ContinentalEWR
Newark-Dusseldorf, Once And For All!
Tue Dec 26, 2000 11:05 pm
What will CO replace the DC10-30 operating on this route with? There are new photos on airliners.net showing a 767-424ER claiming this plane will replace a
DC10-30 on the EWR-DUS route. Previously, it was supposed to be a 767-200.
Then some people said they saw a 757 scheduled to operate it.....which is it??
767-400, 767-200, or 757?
Personally, I think the 757 is too small for this route and the 767-400 is too
large. The 767-224ER seems to be the right plane.
ContinentalEWR
gkirk
RE: Newark-Dusseldorf, Once And For All!
Wed Dec 27, 2000 2:03 am
I thought the 764 was the same size as the DC10?
Notarzt
Wed Dec 27, 2000 2:29 am
First of all, GKirk is correct of course: the B767-400 is most similar to the DC-10 in size. And according to latest DUS airport information, this is the type of aircraft Continental will use for DC-10 replacement on the EWR-DUS v.v. route.
Hope this helps,
Daniel
UAL747
Wed Dec 27, 2000 3:02 am
It is the 767-400ER that will be replacing the DC-10. There is a photo of a 767-400ER of Continental in DUS on the database.
UAL747
flowings
Wed Dec 27, 2000 3:27 am
Hi ,
nobody really knows it !!
The 764 serves DUS only between 22.12. and 31.12. !
On 27.12. and 2.1.2001 comes their B762 !
....and finally there was a 752 on 24.12.2000 .
Latest news is , that CO will serve DUS with 752 from Feb/Mar (I think) on !
Florian
Lear777
Wed Dec 27, 2000 4:05 am
Hello
At the moment EWR-DUS is flown by a 767-400. On January 2nd it switches to a 767-200.
The 757-200 takes over on April 1st, 2001.
Brian
Go Astros!
CB777
Wed Dec 27, 2000 4:35 am
It is going to be a 757 by April 2001!!!!!!!
CB777
Andie007
Wed Dec 27, 2000 5:10 am
We know it already...
Bad news for DUS...
Delta777Jet
Wed Dec 27, 2000 5:46 am
I guess, that they put theB 767-200 on the Newark-Düsseldorf Route. I think they just put the B 767-400 into the EWR-DUS route due the high booking situation during christmas time.
B-717/722/737-200/300/400/500/600/700/800/900/B-747-100/200/400/SP/8i/B-752/3/B-762/3/4/B-772/LR/300ER/B-788/DC-10-10/30/L-1011-1/500/MD-81/82/83/90/A-319/320/321/AB6/312/313/332/333/342/343/346/359/388/TU154/IL-18/ATR-42/72/DH4/DH3/E145/E170/190/CR2/7/9
STT757
Wed Dec 27, 2000 7:15 am
The situation with Continental's fleet plan is very fluid,meaning it's constantly moving to meet demands.
Last Summer the Amsterdam and Brussels flights were 757s and now they're 767-200s,I think Dusseldorf may have a 757 for the Summer and then revert to either a 767-200 or a 400.
They have Hong Kong and Buenos Aires on tap for next year and they are going to be moving aircraft around alot until they have more 767s and the extra 777s the ordered.Things will be fluid for another two years or so,when the Global Gateway project at EWR is finished they will have things in much better order. 2002 is when most of the major projects at EWR should be finished and enough 767s,777s and possibly 757-200XRs should be in the fleet to meet their growth goals of between 25 and 30 trans-Atlantic routes by 2004.
I would expect CAL to excersise some of their options for 767-200s and 777s,and perhaps a 767-300 order as well.Not only will Global Gateway at EWR be finished by 2004 but IAH's new Terminal E should be almost complete by then,and if any one read that Houston Chronicle Story IAH will be seeing more European flights by then like Madrid,Rome, and Frankfurt.
And don't forget Heathrow could open up at some point to CAL and then they would have to order more 767s to meet their schedules,they have asked for ten frequencies into Heathrow 6 from EWR,3 from IAH and one from CLE.
Greg Brennenman also stated in a article a month or so ago that CAL would add about one new Asian route from EWR a year starting in 2001 with Hong Kong,he said the next after that would be Osaka(KIX),then in no particular order Taipei,Seoul,and possibly Singapore and Shanghai.
So things are changing all the time,by 2004 they should have their International route networks in shape.
later
