Jubilee777
AN Grounds 767 Again
Fri Jan 19, 2001 11:17 pm
For Your Info:
SYDNEY -- For the second time in a month, Ansett Australia faced the embarrassment on Friday of being forced to ground some of its jets and reschedule flights because of inadequate servicing.
The airline was ordered to take three Boeing 767s out of service after its engineers found a hairline crack in the horizontal stabiliser of one of two aircraft undergoing a compulsory inspection.
A third 767 was immediately grounded on turnaround at Melbourne Airport where similar cracks were found in its tailplane by Ansett engineers using ultrasound equipment.
The order came less than a month after the airline had to ground seven jets because of servicing irregularities.
Ansett services were thrown into chaos on Dec 23 when the company was forced to cancel 14 scheduled services, which meant delays for 18,000 passengers booked to fly to holiday destinations at the start of the Christmas break.
However, Ansett said only one flight had been cancelled on Friday and it would 'not experience undue disruption' because it had previously planned to remove two of the three aircraft for checks at this time.
Civil Aviation Authority (Casa) spokesman Peter Gibson said the cracks found presented no immediate danger, but they were concerning enough to mean the immediate grounding of all three aircraft involved.
He said the problem had also prompted Casa to immediately cancel an agreement under which Ansett was able to keep flying the seven aircraft grounded at Christmas after passing their date for routine aging inspections due after every 2,500 flights.
The three 767s were among the seven grounded at Christmas and two had been undergoing the compulsory inspections ordered at that time.
Ansett, recently bought out by Air New Zealand and now controlled from Auckland, subsequently came to an agreement with Casa under which it was permitted to keep operating the aircraft provided fortnightly visual inspections were made.
But Casa said it had cancelled the dispensation because of the latest problem. -- AFP
J777
MEA
RE: AN Grounds 767 Again
Fri Jan 19, 2001 11:25 pm
In my opinion, it's about time AN & ANZ get their act together & coomence their fleet renewal programme. This publicity is definitely not good for their images.
Boeing is also coping a lot of flack from the Australian public & media. I have heard some guys who fly with Ansett regularly on business request that they not be booked on any AN B767 aircraft.
It will be interesting to see which widebody aircraft Ansett/Air NZ choose for their domestic & regional services following these incidents.
Sun Jan 21, 2001 11:11 am
It's not a problem with the 767! Its Ansett's fault! They don't need to get a fleet renewal program going, they need to maintain their planes better! This happens to all planes after a certain amount of time. What responsible airlines do is they fix these cracks!
-Tom
USAirways737
Sun Jan 21, 2001 11:21 am
Like King767 said it's not the 767! If it was the 767 that had the problem then wouldn't you think that other airlines like AA or DL (that by the way operate a whole hell of a lot more 767s than AN) and others would be having problems with their 767s too? If I'd had to fly I wouldnt be asking to not fly on the 767s but ask to not fly AN!!
Sun Jan 21, 2001 11:32 am
There would also be a check on all 767s issued by the FAA, and CASA.
-Tom
Sun Jan 21, 2001 11:35 am
A quick question. Do AA and DL B767-200s of the same vintage have anywhere near the same number of cycles as the affected AN aircraft? I doubt it.
I for one would much prefer to fly on a AN aircraft if it came down to a choice of the three airlines.
Feret
Sun Jan 21, 2001 11:52 am
Feret,
Cycles have nothing to do with it. No matter how many cycles an airframe has on it, as long as it is maintinaed properly (Something AN did not do), its perfectly safe to fly. Feret, if you really do live by that theory, then your saying you won't fly on any major US carrier.
-Tom
Sun Jan 21, 2001 12:06 pm
King767,
Cycles are what it IS all about! Ageing aircraft inspections are the issue. I take it you really know little about aircraft maintenance by your statement. I have flown on several different US airlines and I stand by my choice.
Feret
Sun Jan 21, 2001 12:12 pm
Feret,
I take it you know little on how to comprehend a statement. Of course cycles are the whole point. What I was reffering to was that it does not matter if a certain aircraft has more cycles than another. It all comes down to maintence of the airframe. If an airline properly maintains an airframe porperly, than theres nothing to worry about. Of course it takes more maintence as a plane ages and a bit more looking for those hairline cracks, but your analogy reffering to US 767 and AUS 767s made no sense whatsoever. If were talking 767, then no matter what 76 you get, there all fine framewise, not like a 707 or 732 as you were reffering them to.
-Tom
Sun Jan 21, 2001 12:23 pm
King767,
Please clarify your last sentence. There is a mix up here somewhere. I have many hours on the 767 and the 707 and found nothing wrong with the latter's airframe. I also much preferred the 707 but enjoyed the performance of the 767. There are no 732s on the Australian register.
MEA
Sun Jan 21, 2001 12:36 pm
I wasn't knocking the B767, I was merely stating that the publicity AN is receiving is not good for their image or the image of the B767.
The travelling public tend to remember information about crashes & problems with aircraft, for this reason they may not choose to fly on Ansett or their B767.
