Wayfarer515
SSJ100 To Get FAA Airworthiness Certificate
Mon Feb 24, 2014 6:04 am
An interesting link ( in Russian only,sorry) where UAC President Mikhail Pogosyan announces the SSJ100 will soon be granted its airworthiness certificate by the FAA. Probably, the most interesting part is that Mr. Pogosyan mentions there have been several US airlines who have expressed interest in the SSJ100.
http://www.vedomosti.ru/companies/ne...blizhajshee-vremya-mozhet-poluchit
It would be quite interesting to know which carriers could be interested in it. I recently read another article from an airline strategist that mentioned how the SSJ100 would be a very interesting airplane for an LCC/ULCC operation, due to its low acquisition cost, ample cabin room, cargo bins/cargo bay, and low fuel consumption.
IIRC UTAIR's SSJ100LR will come in a single class arrangement of up to 103Y pax. with 29" pitch. Interjet's SSJ100 single class configuration is for 93Y with a 34" pitch. Armavia had a 98Y with 32" pitch configuration. Interjet seems to be performing quite well with its LCC-like operation with the SSJ100 (IAJ is a hybrid with some Southwest-esque features), so it doesn't seem you have to turn it into a tuna can with a 29" pitch to make it profitable.
KELPkid
RE: SSJ100 To Get FAA Airworthiness Certificate
Mon Feb 24, 2014 6:17 am
IIRC, the one issue that holds back FAA certification of the SSJ100 is that the engines don't meet the US FAR fan blade containment requirements in a fan blade failure case...wonder how they plan to address this one    Other than that, they are in pretty good shape as the aircraft holds a European type certificate.
ssteve
Wed Feb 26, 2014 2:57 am
bump.
If true, this puts more heat on the CSeries. But they're clearly feeling it regardless.
tyler81190
Wed Feb 26, 2014 3:06 am
Quoting Wayfarer515 (Thread starter):
As a joke, Ill throw ZK out there... now that the laughing is out of the way, I would more seriously suggest possibly NK, or maybe even F9. Though if you throw in a F cabin and bring it below scope clauses, perhaps some regional operators would buy. Or perhaps a larger airline? But I have no speculation on what company would best suit the SSJ.
Quoting KELPkid (Reply 1):
I would assume a simple engine cowl re-design would solve this, assuming there isn't a major weight change for this. )also probably a costly change for FAA certification) Though it could be that the newer build SSJs have already solved the issue and we just don't know about it yet.
Quoting SSTeve (Reply 2):
If BBD feels anymore heat they might as well re-locate their offices to Mercury. I wish the c-series program the best, but there have been so many delays and issues with the program with no firm interest in it.
Thenoflyzone
Wed Feb 26, 2014 6:04 am
The SSJ and the CSeries do not compete against each other. They cover two different market segments.
If anything, Embraer should be worried, as the SSJ competes directly with the E170/190.
Quoting tyler81190 (Reply 3):
That's not entirely BBD's fault. Boeing and airbus screwed up with the 787 and the A380, and so airlines are playing it safe with the Cseries just in case. The orders will come once initial deliveries commence next year.
BBD is doing good, considering the Cseries is a clean sheet FBW design and a first under wing engined aircraft for BBD. Delays are to be expected. Still nothing compared to the delays of the A380 and 787!
Thenoflyzone
[Edited 2014-02-25 22:16:50]
us Air Traffic Controllers have a good record, we haven't left one up there yet !!
planemaker
Wed Feb 26, 2014 6:36 am
Quoting thenoflyzone (Reply 4):
The SSJ100 and the CS100 do compete against each other as they are both considered in the 100-seat market. People have this misguided notion that if aircraft don't have the exact same seating configuration that they do not compete.
BBD is doing good
Based on...
- The very poor order book?
- Multiple last minute delays?
- The very slow pace of test flights?
- The lack of credibility?
- The firing of the CSeries chief salesman?
- The lay off of 1,700 aerospace workers?
Nationalism is an infantile disease. It is the measles of mankind. - A. Einstein
Wayfarer515
Wed Feb 26, 2014 7:31 am
I´ll try not to turn this into a BBD vrs Sukhoi thread, as my intended OP was to highlight the fact that UAC announced that they should be getting their FAA certificate soon.
That said, if we had to compare the CS100 vrs the SSJ100 programs, I'd say Sukhoi has done a much better job, especially if you consider the excellent reliability record the SSJ100 has shown if we take out Aeroflot, which we can say has a very shady business going on with its SSJ100´s.
