fraport
Airbus Adjusts A350 Seat Config, Cuts Range
Wed Nov 13, 2013 8:41 am
According to german website aero.de Airbus has "silently" adjusted standard seat configurations and range of the A350 family on its website.
Considering that most airlines will operate their A350s with just two insteaf of three classes, Airbus has increased the standard seat count for the A358 by 6, for the A359 by just 1 (???) and for the A351 by 19.
On the other hand they cut the range of each model: for the A358 by 250nm, for the A359 by 350nm and for the A351 by 400nm.
While I understand that more payload means less range, it's quite strange that 1 (one!) additional seat on the A359 leads to 350nm less range (down to 7,750 now). This raises the question if the flight tests revealed some performance shortfall?
Here's the link - sorry for German only: http://www.aero.de/news-18512/Neue-Reichweiten-fuer-Airbus-A350.html
ap305
RE: Airbus Adjusts A350 Seat Config, Cuts Range
Wed Nov 13, 2013 8:50 am
This is already being discussed in the prototypes thread. This range/two class capacity figure is nothing new- it has been publicly known since 2011 and obviously has no relation to flight test performance given that the aircraft only flew in June of this year. All public indications from Airbus management has been that so far things are on track. I am not sure what's secretive about this?- do they expect Airbus to give a press release that their website is now updated?
[Edited 2013-11-13 00:54:37]
[Edited 2013-11-13 00:56:45]
sweair
Wed Nov 13, 2013 9:37 am
Not good sounds like the initial 788 downgrade..
AA737-823
Wed Nov 13, 2013 10:32 am
I wonder if it's in response to the so-called "Emiratization" of the 777-9X... since that airplane is becoming over-qualified for the job, perhaps Airbus is lowering some numbers to make the 350 more appealing to customers who feel snubbed by Boeing?
Especially since BA was complaining about too much range, as I recall.
waly777
Hmm, the A359 is the most surprising with 1pax increase and that much range shortfall. Initial expectations had been for range increases and not the reverse, hopefully this is something that can be improved upon during testing.
The test of first-rate intelligence is the ability to hold 2 opposed ideas in the mind concurrently, and still function
travelavnut
Wed Nov 13, 2013 10:35 am
Quoting sweair (Reply 2):
Nonsense, as been explained in the other thread the 2-class setup has more C-class seats and they're a lot heavier.
Live From Amsterdam!
sweair
Wed Nov 13, 2013 10:44 am
Sure sounds like a performance shortfall to me.
EPA001
Wed Nov 13, 2013 10:52 am
Quoting sweair (Reply 6):
It is not and it is already known for about 2 years that these are the numbers for a two class configured A350. So how would that qualify as a shortfall? This is exactly what is advertised and sold to the customers. So they know these numbers and have based their purchase decision on these numbers. Again, where is the shortfall?
scbriml
Wed Nov 13, 2013 10:54 am
You can make it sound however you like, the simple fact is, this isn't 'news' since it has been known for quite some time.
behramjee
Wed Nov 13, 2013 10:57 am
like i had stated yesterday on the SAA thread, the actual flying range capability of any aircraft sold by both Boeing and Airbus is approximately 15% less than the published stat.
So if the A359 stated range is 15,000KM, it can operate with a full payload under normal conditions a maximum trip journey of 12,750KM.
ap305
Wed Nov 13, 2013 11:06 am
I will try to make this easy
A.Kindly see this AIRBUS PRESENTATION FROM 2011:
http://www.aci-na.org/sites/default/...bus_update_for_aci-na_10-15-11.pdf
B. Go to the slide with the a350 range figures on PAGE 12
C. Carefully look at the figures for the a350 900
D. Compare them with the so called "new figures" at http://www.airbus.com/aircraftfamili...xwbfamily/a350-900/specifications/
At which point using some basic analytical thinking you should be able to conclude that:
These so called new figures have no relevance to current flight testing and do not suggest any shortfall SINCE THEY ARE FROM TWO YEARS AGO WHEN THE A350 WAS NOT YET IN FLIGHT TESTING.
