widebody
High Wing/Low Wing Cruise
Mon Nov 13, 2000 5:23 am
Anybody got an idea why there is no medium-long haul high wing jet aircraft? In other words, no high wing aircraft where the routes entail large cruise segments. Take for example business jets, appart from the RJX 85 and 328, both modified pax jets, there is no high wing business jet, and no dedicated high wing business jet.....
prebennorholm
RE: High Wing/Low Wing Cruise
Mon Nov 13, 2000 10:08 am
Oh, Widebody, there are plenty of medium and long range planes with a high wing. IL-76, AN-124, C-130, C-141, C-5, C-17, just to name a few of the most prominent examples.
It's a question about where it is most practical to have the wing main spar(s) pass through the fuselage. Just talk to those people (myself included!) who have banged their head against the lowered cieling in a F-50 or BAe-146 where the spar passes through.
On a passenger jet plane you simply make the best use of the fuselage space available when having the wing spar just under the cabin floor. And make room for baggage in front of and behind the spar.
On a roomy freighter you have only one room for payload, so the floor is put much lower leaving no room for the spar under the floor. And a flat floor is a must. It has one big disadvantage, the landing gear cannot be connected to the wing and its track becomes very narrow.
So I don't think that you will ever see a high wing ordinary passenger airliner.
Best regards, Preben Norholm
widebody
Tue Nov 14, 2000 9:41 am
Thanks for the info Preben, it was as you mentioned passenger aircraft I was talking about.....
