern, Delta, Northwest, United, American, Varig, Vasp, TransBrasil, Tam, Gol, British, Lufthansa, KLM, Aero
kgaiflyer
Mon Sep 09, 2013 7:53 pm
If you're talking about the "down-low" extension to D concourse, two gates are still used for USAir Express. Some of the offices down there are also used. And part of the day, the Airport Authority Police play with their dogs down there.
I don't want to say 'train' their dogs since most of those dogs behave like puppies.
lightsaber
Crew
Mon Sep 09, 2013 10:21 pm
Quoting ChrisInBrasil (Reply 14):
Dozens. All of the top 50 qualify, there are a lot of hubs out there... :
http://en.wikipedia.org/wiki/World's...iest_airports_by_passenger_traffic
The only merger in process is US/AA (temporarily blocked). That merger could put CLT at some risk. At that point, I see the US hubs as being consolidated.
We're more in an era of expanding hubs. For example, MAA, BLR, or HYD should eventually become a large hub. Which? I don't know. And South America is looking for a dominant hub. If CGH and GRU were merged (new location), than San Paulo would be a natural choice. But not with split hubs 29km apart... too many missed connection opportunities.
Lightsaber
itrade
Mon Sep 09, 2013 10:31 pm
Quoting lightsaber (Reply 16):
http://en.wikipedia.org/wiki/World's...affic
Not sure if MCO qualifies as a hub.
I don't think CLT is going anywhere. After the pulldowns in MEM, RDU, and (to an extent CVG, there are only two major hubs in the South - Atlanta and Charlotte. CLT might lose a couple gates as part of a settlement agreement, but I don't think CLT is going to be significantly affected. Any losses in CLT flying will likely be to the Caribbean. A combined AA/US, will be more likely to funnel them through MIA and JFK.
SLCUT2777
Mon Sep 09, 2013 11:16 pm
Quoting itrade (Reply 17):
I do think however it will be interesting to watch how CLT is impacted with what they decide to allow in this merger. Similarly should DL acquire AS, SLC could see some similar reductions.
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
BoeingMerica
Tue Sep 10, 2013 1:07 am
Quoting SLCUT2777 (Reply 18):
So were not considering Mia a large airport in the southeast? I mean compared to Atl, no it is not. However, the airport has many EU connection opportunities as well as an expansive domestic operation and a well documented strong latin and south american network. There is not much the airport lacks, it is a MAJOR airport in the southeastern United States.
About the only thing it does not do it handle cross country domestic travelers, sheerly due to geography.
BoeingMerica
teneriffe77
Tue Sep 10, 2013 1:18 am
Quoting YQBexYHZBGM Reply 4:
I believe he is referring to PIT as I've flown out of SYR plenty of times during and after it was a hub and I can say for certain that the concourses were not walled off. I know that they did that in PIT but in SYR the concourses are still fully in use with the hub end of the south concourse still in use by US.
prosa
Tue Sep 10, 2013 2:02 am
I would consider DFW and IAH to be in the South. In addition to MIA, as previously noted. If you really want to stretch definitions, IAD too.
"Let me think about it" = the coward's way of saying "no"
xjet
Tue Sep 10, 2013 2:14 am
Quoting flyguy89 (Reply 13):
Actually, all DHL jets at CVG use runway 9-27 exclusively due to noise abatement. Land 9, depart 27. The Shorts, and other turbo props use 36C, but that is only 4 aircraft every night. The departure push is somewhat busy, but the departure times are regulated so there isn't ever much runway congestion unless the sort gets delayed.
chrisinbrasil
Tue Sep 10, 2013 2:17 am
Well, what cities in the USA are hubs now?
tjh8402
Tue Sep 10, 2013 2:30 am
Although perhaps not a hub in the legacy sense of the word, we are a focus city for B6 and WN, and I thought FL did officially label us a hub.