There is quite clearly a mysterious weight difference between the two class "realistic" configuration and the 3 class setup. This mystery can only be solved if we have access to the different assumption of seat weight, ife, mission rules etc. There is also the fundamental fact that these marketing specs likely have little relevance to performance guarantees. Last but not least, John Leahy clearly suggested that the aircraft is performing to spec. The COO of a listed company is unlikely to say this if he was not particularly sure about things. My sincere apologies if this post was rude but people need to keep their biases aside when it comes to understanding what are basic facts- and I am not talking specifically about our a.net friends. This non story seems to be gathering its own ill informed momentum elsewhere.
[Edited 2013-11-13 03:26:22]
EPA001
Wed Nov 13, 2013 11:45 am
Quoting ap305 (Reply 10):
I think you were very successful with this attempt. It is indeed nothing new, nor is it any sort of sudden shortfall. That fact can not be made any clearer than the way you have put in your post.
travelavnut
Wed Nov 13, 2013 12:08 pm
How come?!
XT6Wagon
Wed Nov 13, 2013 12:11 pm
Quoting travelavnut (Reply 12):
How come?!
787 range decrease from the extra weight from going from 8Y to 9Y has long been held to be a "performance shortfall" by all too many people here.
moo
Wed Nov 13, 2013 1:01 pm
Quoting XT6Wagon (Reply 13):
I've not seen any evidence of that here on A.net - adding in extra weight in the form of an additional column of seats and passengers will of course have a negative effect on the aircrafts performance, but that doesn't make it a performance short fall.
kevinkevin
Wed Nov 13, 2013 5:24 pm
Quoting moo (Reply 14):
Glad someone has sense.
astuteman
Wed Nov 13, 2013 5:29 pm
For a long time Boeing advertised the ranges of the 787-8 and -9 as a "range of distances. Most of us were smart enough to work out that the lower number related to the 9Y seating......
How come?!
Because he's who he is?
mham001
Wed Nov 13, 2013 5:52 pm
Ok I get that. So have members here been using those numbers in their modelling?
tortugamon
Wed Nov 13, 2013 5:54 pm
Quoting Fraport (Thread starter):
Considering that most airlines will operate their A350s with just two instead of three classes
I am not sure that I accept this premise. On A358s and to a lesser extent A359 I imagine this might be true. However, on the A351 I would expect most configurations to have a first class cabin as the largest operators currently configure their 777s. 2-class 77Ws are not all that common.
Finally, I accept that first class is becoming less common in favor of more J seats but along with this change has arisen a large market for premium economy. Maybe some do not constitute premium economy as a true separate class the way some airlines currently configure and maybe 2 class seating estimates should be closer to 3-class configurations with premium economy, but I don't know if two-class seating estimates are that great of an indicator either.
However, There must a be marketing move here to be understood. Is Airbus trying to influence the image of their aircraft as larger as they see the market going even further to the right, or is this a response to the 777x and a desire to show that the A351 is a real competitor to the 777-9x. There obviously is an angle here that would be interesting to understand.
As many have stated, I do not see this as a performance short fall.
tortugamon
CRJ900
Wed Nov 13, 2013 6:59 pm
Quoting behramjee (Reply 9):
12,750km is a pretty good range, I'd say. We're talking IST-LAX-SYD, SIN-LHR, FRA-SCL etc and they are some of the longest routes that most airlines will fly, most flights will be shorter than that. Are we getting too caught up in wanting 20-hour nonstops? SIA had to give it up eventually and many trip reports say ULH flights are just too long.
Come, fly the prevailing winds with me
tortugamon
Wed Nov 13, 2013 7:27 pm
Quoting CRJ900 (Reply 20):
Come next month I don't think there will even be a 17-hour direct flight. 20 hrs are a little ways off.