If BBD manages to get a similar reliability to the SSJ100 then the delays will be worthwhile, if they delay it ala Boeing 787 only to turn out a cucumber, then they are going to get in very deep you know what.
Back on topic, I am pretty sure Powerjet International was already undergoing tests to comply with the FAA´s blade containment requirement. That said though, the SAM-146 has been undergoing with this and a weight reduction program for quite a while now, so its probably not linked with any potential orders from a US carrier.
I'd think a 103 seat SSJ100 for airlines such as NK would be perfect for some of their thin routes during low season such as SAP.
Regarding the price, I am pretty sure you can get a SSJ100 for the same list price as an E70, so it is a very good bargain for the amount of seats or extra room you can get.
Let's wait and see what happens.
RussianJet
Wed Feb 26, 2014 8:04 am
Let's hope it happens. I'd love to see a bit of a roll for the SSJ, following the positive InterJet assessment and so on. I know the frame is still apparently having some maturation issues such as flap problems, not to mention the fan blade containment factor required for certification, as mentioned earlier by another here. I still genuinely think this plane is going to do certainly a lot more business than looked likely at one stage, and possibly - with a good bit of luck - even end up doing reasonably well overall, particularly given the generally challenging circumstances of the project (particularly the mere fact it's of Russian-led production/origin) .
✈ Every strike of the hammer is a blow against the enemy. ✈
Aviaponcho
Wed Feb 26, 2014 8:48 am
Airplane and Engine has EASA certification (the same as airbus birds indeed)
I guess FAA certification is only paperworks. Is it?
sturmovik
Wed Feb 26, 2014 11:16 am
Quoting Wayfarer515 (Reply 6):
Could you elaborate on the shady business a bit more? If you think it'll derail the thread, you could PM me.
Off topic, is there any further news from Morocco on the SSJ trials?
'What's it doing now?'
queb
Wed Feb 26, 2014 12:06 pm
Quoting planemaker (Reply 5):
Just to clarify, about these 1,700 layoffs:
- 600 are from Learjet Wichita facility (Lear 70/75 decreasing production and Lear85 slower ramp-up)
- Between 300 and 400 from IT department (mainly in Mtl)
- Between 100 and 200 from Toronto (DHC) facility (Lear 70/75 and Q400 decreasing production)
- The remaining are mostly temporary contract workers in Montreal laid off due to slowing production on the CL605 and production ramp-up slower than expected (because of delays) on the CSeries.
- Among these 1700, an undisclosed number can apply on available jobs on other programs if they are qualified.
Thenoflyzone
Wed Feb 26, 2014 3:04 pm
So did the B737 back in the sixties, but yes, you are right, we all know how that turned out to be a flop.
Details that need to be tweaked. It's normal. What do you want. It'll all be forgotten once the plane is delivered next year.
says who?
About time, he was doing a shity job ! The entire marketing team should be fired !
Typical knee jerk reaction by management. You see it everywhere ! In BBD's case, it has more to do with cash flow problems than anything else. They'll all be back within a year or two.
Since when is a plane that can carry 108 to 160 passengers considered to be a 100 seater?
The lightest Cseries is 10 tonnes heavier than the heaviest SSJ, can carry almost 3 tonnes more payload, and fly 1000 km further. That's direct competition alright.
Now do the same with the E-190/5. Tell me which once is more of a direct competition.
Thenoflyzone
[Edited 2014-02-26 07:08:10]
ssteve
Wed Feb 26, 2014 3:12 pm
Quoting thenoflyzone (Reply 11):
I actually thought they were closer peers than that. And yes, sorry to make things more of a BBD discussion... I just wanted this thread to continue. More in the OP's line, why *would* US airlines want the SSJ. For missions with 90 seats? So it's definitely for regionals?
planemaker
Wed Feb 26, 2014 5:15 pm
Quoting queb (Reply 10):
Bombardier laying off 1,700 aerospace workers, mostly in Montreal area
Honestly, there is absolutely no parallel between the 737's history and the CSeries nor, more importantly, between Boeing and BBD.
BBD said the delay was to the second half of 2015. With the pace of the program it could easily slip into 2016. There is even the possibility that the A320NEO could EIS before the CS100.
BTW, it isn't "normal" when BBD "bragged" in the lead up to the missed original first flight date at the end of 2012 that they had ensured that they wouldn't have any delays.
says who?
There isn't an industry periodical or financial newspaper that says otherwise.