SLCUT2777
Tue Sep 10, 2013 2:45 am
Quoting BoeingMerica (Reply 19):
MIA is clearly the great gateway to Latin America and can do more for AA in that mission than ATL can for DL.
Quoting ChrisInBrasil (Reply 23):
SEA for AS
SFO for US
LAX for AA, UA & DL Pacific Rim
PHX for US
SLC for DL
DEN for UA & F9
DFW for AA
IAH for UA
MSP for DL
ORD for UA & AA
DTW for DL
CVG for DL (downsizing)
CLE for UA (downsizing)
ATL for DL
MIA for AA
IAD for UA
PHL for US
CLT for US
EWR for UA
LGA for DL
JFK for DL & B6, AA lessor extent
DCA for US
BOS for DL, AA & B6
WN big in LAS, PHX, DEN, DAL, HOU, MCI, STL, MDW, MCO, BWI, FLL
Anything I left out feel free to append
itrade
Tue Sep 10, 2013 3:02 am
How about WN/FL at ATL.
christao17
Tue Sep 10, 2013 3:04 am
Quoting SLCUT2777 (Reply 25):
SFO for US
Of course, you mean for UA.
TWA772LR
Tue Sep 10, 2013 3:19 am
SFO for US
I believe you mean UA.
And for my next miracle, I'm gonna turn water into funk!
bohica
Tue Sep 10, 2013 3:25 am
Here we go again.
Can we have one thread without AS merger speculation?
slcdeltarumd11
Tue Sep 10, 2013 3:34 am
Oh yeah the denial is very high sometimes. These airports getting de-hubbed happened for a reason, they are not gonna be re-hubbed unless oil goes way way way back down in price. Those hubs were only financially viable in a much lower fuel world.
LOL you keep saying this, but the reality is Delta has 0.0000001% chance of acquiring Alaska. The government would never allow that go thru now. All these mergers and planes totally full has made politicians on alert and we have had so much consolidation. The government should be fair and let AA/US merge in the end IMHO but AS/DL will just never happen besides the face that AS is very financially strong and doesn't want to, the politicians in Washington, Idaho, Oregon, and probably California would go absolutely crazy to stop that from happening. That merger just isn't happening.
Amwest2United
Tue Sep 10, 2013 3:43 am
How far back are we going?
MCO was a hub for Florida Express, then bought by Braniff II, Also Delta Express had a hub there.
DAY = PI
BWI = PI, then US, now WN
SYR = PI
CLT = EA, then PI now US
PIT = TW
CLE = UA, then CO, now UA
ATL = TW
MDW = ML
SLC = Morris
MCI = BN, then EA, then BN, then KINDA US
IND = US
CMH = HP
I know there are many I am missing
Life is what happens to you while you making plans to live it!
flightsimer
Tue Sep 10, 2013 4:08 am
For PIT, the terminal situation there has already been discussed. So to talk about the runways...
For the runways, pit has four 10/28 L/C/R and runway 14/32.
14/32, I have only ever seen that runway used for arrivals on 32. I have never seen or heard of 14 being used at all in this day in age. It seems every time I have been in the area at night, I have always seen at least one aircraft use 32. I believe this was one of the original runways of the airport.
Now for the three parallel runways.
Of the three, left and right are the primary runways. Typically, northerly arrivals use 28R/10L and southerly arrivals use 28L/10R. 28/10C is used some, but I don't know how much. I know Center only has RNAV GPS and RNP approaches, but it is mainly a VFR runway.
As for the 911th and 171st, I believe that it is in their agreement with the airport that they get priority use of 28L/10R when they need it. Any time I have seen either 130's or the 135's flying, they have been using that runway. I also remember a friend, who works on the 135's, saying that should the shit ever hit the fan, they can take exclusive use of that runway. Hopefully there is someone else on here who may know more about this.
Commercial Pilot- SEL, MEL, Instrument
Noise
Tue Sep 10, 2013 4:27 am
I got a question...will we ever see the creation of new hub cities? I don't know, say, SJC for AS or AUS for B6?