Its not that newer aircraft need to be more capable, its that newer aircraft fly further with fewer pounds of aircraft. When weight is added (cargo) modern aircraft lose more range versus their predecessors. If modern aircraft fly 100nm per ton they also lose 100nm for every ton that is added.
tortugamon
lightsaber
Crew
Wed Nov 13, 2013 8:03 pm
Airbus has been too aggressive in assumed 'fitting weights' in the past. This sounds like customers have demanded the promised range reflect the weight of actual fittings. I do not know how much this plays a role, but I would suspect this is the case.
Now, these assumed weight fittings didn't fool any customers. They know how much seats, WCs, galleys, and overhead bins weight.
The A358 doesn't surprise me. It will not be optimized (for weight) as previously promised. The A35J doesn't either. That plane has a high wing loading and that means small changes in weight greatly effect range.
The A359 does surprise me. I suspect the first production models will be overweight and Airbus wants to claim in a year they beat promised range.
Not even in the same ballpark. The 788 dropped from 8200nm promised to 7400nm delivered (1st examples) and had to implement a MTOW increase ASAP (with altered structure) to have enough range for their customers. We're talking 7,750nm (late correction, I recalled the wrong promise range for the A359) range for the A359 before PIPs.
One thing about the new planes is they go further on every ton of fuel. So a miss in weight has a far greater impact on range. The math tells me the A359 will take off about 3t heavier than prior promise. Now, I don't know *anything* about the A359 coming in overweight, I'm just being realistic (or cynical, reader to decide). That is my interpretation.
The 788 was 6t overweight. See my post #15 in this thread:
AviationWeek - 787 Better Than Expected Fuel Burn (by pygmalion Jun 26 2012 in Civil Aviation)
Now, Boeing was supposed to meet promise weight starting with LN90. Did they? My rumor mill is claiming it will now be LN 130 to LN 140. But that isn't based off anything substantive. I do wonder if it will take the weight savings of the 789 tail to meet promise weight on the 788.    And the 788 will carry 9-across Y which should be another ~3t of payload which cuts range about 350nm... why does that number seem familiar.
So unless Airbus cuts another 350+nm from the A359 range, we are not revisiting the 788 downgrade...
Quoting tortugamon (Reply 21):
   Although that should be about 115nm per ton for the 788/A359.
Edited to correct A359 promise/final range.
Lightsaber
[Edited 2013-11-13 12:05:35]
Aesma
Wed Nov 13, 2013 8:04 pm
Doesn't Y+ count as a class ?
tortugamon
Wed Nov 13, 2013 8:21 pm
Quoting lightsaber (Reply 22):
I have read on here that the A351 has a relatively low wing-loading that rivals the 777-9x. Though I confess that I have given up calculating it as the different wing area calculation methodologies get me frustrated.
Aspire Aviation claims that they hit weight target a little earlier:
LN103 787-8 meeting weight targets
http://www.aspireaviation.com/2013/0...ng-787-is-a-dream-come-true-again/
Quoting Aesma (Reply 23):
I guess it depends. Some airlines seem to just offer an extra 3-4" of pitch and hold everything else constant. And if they offer less then 8 rows of it then it could really not even impact the number of rows total. However, on recent wide bodies it is exceedingly more common to drop a seat or two per row and add pitch. I call this true premium economy versus the former I call economy plus. If its premium economy I think it should definitely be considered a separate class.
tortugamon
Ruscoe
Wed Nov 13, 2013 9:22 pm
Quoting scbriml (Reply 8):
If it is a change since the design was frozen, then I can't see how the longth of time we have known it has any relevance.
Well, what else is he going to say. You will recall Boeing repeatedly saying the 787 would meet promised performance also. The question is what spec. If you keep changing the spec of course you are going to meet it.
Ok so maybe not "silently", but if you go to the current figures on the 350 site you will note that on the opening page the figures given are 315 pax for 7800nm, whilst in a subsequent page it is more than 300pax for 7750nm.
So it appears the article has taken the most optimistic figures 8100nm for 314 pax and compared that with the most current figures and come up with the numbers they have.
I would advise caution here, the numbers and wording from Airbus could indicate a small problem.
