Heavierthanair
Ryanair Restroom Size Equivalent To 11 Seats
Sun Sep 29, 2013 10:54 am
G'day
Here
http://www.ch-aviation.ch/portal/new...s-with-boeing-over-b737-max-millar
it says
Ryanair is pursuing is the possibility of removing one of the Max's rear toilets in order to fit an extra 11 seats
Unquote:
11 seats is a lot of real estate. How on earth are they going to get 11 seats in the space of a typical airline lavatory? The airline lavatories I have seen so far seat one. At times I wonder how some of the bigger passengers get through the door and even more so how they go about their business in there, but that is not the point of this post. I was also not aware that Ryanair treats their customers with Emirates first class style of real bathrooms (powder rooms for you American ladies) that feature a shower and a pissoir err urinal for their male clientele.
The article also implies that they are removing one of the rear toilets, meaning one will stay for the time being until they have figured out how to fit another 11 seats and meeting the minimum crew requirement without adding another crew member (first officer serving the first two seat rows maybe?).
So likely they will fit the extra seats rows across the one remaining rear lavatory and likely using galley space as well (do Ryanair have a galley?). And will they be charging extra for the privilege of sitting next to the lavatory with all those passengers in need roaming around, trying to figure out how the pay for the usage fee and the various extra smells?
Numerous questions I know, but there must be some A-nutters that can answer some, for the remaining of us to get a clear picture, thanks
Peter
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe." (Albert Einstein, 1879 - 1955)
KarelXWB
Crew
RE: Ryanair Restroom Size Equivalent To 11 Seats
Sun Sep 29, 2013 12:18 pm
I think Howard Millar is not telling the whole story. Ryanair currently uses 30" seat pitch, they can get another row with six seats by reducing the pitch to 28-29". Removing one of the aft lavatories will give them another 3 seats. Now we only need to find 2 more seats
http://oi44.tinypic.com/wvrhh3.jpg
Joost
Sun Sep 29, 2013 12:19 pm
Quoting Heavierthanair (Thread starter):
A typical lavatory takes the space of about one and a half row of seats, so say 4.5 seats. It's wider than 29" and runs all the way from the aisle to the cabin, so the width of 3 seats. If there is some space between the last seats and the lavatory now, it might well be a 6 seats gain.
Still not 11, but there's probably more to the story.
1) Ryanair uses a 30" seat pitch. As they are installing 189 seats (the maximum for the 738), there is no use for them to tighten the seat pitch. 29" gives them the space for one extra row (6 seats)
2) On the 737-900ER, Boeing has installed a flat rear pressure bulkhead, instead of a cone-shaped on the 737-800. Boeing is at least considering using the flat bulkhead on all 737 MAX models, providing additional interior space.
The Ryanair goal is 200 seats, 11 up from the current 189. At 50 seats per F/A, 200 seats is the maximum number of seats for 4 F/A's.
The challenge is to get the 737-8MAX certified for 200 pax. And FR is trying to make Boeing do that.
brilondon
Sun Sep 29, 2013 12:31 pm
Goody, another reason to bash FR again.
But they also need room for the plumbing and the sink and, well I know that the lavs in aircraft really don't have that much room but if FR also goes ahead with charging for use of the toilet, there may not be a need for all the toilets on an aircraft. I for one do not like using those places on the aircraft unless I absolutely find it necessary. They are disgusting places and I don't like even sitting near one.
Rush for ever; Yankees all the way!!
Aesma
Sun Sep 29, 2013 1:48 pm
Now you make me wonder why Ryanair is not lobbying EASA to change the rule for the number of F/A, or maybe they are ?
cschleic
Sun Sep 29, 2013 3:33 pm
Quoting joost (Reply 2):
Boeing's name MAX is really going to be appropriate!
nicholasjet
Sun Sep 29, 2013 4:59 pm
I think you'll find there is a difference in the widths of the galleys in their current 737-800 fleets, the forward galley is fairly narrow on some, meaning more space for an extra row at least.... This combined with the removal of the rear galley by the R2 door might allow for another 2-3 rows. Still... I think the '200' is just an easier goal to say for the airline, instead of 198.... which would make much more sense....