AS737MAX
Tue Sep 10, 2013 4:42 am
AS at PDX, ANC, and to a lessor extent LAX
Quoting Noise (Reply 33):
SJC for AS
I think that SAN would be hubbed by AS before SJC
But for an AS lineup of destinations served: (Including QX and OO so some flights may double)
SEA: 79
PDX: 44
ANC: 27
LAX: 19
SAN: 13
SJC: 12
Who knows what could happen but currently 13 destinations isn't really enough to justify a hub
Big version: Width: 720 Height: 360 File size: 21kb
Just a photo of pretty much every hub, do we have enough? Big grin
[Edited 2013-09-09 22:04:34]
48 Flights, 43,720 Miles Flown
BHMNONREV
Tue Sep 10, 2013 8:51 am
Quoting Cubsrule (Reply 6):
Correct. My last three AA flights to DFW departed from 29, and with 29 not used for arrivals it makes for a very quick and easy departure. Not much difference than using 12L or 12R and no waits for inbound traffic. I think it gets quite a bit more use than it used to after it opened.
It's a shame 6/24 does not get used much anymore, and judging by tire marks 6 does not get used at all. Back in the 60's and early 70's it was not uncommon for 6 to carry the majority of arrivals on any given day.
OzarkD9S
Tue Sep 10, 2013 11:08 am
I've used it several times when flying out of A. I've even landed on 24 a couple of times recently.
As the masters write on walls and the angels eat their grapes, I watched Picasso visit The Planet of The Apes. - Adam and The Ants.
PRAirbus
Tue Sep 10, 2013 11:53 am
SJU after AA closed its hub; AA/AE had over 125+ flights per day durings its peak, now AE gone, AA has between 11/13 daily departures per day. B6 has a focus city in SJU w/around 40+ per day allegedly increasing to 70/75. AA's current SJU terminal now belongs to the government of Puerto Rico, rumor is it will be closed for 2yrs, partially demolished and renovated. AA and some other carriers will relocate. B6's brand new terminal will also be modified and expanded to increase US Customs/Immigration capacity.
AVLAirlineFreq
Tue Sep 10, 2013 12:02 pm
And BNA.
Quoting Amwest2united (Reply 31):
DL has had a hub in MCO at least twice.
gsoflyer
Tue Sep 10, 2013 1:25 pm
Technically AGA (GUAM) is a hub too, in the USA for United.
PHX787
Tue Sep 10, 2013 2:07 pm
Quoting FWAERJ (Reply 9):
I believe 2 is slated for demo sometime soon, or renovation into something else.
1 is most likely going to be renamed "charter terminal."
In terms of WN, I heard though not many cincinnatians actually fly with WN...my dad drove to DAY once to fly US.
I'm not holding out on WN. I say get someone like VX here, or have F9 expand operations
CVG is a hub for 5Y and associated services, as well as having a lot of widebodies from DHL fly in every day. In a span of 2 hours of spotting at CVG the other day, I saw 3 747Fs arrive and one depart, along with countless other services fly in and out.
Quoting bohica (Reply 29):
Please!!!
lightsaber
Crew
Tue Sep 10, 2013 2:15 pm
Agreed. Hence why I phrased it as 'risk.'
Yes. Lets.
Quoting AS737MAX (Reply 34):
First, I like the image. But that brings up discussion... Traditional definition of a hub is 30% to 70% connecting traffic. I do not believe SAN, OAK, AZA, SFB, PIE, PGD, MYR, DCA, or BNA qualifies. Some of the others we've already discussed as 'has been hubs.' They might still be hubs, but they are no longer significant.
Lightsaber
USFlyer26
Tue Sep 10, 2013 2:28 pm
Quoting dabpit (Reply 12):
Per kpittrat in the latest PIT update thread, the wall was just taken down in the A concourse for the combined FL/WN operations.
