AA@DFW
US Air: 767 Engine Failure (in Maint) W/ Pics
Wed Nov 29, 2000 7:04 am
Link to the following location to see pictures from AVweb on a US Air 767-200 that experienced a catastrophic engine failure during a full-power run up in maintenance.
Very scarry pictures.
http://www.avweb.com/articles/gobad/
AA@DFW
Orono, Maine
RE: US Air: 767 Engine Failure (in Maint) W/ Pics
Wed Nov 29, 2000 7:28 am
I am glad that is incident did not happen in the air with passengers on board. This would have been a very serious blow for US Airways after what happened with Flt 427 in Pittsburgh in 1994. Does this engine failure involving a GE CF6 have anything to with the inspections the FAA mandated this past summer to look for possible cracks in the engine spools?
Bruce
Wed Nov 29, 2000 7:45 am
Was this jet refurbished or written off? It seems to be in good condition other than the wing/engine area
CV990A
Wed Nov 29, 2000 11:04 am
They wrote it off- apparently the wing spar was damaged in the incident. Thank god this happened on the ground with no pax.
Kittens Give Morbo Gas
HyperMike
Wed Nov 29, 2000 11:48 am
I read this in a newsletter published by a PHL-based Flight Attendant:
NAME THAT ENGINE:
The Federal Aviation Administration today issued an airworthiness directive
making the time required for previously ordered inspections of General
Electric (GE) CF-6 engines more restrictive. The inspections are being done
to detect cracking in the high-pressure compressor stage (3-9 spool) that
could cause an uncontained engine failure. The compressor in an aircraft
engine compresses the incoming air and speeds it up before it enters the
combustion chamber to mix with fuel. The engines affected are CF6-45, -50,
-80A, -80C2 and -80E1 models. Aircraft with these engines include Boeing
747s, 767s, DC-10s and MD-11s, and Airbus A300s, A310s and A330s. There
are about 1,180 such engines in the U. S. fleet approximately 1400
worldwide. Total cost to U.S. operators for removal and inspection of the
high-compressor parts of these engines is estimated at a maximum of
$18,800,000.
Less than two months later here is what appeared in my 10-10 newsletter:
WHO WANTS TO PLAY WITH A 767?
A couple of weeks ago in PHL, three maintenance employees took a 767
(aircraft # 654) out to do a maintenance runup on taxiway kilo when the
left engine experienced an uncontained catastrophic failure. I guess you
could say it was a failed and very expensive, runup. $Cha-ching$
hkgspotter1
Wed Nov 29, 2000 11:55 am
I've not heard of a US Airways 767 write off ??
Wed Nov 29, 2000 12:37 pm
Good God why are GE engines such CRAP????
B747-437B
Wed Nov 29, 2000 12:38 pm
I believe that the aircraft in question is N654US (msn 25225) and the initial decision to write off that aircraft has been changed and they will attempt to fix the damage.
"The A340-300 may boast a long range, but the A340 is underpowered" -- Robert Milton, CEO - Air Canada
ILUV767
Wed Nov 29, 2000 1:17 pm
They will not write off that plane.
The engine can be replaced, and the wing can be fixed. After an investigation by the FAA, GE, and Boeing, that plane will be back up in the skies.  And yes, i'll be the first to fly on it. Its still safe, and the plane is still young, well middl aged. I expect to see it up in the air again by January.