KELPkid
Sun Sep 29, 2013 5:12 pm
What are they trying to do, get regulations enacted to govern the minimum number of lavs per passenger?   Also, at some point, you will bump into the max number of passengers the plane is certified for (due to evacuation capacities of the exits). And I wonder if FR realizes that when you add passengers, at some point, you have to add an (expensive) flight attendant to the aircraft. I guess in FR's case, it's just one more person to stroll the aisles in flight peddling watches, etc.
Pe@rson
Sun Sep 29, 2013 5:20 pm
Quoting KELPkid (Reply 7):
One for every 50 seats, so they require four with their present 189 seats (max certified) or 200.
davies2911
Sun Sep 29, 2013 5:27 pm
On the Easyjet A320 I went on a few months ago, one of the toilets was in the back wall behind the door.
Would the flat pressure bulkhead allow something like this, along with a half galley, would that not free up the space for the extra seats?
BrianDromey
Sun Sep 29, 2013 5:41 pm
I'm sure FR are more than well aware of the maximum certified capacity of the -800, it's 189 their current seat capacity. I'm sure they are also aware of the 50:1 ratio for cabin crew. It's why easyJet's 156 seat A319s have four cabin crew. It's also the reason FR are pushing for 200 seats, it's not a co-incidence. What FR are trying to do is seat more people in the same space. Where would the space come from?
1) Reduce seat pitch
As already mentioned the 73H could seat 195 (an extra row) just by reducing the pitch by 1".29" of pitch is still 1" better than easyJet's A319. Sadly the seats FR currently use are chunky affairs, by using slimline seats FR may well make the cabin more comfortable.
2) Remove galley aft of 1R
Currently FRs 73H have a galley where 1DEF could be. Replacing this with seating could add another 3 seats.
3) Remove one rear lav.
Removing a rear toilet could add another 3 seats.
4) Remove both rear lavs
Removing both rear lavs and placing one or both of them against the rear bulkhead could add 6 seats. Airbus are doing this with SpaceFlex, I'm not sure if boeing could squeeze a little galley in as well as 2 lavs, as Airbus do.
So it seems possible to add even more than 11 seats to the 738, possibly up to 15 extra seats, if Boeing can get it certified. It seems possible to get 9 extra seats without even removing a toilet. If FR would be happy with 2 lav for 200 passengers than no changes to the rear bulkhead would be needed. A 204 seat 738MAX would have amazing seat mile costs and look great in comparison charts in the brochures against the 180 seat A320
Next flights: MAN-ILD, BCN-LHR-CPT, CPT-LHR-MAN, MAN-ORK-KEF, KEF-ORK-MAN.
hOMSaR
Sun Sep 29, 2013 5:43 pm
Wouldn't the door configuration have to be changed? Wasn't the main reason the 737-900's max capacity was the same as the 737-800 because they had the same exit door configuration (which is why Boeing had to throw in the extra door behind the wings on the -900ER)?
The plural of Airbus is Airbuses. Airbii is not a word.
There is no 787-800, nor 787-900 or 747-800. It's 787-8, 787-9, and 747-8.
A321neoLR is also unnecessary. It's simply A321LR.
Airplanes don't have isles, they have aisles.
JAAlbert
Sun Sep 29, 2013 7:37 pm
Remember DL said they could cram a few extra seats into their 737s by reconfiguring the aft lavatory into a previously unused rear bulkhead space or something like that. Perhaps Ryan is taking advantage of that space in the back for seats rather than a lav.
Aesma
Sun Sep 29, 2013 10:24 pm
192 seats A320. Apparently that's what Airbus promised U2.
zkncj
Sun Sep 29, 2013 10:56 pm
Easy, I would say there planning a layout allot like NZ 171D A320 (http://www.airnewzealand.co.nz/seat-map-airbus-a320-171d) just without the 35" pitch up front
roseflyer
Sun Sep 29, 2013 11:04 pm
Lavatories are not what limit 737-800s to 189 seats. It is exit configuration. No narrow bodies in the 2 front door 2 rear door and 4 window exit configuration have been certified for more than 189 seats as far as I know. How will they get past that barrier?
blrsea
Sun Sep 29, 2013 11:07 pm
What is the effect of using the rear bulkhead space on safety and maintenance?
RyanairGuru
Sun Sep 29, 2013 11:08 pm
Quoting davies2911 (Reply 9):
That is how QF's 737-400s are configured, with the lavatory on the ABC side and galley on the DEF side against the back wall, behind the doors. I would therefore assume that it is possible on the 800 if they can do it on the 400.