"As of now the wall is gone, the moving walkways are all functioning to the end, and they are even listing Arrivals/Departures on the boards in the extended wing. It looks like it has only been closed for 2 weeks. That being said there are obviously no stores or food areas open as everything was walled off. Also there are no jetways for gates 24 and 25 from what I saw. Still it was really nice to walk all the way down and get that different perspective of 28R. Got to see some planes take off and land.
From my limited knowledge I believe WN is parking FL RONs on gates A 17 and 19 ,also, all the lines have been repainted for those two gates. The Tampa flight was taxiing into 19 as I was leaving."
BoeingMerica
Tue Sep 10, 2013 2:30 pm
Which is what I clearly said, in my point arguing how MIA SHOULD be considered a top, large scale important airport to the southeastern United States. So I am not so sure what your whole post was about....
Not going to happen. Airlines are fully on alert that there will be no future merging. The cost of entry barriers to the industry are so extreme that unless the government put their wallet behind an entrant(which wont happen) we will not see another carrier large enough to take advantage of cost savings of an economy of scale. As the air travel sector continues to grow, this is only going to become an even bigger issue. For your wallet's sake, I hope in the coming decades we find a few more entrants into the market, we sure need it.
AS737MAX
Tue Sep 10, 2013 2:46 pm
Quoting lightsaber (Reply 41):
SAN, OAK, AZA, PIE, SFB, PGD, MYR, DCA, BNA removed
washingtonflyer
Tue Sep 10, 2013 2:50 pm
SAN won't be hubbed by anyone (not any time soon). Its in the corner of the country and the terminal facilities are not set up for it. You're going to need a second runway and some MCRD land to do that.
stratacruiser
Tue Sep 10, 2013 3:33 pm
BOS for DL, AA & B6
BOS certainly isn't an AA hub, or even a "focus city". See http://www.boston.com/business/2013/.../IPrQPG9xwcIFKf522dvPIO/story.html Only AA destinations left are MIA, JFK, ORD, LAX, DFW and the seasonal 757 to CDG.
For that matter, if you define "hub" as an airport through which a carrier routes significant connecting traffic, BOS has always been a minor player at best. Even for carriers offering a variety of destinations - currently B6, DL and US lead the pack - most traffic is O/D. Boston's geographic location and Logan's limited space make it an unlikely choice for a domestic hub. Over the years a few US carriers have tried to use Logan as a trans-Atlantic hub, but without sustained success. Indeed today there are only four daily TA flights operated by US carriers (DL to 1x LHR, 2x AMS and AA 1x CDG)....BA offers more daily seats to LHR alone than all US carriers do from Logan to all of Europe.
Dave
Italianflyer
Tue Sep 10, 2013 3:45 pm
Quoting AVLAirlineFreq (Reply 38):
UA took a stab at a MCO hublett in the early-mid 90s too. Was a mix of large hub flying, some p2p and intra-Florida on 737s.
AVLAirlineFreq
Tue Sep 10, 2013 4:56 pm
Quoting AS737MAX (Reply 44):
If that's the measuring stick criteria for a hub, then quite a few others on the map above don't qualify: FLL (8%), LAS (15%), PDX (16%), JFK (17%), HNL (19%), LAX (21%), SFO (22%), BWI (26%), SEA (28%), and EWR (28%). Others on the map that I feel wouldn't qualify would include OGG, SJC, BOS, LGB, and MCO.
Perhaps a better definition would be based upon volume rather than percentages, since most people would argue that airports like JFK and EWR are certainly "hubs."
(The connecting passenger stats come from this recent study concerning CLT's governance, pg. 5: http://charmeck.org/city/charlotte/d...irport%20governance%20ow%20vf.pdf)
Noise
Tue Sep 10, 2013 5:31 pm
Quoting washingtonflyer (Reply 45):
I guess hence the reason I mentioned SJC as a potential "new hub" for AS instead of SAN. Geographically, SJC makes more sense than SAN...or even SEA, ANC and PDX for that matter (SJC would be good for North-South traffic, but like how UA uses SFO).