It is permanent...
MONTREAL - Bombardier is permanently laying off 1,700 employees in its aerospace division
If you look at Bombardier's own marketing material it states that the CSeries family (CS100 & CS300) is in the 100 to 149 seat market category. The CS100 which is being discussed obviously doesn't carry 108 to 160 pax as you imply.
As stated previously, no two aircraft have the same seat configuration. Airlines will look at all aircraft in a seat segment and will decide which one is best for their network based on several factors - seat configuration is just one single factor. For example, JetBlue founder David Neeleman flew up to Mirabel to check out the CRJ900 before ultimately choosing the E190.
Quoting SSTeve (Reply 12):
Getting back to the SSJ... if the Russians can spend $50-billion just to "win" hockey gold at home (Ovechkin's pre-Olympic joke that backfired!) what's a billion to get FAA certification?
KELPkid
Wed Feb 26, 2014 8:26 pm
Quoting aviaponcho (Reply 8):
Yes, but I believe the EASA and FAA differ on at least the fan blade containment requirements...
I'm sure that the FAA will take the EASA's word on tests already performed, but require any tests that aren't part of the EASA's certification regimen. I'm not feeling like pouring through FAR Part 25 and the EASA equivalent regulations to find out what those might be
Aviaponcho
Wed Feb 26, 2014 9:26 pm
http://avia.superforum.fr/t1023-sam146-powerjet#17515
For sure Sam146 has passed Fan Blade of
An148/158 engine (D436) is russian certified and has not passed fan blade off.
Tell me if i'm wrong ?
MUWarriors
Wed Feb 26, 2014 10:29 pm
Quoting planemaker (Reply 13):
What's funny is the article you link to backs up his numbers exactly. The article states 1100 jobs were to be from Canada (1700-600 in Witchita = 1100). The article further states 80% of the Canadian jobs are to be from Montreal (1100-200 from Toronto = 900. 900/1100=81.8%). The article also says some of these folks will be recalled, when conditions warrant. So yeah, you sorta proved him right.
I'm not commenting on the rest of you're opinion, but a little more than a knee-jerk anti-BBD reaction may occasionally be helpful.
aryonoco
Thu Feb 27, 2014 12:27 am
Why don't we setup a dedicated thread about BBD and C Series business case since it looks like that's greatly wanted? First the C Series flight testing thread was hijacked for this and now this SSJ thread. I have no objections to discussions about where BBD job cuts are going to fall, but it really is OT here.
Wayfarer515
Thu Feb 27, 2014 5:24 am
Quoting aryonoco (Reply 17):
Couldn't agree more, lets keep the talk here about the SSJ100 FAA certification or at least the SSJ100
Quoting sturmovik (Reply 9):
Ok, I have talked about this extensively in other SSJ100 threads, but to make it short I'll say the following: When AFL agreed to buy the SSJ100, supposedly due to big pressure from Mr Putin, AFL required a penalty clause in which SCAC would pay compensation to AFL every time an SSJ100 went tech., three years later and guess what. The average utilization rate of the SSJ100 in AFL is just about 5 hrs. per day, with about half of the currently available ten airframes being grounded all the time. Compare that to Interjet, Sky Aviation, Yakutia, SSJ100 fleets and you see a big gap, especially when IAJ announces their SSJ100 fly nearly 10hrs per day, all airframes being used simultaneously and dispatch reliability well above 99%. So that's why now everyone is wondering if AFL is intentionally grounding their SSJ100 fleet.
About the RAM and SSJ100, it seems this one will go to BBD and their CRJ1000NG, since there is a big component factory in Morocco producing parts for guess who, BBD CRJ1000NG. It would be very stupid of them not to go with BBD.
sturmovik
Thu Feb 27, 2014 5:31 am
Quoting Wayfarer515 (Reply 18):
Thanks a lot for that info!
lollomz
Thu Feb 27, 2014 7:12 am
Any idea about the US Airlines who have expressed interest in the SSJ-100???
[url="http://www.diecastmodelaircraft.com/collection/Lollomz"]Image[/url]
point2point
Thu Feb 27, 2014 7:55 am
We know that 4O is currently flying the SSJ100 on its Mexico routes.
With this, I'm assuming that 4O will not be allowed to fly any routes with the SSJ100 into the U.S. until the SSJ100 gets certified by the FAA, that would be correct, yes?
