B737-112
Runways Changing Directions....
Tue Nov 28, 2000 4:44 pm
How often does this occur, it happened at my hometown airport BUR. There was Rwy 07/25 and changed later to 08/26. Can someone tell me if this is caused by earthquakes and what other airports have this happened at? I think when BUR was built Rwy 7 was a 074 magnetic and is now 076. Thanks for all help! -Ryan
Dalmd88
RE: Runways Changing Directions....
Tue Nov 28, 2000 4:53 pm
The magnetic field of the earth is consantly changing. Runway numbers have to be changed every so often to reflect the magnetic change
N202PA
Tue Nov 28, 2000 5:01 pm
The main runway at Washington National Airport (DCA), 18/36, was recently changed to 1/19 for this very reason.
gkirk
Wed Nov 29, 2000 12:23 am
DALMD88 is correct.
Wed Nov 29, 2000 4:50 am
Can you please explain the relationship between a runway number and magnetic field?
Best Regards...
flyf15
Wed Nov 29, 2000 5:16 am
In short, the runway number is the magnetic direction of the runway divided by 10, then rounded to the nearest number. For example, if a runway points at 174 degrees magnetic, its number will be 17. The opposite end, being 180 degress off, will be 354, thus 35. The runway is 17/35.
Wed Nov 29, 2000 6:11 pm
Thanks Flyf15, that was helpful.
But what are L and R assigned also to runways with numbers? For example, 27R or 8L.
Thanks...
LBA
Wed Nov 29, 2000 9:40 pm
The L and R mean left and right. This occurs where airports have parallel runways. So Manchester Airport in the Uk used to have a single 6/24 runway - it now has 6/24L and 6/24R as the new runway is almost complete.
