STU
Here's One For You!
Fri Apr 02, 1999 5:33 pm
What is the limiting factor in the maximum speed of the Concorde? In other words why does it cruise at the speed it does and not faster. Lets see how many of you knowitalls can answer this one.
will
RE: Here's One For You!
Fri Apr 02, 1999 6:47 pm
OAT...
vr-hkg
Fri Apr 02, 1999 6:49 pm
Well, I believe it 's the limit of the material it was built on. The Concorde was built using alumunium alloy, which was the boundary of the technology then. The affect of kinetic energy heating on the fuselage structure restricted the max speed to mach 2.2. (at that speed the air passing thru the fuselage creates friction and thus high temperature of about 250 degrees F !) If it was to go faster, either very heavy stainless steel or extremely expensive titanium alloy would have to be utilized.
will
Spot On VR-HKG
Fri Apr 02, 1999 9:20 pm
Good work VR-HKG..and the actual skin temperature, or that which is exprienced on the nose which limits the Concordes speed is 128c (262f)..
BTW...VR-HKG the classic was the first A/C l flew into Kia Tak on.
All the best ...
Will...
CX747
RE: Spot On VR-HKG
Sat Apr 03, 1999 1:15 am
Yes, bravo VR-HKG. Good work.
"History does not long entrust the care of freedom to the weak or timid." D. Eisenhower
STU
The Winner Is?
Sat Apr 03, 1999 6:09 am
The correct answer is indeed the temperature of the nose. Good job.
DL757
Sun Apr 04, 1999 12:36 am
S what if that wasnt the limiting factor? How fast could it go with the current engines?
Fly Delta Jets | DL757
STU
Sun Apr 04, 1999 2:46 am
Faster?