Also, is 4O currently only permitted to fly these inside of Mexico, since so far we know that the government of Mexico has certified this plane. Have any other countries, such as in Central America, or in the Caribbean, where 4O would physically be able to route the SSJ100, of approved this plane.... e.g. could 4O tomorrow put this on its MEX-GUA route, do we know if Guatemala has certified this plane, or what other countries have certified? Although I would assume that probably Cuba has certified this plane, but could the SSJ100 be substituted on the 1100 mile MEX-HAV route tomorrow, does it have the range for this?
Or will the SSJ100 remain inside of Mexico's boarders for a while?
Aquila3
Thu Feb 27, 2014 8:34 am
I think most of the countries you have named would be just fine with the EASA certification. It is not like the SSJ100 was certified in the Soviet Union. Or not that it comes from a place whre they have no clue and are entering the aerospace industry just now, like a few other that just come OTOH.
BTW I am not sure that even to fly to the USA for an airline with Mexico (or EU, for what matters) certificate a FAA approval is necessary. I believe the EASA would suffice, but I will stand corrected if not.
Then, about the (welcomed, in my opinion) modifications in order to get the blade-off containment, if they would cost one billion, as it was said by someone that seems well informed, then they might just go for a re-engine with a more modern unit. That would make the SSJ a killer. But I believe this is not the scope of the project as it was intended at the beginning, at least. The SSJ I believe was done from such airlines and such countries that need a viable, reliable,modern product taking care of the budget. In such countries sometimes the cost of the fuel is less a burden than here. For the ones tha want the top-notch of the technology and the efficiency there will be (very soon I hope) the CS100.
chi vola vale chi vale vola chi non vola è un vile
A342
Thu Feb 27, 2014 9:33 am
Quoting point2point (Reply 21):
No. Not having FAA certification only means you can't register it in the USA, but flying there (or anywhere else for that matter) is perfectly fine. Most Soviet/Russian aircraft don't have a FAA certification, yet operate commercial services to the USA.
Exceptions confirm the rule.
planemaker
Thu Feb 27, 2014 12:48 pm
For those interested in a closer peek, a 360 dynamic tour (with zoom) of the cockpit and cabin is available half way down the page at the "Cabin" section on the SuperJet International website.
http://www.superjetinternational.com/wp-content/uploads/cabin_main.jpg
http://www.scac.ru/en/wp-content/uploads/cockpit_cut-2-rendered-3_en.jpg
http://www.scac.ru/en/wp-content/uploads/cabin_main.jpg
bjorn14
Thu Feb 27, 2014 3:38 pm
Will this be the first Russian craft to get FAA certification? BTW, I can't see any US carrier configuring it for 103 pax . 1 more FA for just 3 seats. I don't think so.
"I want to know the voice of God the rest is just details" --A. Einstein
point2point
Thu Feb 27, 2014 4:08 pm
Quoting Aquila3 (Reply 22):
Quoting A342 (Reply 23):
Thanks for the info.... and I've wondered the process of such here...... and I learned something new today. Let's keep our fingers crossed now so that I can remember it, eh?
Quoting planemaker (Reply 24):
the pic makes this airplane look appealing.... I like the blue/white coloring, and it seems as if the seats would be comfortable....
mhkansan
Thu Feb 27, 2014 4:15 pm
Quoting bjorn14 (Reply 25):
G4 has 156-seat A319s. I have no idea why they thought that was a good idea.
argonaught
Thu Feb 27, 2014 4:39 pm
I thought that (uncle) SAM-146 is a rather new design, developed by Snecma specifically for the SSJ100?
The cabin is very impressive, by the way. I am guessing this would be the Pininfarina interior for 4O?
The global aerospace industry now is not what it used to be when the Soviet Union was its prominent player 30-40-50 years ago. Sometimes past experience and habits are liability and must be unlearned.
Before the SSJ100, Sukhoi had never made a commercially successful civilian aircraft. The aerial displays by Sukhoi Flankers are surely a big crowd-pleaser at airshows, but their competence in building super-maneuverability fighters doesn't automatically translate into mass-producing a superior airliner.
Mr. Puting should have instead passed the law, obliging every oligarch to purchase at least one Superjet
For some reason I thought the Canadians were hustling to build a CRJ1000 FAL in Morocco? Which could have morphed into "the" CRJ1000 FAL, as there aren't many orders for it outside of Morocco.