Quoting BrianDromey (Reply 10):
True. Those seats surely aren't particularly light compared to current models, so I would assume that at some point they will introduce new seats.
Worked Hard, Flew Right
cschleic
Mon Sep 30, 2013 12:15 am
Quoting roseflyer (Reply 15):
Demonstrate they can evacuate it within the 90 seconds? Or would they go so far as to add two more exits, similar to the 737-900ER? Thinking way way back, there were 727-200's that had an extra set of exits between the wing and nose. I think United pushed for it with the intent of making it a "high density" configuration (at least high density at that time) for specific routes that had a lot of traffic....e.g. SFO - LAX, maybe ORD to LGA or similar.
Max Q
Mon Sep 30, 2013 2:02 am
Quoting cschleic (Reply 18):
Never seen or heard of that.
Do you have a picture or the name of the operator with this configuration ?
cschleic
Mon Sep 30, 2013 2:16 am
Quoting Max Q (Reply 19):
Here's a link to earlier discussions.
United Boeing 727-200's With 11 Emergency Exits? (by WesternDC1010 Jul 30 2003 in Civil Aviation)
Link to two photos in the database:
http://www.airliners.net/photo/Unite...d=ed18f69e3f1d78af65d09e3ff0ba5f42
http://www.airliners.net/photo/349476/M/
Max Q
Mon Sep 30, 2013 2:34 am
Thanks, interesting.
Looks like where the Galley service door was on the -100.
Stitch
Mon Sep 30, 2013 2:49 am
Section 25.365 of the FAA TCDS for the 737 family does make note that the 737-800 can be fitted with a flat rear pressure bulkhead, as well:
For 737-800 airplanes configured with a flat aft pressure bulkhead, the airplane is also designed to withstand the effects of a sudden release of pressure venting aft through any 820 square inch opening in that bulkhead at any operating altitude.
Quoting hoMsar (Reply 11):
There were some rumors awhile back that Boeing was considering changing the doors for the MAX.
Looking at the EASA TCDS, the 737-800 has four Type I exit doors and four Type III overwing exits, but the forward LH door is sized like a Type B and the other three are sized like Type Cs which I assume is why the plane is certified for 189 instead of 160 (which would be the limit with 2xType I and 2xType III per side).
Boeing could move to Type II overwing exits, which would raise the per exit limit from 35 to 40 (giving 10 additional seats on the 737-800).
cschleic
Mon Sep 30, 2013 3:03 am
Quoting Stitch (Reply 22):
What's the difference between Type III overwing and Type II? I know the NG's have the emergency exits that hinge upward and, I think, are larger than the previous models. Is there another type that's even larger than that...if that's the criteria for more seats in the plane? Or something else?
Escapehere
Mon Sep 30, 2013 5:34 am
I highly doubt the regulator will allow a plane with 2 lavs for 200 people.
seahawk
Mon Sep 30, 2013 6:02 am
One LAV should be enough. It alos means you carry less water and less waste water. Maybe one could also agree that one FA fpr 75 pax is enough and the seat pitch can be reduced to 26-27". People want to fly for low prices, the governments should not stop airlines from offering that.
KELPkid
Mon Sep 30, 2013 6:28 am
Quoting Pe@rson (Reply 8):
Is that under JAA/EASA rules? I thought the 1 FA/50 PAX rule was FAA only
zkncj
Mon Sep 30, 2013 7:58 am
Quoting escapehere (Reply 24):
Air New Zealand does 2 to 171 on there Domestic A320
BAWairbus
Mon Sep 30, 2013 10:03 am
Quoting seahawk (Reply 25):
Maybe one could also agree that one FA fpr 75 pax is enough People want to fly for low prices, the governments should not stop airlines from offering that.
They certainly should when safety is involved. I don't think we can expect the ruling on the ratio of cabin crew to passengers to change and I don't think it should! Airlines are businesses. They have to evolve their business plan to the times they are operating in and the legislation that applies to them, just like anyone else. Granted there is a lot more regulation for airlines to contend with than the average business, but it's all part and parcel. If they wan't to be profitable, they should figure out how to do it without stamping their feet and expecting the goalposts to be moved.
Also, I really don't think one toilet would be enough on a 737... especially on some of the missions FR uses them on.