Ruscoe
kevinkevin
Wed Nov 13, 2013 10:09 pm
If a newly manufactured long-haul aircraft was unable to do those routes - especially LHR-SIN - there wouldn't be any point in the aircraft.
ap305
Wed Nov 13, 2013 11:47 pm
Quoting Ruscoe (Reply 25):
Kindly go to page 18 of this Airbus presentation from march 2009
http://services.penton.com/Images/SA...3rdAviationIndustrySuppliers_P.PDF
It would appear that this so called range change(at least for the 900) dates back all the way to early 2009 which is around the time when .... you guessed it .... the design of the a350-900 was frozen. I hope this marks the end of this non news.
[Edited 2013-11-13 15:52:24]
billreid
Thu Nov 14, 2013 2:02 am
I think what is broadly missing is what the airlines do.
Planning will take each available frame and run an extensive analysis of possible routes and costs.
What this means is that the end result is seeing how the aircraft from each manufacturer performs under a broad range of criteria.
The marketing BS is all fine and dandy but at the end of the day it is the analysis of all costs with projected routes that delivers the answers for each airline. The thousands of different scenarios using many different data points will determine what the risk is with each frame from a cost perspective is. AB and BA has the ability to impact performance not only with aircraft performance but also through price. A simplistic answer would be if the component of ownership is 20% of CPM and the CPM is 5.0CPM on AB and 5.2CPM on BA then each airline has the ability to adjust many different factors to win the sale.
Where a frame makes a difference is when there is no competitor in its class.
It therefore appears that BA and BA are lining their aircraft between each other all else being equal.
Ie. B787 next A350 next B777X next A380 ...... each aircraft has advantages against each other but at the end of the day the mission average need of the airline will dictate the needs over the projected use life of the frame.
What is hugely interesting is that range difference results in needing different frames. I believe this is why so many small providers have died. They cannot compete without different frames but they do not have demand to justify a broad fleet so they are uncompetitive with the big boys.
Some people don't get it. Business is about making MONEY!
lightsaber
Crew
Thu Nov 14, 2013 2:05 am
Quoting tortugamon (Reply 24):
Thank you, that link stated LN103. So perhaps I just had a dyslexic moment? (LN103 vs. LN130)   Good to hear the 788 is at weight. Everything I'm hearing about the 789 is good (some additional weight reduction that might or might not find its way to the 788).
Did I cross connect the 78J and the A35J? I believe so. Mea Culpa.
Lightsaber
neutronstar73
Thu Nov 14, 2013 3:19 am
So will I:
http://leehamnews.wordpress.com/
I guess the presentation you were linking to was not jiving with the website, and I think that's where people have a problem.
[Edited 2013-11-13 19:27:30]
ap305
Thu Nov 14, 2013 3:40 am
Quoting NeutronStar73 (Reply 30):
So will I:
The presentation says 315 passengers for 7800nm and the Airbus website shows 315 passengers for 7750nm... Whats not jiving for you? And whats with the Leeham link? Everyone is aware where this thing started. Better yet - look at the even older presentation with the same figure- is that not "jiving" too?
[Edited 2013-11-13 20:18:01]
Ruscoe
Thu Nov 14, 2013 7:06 am
Quoting ap305 (Reply 26):
Quoting Ruscoe (Reply 25):If it is a change since the design was frozen, then I can't see how the longth of time we have known it has any relevance. Kindly go to page 18 of this Airbus presentation from march 2009
Thankyou for that, however I have a print out from the Airbus website dated 9/4/2010 which quotes range of 8300nm.
Also have a Flight Global article dated 13/07/2010 which gives a range of 8100nm.
Also at the 2012 EADS Global Investor Forum range for the 350 with 315 pax range is 7750nm
In all this the MTOW has stayed constant, while the range has decreased..
So if you have less range at the same MTOW (and only one extra pax) how is that to be interpreted?