A342
Thu Feb 27, 2014 6:11 pm
No, there are some already: Ilyushin IL-96T and IL-103 as well as the Beriev Be-103. The first is a freighter derivative of the IL-96 with PW2000 engines and westernised avionics. Only the prototype was built and the programme is dead. The latter two are small GA aircraft. Here are the type certificate data sheets, if anyone is interested:
http://rgl.faa.gov/Regulatory_and_Gu...768625723a00561eb6/$FILE/a54nm.pdf
http://rgl.faa.gov/Regulatory_and_Gu...cf86256c40006f40df/$FILE/A45CE.pdf
http://rgl.faa.gov/Regulatory_and_Gu...2d86256d74005d57d2/$FILE/A55CE.pdf
The following Comment on the IL-96T certificate is interesting: "A FAA Certificate of Airworthiness is not to be issued until compliance is found to SFAR 88."
I believe this refers to the recently-introduced fuel tank inerting requirements.
planemaker
Thu Feb 27, 2014 8:54 pm
Quoting point2point (Reply 26):
Some details... (though they should train the pit crews to load the luggage better!)
http://www.superjetinternational.com/wp-content/uploads/Seats.jpg
http://www.superjetinternational.com/wp-content/uploads/Aisle1.jpg
Quoting argonaught (Reply 28):
Yes, that is the Pininfarina interior.
Wayfarer515
Fri Mar 14, 2014 8:55 am
So IAJ's CEO Jose Luis Garza has confirmed today that the FAA has granted IAJ the certificate to operate the SSJ100 to USA.
Only link I could find is in Yahoo MX(Spanish link):
http://es-us.noticias.yahoo.com/auto...rce=twitterfeed&utm_medium=twitter
Would be nice to know which routes they're planning to use their SSJ100's inside the USA.
TheRedBaron
Fri Mar 14, 2014 12:51 pm
I bet they will use it in MEX-SAT... almost 100% sure.
TRB
The best seat in a Plane is the Jumpseat.
a300
Sat Mar 15, 2014 3:32 am
True. Aeroflot flew into IL-62s into JFK for many years during the Cold War and IL-96s into LAX immediately after the fall of Soviet Union.
Boland Aseman Jayegah Man Ast.
rwessel
Sat Mar 15, 2014 4:39 am
Quoting a300 (Reply 33):
For a few years in the 90s, IL-76s were a regular sight in the cargo area at ORD.
r2rho
Sun Mar 16, 2014 7:02 pm
Glad this thread is now back on track. As has been mentioned, FAA certification is not needed to operate into the US. Which means that if they're aiming for FAA certif it's because some kind of interest has beed shown by potential US customers. Otherwise the EASA certification would be enough for Sukhoi's needs.
Why should they? Most are configuring in 98 seats with very generous economy pitch, but for US carriers the attractiveness would be to configure them in dual class while staying under scope clauses, similar to AA E175's.
Yes, and it's a 50-50 joint venture between Snecma and Saturn to be precise. On paper, it should be somewhat better than the CF34, I'd guess by high single digits, but I don't know anything about it's real performance numbers. As a regional engine, I assume it is more optimized for high cycles than long cruise.
Wayfarer515
Mon Mar 17, 2014 5:49 am
Quoting r2rho (Reply 35):
If the cruise fuel consumption is anything to go by, I've seen SSJ100's doing 1400 kg/h, dunno for sure what is the CF-34 in the E190 capable of but I think I've read here in the forums it goes around 1800 kg/h in cruise mode, so it does seem to be pretty good.
By the way, Powerjet International has continued improving the maintenance and weight reduction of the SAM-146, I believe now they have achieved all the original targets regarding reliability and will now shift their focus to continue the weight reduction program. They have even started studies to increase the thermal envelope of the low pressure turbine, so there are also performance gains coming as well.
To get a bit back on topic, SCAC's current backlog goes up till 2015, that's even with the increased target of 60 frames for 2015, so one has to wonder if any orders come from some US carrier when would they be delivered. Unless of course they begin a new manufacturing plant which I heard of some time ago would be in Voronezh.
Of course, we don't know what will be the effects, if any, of the current Crimea affair between USA and Russia commercial relations.
DTWPurserBoy
Mon Mar 17, 2014 11:42 am
I think the current politial tension between the US and Russia will preclude any immediate sales and the aircraft may well be part of any embargo that is imposed. In the long run, that may be beneficial to some carriers as it will give them more time to evaluate performance and reliability prior to placing any orders. I would imagine the Russians would make a very attractive financial package which Bombardier or Embraer would find difficult to match.
