AFa340-300E
NWA LAX Long-hauls
Sun Nov 26, 2000 8:03 am
Hello,
What equipement does NWA uses on its two long-haul services from LAX (KIX and HNL if i'm correct)?
Curious to see that they don't fly LAX-NRT.
What terminal houses NWA ops please?
Click for large version
Photo © AirNikon
Thank you,
Alain Mengus
Mitchell Gant
RE: NWA LAX Long-hauls
Sun Nov 26, 2000 2:05 pm
NW flies out of Terminal 3 at LAX. NW operates a daily NRT-LAX and KIX-LAX with 747-451 equipment.
Adam84
Sun Nov 26, 2000 3:09 pm
The KIX flight is or was a 747-200, the flights to HNL are DC-10-40's.
nwa man
Sun Nov 26, 2000 3:17 pm
OK, to set the record straight:
NW operates from Terminal 2 at LAX. Terminal 3 is just used for overflow operations, or in other words when all the gates at Terminal 2 are full (2 is also used by QF, NZ, Hawaiian, etc.)
NW flies LAX-NRT nonstop...in fact it's flight NW1. NW2 is the return flight, routed BKK-NRT-LAX-LAS. LAX-NRT is a 747-200, but the continuation of that flight (NRT-BKK) is a 747-400. LAX-KIX is also a 747-200. DC-10-30s and -40s are used on NW's two daily LAX-HNL runs.
If you're curious, NW operates these routes from LAX:
LAX-LAS
LAX-SAN
LAX-NRT
LAX-KIX
LAX-HNL
LAX-MSP
LAX-DTW
LAX-MEM
Hope this helps...if I'm incorrect, forgive me, I've been up since 4am EST today, early BOS-MSP run.
NWA Man
Create your own luck.
Red Panda
RE: NWA Man
Sun Nov 26, 2000 4:23 pm
is the route LAX-KIX operated by DC-10 non-stop? I've never thought that DC10 can fly for that long! But I am sure that NRT-LAX is operated by 744.
Best Regards,
R Panda
Sun Nov 26, 2000 6:53 pm
Both NRT and KIX flights from LAX are operated by 742s and have been for the last five years. NW briefly had a 744 on LAX-KIX-MNL aroumd Christmas '95 and before that, NW ended 744s at LAX around mid-92. The777Man
A330_DTW
RE: NWA Man
Mon Nov 27, 2000 4:17 am
Actually, NW flies the DC10 on the SEA/KIX route and SEA/AMS, so yes, a DC10 can fly quite far. In fact, NW flew a DC10 nonstop from LAX to HKG (empty, of course!) when the aircraft was first introduced into the fleet.
MAS777
Mon Nov 27, 2000 5:06 am
From next year - Northwest will also operate a LAX-TPE-KUL and LAX-NRT-KUL route code-sharing with Malaysia Airlines.
