AA@DFW
AA's Service To Dusseldorf (DUS), Germany
Sat Dec 09, 2000 3:03 am
Can you please tell me about AA's former service to DUS? How long did it last? Equiptment? When did it start? Why did it fail?
AA@DFW
blink182
RE: AA's Service To Dusseldorf (DUS), Germany
Sat Dec 09, 2000 7:32 am
The flight to DUS was a 767-200 and I believe it was from Chicago. I think it started in the late 80's and ended around '93. I think it fell due to poor load factors. I think they should restart that route from ORD again to see how well it does.
rgds,
blink182
Give me a break, I created this username when I was a kid...
dutchjet
Sat Dec 09, 2000 8:14 am
The DUS service was a 762, service was dropped due to economics, simply not enough people on the planes. Remember, around the time the service was dropped UA and LH were beginning their alliance, which eventually grew into the Star Alliance, and they now fly the route and can "hub" at both origin and destination. Did you know that AA also flew to Hamburg in the late 80s; one of the US-BRU flights continued on to Hamburg, also a 762 service, also dropped due to lack of interest.
aio86
Sat Dec 09, 2000 4:43 pm
Maybe the best way to find out if it would be succesful is to see how UA's DUS flight is now. I think that it is on a 767-300. 5 of my family members took this flight since it was the only flight available last June for mileage awards on the way to Paris. They then took a UA codeshare from DUS-CDG. So, does DUS only work well for United b/c of the codeshare options with Lufthansa? And if that was the main reason, then why not Munich instead. Bigger city, bigger LH hub.
-Aio86
Rizzibird
RE: Aio86
Sun Dec 10, 2000 12:12 am
Aio86:
Concerning your questions about UA's DUS flight, I don't know for sure about its profiatability but I guess it must be alright as it has been running since the mid 90s. Just look at UA's destinations in Europe, the number is less than AA's, DL's and CO's. UA does not serve routes just because of prestige, it's all about money for them. If DUS wasn't profitable, UA would not serve it! The LH code-share is one factor for the flight being successful but it's not the only one. CO, for example, has a flight to EWR is competition to LH and it works without a hub is DUS. Even though not being as big as other cities like MUC, DUS is located in the most densly populated German state of Northrhein-Westphalia (more than 15Mio. people), so the flight gets passengers from many towns besides DUS. I would not support your suggestion to move the UA flight to MUC because LH and UA already have flights from MUC to EWR, IAD, ORD, SFO and LAX(starting next summer) so there is no need for another UA service to ORD. Just my thoughts.
Rizzibird
kmia
RE: Aio86
Sun Dec 10, 2000 12:45 am
Rizzibird, I agree, as far as I know, CO is very succesful with the DUS destination.
Nightfly
RE: Aio86
Sun Dec 10, 2000 1:52 am
As mentioned, UA has the advance of their hub at Chicago, further UA leeds the flight over ORD to SFO.
In my opinion AA would have success with a flight from DUS to DFW as they have their own hub there. And there are so much possibilities of further stops on this route, perhaps at PHL or ORD. AA should think about this.
best regards,
nightfly
Nightfly
RE: Aio86
Sun Dec 10, 2000 1:55 am
 ...sorry, I said UA flies DUS-ORD-SFO, thats wrong, they fly DUS-ORD-LAX.
nightfly
Andie007
Sun Dec 10, 2000 9:05 pm
But I'm sure UA will start a new service to IAD soon because for German travellers the flight connection in ORD is not very well...
Rizzibird
RE: Andie007
Tue Dec 12, 2000 5:33 am
What's wrong about the ORD flight? It must be the timing! The flight leaves too late (15:30) making connections in ORD harder. They should shift it back to the morning as it used to be!! The destination ORD should work better than IAD as UA has more flights to connect from that airport. I can't foresee DUS-IAD flights replacing the DUS-ORD connection!
Rizzibird
Andie007
RE: Rizzibird
Tue Dec 12, 2000 9:21 pm
I don't mean that the UA connection to ORD will be cancelled. UA will surely start a second daily route to their second hub in the morning (I guess). For european travellers it'll be a better way to travel.