KarelXWB
Crew
Mon Sep 30, 2013 10:04 am
Quoting BAWairbus (Reply 28):
They have one in the front too so that would make 2 toilets instead of 3.
[Edited 2013-09-30 03:05:11]
BAWairbus
Mon Sep 30, 2013 10:17 am
Quoting KarelXWB (Reply 29):
I was just referencing seahawk in reply 25 who seemed to be suggesting that one would be enough for the entire aircraft.
KarelXWB
Crew
Mon Sep 30, 2013 10:22 am
Quoting BAWairbus (Reply 30):
I see. In that case I also agree that one toilet would not be enough.
Tod
Mon Sep 30, 2013 1:32 pm
Does the FAA require lavs?
AWACSooner
Mon Sep 30, 2013 2:20 pm
I think a few of the posters failed to see your sarcasm
speedygonzales
Mon Sep 30, 2013 2:27 pm
What about the extra door behind the wing from the -900ER, but only one overwing exit? Would that be sufficient for 200 pax?
Ignorance kills. :tombstone:
seahawk
Mon Sep 30, 2013 2:57 pm
Quoting awacsooner (Reply 33):
Sarcasm? Who would ever think that anything Ryanair does has another intention than offering the customer the cheapest tickets?   Remember it is the airline which considered taking a "toilet fee" on their flights.
The only bad thing is that people still fly with them.
Pe@rson
Mon Sep 30, 2013 3:01 pm
Quoting seahawk (Reply 35):
81 million in fact.
Stitch
Mon Sep 30, 2013 3:10 pm
Quoting cschleic (Reply 23):
The FAA defines a Type II Exit as a rectangular opening not less than 20 inches wide by 44 inches high. A Type III Exit is not less than 20 inches wide by 36 inches high, A pair of Type II Exits is rated for 40 passengers, while a pair of Type III are rated for 35.
The Type III exits on the 737NG are 20x36 inches per the EASA TCDS.
Quoting speedygonzales (Reply 23):
Replacing both Type III sets of overwing exits with Type II exits would increase the Exit Limit by 10 (from 189 to 199).
Quoting speedygonzales (Reply 34):
The 737-900ER Mid-Cabin Emergency Door can be rated as either a Type I or Type II exit. The difference between the two is 5 passengers, so a Type II raises the Exit Limit from 189 to 215 and a Type II raises it to 220. A Type III exit is worth 35 passengers, so removing one is not an option.
[Edited 2013-09-30 08:50:39]
RussianJet
Mon Sep 30, 2013 3:44 pm
I only ever fly them if it's super cheap, and that's pretty often. Last week for £40 return, for example. It's no bad thing.
*Yawn*. It's the only airline who could say such a thing where you'd KNOW that it was complete rubbish and would never happen. Hear it from another airline and you'd know it was real trouble.
Based on? People generally fly them because the price is right. They generally complain only if they did something stupid and failed to follow the very well-known rules.
✈ Every strike of the hammer is a blow against the enemy. ✈
Pe@rson
Mon Sep 30, 2013 4:21 pm
Quoting RussianJet (Reply 38):
Of course. But also because FR is one of the few airlines where you get exactly what is promised and for which you're willing to pay.
Escapehere
Mon Sep 30, 2013 5:42 pm
I don't know, but I'm sure they would. It's a health and safety issue, especially if one of them breaks mid flight. 2 toilets is probably enough for short 1-1.5 hour hops, but not for longer flights - say UK - Greece.
I was recently on a United A320 from Denver to Dallas, one of the rear toilets was out of order. Although it was a short flight, it still caused a long line to form down the middle of the plane and some rather uncomfortable looking passengers. You would think in situations like this they would allow passengers to use the J class lav at the front, which sat there unused while the line grew ever longer.
AWACSooner
Mon Sep 30, 2013 6:06 pm
I know you're not the only one here who feels that way, but man are you brave for actually stating that.
Quoting escapehere (Reply 40):
Back in 04, I was delayed for 3 hours on a flight from DEN-LAX cause the A320 had a broken lav in the back...NOT fun!
incitatus
Mon Sep 30, 2013 6:32 pm
Unfortunately the 757 is not among us anymore. The same zeal applied to the 757-300 would lead to the 300-seater narrow body.
That would be positively the cheapest capacity around for about 3000 nm. Ryanair could base them in MAN and DUB and send them across the pond to the NE US.
Conservatives against Trump