Ruscoe
ap305
Thu Nov 14, 2013 9:54 am
Quoting Ruscoe (Reply 32):
I would guess different seat weights, galley configs, mission rules, ife configuration etc etc. The 315/2 class at 7750-7800 seem to have been constant for the better part of 5 years since the freeze of the aircraft config. Since that is the lowest figure range wise I guess that would be the most realistic one publicly available. As far as what has been guaranteed to the customers that is something we will not know.
BoeingVista
Thu Nov 14, 2013 10:06 am
As a change in OEW caused by heavier customer furnished equipment, its not rocket science.
But if you want to see a conspiracy you go right ahead.
BV
Ruscoe
Thu Nov 14, 2013 1:41 pm
Quoting BoeingVista (Reply 34):
Fair crack of the whip !
The furnishings etc etc would be the same now as 5 years ago, or if anything lighter, but that is irrelevant.
The MTOW has not changed but the range has gone down at least since 2010.
This is nothing to do with a conspiracy, it is just a fact that the range estimates for the 359 went up and are now on the way down.
To me it looks a performance shortfall. Not a big one, but a shortfall nevertheless
Quoting ap305 (Reply 33):
Yes I agree with that but
As mentioned above. If you look at todays range and that of 5 years ago, it is fairly constant, but if you look into those five years you find that the range went up and is now down again.
Ruscoe
lightsaber
Crew
Thu Nov 14, 2013 1:43 pm
Quoting billreid (Reply 27):
   I think too many analysis departments were tired of telling the BOD that planes didn't have the advertised mission range.
Lightsaber
ap305
Thu Nov 14, 2013 1:55 pm
Quoting Ruscoe (Reply 35):
As has been explained, this is likely down to differing aircraft configurations in terms of seats,ife, galleys etc. i.e there is likley a fundamental difference between the 3 and 2 class configurations beyond just seat numbers.
If the marketing range at a particular configuration is the same at the time of design freeze and is the same now- where are you seeing the shortfall?
[Edited 2013-11-14 06:00:34]
EPA001
Thu Nov 14, 2013 2:14 pm
Quoting ap305 (Reply 37):
Good question.  .
Fact is, there just is no new shortfall as suggested, the numbers are steady since design freeze. And all is on track during flight tests. The first frames, even though slightly overweight, are within specs on the designated performance. The later frames will improve on the specified numbers. So all is looking very good for the A350-XWB performance instead of worrying, what a real and unexpected shortfall would be.
BoeingVista
Thu Nov 14, 2013 11:55 pm
Quoting Ruscoe (Reply 34):
OEW changes effect range even if MTOW remains the same as I say this is not rocket science.
The weight of business suites has been going up to the level where they are now causing CoG issues with older aircraft designs.
BV
Motorhussy
Sat Nov 16, 2013 4:17 am
Quoting BoeingVista (Reply 38):
CoG issues
Excuse my ignorance but what does the acronym stand for?
come visit the south pacific
mham001
Sat Nov 16, 2013 4:28 am
Quoting motorhussy (Reply 39):
Center of gravity.
parapente
Sat Nov 16, 2013 10:34 am
What IAG have done is rather clever. First they are IAG so have the flexibility to switch the aircraft to Airbus loyal Iberia. Second they have 6 ( I think) options on 380's and 18 on 351's so they have airbus covered. If however load factors/routes start to favour the middle ground then they can ( as suggested above) invite Boeing to pitch for 20 779x's. the family of aircraft is already very familiar to BA.
billreid
Sat Nov 16, 2013 3:55 pm
Quoting lightsaber (Reply 35):
Lightsaber
You understand this. It would be interesting to have a thread discussing Aircraft Route and long range planning analysis. We sit and discuss the different frames (on A-net) in very generalist terms but the actual need of each carrier differs so much based upon many different criteria. In short, this industry is not simple at all and a thread to discuss a $300MM frame is all fine and dandy but the reality is there are many different business options and the airlines themselves also have the ability to adjust the way they do business.
In the end the A350, B777X and B787 will all sell. I only question the 4 hole planes because on a broad scale the two holers can do the job at less cost from a MX perspective. As cool as the A380 may be I believe its days are numbered especially if the B777X comes close to the specifications being sold.