Depending on the outcome, I could see some of the conncector carriers using the aircraft in a mixed configuration. But there is still that nagging feeling of unreliability around Russian built aircraft that could make it hard to sell here. It probably would have better luck in South America, Africa and Eastern Europe.
Qualified on Concorde/B707/B720/B727/B737/B747/B757/B767/B777/DC-8/DC-9/DC-10/A319/A320/A330/MD-88-90
argonaught
Mon Mar 17, 2014 12:25 pm
Quoting Wayfarer515 (Reply 36):
A bit off-topic: I'd predict that the mainland Ukraine will eventually join EU, which will likely bring an end to Antonov as an (independent) manufacturer. This is just the way it has gone with most Eastern European indigenous companies. Which would be a pity, because they had a couple of impressive designs like the An225, An124 and An70.
Wayfarer515
Mon Mar 17, 2014 2:44 pm
In the meantime, IAJ gets its 6th SSJ100, and their numbers continue to look impressive:
From the article:
The five SSJ100s in service with Interjet are confirming an excellent performance with over 99% dispatch reliability and an average daily utilization of 9 flight hours, through 9 destinations in Mexico (from Mexico City to Torreon, Aguascalientes, Campeche, Minatitlan, Manzanillo, Zacatecas, Mazatlan, La Paz and Reynosa).
Full link
http://www.scac.ru/en/mediacenter/si...ivered-to-interjet17-03-2014/2014/
I wonder if this one will be destined for the US routes, I'd love to see how it performs in slightly longer thin routes in the 800nm-1000nm range.
kmot
Mon Mar 17, 2014 3:58 pm
What is the list price of the SSJ100?
nws2002
Mon Mar 17, 2014 6:26 pm
Quoting mhkansan (Reply 27):
All of G4's aircraft use 4 flight attendants except the 757. I read somewhere that their load factors exceed 90%, so I imagine those 6 seats are often filled.
argonaught
Mon Mar 17, 2014 8:50 pm
Quoting kmot (Reply 40):
I think it's $35m apiece, but there are different versions (Basic, LR, Full, Light). For some reason, the figure of $24m has stuck in my mind as the "average" real-life price so far. That said, AFL, being the launch customer and thusly risk-sharing partner fanagled themselves a sweeheart deal south of $20m
[Edited 2014-03-17 13:51:37]
Wayfarer515
Tue Mar 18, 2014 2:12 am
Quoting argonaught (Reply 42):
Supposedly the "actual" selling price for the B(for Basic) version is around 24-25M USD give or take, that's about 4 to 6 million lower than the "actual" selling price of the E190. The LR version goes around 2 to 3 million more.
IAJ got theirs around the 20M price tag, two main factors for them getting such a low price is because they were the first Western customer, and secondly because IAJ was their first direct purchase, plus the 15+5 airframes which is not small qty. at all. I think the only other customer who made a direct purchase for their SSJ100's was Gazpromavia, since they have the big bucks to do it. All the rest, including AFL, are using some kind of lease through a Russian bank.
Wayfarer515
Thu Mar 20, 2014 1:56 am
The D.O.T. has extended the following flight certificates to IAJ, wonder if any of these will be covered with the SSJ-100:
Ciudad de México-San Antonio
Ciudad de México -Nueva York
Ciudad de México-Miami
Ciudad de México-Laredo
Wayfarer515
Tue Mar 25, 2014 2:17 am
Speaking of certifications, it seems the SSJ100 has been doing supplemental certifications at Karlovy Vary, supposedly they are testing the latest software that permits flap deployment even with slat failure.
It also seems they are trying to reduce the current landing distance @MLW, which is currently at 1600m.
Short video of the tests @ KLV:
https://www.youtube.com/watch?v=z2a9mSY3J-M&noredirect=1
AM744
Tue Mar 25, 2014 5:23 pm
Quoting Wayfarer515 (Reply 44):
Wow. Can it make JFK from MEX? Doesn't look like it, but I don't know.
AR385
Tue Mar 25, 2014 5:37 pm
Quoting TheRedBAron (Reply 32):
I thought I heard they were planning to used them on medium density routes from MTY, to compete with AM connect which is making a lot of mony doing that with their ERJ-145s.
TheRedBaron
Wed Mar 26, 2014 4:34 am
Its possible MTY used as a hub for other USA cities, with feeding traffic from MEX ...
TRB
AR385
Wed Mar 26, 2014 4:46 am
Quoting TheRedBAron (Reply 48):
TRB
Boy I hope so. I´d love to go on a Saturday joyride on the that Superjet!
