MAH4546
Gol Applies For VCP-SDQ-MIA
Thu Mar 27, 2014 6:35 am
Interesting move by Gol. It has applied with Brazil's ANAC to begin service between Viracopos and Miami via Santo Domingo three times a week.
http://g1.globo.com/sp/campinas-regi...r-voos-entre-campinas-e-miami.html
Gol currently flies two U.S. routes: MIA-SDQ-GIG and MCO-SDQ-GRU, with flights at SDQ acting as a scissor hub.
a.
mhkansan
RE: Gol Applies For VCP-SDQ-MIA
Thu Mar 27, 2014 7:01 am
I flew AD from VCP-GIG last year. VCP is a very interesting setup, but there are plans for a much larger terminal there and I think the area around VCP, Campinas, is heavily involved in technology industry. Azul has a large operation and have dedicated, comfortable bus links to Sao Paulo there. I'm unsure what kind of infrastructure G3 has at VCP but I don't know of anything short of a dedicated high speed rail line that would woo high value business travelers to the USA way out to Campinas!
G500
Thu Mar 27, 2014 7:58 am
GOL is gonna be like Copa, doing long range stuff with the 737. Good luck to them
C010T3
Thu Mar 27, 2014 10:17 am
Quoting mhkansan (Reply 1):
The construction is actually underway:
http://www.skyscrapercity.com/showpost.php?p=112270209&postcount=3164
jfk777
Fri Mar 28, 2014 12:04 am
Quoting g500 (Reply 2):
GOL wants to fly to Nigeria with a 737 from Brazil, from Recife to Lagos. 2,900 miles.
2travel2know2
Fri Mar 28, 2014 12:33 am
Quoting jfk777 (Reply 4):
The market on the Brazilian side for LOS is in GIG perhaps SSA but not in REC.
Routing VCP-MIA via SDQ might have to do with a crew change in SDQ.
I'm not on CM's payroll.
incitatus
Fri Mar 28, 2014 2:20 am
Recife to Lagos is 170 miles farther than Boston to Los Angeles. It seems quite a normal route for a current generation 737.
Conservatives against Trump