I don't think it was entirely Ansett's fault either, media reports here in Australia also point to a problem with communication between both Boeing and Ansett.
Sun Jan 21, 2001 12:50 pm
You are right there. My neighbour is a AN ground engineer (on 767 among other types) so I am in the picture, so to speak. Definitely an oversight by Ansett and Boeing is not so squeaky clean as they are supposed to be monitoring the ageing aircraft progress to determine what has to be done in the way of inspections etc. Last year QF copped all the media flack. Looks as though this year it is Ansett's turn. Haven't seen a shot of either a QF or AN 747 sitting on its nose lately for sensationalism either!
Feret
Sun Jan 21, 2001 12:53 pm
Feret,
You state in your 1st post that you would rather fly on an AN frame than an AA or DL because of the amont of cycles on each. I did not say that there was something wrond with the 732 or 707 but was reffering to the fact that today these frames would have clocked up a large amound of cycles. No I did not say that there were and AUS 732s, I was just stating an example (I don't know where you got that one from).
-Tom
Sun Jan 21, 2001 1:25 pm
King767,
My choice has nothing to do with the actual number of cycles of an aircraft. Read into that sentence whatever you will! You seem to interpret things differently but then, according to you, I have a comprehension problem. Maybe that stems from being around aircraft for 37 years, scrambled my thought processes, then again maybe it was the layovers.  Smile BTW, I was speaking about 767s. You were the one who brought up other types. Why? I dunno.....
Feret
Mon Jan 22, 2001 1:55 am
You stated clearly in your post that you would choose an AN 76 over a DL or AA 76. It was obvious to me that you were talking about cycles. If not, what were you talking about. As to my statement about comprehension, I felt that was a fine way of putting it after you insulted me about my understanding of aircraft maintence  Smile I brought up the other types to use as an example of a high cycle aircraft, to what I thought you were reffering AA and DL 767s to, high cycle aircrafts. Well I guess we both have to make ourselves understood better, so no hard feelings.
The Best, Tom
USAirways737
Feret
Mon Jan 22, 2001 2:13 am
What were you trying to say then Feret??
RayChuang
Mon Jan 22, 2001 9:06 am
Folks,
I have news for you folks.
I believe that the AN and QF 767's were bought almost at the same time. The problem with the AN 767's is they have went through nearly TWICE the takeoff-landing cycles of the QF planes, and that's why the cracks are starting to show.
I think what AN should do is buy a beefed-up version of the 757-300 that is designed for lots of takeoff/landing cycles.
RayChuang
Mon Jan 22, 2001 9:09 am
Another option would be to order more 762s with the new updated cockpit, therefore making it more convienent for the addition of the 764.
-Tom
tullamarine
Mon Jan 22, 2001 3:26 pm
AN's 762s are at least 2 years older than QF's. AN received their first 762 in 1983 whilst QF got their first in 1985 at which time QF was an international airline only therefore cycles are lower. QF did not commence using 762 on high cycle domestic routes until 1993 whereas AN's 762s have spent most of their life doing 1 hour jaunts between MEL and SYD, hence high cycle count.
The missed inspections were due to some shoddy paperwork by AN, CASA and Boeing. No one can take much solace from what has happened and hopefully they all learn from the incident. Fortunately no potentially life threatening faults have been found in any plane though listening to the hysterical media you would think the wings were going to fall off.
AN/NZ need to get on with their fleet renewal but I think we are still a few months away from any announcement. Hopefully Gary Toomey will progress it as a matter of urgency as I'm sure it would be a good "circuit breaker" from bad publicity.
I think we can safely say that there is no chance we will see the 753 in Australia. The choice will be between A332 or 764 if they decide to keep a widebody domestic fleet or A321/738 if they go for narrowbodies only. The 757 has never sold in Australia and the length of 753's single aisle would probably mean turnarounds would take too long. AN's 762s are often turned around in 30 minutes in Australia.
717, 721/2, 732/3/4/5/7/8/9, 742/3/4, 752/3, 762/3, 772/E/W, 300,310, 319,320/1, 332/3, 359, 388, DC9, DC10, F28, F100, 142,143, E90, CR2, D82/3/4, SF3, ATR
DeltaSFO
Mon Jan 22, 2001 4:22 pm
No. AA and DL 767-200s probably have more cycles. The only difference is we actually take care of our aircraft.
DeltaSFO
It's a new day. Every moment matters. Now, more than ever.
Oz777
Mon Jan 22, 2001 7:41 pm
Sorry DeltaSFO, but according to the Boeing records, the AN 767's have the highest cycles.
If you had read the previous parts of this thread you would have seen the statement that the AN 767s essentially have only 60 minute sectors for their operation (in fact 90% of the time)
AA 762 have an average sector time of 124 minutes, and DL have 106 minutes as an average sector time.
Very difficult given the relative ages of the aircraft to have more cycles than the AN ones -- oh of course!!!AA and DL use theirs 26 hours a day or should that be 2.6 hours per day (the rest is spent in maintenance!!)
I would trust an Australian LAME any time.
OZ777
